12-04-2010, 10:22 | #1516 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 1616 flashing done Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 54 products, Filtering DCT4 Products - wait... 11 Products left after filtering. Ready. Retrieving Variants for Product RH-125 - wait... 225 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Checking rh125_004.650... 28 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_r04.650.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Erasing 0x00C60000-0x00EAFFFF... Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Flashing at 0x00C60000... Flashed 2113664 bytes OK Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rh1250_nai04.65ia... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh1250_nai04.65ia.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 356800 bytes OK Box VPP disabled Checking rh125_004.65ia... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_004.65ia.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 2075200 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
The Following 2 Users Say Thank You to RAVI_SINGH For This Useful Post: |
12-05-2010, 08:38 | #1518 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | n73 flash done.convert to music edition http://img585.imageshack.us/i/n73flashdone.jpg Code: Processing N73_rofx_4.0839.42.2.1_PRD.V05 (CMT)... Processing N73_rofx_4.0839.42.2.1_PRD.V05 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 867D989BBF1667ABB36A85CBC50888E4DD18BB41 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 0B000102C49F0154E9F7221EB7631F41908536E5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_rofx_4.0839.42.2.1_PRD.V05, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x03920000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.328s Writing all blocks... Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 39.687s Flashing Speed: 3425.24 kBit/S Restarting MCU... Processing N73_userarea_4.0839.42.2.1.U02 (CMT)... Processing N73_userarea_4.0839.42.2.1.U02 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 867D989BBF1667ABB36A85CBC50888E4DD18BB41 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 0B000102C49F0154E9F7221EB7631F41908536E5 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_userarea_4.0839.42.2.1.U02, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,APE]: 0x04E20000-0x07C9FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.656s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 11.407s Flashing Speed: 5430.49 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! Setting factory defaults of: User data Factory defaults set OK Setting factory defaults of: Factory set full Factory defaults set OK Last edited by ptt; 12-05-2010 at 14:43. Reason: add CODE TAG & remove not necesary big screenshot |
The Following User Says Thank You to themobileshop For This Useful Post: |
12-05-2010, 21:01 | #1519 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | 222o rm_590 succesfully flash by cyclone first i try with mxkey ,dead then try with cyclone box, succesfully flashed Code: Box is activated Started box selftests procedure USB Voltage 4.97v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.91v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 37 products, Filtering DCT4 Products - wait... 2 Products left after filtering. Ready. Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.20.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 843DEAE06F8E6168BEF08A0B1B MSID-Plain: 2C40BAE900418D59AA000000 FAID-Crypted: 85F1B45A0DD50F21D06A903D Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 113.172s Writing 183 blocks... All blocks written OK! Time taken 65.547s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.20.image_m_c_graphi, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8499334E7F83AC9FE18EA2D31F MSID-Plain: D26EBAF100418D59AA000610 FAID-Crypted: DFE3D598F3BF71C41C8884EC Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02180000-0x02E7FFFF] Erasing NOR Region [0x02E80000-0x02FBFFFF] Erase taken 123.782s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 296 blocks... All blocks written OK! Time taken 27.938s Terminating flash session Extracting Content Package... CP Extract Failed -> CP Server not exists WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm590__10.20.ppm_m_c, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.07V MSID-Crypted: 84689E4B1FC7884B82FEFEBC09 MSID-Plain: 3E4EBAE900418D59A9000000 FAID-Crypted: 5CB947C248E7115717CA9E4F Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01D00000-0x0217FFFF] Erase taken 39.922s Writing 32 blocks... All blocks written OK! Time taken 11.531s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! MCU Version V 10.20 MCU Date 04-05-10 Product RM-590 Manufacturer (c) Nokia IMEI 351548042612054 Mastercode 2025207270 IMEI Spare 3A15450824160205 IMEI SV 3315450824160255F8000000 PPM V 10.20, 04-05-10, RM-590, (c) Nokia , M_C CNT Content: m_c_graphi, V 10.20, 04-05-10, RM-590, (c) Nokia , PSN IPO238567 Product Code 0590597 Module Code 0204340 Basic Product Code 0582851 PSD 0000000D00000000 LPSN 0 HW 2000 UEM 1328 UPP 3168 RFIC 0500 DSP ICPR72_09w52_U LCD SUEZ Asic 11 HW Signature 5D5973F35AF4624F Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553515480426120500 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data Last edited by ptt; 12-05-2010 at 21:15. Reason: add Code Tag |
The Following User Says Thank You to alkhaleejmobile For This Useful Post: |
12-06-2010, 04:18 | #1520 (permalink) |
Insane Poster Join Date: Dec 2008 Location: Sampit - Indonesia
Member: 923829 Status: Offline Thanks Meter: 53 | 1616 succesfully Code: Processing pre-flash tasks... Backing up Flash IMEI... No RPL Found at PM, this is not critical, continuing... Flash IMEI Backup OK Pre-flash tasks finished Checking rh125_004.650... 28 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_r04.650.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Erasing 0x00C60000-0x00EAFFFF... Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Flashing at 0x00C60000... Flashed 2113664 bytes OK Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rh1250_nai04.65me... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh1250_nai04.65me.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 301376 bytes OK Box VPP disabled Checking rh125_004.65me... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [PBL] : SE0_091125 F11 [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_004.65me.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 2086848 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Unlocking... MCU Version V 04.65 MCU Date 24-04-10 Product RH-125 (Nokia RH-125) Manufacturer (c) Nokia IMEI 358234037489104 Mastercode 106105273 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 11 HW Signature 8C117CFD0791890C Simlock Server Simlock Key 0010100000000000 Simlock Profile 0000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003582340374891000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Asking card to sign HW Signature... Signed OK (D1F34AF82FB21CEFF491DE3072AFD8BA33CD836A) Calculating SP... Writing SP... Failed to Unlock DCT4 Plus -> Possible cause: RSA Signature Invalid Unlock thread finished, continuing... Post-flash tasks finished... Flash successfully finished! Last edited by ptt; 12-06-2010 at 13:21. Reason: add Code Tag |
The Following User Says Thank You to xcool_sc For This Useful Post: |
12-06-2010, 16:07 | #1521 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 1202 flashing ok Code: Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh112_003.100, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84C3B325B1DC44A9F389E24BDA Using MSID-FAID Cache, Not wasting card FAID-Crypted: D9CCCC1F675B89AC78A6A426 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 69.297s Writing 148 blocks... All blocks written OK! Time taken 11.938s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh1120_nai03.10ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84C470F9AB64C718813005D1A4 Using MSID-FAID Cache, Not wasting card FAID-Crypted: B3E544893739799BF64D1161 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.281s Writing 11 blocks... All blocks written OK! Time taken 0.843s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2293 [HW_UNKNOWN] rh112_003.10ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84C470F9AB64C718813005D1A4 Using MSID-FAID Cache, Not wasting card FAID-Crypted: B3E544893739799BF64D1161 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01240000-0x0124FFFF] Erasing NOR Region [0x01250000-0x0137FFFF] Erase taken 22.171s Writing 63 blocks... All blocks written OK! Time taken 5.79s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
The Following 3 Users Say Thank You to RAVI_SINGH For This Useful Post: |
12-06-2010, 16:10 | #1522 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 1280 flashing Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 56 products, Filtering DCT4 Products - wait... 20 Products left after filtering. Ready. Retrieving Variants for Product RM-647 (Nokia RM-647) - wait... 17 Variants Retrieved Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Processing pre-flash tasks... Pre-flash tasks finished Checking rm647_004.200... 28 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_b2_rm647_r04.200.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Erasing 0x00C60000-0x00EAFFFF... Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Flashing at 0x00C60000... Flashed 2007552 bytes OK Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rm6470_nai04.20ic... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_b2_rm6470_nai04.20ic.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 316800 bytes OK Box VPP disabled Checking rm647_004.20ic... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_b2_rm647_004.20ic.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 1305280 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
12-07-2010, 15:53 | #1523 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 5130 flashing Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm495__07.95.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0AE00008CE1F0056C62B246F5D23F4ED4279E515 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC240000008A31, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2400 (Samsung), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 73.828s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 66.781s Flashing Speed: 2285.78 kBit/S Restarting MCU... Processing rm495__07.95.mcusw (APE)... Processing rm495__07.95.ppm_mena_b (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0AE00008CE1F0056C62B246F5D23F4ED4279E515 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.ppm_mena_b, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC240000008A31, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2400 (Samsung), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Waiting 320s for erasure finish... Erase taken 25.766s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 23.296s Flashing Speed: 2272.09 kBit/S Restarting MCU... Processing rm495__07.95.ppm_mena_b (APE)... Processing rm495__07.95.image_mena_b_red (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0AE00008CE1F0056C62B246F5D23F4ED4279E515 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.image_mena_b_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC240000008A31, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2400 (Samsung), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 144.609s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 28.609s Flashing Speed: 2421.89 kBit/S Restarting MCU... Processing rm495__07.95.image_mena_b_red (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
12-07-2010, 15:54 | #1524 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | N70 flashing ok Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 54 products, Filtering BB5 Products - wait... 6 Products left after filtering. Ready. Retrieving Variants for Product RM-84 (Nokia N70) - wait... 174 Variants Retrieved Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0453DA60E8A2D415369E7AA03C5563F62932CF33 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1A2000116A616351AA63763A5A959EC2CAAEB116 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM84_51003301.C0 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1A2000116A616351AA63763A5A959EC2CAAEB116 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! RM84_51003301.C0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0052B60D, NOR EraseArea[0,CMT]: 0x006A0000-0x006BFFFF, NOR EraseArea[0,CMT]: 0x006DF000-0x006EFFFF, NOR EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR Waiting 320s for erasure finish... Erase taken 38.625s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Skipping CMT PAPUBKEYS Certificate (already sent)... Programming Status OK! All blocks written OK! Time taken 29.844s Flashing Speed: 8265.33 kBit/S Restarting MCU... Processing RM84_51003301.C0 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0453DA60E8A2D415369E7AA03C5563F62932CF33 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1A2000116A616351AA63763A5A959EC2CAAEB116 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! RM84_51003301.C0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0000FFFF, NAND EraseArea[0,APE]: 0x00010000-0x0001FFFF, NAND EraseArea[0,APE]: 0x00020000-0x000203FF, NAND EraseArea[0,APE]: 0x00050000-0x03ECFFFF, NAND Waiting 320s for erasure finish... Erase taken 5.31s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS+XZIP Certificate... Writing APE PASUBTOC Certificate... Writing APE PAPUBKEYS Certificate... Skipping APE PAPUBKEYS Certificate (already sent)... Writing APE SOS*CORE Certificate... Programming Status OK! All blocks written OK! Time taken 32.63s Flashing Speed: 7693.31 kBit/S Restarting MCU... Processing RM84_51003301.V28 (CMT)... Processing RM84_51003301.V28 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0453DA60E8A2D415369E7AA03C5563F62932CF33 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1A2000116A616351AA63763A5A959EC2CAAEB116 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! RM84_51003301.V28, Type: Flash Image, Algo: BB5, OMAP1610 GBBM-1.8.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x01AE0000-0x02AFFFFF, NAND EraseArea[0,APE]: 0x02B00000-0x03ECFFFF, NAND Waiting 320s for erasure finish... Erase taken 2.890s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 20.562s Flashing Speed: 4377.97 kBit/S Restarting MCU... Processing RM84_51003301.UDA (CMT)... Processing RM84_51003301.UDA (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0453DA60E8A2D415369E7AA03C5563F62932CF33 APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1A2000116A616351AA63763A5A959EC2CAAEB116 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! RM84_51003301.UDA, Type: Flash Image, Algo: BB5, OMAP1610 GBBM-1.8.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00980036 (Toshiba), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 9.766s Flashing Speed: 3224.26 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
12-07-2010, 15:56 | #1525 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | successfully Flashed E51 Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm244_41034001_prd.c00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CD0010575B90158FEDCE32E6FAE2ECDCAE13875 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm244_41034001_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000022, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 35AC54F8E31BE1357AB78D73834F020906331653 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x068FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.203s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... Programming Status OK! All blocks written OK! Time taken 60.781s Flashing Speed: 7388.00 kBit/S Restarting MCU... Processing rm244_41034001_prd.c00 (APE)... Processing rm244_41034001_prd.v10 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CD0010575B90158FEDCE32E6FAE2ECDCAE13875 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm244_41034001_prd.v10, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000022, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 35AC54F8E31BE1357AB78D73834F020906331653 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x04A00000-0x068FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.359s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 17.188s Flashing Speed: 7204.49 kBit/S Restarting MCU... Processing rm244_41034001_prd.v10 (APE)... Processing rm244_41034001.01U (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1CD0010575B90158FEDCE32E6FAE2ECDCAE13875 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm244_41034001.01U, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000022, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 35AC54F8E31BE1357AB78D73834F020906331653 Flashbus Write baud set to 5.0Mbits Started group flash erase Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.172s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 4.485s Flashing Speed: 6932.66 kBit/S Restarting MCU... Processing rm244_41034001.01U (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
12-08-2010, 08:57 | #1526 (permalink) |
No Life Poster Join Date: May 2004 Location: Coimbatore, India Age: 41
Member: 65535 Status: Offline Thanks Meter: 451 | 7020a flash done with usb Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.49, (Dec 2 2010 13:37:45, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00***** HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D00***** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.97v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.82v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.70v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 114 products, Filtering BB5 Products - wait... 55 Products left after filtering. Ready. Retrieving Variants for Product RM-497 (Nokia 7020/7020a-2/7020a-2b) - wait... 6 Variants Retrieved Failed to Process all Image files -> No images in queue to process, add some Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Sending User Abort Signal... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... Sending User Abort Signal... BB5 USB Boot Rom not Detected -> User Abort Failed to Boot CMT -> No compatible USB devices detected Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Backing up simlock... Sending User Abort Signal... Phone not detected at USB -> User Abort Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm497__08.11.mcusw (CMT)... Booting CMT... Sending User Abort Signal... BB5 USB Boot Rom not Detected -> User Abort Failed to Boot CMT -> No compatible USB devices detected Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm497__08.11.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm497__08.11.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005331 CMT_PUBLIC_ID: E43FDE820B7B94155AF5FA1F2352762A5FE9E030 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm497__08.11.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.10.34.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x01FFFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.281s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Writing CMT GENIO_INIT Certificate... Programming Status OK! All blocks written OK! Time taken 5.47s Flashing Speed: 40325.78 kBit/S Processing rm497__08.11.mcusw (APE)... Processing rm497__08.11.ppm_mk (CMT)... rm497__08.11.ppm_mk, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02000000-0x027FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 1.390s Flashing Speed: 44229.32 kBit/S Processing rm497__08.11.ppm_mk (APE)... Processing rm497__08.11.image_mk_059B760_001 (CMT)... rm497__08.11.image_mk_059B760_001, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 57B0CD145768F65CDF89F47F1FAE61BF16EF7DD7 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02800000-0x0753FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.969s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 2.531s Flashing Speed: 41306.61 kBit/S Processing rm497__08.11.image_mk_059B760_001 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia 7020 USB Phonet]: Port opened OK! [Nokia 7020 USB Phonet]: Port opened OK! [Nokia 7020 USB Phonet]: Port opened OK! [Nokia 7020 USB Phonet]: Port opened OK! [Nokia 7020 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia 7020 USB Phonet]: Port opened OK! MCU Version V 08.11 MCU Date 04-05-10 Product RM-497 (Nokia 7020/7020a-2/7020a-2b) Manufacturer (c) Nokia IMEI 35198********** Mastercode 3271334525 IMEI Spare 3A15890984311508 IMEI SV 3315890984311548F1000000 PPM V 08.11, 04-05-10, RM-497, (c) Nokia , MK CNT Content: mk_059B760, V 08.11, 04-05-10, RM-497, (c) Nokia , PSN HGC837821 Product Code 059B760 Module Code 0204040 Basic Product Code 0570540 PSD 0000000000000000 LPSN 0 HW 1000 RFIC 9 LCD SEIKO BT 2.31-SP2.26 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000002 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-08-2010 at 15:50. Reason: add Code Tag |
12-08-2010, 22:50 | #1527 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1168892 Status: Offline Thanks Meter: 14 | C7 killed by mxkey successfully flashed with cyclone - cyclone team you done realy good job with new update.....but remained a problem with the files from the server,all files i download are corupted... -In any case I appreciate your effort and the well done job with new update thanks... Code: Retrieving Variants for Product RM-675 (Nokia C7-00) - wait... 45 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Sending User Abort Signal... Phone not detected at USB -> User Abort Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1DB00116AF3A00499FBA4B72FC603F0CBE6C3EA2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FEC ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... Sending User Abort Signal... Phone not detected at USB -> User Abort Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-675_012.003_79.92_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1DB00116AF3A00499FBA4B72FC603F0CBE6C3EA2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_012.003_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.34.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FEC ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.34.1, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 18.359s Flashing Speed: 57943,18 kBit/S Processing RM-675_012.003_79.92_prd.core.fpsx (APE)... Processing RM-675_012.003_07.01_Balkans_79.92_prd.rofs2.fpsx (CMT)... BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.250s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 4.281s Flashing Speed: 68038,69 kBit/S Processing RM-675_012.003_07.01_Balkans_79.92_prd.rofs2.fpsx (APE)... Processing RM-675_012.003_00.01_79.92_prd.rofs3.fpsx (CMT)... RM-675_012.003_00.01_79.92_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.266s Flashing Speed: 147,85 kBit/S Processing RM-675_012.003_00.01_79.92_prd.rofs3.fpsx (APE)... Processing RM-675_012.003_U01.01_79.92_prd.uda.fpsx (CMT)... RM-675_012.003_U01.01_79.92_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0E980000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 2.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.110s Flashing Speed: 53679,58 kBit/S Processing RM-675_012.003_U01.01_79.92_prd.uda.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 92PS1_10w36.2 MCU Date 14-09-10 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755045732155 Mastercode 524631312 IMEI Spare 3A35570554371205 IMEI SV 3335570554371205F2000000 PSN CFN770095 Product Code 059B532 Module Code 0204505 Basic Product Code 0595319 PSD 0000000000000000 LPSN 0 WLAN MAC C8DF7C08D8E3 APE SW 012.003 APE Variant 012.003.00.01012.003.07.01012.003.00.01 APE Test rm675_ENO_v_0.0308 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6003 RFIC |Alli_4.3.4 DSP TB92PS1_10w36 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-09-2010 at 13:39. Reason: add Code Tag |
12-09-2010, 07:00 | #1528 (permalink) |
Freak Poster Join Date: Oct 2010 Location: lapu-lapu cebu
Member: 1421076 Status: Offline Sonork: 100.1595996 Thanks Meter: 31 | 2680s successfully flash Code: Box is activated Started box selftests procedure USB Voltage 4.93v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.77v PASSED VBAT Voltage 1.41v PASSED VBAT Voltage 4.93v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.81v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm392__06.17.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221 FlashChip[1]: 0x0001317E @ 0x02000000, AMD, SectorSize: 128kB, Ext: 00419221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84928ECCECF25002716EF8FBBB MSID-Plain: 2C40BAE9001B07BDA9000000 FAID-Crypted: 5591D07455E16FCEB5B282AF Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 53.578s Writing 190 blocks... All blocks written OK! Time taken 231.391s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm392__06.17.image_el, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221 FlashChip[1]: 0x0001317E @ 0x02000000, AMD, SectorSize: 128kB, Ext: 00419221 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84658C0033F762C784D4480FEA MSID-Plain: D26EBAF1001B07BDAA000610 FAID-Crypted: 8553785915329FAEC1C2897A Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02180000-0x02E7FFFF] Erasing NOR Region [0x02E80000-0x02FBFFFF] Erase taken 69.516s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 240 blocks... All blocks written OK! Time taken 69.297s Terminating flash session Extracting Content Package... CP Extract Failed -> CP Server not exists WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm392__06.17.ppm_el, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221 FlashChip[1]: 0x0001317E @ 0x02000000, AMD, SectorSize: 128kB, Ext: 00419221 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8456789D27884EE69D8854165C MSID-Plain: 3E4EBAE9001B07BDA8000000 FAID-Crypted: 1320F6993C58EF2B2BE625C7 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01D00000-0x0217FFFF] Erase taken 21.344s Writing 34 blocks... All blocks written OK! Time taken 44.312s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! Last edited by ptt; 12-09-2010 at 13:33. Reason: add Code Tag |
12-09-2010, 09:52 | #1529 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 1200 flashing done Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 51 products, Filtering DCT4 Products - wait... 19 Products left after filtering. Ready. Retrieving Variants for Product RH-99 (Nokia 1200 CABLE 1100) - wait... 322 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_03.120, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 841FA95FC3A6D66C3996375286 MSID-Plain: 3E4EBAE9008F24C6A8000000 FAID-Crypted: 6A290D9D88A5FD7ADDA256DE Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013BFFFF] Erasing NOR Region [0x013C0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 67.313s Writing 147 blocks... All blocks written OK! Time taken 12.485s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh990_nai3.12ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8468D1CA6B340AC6B4D15A56D1 MSID-Plain: 3E4EBAE9008F24C6A9000000 FAID-Crypted: 09B490592225111A27E384FE Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013BFFFF] Erase taken 4.250s Writing 8 blocks... All blocks written OK! Time taken 0.610s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh99_03.12ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 841FA95FC3A6D66C3996375286 Using MSID-FAID Cache, Not wasting card FAID-Crypted: 6A290D9D88A5FD7ADDA256DE Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01240000-0x0124FFFF] Erasing NOR Region [0x01250000-0x0137FFFF] Erase taken 21.203s Writing 69 blocks... All blocks written OK! Time taken 5.828s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
The Following 2 Users Say Thank You to RAVI_SINGH For This Useful Post: |
12-09-2010, 11:04 | #1530 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | N97 Flashing Ok Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 51 products, Filtering BB5 Products - wait... 5 Products left after filtering. Ready. Retrieving Variants for Product RM-505 (Nokia N97) - wait... 44 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-505_22.0.110_prd.core.C00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EB0010BA9DA0158169C17218ADA47C8FCABAF28 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x0AB9FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.969s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 130.31s Flashing Speed: 6860.40 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.core.C00 (APE)... Processing RM-505_22.0.110_prd.rofs2.V16 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EB0010BA9DA0158169C17218ADA47C8FCABAF28 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_prd.rofs2.V16, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x079A0000-0x09C9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.187s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 23.969s Flashing Speed: 6642.02 kBit/S Restarting MCU... Processing RM-505_22.0.110_prd.rofs2.V16 (APE)... Processing RM-505_22.0.110_C01_prd.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EB0010BA9DA0158169C17218ADA47C8FCABAF28 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-505_22.0.110_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09CA0000-0x0AB9FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.78s Flashing Speed: 946.46 kBit/S Restarting MCU... Processing RM-505_22.0.110_C01_prd.rofs3.fpsx (APE)... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EB0010BA9DA0158169C17218ADA47C8FCABAF28 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_507_22.0.110_uda_4_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0ABA0000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.422s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 11.907s Flashing Speed: 6192.62 kBit/S Restarting MCU... Processing RM505_507_22.0.110_uda_4_001.uda.fpsx (APE)... Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EB0010BA9DA0158169C17218ADA47C8FCABAF28 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM505_APE_ONLY_ENO_09w23_v0.072.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: DAEF2C397A3F8FC5CA8B1F429D73C94C4A25B15B Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.16s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 3.469s Flashing Speed: 6649.36 kBit/S Restarting MCU... Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
