Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
View Poll Results: add new gpu ati 6xxx in log to code
yes 442 91.70%
no 43 8.92%
Multiple Choice Poll. Voters: 482. You may not vote on this poll
Old 08-17-2011, 07:00   #811 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Originally Posted by zatman View Post
hola. i have tried my 2 cards hd 5870 and hd 5770 with catalyst 11.4 and 11.6 but only hd 5870 apair on oclHashcat-lite-0.06.but with catalyst 11.7 .is working is possibleżżż i think we can mix diferent cards having catlyst 11.7.and for exemple 2x5770+5870 give 2days @900mhz good solution for poor unlocker.BR
Not possible to mix different gpus. all the gpu must be same type (eg all cayman or cypress) and same speed too
Alex
Old 08-17-2011, 15:25   #812 (permalink)
zatman's Avatar
Member: 980172
Thanks Meter: 85
yes but not sur
i think we can. but my probleme is ,the pc restart after 7 or 10 min because my power suply is 700w and my atx is small the temperatur is hot .to be sur i muse to put p.s more than 850w and more coolers and i try .BR
http://img10.imageshack.us/img10/9622/hd5870hd5770.jpg
http://img202.imageshack.us/img202/2959/catalyst114.jpg
http://img814.imageshack.us/img814/8944/catalyst117.jpg
Last edited by ptt; 08-17-2011 at 23:18. Reason: remove big IMG--> at least you can Edit/Resize IMG before post
Old 08-17-2011, 21:11   #813 (permalink)
moulnisky's Avatar
Member: 947561
If you think you can just try.
Atom says it won't work and considering he is the actual coder of the software oclhashcat-lite, should be a trusteable source.
Let me know if you will finish a Bruteforce successfully
Alex
Old 08-18-2011, 00:25   #814 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
how can i change the scan routine . i want to scan form 0%-30% then 70%-100% then 30%-70%. anyone pls asvise. thanks
Old 08-18-2011, 03:20   #815 (permalink)
zatman's Avatar
Member: 980172
Thanks Meter: 85
Alex
ok but i must to do some change in my pc.and i tel you abot it.
pc is msi Z68A-GD80(B3)
i5 2500k and 8gb ram......
Old 08-18-2011, 04:26   #816 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
in your command line (bat file)
change ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -> ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2
add new paramater -2 00010207080903040506
and run it
The Following 3 Users Say Thank You to SPUnlock_SK For This Useful Post:
Old 08-18-2011, 17:42   #817 (permalink)
moulnisky's Avatar
Member: 947561
4x6990 working!!! :)
Solved the configuration problems and now all 4 cards and their 8 gpus are working.
At 880 Mhz 15.500 Mhash/sec aka one full range bruteforce in less then 18 hours I think it is a world record now
Alex
The Following 6 Users Say Thank You to moulnisky For This Useful Post:
Old 08-18-2011, 17:58   #818 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
http://www.moulnisky.com/4_6990_score.jpg
Alex
can share with us for what configuration problems and how to solve it??
Old 08-18-2011, 18:02   #819 (permalink)
moulnisky's Avatar
Member: 947561
I must spend a couple of hours to put together the parts list
once done I'll put it here
The problem is, I think, an ati driver limit: it didn't inistall the drivers automatically. had to do it manually and reboot twice the computer (once for each gpu).
once done it worked like a charme
Alex
Old 08-18-2011, 18:28   #820 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
waiting for you part list
Old 08-18-2011, 19:24   #821 (permalink)
moni108's Avatar
Member: 26440
Thanks Meter: 6
[/QUOTE=SPUnlock_SK;7637790]in your command line (bat file)
and run it
E:\2730 matrix>oclHashcat-lite32 0D8ED9B16F1156A17D90D3D8504CC3330CC0F6B0:003560
5703263***00 -2 00010208090703040506 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?2 -n 1
60 --outfile-format=1 --outfile=35605703263***6.cod
above is the .bat file. i know how to change percentage scan but can some one show me by doing the info i provided. thanks
Old 08-19-2011, 08:50   #822 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Hi,
Anyone can help me about if its possible to put in crossfire 1 HD5970 Black edition 4Gb and with Hd5970 2Gb ?
Are there compatibility?
Many thanks
Old 08-19-2011, 08:59   #823 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
Alex
*******rrrrrrrrrr!!!!
The Following User Says Thank You to Ron2pet For This Useful Post:
Old 08-19-2011, 11:22   #824 (permalink)
moulnisky's Avatar
Member: 947561
Originally Posted by Dany View Post
Hi,
Many thanks
It will work.. just be carefull to set the same gpu speed for both the cards
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 08-19-2011, 14:03   #825 (permalink)
Member: 357208
Thanks Meter: 6
hello i have good computer but i not download catalys controller ,can sombody help me
give me one links te download latst version of catalys ?thanks a lot
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.32816 seconds with 11 queries
