Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #2251 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: England Age: 58
Member: 947561 Status: Offline Thanks Meter: 14,048 | Nokia C3-00 RM-614 successfully unlocked Code: Checking job status... Code Ready, Code: #pw+906910656004513+7# [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 04.60 MCU Date 31-08-10 Product RM-614 (Nokia C3-00 C3-00.2) Manufacturer (c) Nokia IMEI 355966040474978 Mastercode 2416543270 Simlock Server SIMLOCK SERVER Simlock Key 2341500000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23415F Simlock NCK #pw+9Š6910656004513+7# Alex |
![]() | #2252 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 37
Member: 977491 Status: Offline Thanks Meter: 82 | 2700 restart on ring tones and audio songs flash ok Code: Processing rm561__09.98.ppm_t (APE)... Processing rm561__09.98.image_ctv_nz_gray (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 108001073C268D56804E2B327115CA1187C13872 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm561__09.98.image_ctv_nz_gray, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3EA22A1DDA660002E56108DB5072A10F8709443F Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 202.297s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 36.782s Flashing Speed: 2483.10 kBit/S Restarting MCU... Processing rm561__09.98.image_ctv_nz_gray (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 11-21-2011 at 16:25. Reason: ADD [CODE] ____________ [/CODE] TAG |
![]() | #2253 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 212683 Status: Offline Thanks Meter: 115 | 6300 unlock done Code: BB5 Unlock Started... MCU Version V 07.21 MCU Date 05-11-08 Product RM-217 (Nokia 6300) Manufacturer (c) Nokia. IMEI 3582880 Mastercode 436756451 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F Reading Security Block... Security block OK and saved to "RM-217_358288030880727_11282011_70720 AM.SecurityBlock.PM" Determining PA Simlock... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2AB00004CA268C560A98F02FF536A5B12DD73B3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (old method) BB5 Unlock Failed -> Unsupported Rootkey Hash for selected Unlock Method, this is critical BB5 Unlock Started... MCU Version V 07.21 MCU Date 05-11-08 Product RM-217 (Nokia 6300) Manufacturer (c) Nokia. IMEI 358288 Mastercode 436756451 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F Reading Security Block... Security block OK and saved to "RM-217_358288030880727_11282011_70744 AM.SecurityBlock.PM" "2AB00004CA268C560A98F02FF536A5B12DD73B3E.C00001B6" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V 07.21 MCU Date 05-11-08 Product RM-217 (Nokia 6300) Manufacturer (c) Nokia. IMEI 358288 Mastercode 436756451 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 3.640 Last edited by ptt; 11-21-2011 at 16:26. Reason: ADD [CODE] ___________________ [/CODE] TAG |
![]() | #2254 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: ROMANIA
Member: 727888 Status: Offline Thanks Meter: 219 | C1-01 flash succesfully! Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm607__03.35.mcusw (XGold2)... Checking rm607__03.35.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.37_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Processing "rm607__03.35.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4007FFFF... Flashing at 0x40040000... Flashed 262144 bytes OK Erasing 0x40080000-0x4009FFFF... Flashing at 0x40080000... Flashed 131072 bytes OK Erasing 0x400A0000-0x4019FFFF... Flashing at 0x400A0000... Flashed 1048576 bytes OK Erasing 0x40400000-0x41BFFFFF... Flashing at 0x40400000... Flashed 24641536 bytes OK Processing rm607__03.35.ppm_b (XGold2)... Checking rm607__03.35.ppm_b... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_b.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41C00000-0x421FFFFF... Flashing at 0x41C00000... Flashed 3643960 bytes OK Processing rm607__03.35_001.image_b_voda_ro_9f530 (XGold2)... Checking rm607__03.35_001.image_b_voda_ro_9f530... Flash file sorted Okay. 1 file(s) embedded into image. Processing "/WORKAREA/C1-01_RM607/rm607_sw_settings_34/temp/059F530/CONTENT_CONFIG/package_b_voda_ro.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x42200000-0x43E5FFFF... Flashing at 0x42200000... Flashed 11796480 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 11-21-2011 at 19:14. Reason: ADD [CODE] ___________________ [/CODE] TAG |
![]() | #2255 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,048 | Nokia 1112 RH-93 successfully unlocked Just curious to test if the old asics unlock worked and actually did!!! Code: MCU Version V 6.40 MCU Date 12-01-07 Product RH-93 (Nokia 1110i/1112/1116) Manufacturer (c) NMP IMEI 359548013644179 Mastercode 522513173 IMEI Spare 3A95450831461407 IMEI SV 3395450831461437F5000000 PPM V 6.40, 12-01-07, RH-93, (c) NMP, AE PSN KHS099309 Product Code 0545700 Module Code 0203167 Basic Product Code 0532665 PSD 0000000D00000000 HW 0526 UEM 1328 UPP 2201 RFIC 0500 DSP P05w06.v34 LCD WIN:SYRS:01, ST7506 ADSP Sw p%V 6.40\n12-01-07\nRH-93\n(c) NMP\nae Asic 2 HW Signature 5D49E71AE42CF411 Simlock Server Simlock Key 2340000300000000 Simlock Profile 8000000000010002 Simlock Aux 00025C6E Simlock IMEI 00003595480136441700 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Simlock [1,2] State: CLOSED Type: 3F007F206F3EFFFF @ E000 Data: 0AFF Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23410F Simlock [2,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ E000 Data: 0AFF Auto Selecting Flash Files on User Request... Product Code: 0545700 No Flash Datapackage installed for this Phone! MCU Version V 6.40 MCU Date 12-01-07 Product RH-93 (Nokia 1110i/1112/1116) Manufacturer (c) NMP IMEI 359548013644179 Mastercode 522513173 Setting Local Mode... Local mode Set Asic 2 HW Signature 5D49E71AE42CF411 Simlock Server Simlock Key 2340000300000000 Simlock Profile 8000000000010002 Simlock Aux 00020000 Simlock IMEI 00003595480136441700 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Simlock [1,2] State: CLOSED Type: 3F007F206F3EFFFF @ E000 Data: 0AFF Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23410F Simlock [2,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ E000 Data: 0AFF Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (FB3908566EFC8333A3F1DA80B5EA7BB52FBDBFD2) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 6.40 MCU Date 12-01-07 Product RH-93 (Nokia 1110i/1112/1116) Manufacturer (c) NMP IMEI 359548013644179 Mastercode 522513173 IMEI Spare 3A95450831461407 IMEI SV 3395450831461437F5000000 PPM V 6.40, 12-01-07, RH-93, (c) NMP, AE PSN KHS099309 Product Code 0545700 Module Code 0203167 Basic Product Code 0532665 PSD 0000000D00000000 HW 0526 UEM 1328 UPP 2201 RFIC 0500 DSP P05w06.v34 LCD WIN:SYRS:01, ST7506 ADSP Sw p%V 6.40\n12-01-07\nRH-93\n(c) NMP\nae Asic 2 HW Signature 5D49E71AE42CF411 Simlock Server Simlock Key 0010100000000000 Simlock Profile 8000000000010002 Simlock Aux 00025C6E Simlock IMEI 00003595480136441700 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... Product Code: 0545700 No Flash Datapackage installed for this Phone! Alex |
![]() | #2256 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 812 | c3 flash done Code: Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000037 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D000028C Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.83v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.09v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.09v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 100 Avaiable Physical Memory: 246.792MB Avaiable Virtual Memory: 1.501GB Avaiable Pagefile: 1.695GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 334 products, Filtering BB5 Products - wait... 13 Products left after filtering. Ready. Retrieving Variants for Product RM-614 - wait... 82 Variants Retrieved Booting CMT... Sending User Abort Signal... CBUS Request Error -> User abort Sending User Abort Signal... BB5 USB Boot Rom not Detected -> User Abort Failed to Boot CMT -> No compatible USB devices detected Prepare phone failed with message -> Failed to Boot CMT Sending User Abort Signal... Phone not detected at USB -> Timeout, no any compatible USB device detected. Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm614__08.65.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 00000000004A7FC0A9A7871B4D751CD43BA46E7A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm614__08.65.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.16.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.16.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x012FFFFF, ONENAND EraseArea[0,CMT]: 0x01300000-0x01DFFFFF, ONENAND EraseArea[0,CMT]: 0x02600000-0x029FFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.297s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT ADA Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 5.985s Flashing Speed: 39124.69 kBit/S Processing rm614__08.65.mcusw (APE)... Processing rm614__08.65.ppm_mc1 (CMT)... rm614__08.65.ppm_mc1, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x01E00000-0x025FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 1.47s Flashing Speed: 42263.27 kBit/S Processing rm614__08.65.ppm_mc1 (APE)... Processing rm614__08.65.image_mc1_059B4D4 (CMT)... rm614__08.65.image_mc1_059B4D4, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02A00000-0x0753FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.969s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 3.16s Flashing Speed: 39389.76 kBit/S Processing rm614__08.65.image_mc1_059B4D4 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! [Nokia C3-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.65 MCU Date 12-05-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 355966049295499 Mastercode 6344737625 IMEI Spare 3A55690694924509 IMEI SV 3355690694924539F8000000 PPM V 08.65, 12-05-11, RM-614, (c) Nokia , MC1 CNT Content: mc1_059B4D4, V 08.65, 12-05-11, RM-614, (c) Nokia PSN 59A50C0AI Product Code 0594154 Module Code 0204418 Basic Product Code 0587486 PSD 0000000000000000 LPSN 0 WLAN MAC D82A7E3B5408 HW 2008 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by Mr.3.; 11-22-2011 at 06:52. Reason: Added Code tag |
![]() | #2257 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2004 Age: 44
Member: 93284 Status: Offline Thanks Meter: 202 | X2-00 log readed successfully Code: [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.17 MCU Date 09-03-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 354854045510791 Mastercode 6617554541 IMEI Spare 3A45580454157009 IMEI SV 3345580454157039F1000000 PPM V 08.17, 09-03-11, RM-618, (c) Nokia , B CNT Content: b_0595038, V 08.17, 09-03-11, RM-618, (c) Nokia PSN HTE346430 Product Code 059B8Q2 Module Code 0204491 Basic Product Code 0591973 PSD 0000000000000000 LPSN 0 HW 1000 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 2341000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Reading SL3 LOG File... [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.17 MCU Date 09-03-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 354854045510791 Mastercode 6617554541 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found WARNING: "0000000000EC96F0D7FDE2E36917896193019350.C0007F4C" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 0000000000EC96F0D7FDE2E36917896193019350 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.24.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! Loader: RAPxx CommonBoot v1.07 (C) 2011 KarwosLabs Custom loader running OK! Working... Cyclone Server (1.0.0.677), Cyclone Box Team 2008-2011 - Ready. If phone doesn't powering into Local Mode now for some reason do following: 1. Re-insert battery 2. Power it on, when asked use Ovi/Pc Suite Mode Readed OK, Saving to "0000000000EC96F0D7FDE2E36917896193019350.C0007F4C" Success! |
![]() | #2258 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: *** TUNISIA *** Age: 41
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | 5230 unlocked 5230 unlocked USB. -------------------------------------------------- Code: [Nokia 5230 USB Phonet]: Port opened OK! Product Code: 0599729 No Flash Datapackage installed for this Phone! BB5 Unlock Started... [Nokia 5230 USB Phonet]: Port opened OK! MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-588 (Nokia 5230) Manufacturer (c) Nokia IMEI 353424043316665 Mastercode 1733103144 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23594F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 23594F Connecting to Cyclone Server... Cyclone Server (1.0.0.677), Cyclone Box Team 2008-2011 - Ready. Checking job status... Code Ready, Code: #pw+859336278112090+7# Sending code via FBUS... [Nokia 5230 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED Code Accepted! Unlocking Finished! Last edited by ptt; 11-23-2011 at 21:54. Reason: CHANGE [QUOTE] =====> [CODE] |
![]() | #2259 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: TR-LAZ
Member: 178227 Status: Offline Sonork: 100.1597371 Thanks Meter: 175 ![]() | ![]() Code: Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: tr_gargi HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: TR_GARGİ Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,00v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,95v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 99 Avaiable Physical Memory: 1.900GB Avaiable Virtual Memory: 1.509GB Avaiable Pagefile: 2.959GB Initializing FBUS... All initialized - Ready to work Phone not detected at USB -> Timeout, no any compatible USB device detected. Failed to read info -> Phone not detected [Nokia C2-03 USB Phonet]: Port opened OK! MCU Version V 06.96 MCU Date 09-09-11 Product RM-702 (Nokia C2-03 / C2-06 / C2-08) Manufacturer (c) Nokia IMEI 35*****2****0 Mastercode 506*2556 IMEI Spare 3A95***524292502 IMEI SV 339**3052****2502***00000 PPM V 06.96, 09-09-11, RM-702, (c) Nokia , M_A CNT Content: m_a_059D432, V 06.96, 09-09-11, RM-702, (c) Nokia PSN D2EA36CAI Product Code 059D432 Module Code 0204579 Basic Product Code 059C0J7 PSD 0000000000000000 LPSN 0 HW 2000 RFIC Dummy RFIC version LCD TPO BT 19b5-22012 Asic 11 HW Signature 4B13A0**60B81723 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 00003593****29252200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... [Nokia C2-03 USB Phonet]: Port opened OK! Product Code: 059D432 Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 13 products, Filtering DCT4 Products - wait... 4 Products left after filtering. Ready. Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 13 products, Filtering BB5 Products - wait... 8 Products left after filtering. Ready. This is Valid BB5 Product Retrieving Variants for Product RM-702 - wait... 1 Variants Retrieved No variant found with given Product Code, selecting first one Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia C2-03 USB Phonet]: Port opened OK! Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical Failed to Create RPL from phone -> Failed to read Security Block RPL backup thread finished, continuing... Backing up simlock... [Nokia C2-03 USB Phonet]: Port opened OK! MCU Version V 06.96 MCU Date 09-09-11 Product RM-702 (Nokia C2-03 / C2-06 / C2-08) Manufacturer (c) Nokia IMEI 359******925220 Mastercode 5060****56 Simlock backup problem -> Failed to read PM 308, this is critical Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm702__06.96.mcusw (XGold2)... Checking rm702__06.96.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia C2-03 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.46_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00EC3012, Samsung, Size: 64MBytes Processing "rm702__06.96.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4015FFFF... Flashing at 0x40060000... Flashed 1048576 bytes OK Erasing 0x40280000-0x41DBFFFF... Flashing at 0x40280000... Flashed 28049408 bytes OK Erasing 0x43E20000-0x43E5FFFF... Processing rm702__06.96.ppm_tr (XGold2)... Checking rm702__06.96.ppm_tr... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_tr.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41DC0000-0x424BFFFF... Flashing at 0x41DC0000... Flashed 3949992 bytes OK Processing rm702__06.96.image_tr_059H279 (XGold2)... Checking rm702__06.96.image_tr_059H279... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_tr_059H279.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x424C0000-0x43E1FFFF... Flashing at 0x424C0000... Flashed 12058624 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C2-03 USB Phonet]: Port opened OK! [Nokia C2-03 USB Phonet]: Port opened OK! [Nokia C2-03 USB Phonet]: Port opened OK! [Nokia C2-03 USB Phonet]: Port opened OK! [Nokia C2-03 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C2-03 USB Phonet]: Port opened OK! MCU Version V 06.96 MCU Date 09-09-11 Product RM-702 (Nokia C2-03 / C2-06 / C2-08) Manufacturer (c) Nokia IMEI 359****042*****0 Mastercode 5060****556 IMEI Spare 3A9523****292502 IMEI SV 33952305*****2502F5000000 PPM V 06.96, 09-09-11, RM-702, (c) Nokia , TR CNT Content: tr_059H279, V 06.96, 09-09-11, RM-702, (c) Nokia PSN D2EA36CAI Product Code 059D432 Module Code 0204579 Basic Product Code 059C0J7 PSD 0000000000000000 LPSN 0 HW 2000 RFIC Dummy RFIC version LCD TPO BT 19b5-22012 Asic 11 HW Signature 4B13A03***B81723 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 000035*93****29252200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! CYCLONE TEAM_TNXXXXXXXXXXXXXX TR GARGİ Last edited by ptt; 11-23-2011 at 22:12. Reason: USE NORMAL SIZE FONTS - ADD [CODE] ____ [/CODE] - MOVE TO THE RIGTH THREAD |
![]() | #2260 (permalink) |
Member: 506993 Status: Offline Sonork: 100.1580692 Thanks Meter: 1,003 | 5230 flash usb done................ Code: [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C000216F89E0052FBA5D8533A0572535A995442 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM-356_51.0.006_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.24.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.24.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.733s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*ENO Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 95.878s Flashing Speed: 9631,33 kBit/S Processing RM-356_51.0.006_prd.core.C00 (APE)... Processing RM-356_51.0.006_prd.rofs2.V01 (CMT)... RM-356_51.0.006_prd.rofs2.V01, Type: Flash Image, Algo: XSR 1.5, BB5 PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Started group flash erase EraseArea[0,CMT]: 0x07180000-0x0915FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.141s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 21.840s Flashing Speed: 9401,99 kBit/S Processing RM-356_51.0.006_prd.rofs2.V01 (APE)... Processing RM-356_51.0.006_C04_prd.rofs3.fpsx (CMT)... RM-356_51.0.006_C04_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Started group flash erase EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.62s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.873s Flashing Speed: 8878,10 kBit/S Processing RM-356_51.0.006_C04_prd.rofs3.fpsx (APE)... Processing RM-356_51.0.006_026_000_U01.uda.fpsx (CMT)... RM-356_51.0.006_026_000_U01.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Started group flash erase EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.390s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 7.208s Flashing Speed: 8256,53 kBit/S Processing RM-356_51.0.006_026_000_U01.uda.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_10w21.3 MCU Date 23-06-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 353781049850355 Mastercode 4766362574 IMEI Spare 3A35870194583005 IMEI SV 3335870194583065F8000000 PSN MSD570452 Product Code 0578313 Module Code 0204481 Basic Product Code 0591283 PSD 0000000000000000 LPSN 0 WLAN MAC 303855E8C3D6 APE SW V 51.0.006 APE Variant V 51.0.006V 51.0.006 V 51.0.006 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 2003 RFIC 17141716 DSP tube_ICPR72_10w16_1 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 11-23-2011 at 21:55. Reason: CHANGE [QUOTE] =====> [CODE] |
![]() | #2261 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Nokia 2700 SL3 Unlock Done! Code: Initializing FBUS... All initialized - Ready to work [Nokia 2700 classic USB Phonet]: Port opened OK! MCU Version V 07.80 MCU Date 18-08-09 Product RM-561 (Nokia 2700 classic) Manufacturer (c) Nokia IMEI 355360047641278 Mastercode 552645356 IMEI Spare 3A55630074462107 IMEI SV 3355630074462147F4000000 PPM V 07.80, 18-08-09, RM-561, (c) Nokia , EB CNT Content: eb_black, TELENOR RS, 18-08-09, RM-561, (c) Nokia , , PSN DJX306881 Product Code 0590034 Module Code 0204245 Basic Product Code 0577212 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 1002 RFIC 06560601 DSP ICPR72_09w24 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 2200100032285695 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 22001F Auto Selecting Flash Files on User Request... [Nokia 2700 classic USB Phonet]: Port opened OK! Product Code: 0590034 No Flash Datapackage installed for this Phone! Sending BB5 NCK Code... [Nokia 2700 classic USB Phonet]: Port opened OK! NCK[7] - Unknown Error (0x02) Sending BB5 NCK Code... [Nokia 2700 classic USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 2700 classic USB Phonet]: Port opened OK! MCU Version V 07.80 MCU Date 18-08-09 Product RM-561 (Nokia 2700 classic) Manufacturer (c) Nokia IMEI 355360047641278 Mastercode 552645356 IMEI Spare 3A55630074462107 IMEI SV 3355630074462147F4000000 PPM V 07.80, 18-08-09, RM-561, (c) Nokia , EB CNT Content: eb_black, TELENOR RS, 18-08-09, RM-561, (c) Nokia , , PSN DJX306881 Product Code 0590034 Module Code 0204245 Basic Product Code 0577212 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 1002 RFIC 06560601 DSP ICPR72_09w24 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 2200100032285695 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 22001F Simlock NCK #pw+2r<;40178326736+7# Auto Selecting Flash Files on User Request... [Nokia 2700 classic USB Phonet]: Port opened OK! Product Code: 0590034 No Flash Datapackage installed for this Phone! Last edited by ptt; 11-24-2011 at 21:47. Reason: ADD [CODE] _________________ [/CODE] TAG |
![]() | #2262 (permalink) |
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Nokia 2730 Unlock SL3 Unlock Done! Code: [Nokia 2730 classic USB Phonet]: Port opened OK! MCU Version V 07.70 MCU Date 18-09-09 Product RM-579 (Nokia 2730 classic) Manufacturer (c) Nokia IMEI 356058030013518 Mastercode 7566511432 IMEI Spare 3A65500803105301 IMEI SV 3365500803105341F7000000 PPM V 07.70, 18-09-09, RM-578, (c) Nokia , UCC CNT Content: ucc_black_bell_ca_black, V 07.70, 18-09-09, RM-578, (c) Nokia , , PSN DNK261315 Product Code 0588611 Module Code 0204323 Basic Product Code 0580666 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2501 RFIC 17141715 DSP ICPR72_TOMMY_09w21 LCD SEIKO BT .31 Simlock Server SIMLOCK SERVER Simlock Key 3026100076705775 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 302610 Simlock [1,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20404F Simlock [2,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Auto Selecting Flash Files on User Request... [Nokia 2730 classic USB Phonet]: Port opened OK! Product Code: 0588611 No Flash Datapackage installed for this Phone! Sending BB5 NCK Code... [Nokia 2730 classic USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 2730 classic USB Phonet]: Port opened OK! MCU Version V 07.70 MCU Date 18-09-09 Product RM-579 (Nokia 2730 classic) Manufacturer (c) Nokia IMEI 356058030013518 Mastercode 7566511432 IMEI Spare 3A65500803105301 IMEI SV 3365500803105341F7000000 PPM V 07.70, 18-09-09, RM-578, (c) Nokia , UCC CNT Content: ucc_black_bell_ca_black, V 07.70, 18-09-09, RM-578, (c) Nokia , , PSN DNK261315 Product Code 0588611 Module Code 0204323 Basic Product Code 0580666 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2501 RFIC 17141715 DSP ICPR72_TOMMY_09w21 LCD SEIKO BT .31 Simlock Server SIMLOCK SERVER Simlock Key 3026100076705775 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 302610 Simlock [1,2] State: OPENED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock [2,1] State: OPENED Type: MCC-MNC Data: 20404F Simlock [2,2] State: OPENED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock NCK #pw+49ZM60827656718+7# Auto Selecting Flash Files on User Request... [Nokia 2730 classic USB Phonet]: Port opened OK! Product Code: 0588611 No Flash Datapackage installed for this Phone! Last edited by ptt; 11-24-2011 at 21:47. Reason: ADD [CODE] _________________ [/CODE] TAG |
![]() | #2263 (permalink) |
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Nokia 6230i Old Asic unlock done! Code: Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 1052 [HW_TIKUEDGE_v1_1] Flashbus Write baud set to 100Kbits te_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: TIKU BT2 PLL Factor: 1 FlashChip[0]: 0x00EC22F8 @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000011 FlashChip[1]: 0x00EC0035 @ 0x02000000, Samsung, SectorSize: 576kB, Ext: 00000000 Signature: 0000000018F09FE518F09FE518F09FE5 Flashbus Write baud set to 500Kbits Flashbus Read baud set to 4Kbits te_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC22F8 (128Mbits), Rev: 7.4.76.0, Algo: TIKU ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.07V Terminating flash session Boot operation took 6.484s Check Flashing Bus finished MCU Version V 03.30 MCU Date 21-04-05 Product RM-72 (Nokia 6230i CABLE 6230) Manufacturer GSM P1.1, (c) NMP. IMEI 355386008859641 Mastercode 65573035 IMEI Spare 3A55830680586904 IMEI SV 3355830680586904F4000000 PPM V 03.30, 21-04-05, RM72_73_-, GSM P1.1, C CNT V 03.30, 21-04-05, RM72_73_-, GSM P1.1, (c) NMP. PSN KHK076636 Product Code 0524422 Module Code 0202552 Basic Product Code 0519797 PSD 0000001700000000 HW 1000 UEM 400 UPP 1052 RFIC p10ff11ff0205 DSP pB0446T_05w14 LCD SHARP ADSP Sw pMATRIX2_05_w47_prod_w13 Asic 6 HW Signature 795A1914D57846D8 Simlock Server SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Simlock Key 2343000000000000 Simlock Profile 0000000000000006 Simlock Aux 00065555 Simlock IMEI 00553553860088596400 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23430F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23430F Auto Selecting Flash Files on User Request... Product Code: 0524422 No Flash Datapackage installed for this Phone! MCU Version V 03.30 MCU Date 21-04-05 Product RM-72 (Nokia 6230i CABLE 6230) Manufacturer GSM P1.1, (c) NMP. IMEI 355386008859641 Mastercode 65573035 Setting Local Mode... Local mode Set Asic 6 HW Signature D9976D93DEAC6B3C Simlock Server SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Simlock Key 2343000000000000 Simlock Profile 0000000000000006 Simlock Aux 00065555 Simlock IMEI 00553553860088596400 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23430F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23430F Autodetecting SP Type... Autodetection Finished Proceeding with Normal DCT4 Unlock... Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 03.30 MCU Date 21-04-05 Product RM-72 (Nokia 6230i CABLE 6230) Manufacturer GSM P1.1, (c) NMP. IMEI 355386008859641 Mastercode 65573035 IMEI Spare 3A55830680586904 IMEI SV 3355830680586904F4000000 PPM V 03.30, 21-04-05, RM72_73_-, GSM P1.1, C CNT V 03.30, 21-04-05, RM72_73_-, GSM P1.1, (c) NMP. PSN KHK076636 Product Code 0524422 Module Code 0202552 Basic Product Code 0519797 PSD 0000001700000000 HW 1000 UEM 400 UPP 1052 RFIC p10ff11ff0205 DSP pB0446T_05w14 LCD SHARP ADSP Sw pMATRIX2_05_w47_prod_w13 Asic 6 HW Signature A68A3502DE633D1D Simlock Server SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Simlock Key 0010100000000000 Simlock Profile 0000000000000006 Simlock Aux 00065555 Simlock IMEI 00553553860088596400 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... Product Code: 0524422 No Flash Datapackage installed for this Phone! Security Code 12345 Attempts 00 Attempts counter was resetted OK Security code was resetted to 12345 Last edited by ptt; 11-24-2011 at 21:48. Reason: ADD [CODE] _________________ [/CODE] TAG |
![]() | #2264 (permalink) |
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | Nokia 6350 SL3 Unlock Done! Code: [Nokia 6350 USB Phonet]: Port opened OK! MCU Version V 5.93 MCU Date 28-08-09 Product RM-455 (Nokia 6350) Manufacturer (c) Nokia IMEI 356917030051507 Mastercode 6166241274 IMEI Spare 3A65190703505100 IMEI SV 3365190703505120F5000000 PPM V 5.93, 28-08-09, RM-455, (c) Nokia , N CNT Content: n_bell_ca_red, V 5.93, 28-08-09, RM-455, (c) Nokia , , PSN RJN633426 Product Code 0590512 Module Code 0203790 Basic Product Code 0585070 PSD 0000000000000000 LPSN 0 RETU 34 TAHVO 00 AHNE 11 HW 1000 RFIC |Vapaus_4.0 | ??? DSP ICPR81_09w21 LCD TPO BT 410B-v170 Simlock Server SIMLOCK SERVER Simlock Key 3026100076705775 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 302610 Simlock [1,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20404F Simlock [2,2] State: CLOSED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Auto Selecting Flash Files on User Request... [Nokia 6350 USB Phonet]: Port opened OK! Product Code: 0590512 No Flash Datapackage installed for this Phone! Sending BB5 NCK Code... [Nokia 6350 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 6350 USB Phonet]: Port opened OK! MCU Version V 5.93 MCU Date 28-08-09 Product RM-455 (Nokia 6350) Manufacturer (c) Nokia IMEI 356917030051507 Mastercode 6166241274 IMEI Spare 3A65190703505100 IMEI SV 3365190703505120F5000000 PPM V 5.93, 28-08-09, RM-455, (c) Nokia , N CNT Content: n_bell_ca_red, V 5.93, 28-08-09, RM-455, (c) Nokia , , PSN RJN633426 Product Code 0590512 Module Code 0203790 Basic Product Code 0585070 PSD 0000000000000000 LPSN 0 RETU 34 TAHVO 00 AHNE 11 HW 1000 RFIC |Vapaus_4.0 | ??? DSP ICPR81_09w21 LCD TPO BT 410B-v170 Simlock Server SIMLOCK SERVER Simlock Key 3026100076705775 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 302610 Simlock [1,2] State: OPENED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock [2,1] State: OPENED Type: MCC-MNC Data: 20404F Simlock [2,2] State: OPENED Type: 7FFF6F3EFFFFFFFF @ 8000 Data: 3D Simlock NCK #pw+5W“O51515203650+7# Auto Selecting Flash Files on User Request... Last edited by ptt; 11-24-2011 at 21:48. Reason: ADD [CODE] _________________ [/CODE] TAG |
![]() | #2265 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: Paraguay
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock 5230 RM-594 Done! Code: MCU Version V ICPR72_10w21.3.1 MCU Date 08-09-10 Product RM-594 (Nokia 5230) Manufacturer (c) Nokia IMEI 35482704 Mastercode 245211315 IMEI Spare 3A45280704732406 IMEI SV 3345280704732416F6000000 CNT 21.2.103_001_U295 PSN 0866584AA Product Code 0596628 Module Code 0204358 Basic Product Code 0584531 PSD 0000000000000000 LPSN 0 APE SW V 21.2.103 APE Variant V 21.2.103V 21.2.103 21.2.103.295.01 APE Test 09wk43v0.060_4GBit APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0522 RFIC 17141716 DSP ICPR72_10w16p1 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 74402F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74402F Simlock [3,1] State: CLOSED Type: 3F007F206F07FFFF @ FC00 Data: 722310 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 74810F MCU Version V ICPR72_10w21.3.1 MCU Date 08-09-10 Product RM-594 (Nokia 5230) Manufacturer (c) Nokia IMEI 35482704 Mastercode 245211315 IMEI Spare 3A45280704732406 IMEI SV 3345280704732416F6000000 CNT 21.2.103_001_U295 PSN 0866584AA Product Code 0596628 Module Code 0204358 Basic Product Code 0584531 PSD 0000000000000000 LPSN 0 APE SW V 21.2.103 APE Variant V 21.2.103V 21.2.103 21.2.103.295.01 APE Test 09wk43v0.060_4GBit APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0522 RFIC 17141716 DSP ICPR72_10w16p1 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock [3,1] State: OPENED Type: 3F007F206F07FFFF @ FC00 Data: 722310 Simlock [4,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [5,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [6,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock NCK #pw+52Q‘92186273363+7# ![]() ![]() |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
