GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Cyclonebox (https://forum.gsmhosting.com/vbb/f528/)
-   -   Put in this thread all successfull story with Cyclone-box (https://forum.gsmhosting.com/vbb/f528/put-thread-all-successfull-story-cyclone-box-709123/)
LIEREN 06-19-2009 07:16
6670 Flash ok
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT
Box Serial Number: C0000A19
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: D0000548
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.95v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 1.27v PASSED
VBAT Voltage 4.83v PASSED
Box VPP disabled
VPP Voltage 0.09v PASSED
Internal Box VPP Enabled
VPP Voltage 4.77v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 1081 [HW_UPP_WD2_v3_1]
RH51_67PE706420.C2, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM
Flashbus Write baud set to 100Kbits
w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 4
FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121
FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121
FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121
Signature: C60000EA750100EA780100EA7B0100EA
Flashbus Write baud set to 333Kbits
Flashbus Read baud set to 51Kbits
w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.02V
MSID-Crypted: 844F59D7468942415E531770EA
MSID-Plain: 3E4EBAF700D4F450A8000000
FAID-Crypted: 3D50F9F56BDBE466779954BC
Flashbus Write baud set to 1.80Mbits
4 Region(s) to erase
Erasing NOR Region [0x00000000-0x0000FFFF]
Erasing NOR Region [0x00010000-0x00FFFFFF]
Erasing NOR Region [0x02000000-0x029FFFFF]
Erasing NOR Region [0x02FC0000-0x02FEFFFF]
Erase taken 180.313s
Writing 3322 blocks...
All blocks written OK! Time taken 231.281s
Terminating flash session
Box VPP disabled
Booting UPP...
RH67PE706420.31, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM
Box VPP disabled
PLL Factor: 4
Nominal VPP Voltage: 9V, Detected: 0.04V
Using MSID-FAID Cache, Not wasting card
2 Region(s) to erase
Erasing NOR Region [0x02B00000-0x02DBFFFF]
Erase taken 19.234s
Writing 358 blocks...
All blocks written OK! Time taken 24.578s
Box VPP disabled
Processing post-flash tasks...
Setting Factory Defaults...
Factory defaults OK
baggyPants 06-19-2009 08:04
Unlocked Nokia 6121C after IMEI drama and writing certs back.
xerraco 06-19-2009 10:30
N73 Unlocked
Handling device: [Cyclone Team], [Cyclone Bootloader]
Initializing box...
Box Serial Number: C0123456
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Card Serial Number: D1123456
Card is activated
Box is activated
USB Voltage        4.89v        PASSED
Core Voltage        1.82v        PASSED
VBAT Voltage        0.01v        PASSED
VBAT Voltage        4.72v        PASSED
Box VPP disabled
VPP Voltage        0.00v        PASSED
VPP Voltage        4.66v        PASSED
Box VPP disabled
VPP Voltage        0.00v        FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
MCU Version        V 05wk47v34.1
MCU Date        05-10-06
Product                RM-133
Manufacturer        (c) Nokia.
IMEI                351851018909896
Mastercode        245461510
IMEI Spare        3A15580181098909
IMEI SV                3315580181098909F0000000
PSN                CNF497098
Product Code        0539684
Module Code        0202855
Basic Product Code        0527006
PSD                0000002200000000
RETU                15
TAHVO                21
AHNE                30
HW                6000
RFIC                17191719
DSP                scarfe_05wk46v39
Simlock Server        SIMLOCK SERVER VERSION 63
Simlock Key        5150200000000000
Simlock Profile        0000000000000000
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: CLOSED        Type: MCC-MNC        Data: 51502F
Simlock[2,1]        State: CLOSED        Type: MCC-MNC        Data: 51502F
Booting RAP...
APE_SYSTEM_ASIC_ID:        17100708
APE_ASIC_MODE_ID:        00
APE_PUBLIC_ID:                2BCA0C9A4271CF7DF25D368831C4E9255412873A
APE_ROOT_KEY_HASH:        49A97E826B93BA20B7ED0B082475C00500000000
APE_ROM_ID:                1DFD66132C872FD4
CMT_SYSTEM_ASIC_ID:        000000010000022600010006010C192101003000
CMT_EM_ASIC_ID:                00000295
CMT_EM_ASIC_ID:                00000B21
CMT_PUBLIC_ID:                0CE0000D73BF0054A594269B2077246C374EADC7
CMT_ASIC_MODE_ID:        00
CMT_ROOT_KEY_HASH:        BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID:                273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND
FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND
h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG
Box VPP disabled
Internal APE Phone VPP Enabled
Failed to Read All Certificates -> Failed to Boot / Prepare Phone
BB5 Unlock Started...
MCU Date        05-10-06
Product                RM-133
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
Box VPP disabled
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Writing Security Block...
SP Accepted, doing reset to update block...
MCU Date        05-10-06
Product                RM-133
Simlock Key        2440700000000000
Simlock Profile        8000000000000006
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[1,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[1,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[1,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[1,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[2,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[2,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[2,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[2,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[2,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[3,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[3,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[3,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[3,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[3,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[4,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[4,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[4,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[4,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[4,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[5,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[5,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[5,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[5,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[5,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[6,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[6,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[6,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[6,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[6,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[7,1]        State: OPENED        Type: MCC-MNC        Data: FFFFFF
Simlock[7,2]        State: OPENED        Type: GID        Data: FFFF
Simlock[7,3]        State: OPENED        Type: GID        Data: FFFF
Simlock[7,4]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Simlock[7,5]        State: OPENED        Type: IMSI        Data: FFFFFFFFFFFFFFFF
Unlock finished!
nelsky 06-20-2009 05:11
E71 FROM UK UNLOCKED...
LOGS:
Initializing box...
Box Serial Number: nelsky
Card Serial Number: nelsky
Card is activated
Box is activated
USB Voltage        5.17v        PASSED
MCU Voltage        3.27v        PASSED
Core Voltage        1.80v        PASSED
VBAT Voltage        5.06v        PASSED
Box VPP disabled
VPP Voltage        0.02v        PASSED
VPP Voltage        4.92v        PASSED
Box VPP disabled
Box VPP disabled
MCU Version        V 100.71.821.4
MCU Date        06-06-08
Product                RM-346
IMEI                352924020nelsky
Mastercode        1434422333
IMEI Spare        3A25290402986201
IMEI SV                3325290402986201F1000000
PPM                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
PSN                SIK066618
Product Code        0569999
Basic Product Code        0552256
PSD                0000000000000000
LPSN                0
WLAN MAC        0021FE55319D
APE SW                100.07.76
APE Variant        100.07.76100.07.76_v241.02
APE Test                RM346ENO7411718214.029
APE HW                256
APE ADSP        256
RETU                15
TAHVO                22
AHNE                11
HW                0910i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
PCI                i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
UEM                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
UPP                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
RFIC                17141715i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256
DSP                L07w15PB_08w20i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256
LCD                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256
BT                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256
ADSP Sw                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
ADSP DevID                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
ADSP RevID                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
AEM                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o2560(100.07.76, 08-06-2008, RM-346, (c)Nokia ,
Flip MCUSW                100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256
Simlock Key        2342000000000000
Simlock Profile        8000000000000000
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: CLOSED        Type: MCC-MNC        Data: 23420F
Simlock[2,1]        State: CLOSED        Type: MCC-MNC        Data: 23595F
MCU Date        06-06-08
Product                RM-346
IMEI                3529240208nelsky
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID:        000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:                00000B22
CMT_PUBLIC_ID:                05000118199A0158172F8DA87CFC8577422D805F
CMT_ROOT_KEY_HASH:        CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_ROM_ID:                4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5
Box VPP disabled
PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7
Restarting MCU...
Determined PA Simlock: PA_SL2
Restarting MCU...
Booting RAP...
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Writing Simlock Key...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Date        06-06-08
Product                RM-346
Simlock Key        0010100000000000
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: OPENED        Type: MCC-MNC        Data: 00101F
Unlock finished!
BR,
nicnec 06-20-2009 07:48
6120c-1 unlock OK
MCU Version        V 03.83
MCU Date        18-06-07
Product                RM-243
IMEI                359849014391756
Mastercode        234465466
Simlock Key        2140100000000000
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: CLOSED        Type: MCC-MNC        Data: 21401F
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID:        000000010000022600010006400C192101021103
CMT_PUBLIC_ID:                08000112BA590052CEA91DB89968FAE6EB395685
CMT_ROM_ID:                A8C1D6713E691FF8
FlashChip[0,CMT]: 0x00EC003000400221, Samsung, ONENAND
Box VPP disabled
PAPUBKEYS Hash for CMT: 0FE1BA92D924A658E4800780FA6F4868100AC947
Restarting MCU...
Restarting MCU...
Booting RAP...
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version        V 03.83
MCU Date        18-06-07
Product                RM-243
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Unlock finished!
Qaisar Mahmood 06-20-2009 09:25
2630 Unlocking Successfully
Booting UPP...
UPP ID: 3162 [HW_UNKNOWN]
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4
PLL Factor: 3
FlashChip[0]: 0x0020881C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009221
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
Flashbus Read baud set to 4Kbits
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020881C (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM
Boot operation took 5.593s
Check Flashing Bus finished
MCU Version        V 05.20
MCU Date        06-12-07
Product                RM-298
IMEI                3520460200-----
Mastercode        2522255120
Asic                11
HW Signature        F51831A946E34951
Simlock Profile        800000000001000B
Simlock Aux        000B5555
Simlock IMEI        00553520460200====
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Selecting unlock method...
Search in: C:\Program Files\Cyclone Box\UnlockData\
Searching for: RM-298_V 05.20.unlock_img
Asking card to sign HW Signature...
Signed OK (6AC31DC2DD5D3EC7FBCDBE18078944AEC35D2273)
Writing patch file...
Booting UPP...
shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
FlashChip[1]: 0x0020881C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009221
MSID-Crypted: 84D2FD57AC162E80DFF627F7DE
MSID-Plain: 2C40BAE9008B4713A8000000
FAID-Crypted: 43960A219BB8346BC91CC68A
Flashbus Write baud set to 6.50Mbits
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01080000-0x0109FFFF]
Erase taken 1.140s
Writing 10 blocks...
All blocks written OK! Time taken 9.688s
Box VPP disabled
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
nicnec 06-20-2009 11:14
E50 repair OK
Simlock Key FFFFFFFFFFFFFFFF
Simlock Profile FFFFFFFFFFFFFFFF
Backing up simlock...
MCU Version        V 4.41.41
MCU Date        28-06-07
Product                RM-170
IMEI                353672018031525
Mastercode        3415615317
Simlock backup OK, saved to RM-170_353672018031525_6202009_10857 PM.SLBackup.PM
MCU Date        28-06-07
Product                RM-170
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: CLOSED        Type: MCC-MNC        Data: 00101F
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID:        000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:                00000232
CMT_EM_ASIC_ID:                00000353
CMT_PUBLIC_ID:                12400106EDF067505E68E0BE74DA557455579411
CMT_ROM_ID:                191EC665DFAAF68F
FlashChip[0,CMT]: 0x00EC220800008D21, Samsung, NOR
FlashChip[0,CMT]: 0x00EC003000000121, Samsung, ONENAND
Requested Algorithm: BB5 ALGORITHM (CMT)
Box VPP disabled
PAPUBKEYS Hash for CMT: 378E6A71B6975E4F03868F793B3BCC7502219779
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Date        28-06-07
Product                RM-170
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Unlock finished!
LIEREN 06-20-2009 13:33
5300 USB Flsah
5300 (die phone) USB Flashing successfully finished!
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Selecting USB Flashing Method...
[BB5 ADL Server]: Found 1 active devices
[Nokia BB5 ADL Loader USB Generic]: Opening Connection
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
Phone already spawned ADL Services
ROOTKEY Hash for CMT:  BAF3A9C3DBFA8454937DB77F2B8852B1
PAPUBKEYS Hash for CMT:  7C1A1F5C3DB717937F54455937AF9DA76AA2EE13
Product Code:  0542769C
IMEI:    352734010968939
Processing rm146__07.00.mcusw (CMT)...
rm146__07.00.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR
EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR
EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR
EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR
EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR
Erase taken 100.562s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT PMM_CONF Certificate...
Writing CMT SBIF_CONF Certificate...
Programming Status OK!
All blocks written OK! Time taken 118.875s
Processing rm146__07.00.ppm_s (CMT)...
rm146__07.00.ppm_s, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01080000-0x015FFFFF, NOR
Erase taken 37.609s
All blocks written OK! Time taken 43.500s
Processing rm146__07.00.image_r (CMT)...
rm146__07.00.image_r, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01600000-0x01FDFFFF, NOR
Erase taken 1.219s
All blocks written OK! Time taken 23.968s
Restarting CMT...
All images processed OK! Processing post flash tasks...
[BB5 NMWCD]: Found 0 active devices
[BB5 NMWCD]: Not Found!
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Read info thread finished, continuing...
Post flash tasks finished!
24gsm 06-20-2009 15:24
N95 RM-159 unlock success
MCU Version    V 06wk41v59.1
MCU Date    02-06-08
Product        RM-159
IMEI        356843022459336
Mastercode    2370572041
Simlock Key    2082000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock[1,1]    State: CLOSED    Type: MCC-MNC    Data: 20820F
Simlock[2,1]    State: CLOSED    Type: MCC-MNC    Data: 20820F
Security block OK!
Booting RAP...
APE_SYSTEM_ASIC_ID:    24200705
APE_PUBLIC_ID:        566FD058BDFB33DF293984D2A6D28CF3470B6718
APE_ROOT_KEY_HASH:    BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_PUBLIC_ID:        2080001283B901585197AD2035EF266D822A33BF
FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Date    02-06-08
Product        RM-159
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Unlock finished!
carmelillo 06-20-2009 15:56
NOKIA 5700
http://www.gadgetvenue.com/wp-conten...nokia-5700.JPG
Initializing box...
Box Serial Number: C00005BD
Card Serial Number: D00001A6
Card is activated
Box is activated
USB Voltage        4,94v        PASSED
MCU Voltage        3,28v        PASSED
Core Voltage        1,81v        PASSED
VBAT Voltage        0,01v        PASSED
VBAT Voltage        4,81v        PASSED
Box VPP disabled
VPP Voltage        0,02v        PASSED
VPP Voltage        4,70v        PASSED
Box VPP disabled
VPP Voltage        0,04v        FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
MCU Version        V 03.83.1
MCU Date        25-06-07
Product                RM-302
IMEI                353966014055466
Mastercode        2742757262
IMEI Spare        3A35690641504506
IMEI SV                3335690641504516F1000000
PPM                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
PSN                CLE373739
Product Code        0554875
Basic Product Code        0544062
LPSN                0
APE SW                03.83.1
APE Variant        rofs_version_inforofx_version_info
APE Test                rm302_ENO_x_2007wk24v0.010
APE HW                256
APE ADSP        256
RETU                15
TAHVO                22
AHNE                11
HW                0206i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
PCI                i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
UEM                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
UPP                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
RFIC                17141715
DSP                pb06w41v34.3_rm230
LCD                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
BT                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
ADSP Sw                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
ADSP DevID                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
ADSP RevID                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
AEM                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
Flip MCUSW                03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256
Simlock Key        7321030000000000
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Simlock[1,1]        State: CLOSED        Type: 7FFF6F07FFFFFFFF @ FC00        Data: 732103
Simlock[2,1]        State: CLOSED        Type: 7FFF6F07FFFFFFFF @ FC00        Data: 732111
Booting RAP...
Booting RAP...
CMT_SYSTEM_ASIC_ID:        000000010000022600010006400C192101021105
CMT_PUBLIC_ID:                1C30011671720058F298A6D139F1B689DA14E84B
CMT_ROOT_KEY_HASH:        F2D76DFAFD66C7F195F278417DF05888
FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND
Box VPP disabled
PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73
APE Subsystem Not Found
Failed to Read All Certificates -> Failed to read CMT NPC
Booting RAP...
Booting RAP...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT HWC Ok
CMT CCC Ok
CMT R&D Ok
CMT VARIANT Not Found
CMT PAPUBKEYS Ok
CMT KEYS Ok
Restarting MCU...
Read all certificates finished
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
Booting RAP...
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
Failed to Create RPL from phone -> Phone not detected
MCU Date        25-06-07
Product                RM-302
PSN                CLE373739
LPSN                0
APE HW                256
APE ADSP        256
RETU                15
TAHVO                22
AHNE                11
RFIC                17141715
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Storing PSN...
Storing HWID...
Booting RAP...
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Date        25-06-07
Product                RM-302
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Security block OK!
Booting RAP...
Box VPP disabled
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Date        25-06-07
Product                RM-302
Simlock Key Cnt        0
Simlock FBUS Cnt        0
Unlock finished!
emmanueldraper 06-20-2009 18:51
nokia 1680c-2 rm-394 v06.82
sucessfully unlock by cyclone box
good work cyclone team
24gsm 06-20-2009 18:59
other 5200 locked orange france
MCU Version    V 05.51
MCU Date    05-09-07
Product        RM-174
IMEI        354565010210072
Mastercode    655324054
IMEI Spare    3A45650501120007
IMEI SV        3345650501120017F3000000
PPM        V 05.51, 05-09-07, RM-174, (c) Nokia.          , C
CNT        Content: ora_fr, V 05.51, 05-09-07, RM-174, (c) Nokia.          , ,
PSN        DAG417129
Product Code    0542762
Module Code    0203053
Basic Product Code    0530542
RETU        32
TAHVO        53
AHNE        11
HW        2001
RFIC        17211721
DSP        06w14pb_07w32
BT        06cc-P9.1
Simlock Key    2080100000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock[1,1]    State: CLOSED    Type: MCC-MNC    Data: 20801F
and unlock processe
MCU Version    V 05.51
MCU Date    05-09-07
Product        RM-174
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Security block OK!
Booting RAP...
CMT_PUBLIC_ID:        0A700009BC4300581586DA9A9FB41C272ACA7269
FlashChip[0,CMT]: 0x00EC22FE00006921, Samsung, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Version    V 05.51
MCU Date    05-09-07
Product        RM-174
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Unlock finished!
24gsm 06-20-2009 19:41
other 2610 orange locked :D
MCU Version    V 06.73
MCU Date    08-05-08
Product        RH-86
IMEI        356863020536067
Mastercode    3236551254
IMEI Spare    3A65680302350606
IMEI SV        3365680302350656F8000000
PPM        V 06.73, 08-05-08, RH-86_87, (c) Nokia.  , AE
CNT        Content: ora_fr_v2, V 06.73, 08-05-08, RH-86_87, (c) Nokia.  ,
PSN        FB3842758
Product Code    0553516
Module Code    0202930
Basic Product Code    0530409
PSD        0000000D00000000
HW        8002
UEM        1328
UPP        12352
RFIC        0500
DSP        P05w45.v49
LCD        ELBE
Asic        11
HW Signature    85879F295C635E6E
Simlock IMEI    00553568630205360600
Simlock Key Cnt    0
Simlock FBUS Cnt    0
unlock process
MCU Version    V 06.73
MCU Date    08-05-08
Product        RH-86
Asic        11
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Searching for: RH-86_V 06.73.unlock_img
Signed OK (FC7B1E57F0CFA0558DF5F5EF1857622DCC049B67)
Booting UPP...
UPP ID: 3040 [HW_UNKNOWN]
Box VPP disabled
PLL Factor: 3
FlashChip[0]: 0x00012C7E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00357021
u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00012C7E (128Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,00V
MSID-Crypted: 843914E510862FB0A2AC658F26
MSID-Plain: 8F3CBAE90005A35FA9000000
FAID-Crypted: A23BBA2861A7F93D3B12AC64
1 Region(s) to erase
Erasing NOR Region [0x010A0000-0x010BFFFF]
Erase taken 0.750s
Writing 8 blocks...
All blocks written OK! Time taken 1.859s
Box VPP disabled
Writing SP...
New SP Accepted OK!
Writing restore file...
Booting UPP...
Box VPP disabled
PLL Factor: 3
Nominal VPP Voltage: 9V, Detected: 0,04V
Erase taken 0.765s
Writing 8 blocks...
Box VPP disabled
Phone unlocked OK!
24gsm 06-21-2009 17:56
other E65 sfr france locked ....:D
MCU Version    V 2.0615.30
MCU Date    13-09-07
Product        RM-208
IMEI        356961018594898
Mastercode    1523655762
IMEI Spare    3A65690181958409
IMEI SV        3365690181958429F5000000
PSN        SCN570348
Product Code    0561957
Basic Product Code    0560030
WLAN MAC    001EA4ABF6BB
RETU        15
TAHVO        22
AHNE        30
HW        0810
RFIC        17141715
DSP        A06w14PB_07w32
Simlock Key    2081000000000000
Simlock Profile    0100000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock[1,1]    State: CLOSED    Type: MCC-MNC    Data: 20810F
Simlock[2,1]    State: CLOSED    Type: MCC-MNC    Data: 20810F
Simlock[3,1]    State: CLOSED    Type: MCC-MNC    Data: 64710F
Simlock[4,1]    State: CLOSED    Type: MCC-MNC    Data: 64710F
unlock process
MCU Date    13-09-07
Product        RM-208
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Security block OK!
Booting RAP...
APE_PUBLIC_ID:        959D042720BDAC1A3C3A56C9FD117DA079165A6D
CMT_PUBLIC_ID:        1A800115557502544DF500ED4FEFF1C54232F4E1
Box VPP disabled
PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896
Restarting MCU...
Restarting MCU...
Booting RAP...
MCU Date    13-09-07
Product        RM-208
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Unlock finished!
24gsm best regard
zubairhussain 06-21-2009 20:40
not save logs but n95, 5310 x 2 and 6500s all done and tested today. so fast and smart..
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.51863 seconds with 6 queries
