probleme cyclone box cuonter hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005897 HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44 Initializing security card... Card Serial Number: D008032E Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,12v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,09v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,06v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 0 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 1.972GB Avaiable Virtual Memory: 1.888GB Avaiable Pagefile: 3.819GB Initializing FBUS... All initialized - Ready to work Failed to Read X-Gold LOG2COD File -> XGold Service Counter is 0. UPGRADE YOUR BOX TO CONTINUE USING SERVICE. i have uprade box correctly and same problme |
uninstall cyclone, then again install setup and drivers, then make box wizard try and post results |
hello I have the same problem blackberry counter to zero probe desintalando and installing the software and branding wizard box below to log Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000135A HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14 Initializing security card... Card Serial Number: D30001B9 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,73v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,00v PASSED VBAT Voltage 4,73v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,66v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 0 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 744.288MB Avaiable Virtual Memory: 1.860GB Avaiable Pagefile: 1011.856MB Initializing FBUS... All initialized - Ready to work |
uninstall cyclone and delete cyclone folder in c:/program files....... install latest version,,,,,, install driver............ then open cyclone.exe and make box wizard...... |
