Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-25-2010, 09:34   #1486 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Arrow BlackBerry 8900 Unlocking Done
Waiting for new Blackberry USB Device (timeout 30 seconds)...
New device attached, checking if it's Blackberry...
Blackberry Found!
PIN: 21AEB0F9
"RIM CalTask" Channel open failed, Retrying...
PIN: 21AEB0F9
"RIM CalTask" Channel open failed, Trying "Caltask Config" ...
PIN: 21AEB0F9
Opened Channel "Caltask Config", Proceeding...
IMEI: 357239031166211
HWV-17811-006-6
SVP-20233-002_1
SVP-20234-002_1
ASY-17225-001
MEP-09292-004
VSM-22096-001
CFG-10695-112
SFI-19378-063
APP-21503-017
Calculating Codes using Fetched Data...
Handling device: [Cyclone Team], [Cyclone Box]
Service Tag: 17CA0DF35FE4E3F4428561BE2E2A6D49
Cyclone Server (1.0.0.651), Cyclone Box Team 2008, 2009, 2010 - Ready.
Please wait...
Codes received: 1
MEP-2 Code: 0132547026366239
All Done!
The Following User Says Thank You to RAVI_SINGH For This Useful Post:
Old 11-25-2010, 10:37   #1487 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Wink 7210c Flashing Done
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 55 products, Filtering BB5 Products - wait...
8 Products left after filtering. Ready.
Retrieving Variants for Product RM-436 - wait...
371 Variants Retrieved
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm436__07.23.mcusw (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID:  00000295
CMT_EM_ASIC_ID:  00000B22
CMT_PUBLIC_ID:  04000216A87D7C5649A60CF8808958914E2D03C3
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
rm436__07.23.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
Warning: PAPUBKEYS Hash Missing!
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0119FFFF, NOR
EraseArea[0,CMT]: 0x011A0000-0x0133FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 0.203s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 54.391s
Flashing Speed: 2785.26 kBit/S
Restarting MCU...
Processing rm436__07.23.mcusw (APE)...
Processing rm436__07.23.ppm_mb (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.ppm_mb, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
Box VPP disabled
PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
EraseArea[0,CMT]: 0x01340000-0x01BDFFFF, NOR
Erase taken 32.297s
All blocks written OK! Time taken 14.641s
Flashing Speed: 3523.67 kBit/S
Restarting MCU...
Processing rm436__07.23.ppm_mb (APE)...
Processing rm436__07.23.image_mb (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.image_mb, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01BE0000-0x01F7FFFF, NOR
EraseArea[0,CMT]: 0x01F80000-0x03FBFFFF, NOR
Erase taken 249.641s
All blocks written OK! Time taken 51.125s
Flashing Speed: 3326.51 kBit/S
Restarting MCU...
Processing rm436__07.23.image_mb (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Post flash tasks finished!
Flashing successfully finished!
Old 11-25-2010, 11:09   #1488 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Arrow N73 phone Startup Failed done
Started Phone Security Analysis...
MCU Version V 05wk47v60
MCU Date 19-03-08
Product  RM-133
Manufacturer (c) Nokia.
IMEI  353546026058573
Mastercode 230104760
Reading Security Block...
Security block OK and saved to "RM-133_353546026058573_11252010_20438 AM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
APE_SYSTEM_ASIC_ID: 17100708
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID:  70AFAC17BA114BF2154DD9EDEC2F555412AB67C6
APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000
APE_BOOT_ROM_CRC: 1DFD6613
APE_SECURE_ROM_CRC: 2C872FD4
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_PUBLIC_ID:  18C0001443954F5084DE7C2AE0A78F311D1765BC
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT Ready!
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V
Box VPP disabled
PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND
FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND
FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V
h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1  ALG
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
 !!!!! HWC IS EMPTY, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
 !!!!! CCC IS EMPTY, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
Restarting MCU...
Step 3 : Analyzing Security Block
WARNING: "18C0001443954F5084DE7C2AE0A78F311D1765BC.C0000B78" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Readed OK, Saving to "18C0001443954F5084DE7C2AE0A78F311D1765BC.C0000B78"
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
SIMLOCK FOUND AND CHECKSUM OK! PASSED!
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking ECC KEYS...
Checking DIV KEYS...
Analyze finished!
Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder.
SX4 Authorization / SD Repair Procedure Started....
"18C0001443954F5084DE7C2AE0A78F311D1765BC.C0000B78" Exists, That is good...
MCU Date 19-03-08
Product  RM-133
Security block OK and saved to "RM-133_353546026058573_11252010_20510 AM.SecurityBlock.PM"
SX4 Status: Not authorized (76)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 98 bytes, Status: OK
[1,18] Written, Length: 98 bytes, Status: OK
[1,20] Written, Length: 98 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 98 bytes, Status: OK
[1,29] Written, Length: 6 bytes, Status: OK
[1,31] Written, Length: 98 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 29, Record written NOT OK: 0
BB5 Unlock Started...
MCU Date 19-03-08
Product  RM-133
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Security block OK and saved to "RM-133_353546026058573_11252010_20525 AM.SecurityBlock.PM"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 19-03-08
Product  RM-133
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished! Time taken 4.0s
Old 11-25-2010, 12:57   #1489 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
3110c flashing ok
Found 56 products, Filtering BB5 Products - wait...
Retrieving Variants for Product RM-237 - wait...
12 Variants Retrieved
Processing rm237__07.30.mcusw (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:  00000232
CMT_EM_ASIC_ID:  00000353
CMT_PUBLIC_ID:  2E000112CE517E5624D0746862EA3ED05E55CC0C
CMT_BOOT_ROM_CRC: 191EC665
CMT Ready!
rm237__07.30.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR
FlashChip 0x00898981 (Intel), Size: 32MBytes, VPP: 9V
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR
EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR
EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR
EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR
EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR
Erase taken 9.235s
Skipping CMT PAPUBKEYS Certificate (already sent)...
Writing CMT PMM_CONF Certificate...
Writing CMT SBIF_CONF Certificate...
All blocks written OK! Time taken 45.156s
Flashing Speed: 2690.98 kBit/S
Restarting MCU...
Processing rm237__07.30.mcusw (APE)...
Processing rm237__07.30.ppm_c (CMT)...
Booting CMT...
CMT Ready!
rm237__07.30.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D
EraseArea[0,CMT]: 0x01080000-0x0151FFFF, NOR
Erase taken 0.735s
All blocks written OK! Time taken 8.469s
Flashing Speed: 3714.27 kBit/S
Restarting MCU...
Processing rm237__07.30.ppm_c (APE)...
Processing rm237__07.30.image_c_tr (CMT)...
Booting CMT...
CMT Ready!
rm237__07.30.image_c_tr, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01520000-0x01FDFFFF, NOR
Erase taken 4.625s
All blocks written OK! Time taken 8.843s
Flashing Speed: 3502.24 kBit/S
Restarting MCU...
Processing rm237__07.30.image_c_tr (APE)...
Factory defaults OK
Old 11-25-2010, 13:07   #1490 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Thumbs up Successfully Flash 6303c
Found 57 products, Filtering BB5 Products - wait...
9 Products left after filtering. Ready.
Retrieving Variants for Product RM-443 - wait...
321 Variants Retrieved
Processing rm443__10.12.mcusw (CMT)...
Booting CMT...
CMT_PUBLIC_ID:  19D00105BA337F56A51916E012550DA8BF29E66C
CMT Ready!
rm443__10.12.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
Certificates OK
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00060000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x0015FFFF, NOR
EraseArea[0,CMT]: 0x00160000-0x0023FFFF, NOR
EraseArea[0,CMT]: 0x01740000-0x0191FFFF, NOR
EraseArea[0,CMT]: 0x00240000-0x0173FFFF, NOR
EraseArea[0,CMT]: 0x022E0000-0x0261FFFF, NOR
Erase taken 129.406s
Writing CMT ISA+DYNSW Certificate...
All blocks written OK! Time taken 71.140s
Flashing Speed: 2909.34 kBit/S
Restarting MCU...
Processing rm443__10.12.mcusw (APE)...
Processing rm443__10.12.ppm_f (CMT)...
Booting CMT...
CMT Ready!
rm443__10.12.ppm_f, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01920000-0x022DFFFF, NOR
Erase taken 31.750s
All blocks written OK! Time taken 18.500s
Flashing Speed: 2770.86 kBit/S
Restarting MCU...
Processing rm443__10.12.ppm_f (APE)...
Processing rm443__10.12.image_f_illuvial (CMT)...
Booting CMT...
CMT Ready!
rm443__10.12.image_f_illuvial, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x02620000-0x029BFFFF, NOR
EraseArea[0,CMT]: 0x029C0000-0x03FBFFFF, NOR
Erase taken 183.406s
All blocks written OK! Time taken 24.0s
Flashing Speed: 3499.37 kBit/S
Restarting MCU...
Processing rm443__10.12.image_f_illuvial (APE)...
Factory defaults OK
Old 11-26-2010, 10:07   #1491 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Thumbs up 2220s Flashing Done
Found 52 products, Filtering DCT4 Products - wait...
11 Products left after filtering. Ready.
Retrieving Variants for Product RM-590 - wait...
254 Variants Retrieved
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
rm590__10.25.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321
FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321
Signature: AD7EB61B23100340C605E40120A20000
Flashbus Read baud set to 51Kbits
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.04V
MSID-Crypted: 841857FFC0D670754FA9CBC9D1
MSID-Plain: 2C40BAE90015FDFEAA000000
FAID-Crypted: 512B6A7A0B5EED6CEAEAD13D
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01CFFFFF]
Erase taken 120.109s
Writing 183 blocks...
All blocks written OK! Time taken 71.422s
Terminating flash session
Box VPP disabled
Booting UPP...
rm590__10.25.image_m_c_hpink, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 84E09FF9188313BE6D0061D8A8
MSID-Plain: D26EBAF10015FDFEAA000610
FAID-Crypted: 1F24E1D49E3561684936ED10
Erasing NOR Region [0x02180000-0x02E7FFFF]
Erasing NOR Region [0x02E80000-0x02FBFFFF]
Erase taken 130.235s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 312 blocks...
All blocks written OK! Time taken 30.922s
Extracting Content Package...
CP Extract Failed -> CP Server not exists
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rm590__10.25.ppm_m_c, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 844709B9C7702374F9C5FA371E
MSID-Plain: 3E4EBAE90015FDFEA8000000
FAID-Crypted: 2F471F2F440A616643EF2EEF
1 Region(s) to erase
Erasing NOR Region [0x01D00000-0x0217FFFF]
Erase taken 42.296s
Writing 32 blocks...
All blocks written OK! Time taken 12.516s
Box VPP disabled
Processing post-flash tasks...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
Old 11-26-2010, 12:18   #1492 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Wink Successfully Flash E66
Found 52 products, Filtering BB5 Products - wait...
4 Products left after filtering. Ready.
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_PUBLIC_ID:  18C0010A197A0052FF3005DCCF1D3672FE17818F
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
APE Boot skipped on user request
Restarting MCU...
Scanning avaiable products...
Found 53 products, Filtering BB5 Products - wait...
5 Products left after filtering. Ready.
Retrieving Variants for Product RM-343 - wait...
36 Variants Retrieved
Processing rm343_500.21.009_prd.c00 (CMT)...
Booting CMT...
CMT Ready!
rm343_500.21.009_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5
Flashbus Write baud set to 650Kbits
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND
EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND
Erase Partition (CMT)
Erase taken 0.781s
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS*CORE Certificate...
Writing CMT SOS+ROFS Certificate...
All blocks written OK! Time taken 84.703s
Flashing Speed: 6812.33 kBit/S
Restarting MCU...
Processing rm343_500.21.009_prd.c00 (APE)...
Processing rm343_500.21.009_prd.v10 (CMT)...
Booting CMT...
CMT Ready!
rm343_500.21.009_prd.v10, Type: Flash Image, Algo: BB5, XSR 1.5
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND
Erase taken 0.281s
Writing CMT SOS+ROFX Certificate...
All blocks written OK! Time taken 28.297s
Flashing Speed: 6615.43 kBit/S
Restarting MCU...
Processing rm343_500.21.009_prd.v10 (APE)...
Processing rm343_500.21.009.07U (CMT)...
Booting CMT...
CMT Ready!
rm343_500.21.009.07U, Type: Flash Image, Algo: BB5, XSR 1.5
CMT FUR Ready!
Box VPP disabled
Erase taken 1.343s
All blocks written OK! Time taken 20.204s
Flashing Speed: 6561.02 kBit/S
Restarting MCU...
Processing rm343_500.21.009.07U (APE)...
Processing RM343_ENO_0741.10_08wk42.a26.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM343_ENO_0741.10_08wk42.a26.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5
CMT FUR Ready!
Box VPP disabled
Certificates OK
Erase Certificate: SOS*ENO (CMT)
Erase taken 0.31s
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 2.47s
Flashing Speed: 6326.85 kBit/S
Restarting MCU...
Processing RM343_ENO_0741.10_08wk42.a26.fpsx (APE)...
Processing dawn_erase_y_drive.fpsx (CMT)...
Processing dawn_erase_y_drive.fpsx (APE)...
Factory defaults OK
Old 11-26-2010, 14:58   #1493 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Thumbs up 5130c flashing
7 Products left after filtering. Ready.
Retrieving Variants for Product RM-495 - wait...
419 Variants Retrieved
Processing rm495__07.95.mcusw (CMT)...
Booting CMT...
CMT_EM_ASIC_ID:        00000296
CMT_PUBLIC_ID:        1160000C96607D56E44F9CE2FD0F419FC6DFE148
CMT Ready!
rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Certificates OK
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Erase taken 94.359s
All blocks written OK! Time taken 48.734s
Flashing Speed: 3132.24 kBit/S
Restarting MCU...
Processing rm495__07.95.mcusw (APE)...
Processing rm495__07.95.ppm_mena_b (CMT)...
Booting CMT...
CMT Ready!
rm495__07.95.ppm_mena_b, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR
Erase taken 32.203s
All blocks written OK! Time taken 15.250s
Flashing Speed: 3470.85 kBit/S
Restarting MCU...
Processing rm495__07.95.ppm_mena_b (APE)...
Processing rm495__07.95.image_mena_b_red (CMT)...
Booting CMT...
CMT Ready!
rm495__07.95.image_mena_b_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR
EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR
Erase taken 249.31s
All blocks written OK! Time taken 20.157s
Flashing Speed: 3437.41 kBit/S
Restarting MCU...
Processing rm495__07.95.image_mena_b_red (APE)...
Factory defaults OK
Old 11-26-2010, 19:59   #1494 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 190
6600slide Successfully Unlocked
MCU Version	V 05.60
MCU Date	10-12-08
Product		RM-414
IMEI		35xxxxxxxx
Mastercode	33272647
IMEI Spare	3A15590453308309
IMEI SV		3315590453308329F5000000
PPM		V 05.60, 10-12-08, RM-414, (c) Nokia            , SP
CNT		Content: sp_black_movi_es_black, V 05.60, 10-12-08, RM-414, (c) Nokia            , ,
PSN		KNI633026
Product Code	0580627
Module Code	0203776
Basic Product Code	0558090
PSD		0000000000000000
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		2001
RFIC		17141715
DSP		ICPR72_vs08w40.1
LCD		SEIKO
BT		2222-sm143C
Simlock Key	2140700000000000
Simlock Profile	8000000000000002
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
MCU Version	V 05.60
MCU Date	10-12-08
Product		RM-414
IMEI		351954035033896
Mastercode	33272647
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security block OK and saved to "RM-414_351954035033896_26-11-2010_181949.SecurityBlock.PM"
WARNING: "131000150F877D560D17AEDD67EDC5ED20CBE46D.C0003343" Not Exists, Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006030C192101023000
CMT_PUBLIC_ID:		131000150F877D560D17AEDD67EDC5ED20CBE46D
CMT Ready!
Readed OK, Saving to "131000150F877D560D17AEDD67EDC5ED20CBE46D.C0003343"
Writing Simlock...
MCU Version	V 05.60
MCU Date	10-12-08
Product		RM-414
IMEI		35xxxxxxxxxx
Mastercode	33272647
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Unlock finished! Time taken 12.563s
Old 11-27-2010, 09:29   #1495 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 218
Nokia 7230 security code reset OK with USB cable.
[BB5 NMWCD]: Found 1 active devices
[Nokia 7230 USB Phonet]: Opening Connection
[Nokia 7230 USB Phonet]: Port opened OK!
MCU Version	V 09.83
MCU Date	21-09-10
Product		RM-604
IMEI		353798047305414
Mastercode	350233236
IMEI Spare	3A35970874034501
IMEI SV		3335970874034551F7000000
PPM		V 09.83, 21-09-10, RM-598, (c) Nokia            , I
CNT		Content: i_0590115, V 09.83, 21-09-10, RM-604, (c) Nokia
PSN		DKN696107
Product Code	0590224
Module Code	0204267
Basic Product Code	0585700
LPSN		0
RETU		40
TAHVO		00
AHNE		41
HW		1000
RFIC		|Vapaus_5.1 | Mikki_1.1
DSP		ICPR91_10w19_1
LCD		SEIKO
BT		1673-46038
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Setting factory defaults of: Factory set full
Factory defaults set OK
Old 11-27-2010, 10:04   #1496 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Wink 1280 flashing
Found 56 products, Filtering DCT4 Products - wait...
12 Products left after filtering. Ready.
Retrieving Variants for Product RM-647 - wait...
17 Variants Retrieved
Checking rm647_004.200...
28 Blocks Parsed
Flash file sorted Okay.
Booting X-Gold (press power-on if used non-battery cable)...
X-Gold: Ready, MCU ID: 0x3400
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Default_RAM_Bootloader
[EBL] : Ready
Setting Baudrate to 921600bps...
Baudrate Accepted (921600bps)
Flash Chip 0x002088C0, ST, Size: 8MBytes
1 file(s) embedded into image.
Processing "hw_b2_rm647_r04.200.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x00800000-0x00A0FFFF...
Erasing 0x00C60000-0x00EAFFFF...
Erasing 0x00FFC000-0x00FFFFFF...
Flashing at 0x00800000...
Flashed 2162688 bytes OK
Flashing at 0x00C60000...
Flashed 2007552 bytes OK
Flashing at 0x00FFC000...
Flashed 64 bytes OK
Box VPP disabled
Checking rm6470_nai04.20ic...
26 Blocks Parsed
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_b2_rm6470_nai04.20ic.fls"...
Erasing 0x00EB0000-0x00F7FFFF...
Flashing at 0x00EB0000...
Flashed 316800 bytes OK
Box VPP disabled
Checking rm647_004.20ic...
26 Blocks Parsed
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_b2_rm647_004.20ic.fls"...
Erasing 0x00210000-0x0045FFFF...
Flashing at 0x00210000...
Flashed 1305280 bytes OK
Box VPP disabled
Factory defaults OK
Old 11-27-2010, 14:19   #1497 (permalink)
Member: 977491
Thanks Meter: 82
5800 unlock done cheq complet report
Booting CMT...
CMT_PUBLIC_ID:  05300103A69400521BD60BE08FDB9F2E1B73055C
CMT Ready!
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
Restarting MCU...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-356_353382047790097_12272010_55233 AM.SecurityBlock.PM"
WARNING: "05300103A69400521BD60BE08FDB9F2E1B73055C.C0000D04" Not Exists, Will read it...
Booting CMT...
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Readed OK, Saving to "05300103A69400521BD60BE08FDB9F2E1B73055C.C0000D04"
Storing Additional Data...
Checking Superdongle Key...
Superdongle Store Problem -> Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?)
Checking CMLA Key...
CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?)
Booting CMT...
CMT Ready!
CMT FUR Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
MCU Version V ICPR72_10w04.5
MCU Date 22-03-10
Product  RM-356
IMEI  353382047790097
Mastercode 6325507770
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-356_353382047790097_12272010_55304 AM.SecurityBlock.PM"
"05300103A69400521BD60BE08FDB9F2E1B73055C.C0000D04" Exists, That is good...
Writing Simlock...
MCU Date 22-03-10
Product  RM-356
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished! Time taken 3.813s
Last edited by ptt; 11-27-2010 at 14:22. Reason: add Code Tag - Use readable color fonts
Old 11-28-2010, 07:33   #1498 (permalink)
Member: 977491
Thanks Meter: 82
E71 unlock done.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Handling device: [Cyclone Team], [Cyclone Bootloader]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags
Box Serial Number: C0000D04
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06
Initializing security card...
Card Serial Number: D000041A
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.07v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 3.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.12v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting RAP...
CMT_PUBLIC_ID:   0CF00113D0D98A52904E2C8CE221A98C10C126E2
CMT_ROM_ID:   4B9B75103E691FF8
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Box VPP disabled
PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7
Restarting MCU...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Booting RAP...
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Version V ICPR71_08w44.2
MCU Date 19-11-08
Product  RM-346
IMEI  356059033464898
Mastercode 1770756762
Simlock Key 2080100000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20801F
Security block OK!
Determining PA Simlock...
Booting RAP...
Box VPP disabled
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP...
#pw+526952384051847+1#
#pw+955190423737655+2#
#pw+762718595627645+3#
#pw+344112012964690+4#
#pw+532003142023044+5#
#pw+175991830913638+6#
#pw+773384704879995+7#
BB5 Unlock Failed -> Phone not detected (FBUS)
Old 11-29-2010, 03:53   #1499 (permalink)
Member: 901335
Sonork: 100.1652281
Thanks Meter: 151
7210 flash done , failed in other tool
Booting CMT...
CMT_PUBLIC_ID:		22E00010B3757F567054B23D2D931C6F4A8531B6
CMT Ready!
Box VPP disabled
Restarting MCU...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Found 51 products, Filtering BB5 Products - wait...
13 Products left after filtering. Ready.
318 Variants Retrieved
Booting CMT...
CMT Ready!
Box VPP disabled
Restarting MCU...
Backing up RPL...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Booting CMT...
CMT Ready!
Box VPP disabled
Certificates OK
Erase taken 108.781s
All blocks written OK! Time taken 52.344s
Flashing Speed: 2894.18 kBit/S
Restarting MCU...
Processing rm436__07.23.ppm_mr (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.ppm_mr, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 41.375s
All blocks written OK! Time taken 18.391s
Flashing Speed: 3238.97 kBit/S
Restarting MCU...
Processing rm436__07.23.ppm_mr (APE)...
Processing rm436__07.23.image_mr (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.image_mr, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 43.156s
All blocks written OK! Time taken 20.906s
Flashing Speed: 3314.26 kBit/S
Restarting MCU...
Processing rm436__07.23.image_mr (APE)...
Factory defaults OK
Reading info...
MCU Version	V 07.23
MCU Date	17-07-09
Product		RM-436
IMEI		353180036730896
Mastercode	4330223152
IMEI Spare	3A35810063378009
IMEI SV		3335810063378049F0000000
PPM		V 07.23, 17-07-09, RM-436, (c) Nokia            , MR
CNT		Content: mr, V 07.23, 12-08-09, RM-436, (c) Nokia            ,
PSN		DAP937743
Product Code	0581686
Module Code	0203868
Basic Product Code	0563951
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1001
RFIC		06540601
DSP		ICPR72_09w17
LCD		SHARP
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Read info thread finished, continuing...
Old 11-30-2010, 08:09   #1500 (permalink)
Registered User
Member: 1178981
Sonork: 100.1596342
Thanks Meter: 500
Thumbs up 5530 Flashing Ok
Retrieving Variants for Product RM-504 - wait...
96 Variants Retrieved
Processing RM-504_31.0.005_prd.core.C00 (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105
CMT_PUBLIC_ID:  0EB00113DE8F0052515ACC11A1A6ACBC87A927B3
CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT Ready!
RM-504_31.0.005_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase taken 0.750s
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 119.360s
Flashing Speed: 7226.41 kBit/S
Restarting MCU...
Processing RM-504_31.0.005_prd.core.C00 (APE)...
Processing RM-504_31.0.005_prd.rofs2.V12 (CMT)...
Booting CMT...
CMT Ready!
RM-504_31.0.005_prd.rofs2.V12, Type: Flash Image, Algo: XSR 1.5, BB5
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x07260000-0x0935FFFF, ONENAND
Erase taken 0.141s
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 23.969s
Flashing Speed: 7116.21 kBit/S
Restarting MCU...
Processing RM-504_31.0.005_prd.rofs2.V12 (APE)...
Processing RM-504_31.0.005_C02_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-504_31.0.005_C02_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09360000-0x09E5FFFF, ONENAND
Erase taken 0.47s
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 6.157s
Flashing Speed: 7069.31 kBit/S
Restarting MCU...
Processing RM-504_31.0.005_C02_prd.rofs3.fpsx (APE)...
Processing RM-504_31.0.005_007_000_U001.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-504_31.0.005_007_000_U001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND
Erase taken 0.375s
All blocks written OK! Time taken 8.563s
Flashing Speed: 6008.55 kBit/S
Restarting MCU...
Processing RM-504_31.0.005_007_000_U001.uda.fpsx (APE)...
Factory defaults OK
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.57549 seconds with 10 queries
