Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-21-2012, 05:19   #2536 (permalink)
Azhar Nazeer's Avatar
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
MCU Version V 07.01
MCU Date 23-05-08
Product  RM-303
Manufacturer (c) Nokia
IMEI  35204********
Mastercode 41306601
IMEI Spare 3A25400452286605
IMEI SV  3325400452286645F6000000
PPM  V 07.01, 23-05-08, RM-303, (c) Nokia            , C
CNT  Content: c_blue, V 07.01, 23-05-08, RM-303, (c) Nokia            ,
PSN  KJP377967
Product Code 0547371
Module Code 0203414
Basic Product Code 0544850
PSD  0000000000000000
LPSN  0
RETU  15
TAHVO  22
AHNE  30
HW  2002
RFIC  064c0609
DSP  ICPR71_08w10
LCD  SEIKO
BT  2222-143
BB5 Unlock Started...
MCU Version V 07.01
MCU Date 23-05-08
Product  RM-303
IMEI  35204********
Mastercode 41306601
Warning: Failed to read SP Info, Assuming defaults
Simlock Server SIMLOCK SERVER
Simlock Key 0000000000000000
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
CMT_SYSTEM_ASIC_ID:  000000010000022600010006010C192101013000
CMT_EM_ASIC_ID:   00000295
CMT_EM_ASIC_ID:   00000B22
CMT_PUBLIC_ID:   2B600106E36D0254D5E64CF406655D1CFD202EE3
CMT_ASIC_MODE_ID:  00
CMT_ROOT_KEY_HASH:  BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID:   273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Restarting MCU...
Booting RAP...
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Bypassing SX4...
Booting RAP...
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Writing Security Block...
Writing Simlock Key...
SP Accepted, doing reset to update block...
Booting RAP...
Box VPP disabled
Restoring NPC...
Restarting MCU...
SX4 Bypass Finished
MCU Version V 07.01
MCU Date 23-05-08
Product  RM-303
IMEI  35204*********
Mastercode 41306601
Simlock Key 0010100000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock[1,1] State: OPENED Type: MCC-MNC Data: 00101F
Unlock finished!
Old 04-21-2012, 09:50   #2537 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
X1-01 Flashed Done
X1-01 Flashed Done
Processing pre-flash tasks...
Pre-flash tasks finished
Checking rm713_005.370...
Flash file sorted Okay.
1 file(s) embedded into image.
Booting X-Gold via ASC (press power-on if used non-battery cable)...
X-Gold: Ready, MCU ID: 0x3400
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Default_RAM_Bootloader
[EBL] : Ready
Setting Baudrate to 921600bps...
Baudrate Accepted (921600bps)
Flash Chip 0x00EC2404, Samsung, Size: 16MBytes
Processing "hw_b1_rm713_r05.370.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x00000000-0x0001FFFF...
Flashing at 0x00000000...
Flashed 24576 bytes OK
Erasing 0x00800000-0x00BFFFFF...
Flashing at 0x00800000...
Flashed 4128768 bytes OK
Erasing 0x00C5D000-0x00E5FFFF...
Flashing at 0x00C5D000...
Flashed 1697536 bytes OK
Box VPP disabled
Checking rm7130_nai05.37ia...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_b1_rm7130_nai05.37ia.fls"...
Erasing 0x00E60000-0x00F5FFFF...
Flashing at 0x00E60000...
Flashed 722304 bytes OK
Box VPP disabled
Checking rm713_005.37ia...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_b1_rm713_005.37ia.fls"...
Erasing 0x00100000-0x007FFFFF...
Flashing at 0x00100000...
Flashed 5164544 bytes OK
Box VPP disabled
Processing post-flash tasks...
Setting Factory Defaults...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
B.R
oMeR
Last edited by Mr.3.; 04-21-2012 at 10:27. Reason: Moved to correct place and added coda tag
Old 04-21-2012, 16:41   #2538 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Unlock 5130 RM-495 Done
MCU Version	V 07.95
MCU Date	03-02-10
Product		RM-495 (Nokia 5130 XpressMusic)
IMEI		354873041
Mastercode	702721526
IMEI Spare	3A45780314334409
IMEI SV		3345780314334449F8000000
PPM		V 07.95, 03-02-10, RM-495, (c) Nokia            , UA
CNT		Content: movistar AR, V 07.95, 03-02-10, RM-495, (c) Nokia            , ,
PSN		HMN069677
Product Code	059B2B0
Module Code	0204024
Basic Product Code	0567773
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		1004
RFIC		06560601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key	7220700000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
Sending BB5 NCK Code...
NCK[7] - Unlocked Already
MCU Version	V 07.95
MCU Date	03-02-10
IMEI		354873041
PSN		HMN069677
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		1004
RFIC		06560601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock NCK	#pw+0X97088067283+7#
Old 04-22-2012, 12:02   #2539 (permalink)
andy-r's Avatar
Member: 568295
Thanks Meter: 162
Blackberry 8310 Successfully Unlock by Cyclone
Tools;
Cyclone Box
V3 USB Cable
MEP reader
Procedure;
1. Open MEP reader software
2. Click Read Phone
3. Open Cyclone software
4. Select Blackberry Tool tab
5. Input IMEI from readed phone
6. Select MEP code
7. Click Calculate Codes
6. Done...
Instruction on how to enter code
1. Go to settings menu => and then Options
2. Select Advanced options => and then Sim card
3. Hold the ALT Key while typing in MEPE on your Blackberry keyboard
(NOTE: You will not see any text appear on the screen while typing MEPD)
4. You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received and press in
the track wheel / jog dial to confirm
5. Your phone is now unlocked
Thanks...
Old 04-23-2012, 16:12   #2540 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Unlock E5-00 RM-634!
[Nokia E5-00 USB Phonet]: Port opened OK!
MCU Version	V ICPR82_11w16.3
MCU Date	19-05-11
Product		RM-634 (NOkia E5-00)
IMEI		357920046
Mastercode	607423147
IMEI Spare	3A75290064805706
IMEI SV		3375290064805726F3000000
PSN		2F56E84AA
Product Code	059K4P6
Module Code	0204474
Basic Product Code	059H390
LPSN		0
WLAN MAC	28D1AF5D7124
APE SW		071.003
APE Variant	071.003071.003.57.01071.003.387.01
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
RFIC		|Vapaus_5.1 | Mikki_1.1
DSP		ICPR82_11w16
Simlock Key	7223100000000000
Simlock Profile	0000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
Simlock [3,1]	State: CLOSED	Type: 3F007F206F07FFFF @ FC00	Data: 722310
Simlock [4,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [5,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
Simlock [6,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
MCU Date	19-05-11
IMEI		357920046
PSN		2F56E84AA
Module Code	0204474
LPSN		0
APE SW		071.003
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
DSP		ICPR82_11w16
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [3,1]	State: OPENED	Type: 3F007F206F07FFFF @ FC00	Data: 722310
Simlock [4,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock NCK	#pw+9nh}91788014388+7#
Old 04-24-2012, 07:34   #2541 (permalink)
dampealdany's Avatar
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
nokia 2220s-b RM-591 successfully direct unlocked
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr  6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C000785D
HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19
Initializing security card...
Card Serial Number: D00B025E
Card Firmware Revision: 010A
Card is activated
Box is activated
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Credits Left: 98
Avaiable Physical Memory: 3.1023GB
Avaiable Virtual Memory: 1.359GB
Avaiable Pagefile: 3.1023GB
MCU Version	V 09.55
MCU Date	12-11-09
Product		RM-591 (Nokia RM-591)
IMEI		012822006636032
Mastercode	2754262166
Setting Local Mode...
Local mode Set
Asic		11
HW Signature	014AE41D93D2D41C
Simlock Key	7321010000000000
Simlock Profile	800000000003000B
Simlock Aux	000B5555
Simlock IMEI	00550128220066360300
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 732101
Autodetecting SP Type...
Autodetection Finished
Proceeding with RSA Unlock...
Asking card to sign HW Signature...
Signed OK (A84912EF8103736A0F3044569DE3A2A92E1E491A)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 04-27-2012 at 01:02. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 04-24-2012, 10:40   #2542 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
rh99 FLASH OK
Initializing box...
Box Serial Number: C0001215
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14
Card Serial Number: D30004AC
Card Firmware Revision: 0109
Card is activated
Box is activated
XGold/Blackberry Service Running, Credits Left: 99
Avaiable Physical Memory: 1.6GB
Avaiable Virtual Memory: 1.491GB
Avaiable Pagefile: 2.28GB
Booting UPP...
UPP ID: 2292 [HW_UNKNOWN]
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
PLL Factor: 3
FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
Flashbus Write baud set to 500Kbits
Flashbus Read baud set to 4Kbits
u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,04V
Terminating flash session
Boot operation took 7.0s
Check Flashing Bus finished
Booting UPP...
rh99_06.000, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
Flashbus Read baud set to 51Kbits
Nominal VPP Voltage: 9V, Detected: 0,02V
MSID-Crypted: 84BF184AB857DBF7FC0463AF6E
MSID-Plain: 3E4EBAE90055E144AA000000
FAID-Crypted: E8C831392B83563311A8B3E0
Flashbus Write baud set to 6.50Mbits
5 Region(s) to erase
Erasing NOR Region [0x01000000-0x0100FFFF]
Erasing NOR Region [0x01010000-0x013AFFFF]
Erasing NOR Region [0x013B0000-0x013EFFFF]
Erasing NOR Region [0x017C0000-0x017EFFFF]
Erasing NOR Region [0x01FC0000-0x01FEFFFF]
Erase taken 64.281s
Writing 146 blocks...
All blocks written OK! Time taken 11.906s
Box VPP disabled
Booting UPP...
rh990_nai6.00ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Using MSID-FAID Cache, Not wasting card
1 Region(s) to erase
Erasing NOR Region [0x01380000-0x013AFFFF]
Erase taken 3.110s
Writing 7 blocks...
All blocks written OK! Time taken 0.563s
Extracting Content Package...
CP Server: File Server fake reply for CUI phone.
CP Extract Failed -> CP Not Extracted, Code: 1
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rh99_06.00ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8428946F1756F9D6C1A3BBD1C4
MSID-Plain: 3E4EBAE90055E144A9000000
FAID-Crypted: 0D7E7066B62139E37194D29D
2 Region(s) to erase
Erasing NOR Region [0x01240000-0x0124FFFF]
Erasing NOR Region [0x01250000-0x0137FFFF]
Erase taken 20.390s
Writing 75 blocks...
All blocks written OK! Time taken 6.141s
Box VPP disabled
Factory defaults OK
Old 04-24-2012, 15:45   #2543 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Full Flash 6500s Rm-240
MCU Version	V 08.30
MCU Date	03-07-08
Product		RM-240 (Nokia 6500 slide)
IMEI		356400022601225
Mastercode	355324715
IMEI Spare	3A65040022062102
IMEI SV		3365040022062152F1000000
PPM		V 08.30, 03-07-08, RM-240, (c) Nokia            , W
CNT		          0>>..         0>
PSN		CWB741366
Product Code	0565059
Module Code	0203327
Basic Product Code	0550669
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1003
RFIC		17141715
DSP		ICPR71_08w22
LCD		SHARP
BT		2222-143
Simlock Key	2440700000000000
Simlock Profile	8000000000000002
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [1,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [1,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [1,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [2,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [2,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [2,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [3,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [3,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [3,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [4,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [4,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [4,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [5,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [5,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [5,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [6,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [6,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [6,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,1]	State: OPENED	Type: MCC-MNC	Data: FFFFFF
Simlock [7,2]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,3]	State: OPENED	Type: GID	Data: FFFF
Simlock [7,4]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Simlock [7,5]	State: OPENED	Type: IMSI	Data: FFFFFFFFFFFFFFFF
Auto Selecting Flash Files on User Request...
Product Code: 0565059
Scanning avaiable products...
Processing C:\Archivos de programa\Nokia\Phoenix\Products\...
Found 46 products, Filtering DCT4 Products - wait...
10 Products left after filtering. Ready.
Found 46 products, Filtering BB5 Products - wait...
36 Products left after filtering. Ready.
This is Valid BB5 Product
Retrieving Variants for Product RM-240 - wait...
5 Variants Retrieved
No variant found with given Product Code, selecting first one
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
"RM-240_356400022601225_21042012_125654.SecurityBlock.PM"
Will read it...
Reading CYC file from phone...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101003000
CMT_PUBLIC_ID:		08D00016DC4D5450CE4D119AE3D868A943A8B4E5
CMT_SECURE_ROM_CRC:	DFAAF68F
CMT Ready!
Using OLD BB5 FLASHING PROTOCOL
Old Loader Detected
Readed OK, Saving to "08D00016DC4D5450CE4D119AE3D868A943A8B4E5.C0001FF6"
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
If software STUCK HERE with box TX LED lit, that means:
USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR
FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Box VPP disabled
PAPUBKEYS Hash for CMT: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
MCU Version	V 08.30
MCU Date	03-07-08
Simlock backup OK, saved to RM-240_356400022601225_21042012_125755.SLBackup.PM
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm240__10.30.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x01480000-0x015FFFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0147FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 108.625s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 227.953s
Flashing Speed: 750,48 kBit/S
Restarting MCU...
Processing rm240__10.30.mcusw (APE)...
Processing rm240__10.30.ppm_c (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01600000-0x01CBFFFF, NOR
Erase taken 34.47s
TurboCache Loaded!
All blocks written OK! Time taken 73.265s
Flashing Speed: 734,98 kBit/S
Restarting MCU...
Processing rm240__10.30.ppm_c (APE)...
Processing rm240__10.30_ism_023.image_c_tr (CMT)...
Booting CMT...
CMT Ready!
rm240__10.30_ism_023.image_c_tr, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR
EraseArea[0,CMT]: 0x01CC0000-0x01FBFFFF, NOR
Erase taken 211.313s
TurboCache Loaded!
All blocks written OK! Time taken 98.15s
Flashing Speed: 985,38 kBit/S
Restarting MCU...
Processing rm240__10.30_ism_023.image_c_tr (APE)...
All images processed OK! Processing post flash tasks...
Reading info...
MCU Version	V 10.30
MCU Date	23-04-09
IMEI SV		3365040022062172F8000000
PPM		V 10.30, 23-04-09, RM-240, (c) Nokia            , C
CNT		Content: c_tr, V 10.30, 23-04-09, RM-240, (c) Nokia            ,
PSN		CWB741366
Module Code	0203327
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1003
RFIC		17141715
DSP		ICPR71_09w03
LCD		SHARP
BT		2222-143
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfu
User Code C3 RM-614 Done
[Nokia C3-00 USB Phonet]: Port opened OK!
MCU Version	V 07.20
MCU Date	29-10-10
Product		RM-614 (Nokia C3-00)
IMEI		355384041515486
Mastercode	650744433
IMEI Spare	3A55830414154508
IMEI SV		3355830414154528F3000000
PPM		V 07.20, 29-10-10, RM-614, (c) Nokia            , SP
CNT		Content: sp_0597580, V 07.20, 29-10-10, RM-614, (c) Nokia
PSN		8CA457FAI
Product Code	059D7L4
Module Code	0204418
Basic Product Code	059D7N6
LPSN		0
WLAN MAC	942053810800
HW		2009
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security Code	4710271
Attempts		00
User Code 2330 RM-513 Done
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
Signature: AD7EB61B23100340C605E40120A20000
DCT4 ALGORITHM
Boot operation took 6.781s
MCU Version	V 08.20
MCU Date	30-06-09
Product		RM-513 (Nokia 2330 Classic)
IMEI		011869005215962
Mastercode	3652204066
IMEI Spare	0A11680950129506
IMEI SV		0311680950129536F9000000
PPM		V 08.20, 30-06-09, RM-512, (c) Nokia            , UB
PSN		GDK652384
Product Code	0575309
Module Code	0204045
Basic Product Code	0571674
PSD		0000001800000000
LPSN		0
HW		4100
UEM		4386
UPP		3168
RFIC		0500
DSP		ICPR72_09w24_U
LCD		SUEZ
BT		2222-143C
Asic		11
HW Signature	D3CF8B1E10C61E72
Simlock IMEI	00550118690052159600
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security Code	84372622
Attempts		03
Setting factory defaults of: Factory set full
Factory defaults set OK
Full Flash 3120 RM-364 Done
Booting CMT...
CMT_PUBLIC_ID:		2610020889964F509D95B82A7177D19D0B671AE1
CMT Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79
Restarting MCU...
MCU Version	V 06.20
MCU Date	29-02-08
Product		RM-364 (Nokia 3120 classic)
IMEI		353101021153365
Mastercode	2741564420
IMEI Spare	3A35010112513306
IMEI SV		3335010112513336F2000000
PPM		V 06.20, 29-02-08, RM-364, (c) Nokia            , C
PSN		DEJ097848
Product Code	0559101
Module Code	0203643
Basic Product Code	0553930
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1000
RFIC		17141715
DSP		ICPR71_08w03_3_1
LCD		SEIKO
BT		06cc-P9.2
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Product Code: 0559101
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
"RM-364_353101021153365_23042012_133034.SecurityBlock.PM"
read it...
Booting CMT...
CMT Ready!
Old Loader Detected
Readed OK, Saving to "2610020889964F509D95B82A7177D19D0B671AE1.C0001FF6"
Storing CMLA Key...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Version	V 06.20
MCU Date	29-02-08
Simlock backup OK, saved to RM-364_353101021153365_23042012_133145.SLBackup.PM
Processing rm364__09.41.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm364__09.41.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 105.890s
TurboCache Loaded!
All blocks written OK! Time taken 117.218s
Flashing Speed: 1474,61 kBit/S
Restarting MCU...
Processing rm364__09.41.mcusw (APE)...
Processing rm364__09.41.ppm_l (CMT)...
Booting CMT...
CMT Ready!
rm364__09.41.ppm_l, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 31.844s
TurboCache Loaded!
All blocks written OK! Time taken 28.969s
Flashing Speed: 1460,00 kBit/S
Restarting MCU...
Processing rm364__09.41.ppm_l (APE)...
Processing rm364__09.41_ISM_002.image_vivo_br_graphite (CMT)...
Booting CMT...
CMT Ready!
ALGORITHM
Box VPP disabled
Erase taken 191.578s
TurboCache Loaded!
All blocks written OK! Time taken 59.953s
Flashing Speed: 1381,83 kBit/S
Restarting MCU...
Processing rm364__09.41_ISM_002.image_vivo_br_graphite (APE)...
Reading info...
MCU Version	V 09.41
MCU Date	06-11-08
IMEI SV		3335010112513356F9000000
PPM		V 09.41, 06-11-08, RM-364, (c) Nokia            , L
CNT		Content: vivo_br_graphite, V 09.41, 06-11-08, RM-364, (c) Nokia            , ,
PSN		DEJ097848
Module Code	0203643
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1000
RFIC		17141715
DSP		ICPR71_08w30
LCD		SEIKO
BT		06cc-P9.2
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Flashing successfully finished!
Security Code	5260147
Attempts		00
Full Flash Death X3 RM-540 Done
[Nokia USB Flashing Generic]: Port opened OK!
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Sending User Abort Signal...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Failed to Check BB5 Flashing Bus  -> Failed to Boot / Prepare Phone
Processing rm540__11.00.mcusw (CMT)...
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000010000022600000001020C192102054100
CMT_EM_ASIC_ID:		00001040
CMT_EM_ASIC_ID:		00001030
CMT_PUBLIC_ID:		0FE00012BF36004945EAAA71020D3BC67EC9C5FB
CMT_ROOT_KEY_HASH:	7B045400E1752022F9EB80B0DEA9C65D
CMT_SECURE_ROM_CRC:	F29CEA60
CMT Ready!
rm540__11.00.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.40.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0x0005317F
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC003000000321, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported
RAP3Gv40_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.40.0, Algo: XSR 1.6
TurboCache Loaded!
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
PAPUBKEYS Hash for CMT: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x0009FFFF, ONENAND
EraseArea[0,CMT]: 0x000A0000-0x0025FFFF, ONENAND
EraseArea[0,CMT]: 0x003E0000-0x005DFFFF, ONENAND
EraseArea[0,CMT]: 0x005E0000-0x010DFFFF, ONENAND
EraseArea[0,CMT]: 0x01EC0000-0x01EDFFFF, ONENAND
EraseArea[0,CMT]: 0x027C0000-0x02CBFFFF, ONENAND
EraseArea[0,CMT]: 0x077C0000-0x07B3FFFF, ONENAND
EraseArea[0,CMT]: 0x010E0000-0x01EBFFFF, ONENAND
Erase Partition (CMT)
Erase taken 0.563s
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT MCUSW1 Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT ISA+DYNSW Certificate...
All blocks written OK! Time taken 49.63s
Flashing Speed: 4467,57 kBit/S
Processing rm540__11.00.mcusw (APE)...
Processing rm540__11.00.ppm_l (CMT)...
rm540__11.00.ppm_l, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x01EE0000-0x027BFFFF, ONENAND
Erase taken 0.234s
TurboCache Loaded!
All blocks written OK! Time taken 9.687s
Flashing Speed: 4695,74 kBit/S
Processing rm540__11.00.ppm_l (APE)...
Processing rm540__11.00.image_l_0587195_008 (CMT)...
rm540__11.00.image_l_0587195_008, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x02CC0000-0x077BFFFF, ONENAND
Erase taken 1.187s
TurboCache Loaded!
All blocks written OK! Time taken 29.187s
Flashing Speed: 4957,41 kBit/S
Processing rm540__11.00.image_l_0587195_008 (APE)...
Restarting MCU...
Reading info...
[Nokia X3 USB Phonet]: Port opened OK!
MCU Version	V 11.00
MCU Date	17-03-11
Product		RM-540 (Nokia X3)
IMEI		354865047390156
Mastercode	30116577
IMEI Spare	3A45680574931005
IMEI SV		3345680574931065F9000000
PPM		V 11.00, 17-03-11, RM-540, (c) Nokia            , L
CNT		Content: l_0587195, V 11.00, 17-03-11, RM-540, (c) Nokia
PSN		CCL472479
Product Code	0591773
Module Code	0204201
Basic Product Code	0575592
LPSN		0
RETU		40
TAHVO		00
AHNE		41
HW		5001
RFIC		0831
DSP		SPR91_09w09_11w10
LCD		SEIKO
BT		1673-46038
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security Code	12345
Attempts		00
User Code X2-01 RM-709 Done
Booting CMT...
New ROM Detected
CMT_SYSTEM_ASIC_ID:	000000000000000022000509200C0000
CMT_EM_ASIC_ID:		00005361
CMT_PUBLIC_ID:		0000000000D663BD09717D4D90B31B250DC87604
CMT_ROOT_KEY_HASH:	1B0D74C532CA1C6133940C740E8C786E
CMT_SECURE_ROM_CRC:	BDDE7A3A
CMT Ready!
BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.40.0, Algo: BB5
FlashChip[0,CMT]: 0x0020003000000131, ST, NOR
FlashChip[1,CMT]: 0x0010001100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND
FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported
BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.40.0, Algo: XSR 1.6
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 37955B6FC432998EF0DB240E332228384D19ED09
Restarting MCU...
[Nokia X2-01 USB Phonet]: Port opened OK!
MCU Version	V 08.63
MCU Date	25-03-11
Product		RM-709 (Nokia X2-01)
IMEI		357410044859122
Mastercode	46665721
IMEI Spare	3A75140044581902
IMEI SV		3375140044581932F2000000
PPM		V 08.63, 25-03-11, RM-709, (c) Nokia            , L
CNT		Content: ctv HN, V 08.63, 25-03-11, RM-709, (c) Nokia
PSN		1A80499AH
Product Code	059D586
Module Code	0204674
Basic Product Code	059B859
LPSN		0
HW		1001
RFIC		9
LCD		SEIKO
BT		2.31-SP2.31
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security Code	96543
Attempts		05
Unlock 1680 RM-395
MCU Version	V 06.82
MCU Date	26-09-08
Product		RM-395 (Nokia 1680C-2B CLASSIC)
IMEI		011672006823663
Mastercode	1270702240
IMEI Spare	0A11760260286306
IMEI SV		0311760260286346F5000000
PPM		V 06.82, 26-09-08, RM-394, (c) Nokia, UB
CNT		Content: ub_grey_claro_argentina, V 06.82, 26-09-08, RM-394, (c) Nokia, ,
PSN		GDJ458819
Product Code	0569014
Module Code	0203778
Basic Product Code	0556747
LPSN		0
HW		4501
UEM		1328
UPP		3162
RFIC		0500
DSP		ICPR62_08w27_U
LCD		SUEZ
Asic		11
HW Signature	3B387EC8B8C95F53
Simlock Profile	800000000001000B
Simlock IMEI	00550116720068236600
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 74810F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 74402F
MCU Version	V 06.82
MCU Date	26-09-08
Local mode Set
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Signed OK (18AF336419711C89A3D0AD1D8F52C0D3566170D2)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
MCU Version	V 06.82
MCU Date	26-09-08
PSN		GDJ458819
Module Code	0203778
LPSN		0
HW		4501
UEM		1328
UPP		3162
RFIC		0500
DSP		ICPR62_08w27_U
LCD		SUEZ
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 04-24-2012, 16:09   #2544 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Unlock BB8520 Done!
Waiting for new Blackberry USB Device (timeout 30 seconds)...
New device attached, checking if it's Blackberry...
Blackberry Found!
PIN: 28519CBE
"RIM CalTask" Channel open failed, Retrying...
PIN: 28519CBE
"RIM CalTask" Channel open failed, Trying "Caltask Config" ...
PIN: 28519CBE
Opened Channel "Caltask Config", Proceeding...
IMEI: 359199041848232
HWV-21408-004-5
SVP-23743-002_1
SVP-23744-008_1
SVP-26603-004_1A
ASY-22465-004
MEP-11534-008
VSM-28211-001
CFG-10993-052
SFI-24398-050
APP-32381-006
Calculating Codes using Fetched Data...
Service Tag: F2BE945C6FEB33717544B3AAE70B81F1
MEP-2: 0140731601760028
Calculations Left: 98
All Done!
Read Log 2690 RM-635
MCU Version	V 10.10
MCU Date	22-04-10
Product		RM-635 (Nokia 2690)
IMEI		354869040243727
Mastercode	6744377614
IMEI Spare	3A45680904427302
IMEI SV		3345680904427352F8000000
PPM		V 10.10, 22-04-10, RM-635, (c) Nokia            , AG
CNT		Content: movistar ES, V 10.10, 22-04-10, RM-635, (c) Nokia            ,
PSN		5476AF8AI
Product Code	059C821
Module Code	0204767
Basic Product Code	059C5Z2
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		3004
RFIC		06560601
DSP		ICPR72_10w06
LCD		SUEZ
BT		2.31-SP2.26
Simlock Key	2140700000000000
Simlock Key Cnt	3
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
Reading SL3 LOG File...
MCU Version	V 10.10
MCU Date	22-04-10
Analyzing Profile Bits...
Phone can be NCK unlocked using KEYPAD
Phone can be NCK unlocked using FBUS
15 Digits NCK Found
WARNING: "08400108F9175650F026FA88A4078890B975FCA8.C0001FF6" Not Exists, Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006030C192101033000
CMT_EM_ASIC_ID:		00000296
CMT_PUBLIC_ID:		08400108F9175650F026FA88A4078890B975FCA8
CMT_ROOT_KEY_HASH:	9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC:	273F6D55
CMT Ready!
Old Loader Detected
Readed OK, Saving to "08400108F9175650F026FA88A4078890B975FCA8.C0001FF6"
Success!
Read Log 5130 RM-495
MCU Version	V 05.80
MCU Date	18-12-08
IMEI		358318035239650
Mastercode	422353364
IMEI Spare	3A85130853326905
IMEI SV		3385130853326925F6000000
PPM		V 05.80, 18-12-08, RM-495, (c) Nokia            , UA
CNT		Content: ua_red_claro_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia            , ,
PSN		GEM637809
Product Code	0580923
Module Code	0204024
Basic Product Code	0567772
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		4000
RFIC		06540601
DSP		ICPR72_08w50
LCD		SEIKO
BT		2222-143C
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 05.80
MCU Date	18-12-08
15 Digits NCK Found
WARNING: "2600020C54DE8C56A1570F3BBE15BF0975135207.C0001FF6" Not Exists, Will read it...
Booting CMT...
CMT_PUBLIC_ID:		2600020C54DE8C56A1570F3BBE15BF0975135207
CMT Ready!
Old Loader Detected
Readed OK, Saving to "2600020C54DE8C56A1570F3BBE15BF0975135207.C0001FF6"
Success!
MCU Version	V 07.95
MCU Date	03-02-10
IMEI		353223039775235
Mastercode	227476520
IMEI Spare	3A35220393772503
IMEI SV		3335220393772543F8000000
PPM		V 07.95, 03-02-10, RM-495, (c) Nokia            , AG
PSN		HGA339887
Product Code	0580572
Module Code	0204024
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		1000
RFIC		06540601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 07.95
MCU Date	03-02-10
15 Digits NCK Found
WARNING: "2190000C62877D564EF0160C194CCEBB18E34DF2.C0001FF6" Not Exists, Will read it...
Booting CMT...
CMT_PUBLIC_ID:		2190000C62877D564EF0160C194CCEBB18E34DF2
CMT Ready!
Old Loader Detected
Readed OK, Saving to "2190000C62877D564EF0160C194CCEBB18E34DF2.C0001FF6"
Success!
Old 04-24-2012, 16:54   #2545 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Full Flash 2320 RM-515
PLL Factor: 3
FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM
Boot operation took 6.31s
MCU Version	V 11.10
MCU Date	19-05-10
Product		RM-515 (Nokia 2320 Classic)
IMEI		012185001798565
Mastercode	607121656
IMEI Spare	0A21810510975806
IMEI SV		0321810510975856F8000000
PPM		V 11.10, 19-05-10, RM-515, (c) Nokia            , NCR
CNT		Content: ncr_attus_19May10, V 11.10, 19-05-10, RM-515, (c) Nokia            ,
PSN		HGD656885
Product Code	059D431
Module Code	0204047
Basic Product Code	0571673
LPSN		0
HW		1501
UEM		4386
UPP		3168
RFIC		0500
DSP		unnithan23061610
LCD		SUEZ
Asic		11
HW Signature	4A8F8B7896458823
Simlock Profile	000000000003000B
Simlock IMEI	00550121850017985600
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Product Code: 059D431
This is Valid DCT4 Product
Retrieving Variants for Product RM-515 - wait...
3 Variants Retrieved
Booting UPP...
rm515__06.88.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221
MSID-Crypted: 8482167A6648ED6BE4E707260F
MSID-Plain: 2C40BAE900D1F217AA000000
FAID-Crypted: FA350FF7C8612F7BF90FBB00
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01CFFFFF]
Erase taken 65.359s
Writing 174 blocks...
All blocks written OK! Time taken 785.625s
Box VPP disabled
Booting UPP...
rm515__06.88_ISM_002.image_ncr_attus, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 84BA303E0D13965A686568588E
MSID-Plain: D26EBAF100D1F217AA000610
FAID-Crypted: C9AEC37446FAD06B3D97EB96
Erasing NOR Region [0x02180000-0x02E7FFFF]
Erasing NOR Region [0x02E80000-0x02FBFFFF]
Erase taken 116.437s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 304 blocks...
All blocks written OK! Time taken 320.578s
CP Extract Failed -> CP Server not exists
Box VPP disabled
Booting UPP...
rm515__06.88.ppm_ncr, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8493501D10077B83EDC90A0205
MSID-Plain: 3E4EBAE900D1F217AA000000
FAID-Crypted: 86114D28AE70FACFCD1D417F
Erasing NOR Region [0x01D00000-0x0217FFFF]
Erase taken 15.250s
Writing 37 blocks...
All blocks written OK! Time taken 156.875s
Box VPP disabled
MCU Version	V 06.88
MCU Date	06-07-09
IMEI SV		0321810510975846F0000000
PPM		V 06.88, 06-07-09, RM-515, (c) Nokia            , NCR
CNT		Content: ncr_attus_07thJul09, V 06.88, 06-07-09, RM-515, (c) Nokia            ,
PSN		HGD656885
Module Code	0204047
LPSN		0
HW		1501
UEM		4386
UPP		3168
RFIC		0500
LCD		SUEZ
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Read Log X2-01 RM-709 Done
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		358645045074085
Mastercode	4121316056
IMEI Spare	3A85460554700408
IMEI SV		3385460554700438F2000000
CNT		Content: telecom AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia
PSN		0631574AY
Product Code	059K1C2
Module Code	0204674
Basic Product Code	059J9S5
LPSN		0
HW		1001
RFIC		9
LCD		SEIKO
BT		2.31-SP2.31
Simlock Key	7223400000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72234F
MCU Version	V 08.63
MCU Date	25-03-11
15 Digits NCK Found
WARNING: "0000000000745528876556B141D6F4FDA77DFAA7.C0001FF6" Not Exists, Will read it...
Booting CMT...
Switching to RAW Mode...
New ROM Detected
CMT_PUBLIC_ID:		0000000000745528876556B141D6F4FDA77DFAA7
CMT_BOOT_ROM_CRC:	DE56D582
CMT Ready!
BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.24.0, Algo: BB5
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.07 (C) 2011 KarwosLabs
If phone doesn't powering into Local Mode now for some reason do following:
1. Re-insert battery
2. Power it on, when asked use Ovi/Pc Suite Mode
Readed OK, Saving to "0000000000745528876556B141D6F4FDA77DFAA7.C0001FF6"
Success!
Read Log 7020 RM-497 Done
[Nokia 7020 USB Phonet]: Port opened OK!
MCU Version	V 05.41
MCU Date	29-01-10
Product		RM-497 (Nokia 7020/7020a-2/7020a-2b)
IMEI		356073034006228
Mastercode	402102433
IMEI Spare	3A65700343002602
IMEI SV		3365700343002622F1000000
PPM		V 05.41, 29-01-10, RM-497, (c) Nokia            , L
CNT		Content: movi_ar_graph, V 05.41, 29-01-10, RM-497, (c) Nokia            , ,
PSN		GGU629595
Product Code	0592377
Module Code	0204040
Basic Product Code	0570540
PSD		0000001D00000000
LPSN		0
HW		2000
RFIC		9
LCD		SEIKO
BT		2.31-SP2.26
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 05.41
MCU Date	29-01-10
15 Digits NCK Found
"520110FD0FA5852B19668762E7DE0C611CABCAA1.C0001FF6" Exists, That is good...
Success!
Old 04-24-2012, 18:05   #2546 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Full Flash 6085 RM-198 Done
MCU Version	V 04.26
MCU Date	16-03-07
Product		RM-198 (Nokia 6085)
Manufacturer	(c) Nokia.
IMEI		353232015714233
Mastercode	50766314
IMEI Spare	3A35320251172403
IMEI SV		3335320251172413F6000000
PPM		V 04.26, 16-03-07, RM-198, (c) Nokia.        , L
CNT		Content: l Vivo v1, 10-08-07, RM-198, (c) Nokia.        ,
PSN		GBI426438
Product Code	0554267
Basic Product Code	0531926
RETU		32
TAHVO		53
AHNE		11
HW		1201
RFIC		17211721
DSP		pb06w14v42.1
BT		06cc-P9.0
Simlock Server	SIMLOCK SERVER VERSION 63
Simlock Key	7240600086388183
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72406F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 72410F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 72411F
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: 26806F
MCU Version	V 04.26
MCU Date	16-03-07
Mastercode	50766314
RETU		32
TAHVO		53
AHNE		11
HW		1201
RFIC		17211721
DSP		pb06w14v42.1
BT		06cc-P9.0
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Product Code: 0554267
Found 48 products, Filtering DCT4 Products - wait...
11 Products left after filtering. Ready.
Retrieving Variants for Product RM-198 - wait...
MCU Version	V 04.26
MCU Date	16-03-07
Mastercode	50766314
PSN		GBI426438
RETU		32
TAHVO		53
AHNE		11
HW		1201
RFIC		17211721
DSP		pb06w14v42.1
BT		06cc-P9.0
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Backing up RPL...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
"RM-198_353232015714233_24042012_135300.SecurityBlock.PM"
Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:		00000232
CMT_EM_ASIC_ID:		00000353
CMT_PUBLIC_ID:		0FE00002E49E6C561291F0CD5B34E1AC1DBADEDA
CMT Ready!
Old Loader Detected
Readed OK, Saving to "0FE00002E49E6C561291F0CD5B34E1AC1DBADEDA.C0001FF6"
Not Found (SL3 phone?)
Booting CMT...
CMT Ready!
FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR
FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V
Box VPP disabled
PAPUBKEYS Hash for CMT: C44614CCC0A09C4A52B890FA55B4B31AF4787668
Storing NPC...
Storing CCC...
Storing HWC...
Storing VARIANT...
Restarting MCU...
RPL Saved OK
MCU Version	V 04.26
MCU Date	16-03-07
Mastercode	50766314
Simlock backup OK, saved to RM-198_353232015714233_24042012_135445.SLBackup.PM
Processing rm198__06.00.mcusw.bin (CMT)...
Booting CMT...
CMT Ready!
rm198__06.00.mcusw.bin, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Flashbus Write baud set to 51Kbits
Box VPP disabled
EraseArea[0,CMT]: 0x00000000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00100000-0x0110FFFF, NOR
Erase taken 60.250s
TurboCache Loaded!
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm198__06.00.mcusw.bin
Booting CMT...
CMT Ready!
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Erase taken 5.484s
TurboCache Loaded!
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PMM_CONF Certificate...
Writing CMT SBIF_CONF Certificate...
All blocks written OK! Time taken 144.453s
Flashing Speed: 841,32 kBit/S
Restarting MCU...
Processing rm198__06.00.mcusw.bin (APE)...
Processing rm198__06.00.ppm_c (CMT)...
Booting CMT...
CMT Ready!
rm198__06.00.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01120000-0x015DFFFF, NOR
Erase taken 12.734s
TurboCache Loaded!
All blocks written OK! Time taken 21.93s
Flashing Speed: 1494,55 kBit/S
Restarting MCU...
Processing rm198__06.00.ppm_c (APE)...
Processing rm198__06.00.image_c (CMT)...
Booting CMT...
CMT Ready!
rm198__06.00.image_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x015E0000-0x01FDFFFF, NOR
Erase taken 43.281s
TurboCache Loaded!
All blocks written OK! Time taken 16.187s
Flashing Speed: 1652,91 kBit/S
Restarting MCU...
Processing rm198__06.00.image_c (APE)...
Reading info...
MCU Version	V 06.00
MCU Date	28-11-07
Mastercode	50766314
IMEI SV		3335320251172423F4000000
PPM		V 06.00, 28-11-07, RM-198, (c) Nokia.           , C
PSN		GBI426438
RETU		32
TAHVO		53
AHNE		11
HW		1201
RFIC		17211721
DSP		pb06w14v50.1
BT		06cc-P9.1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Read Log C3 RM-614 Done!
MCU Version	V 08.63
MCU Date	25-03-11
IMEI		358608044288254
Mastercode	7256715626
IMEI Spare	3A85060844822805
IMEI SV		3385060844822835F2000000
PPM		V 08.63, 25-03-11, RM-614, (c) Nokia            , L
CNT		Content: claro AR SKD V3, V 08.63, 25-03-11, RM-614, (c) Nokia
PSN		034E502AY
Product Code	059D9P8
Module Code	0204418
Basic Product Code	059D7P2
LPSN		0
WLAN MAC	10F9EE72840D
HW		1008
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 08.63
MCU Date	25-03-11
15 Digits NCK Found
WARNING: "0000000000488D3D4647AB0ADAD678C635584429.C0001FF6" Not Exists, Will read it...
Booting CMT...
New ROM Detected
CMT_PUBLIC_ID:		0000000000488D3D4647AB0ADAD678C635584429
CMT Ready!
FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND
Readed OK, Saving to "0000000000488D3D4647AB0ADAD678C635584429.C0001FF6"
Success!
Old 04-24-2012, 19:19   #2547 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 704
Thumbs up c1 rm607 flashing successful
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.11988
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Box Serial Number: C0005CBB
2009, wk23
Card Serial Number: D0080467
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	4.99v	PASSED
MCU Voltage	3.28v	PASSED
Core Voltage	1.79v	PASSED
VBAT Voltage	0.01v	PASSED
VBAT Voltage	4.96v	PASSED
Box VPP disabled
VPP Voltage	0.00v	PASSED
Internal Box VPP Enabled
VPP Voltage	4.88v	PASSED
Box VPP disabled
VPP Voltage	0.02v	PASSED
External Box VPP Enabled
VPP Voltage	0.00v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
XGold/Blackberry Service Running, Credits Left: 100
Avaiable Physical Memory: 852.892MB
Avaiable Virtual Memory: 1.422GB
Avaiable Pagefile: 2.40GB
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 2 products, Filtering DCT4 Products - wait...
Found 2 products, Filtering BB5 Products - wait...
2 Products left after filtering. Ready.
Retrieving Variants for Product RM-607 - wait...
2 Variants Retrieved
Processing rm607__06.15.mcusw (XGold2)...
Checking rm607__06.15.mcusw...
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_2.5_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00EC3012, Samsung, Size: 64MBytes
Processing "rm607__06.15.mcusw_ebl_psi.fls"...
Erasing 0x40000000-0x4001FFFF...
Flashing at 0x40000000...
Flashed 131072 bytes OK
Erasing 0x40040000-0x4007FFFF...
Flashing at 0x40040000...
Flashed 262144 bytes OK
Erasing 0x40080000-0x4009FFFF...
Flashing at 0x40080000...
Erasing 0x400A0000-0x4019FFFF...
Flashing at 0x400A0000...
Flashed 1048576 bytes OK
Erasing 0x40400000-0x41BFFFFF...
Flashing at 0x40400000...
Flashed 24641536 bytes OK
Processing rm607__06.15.ppm_h (XGold2)...
Checking rm607__06.15.ppm_h...
Processing "package_h.ppm_ebl_psi.fls"...
Erasing 0x41C00000-0x421FFFFF...
Flashing at 0x41C00000...
Flashed 3340928 bytes OK
Processing rm607__06.15.image_h_0595553 (XGold2)...
Checking rm607__06.15.image_h_0595553...
Processing "package_h_0595553.image.fls"...
Erasing 0x42200000-0x43E5FFFF...
Flashing at 0x42200000...
Flashed 11796480 bytes OK
Erasing 0x43E60000-0x43F3FFFF...
[Nokia C1-01 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version	V 06.15
MCU Date	25-11-11
Product		RM-607 (Nokia C1-01)
IMEI		359745044119078
Mastercode	3617566034
IMEI Spare	3A95470544110907
IMEI SV		3395470544110927F2000000
PPM		V 06.15, 25-11-11, RM-607, (c) Nokia            , H
CNT		Content: h_0595553, V 06.15, 25-11-11, RM-607, (c) Nokia
PSN		DC3C1D3AI
Product Code	059D9M8
Module Code	0204427
Basic Product Code	0585582
LPSN		0
HW		2001
RFIC		96
LCD		AUO
BT		19b5-22012
Asic		11
HW Signature	016DD2E02A57F3AE
Simlock Aux	000B0000
Simlock IMEI	00003597450441190700
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Setting factory defaults of: User data
Setting factory defaults of: Leave factory
Setting factory defaults of: Service Center
Setting factory defaults of: Software Upgrade
Setting factory defaults of: Production Tune
Phone not detected at USB -> User Abort
Failed to set Normal Mode -> Mode not accepted
Old 04-24-2012, 19:22   #2548 (permalink)
Member: 388033
Thanks Meter: 704
Thumbs up 6300 rm-217 dead usb flashing
Initializing box...
2009, wk23
Card is activated
Box is activated
Box VPP disabled
VPP Voltage	0.04v	PASSED
VPP Voltage	4.97v	PASSED
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 873.884MB
Avaiable Virtual Memory: 1.426GB
Avaiable Pagefile: 2.106GB
Found 1 products, Filtering BB5 Products - wait...
Retrieving Variants for Product RM-217 - wait...
1 Variants Retrieved
Selecting USB Flashing Method...
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to prepare BB5 USB Connection -> USB Boot ROM Not detected, timeout
Failed to Process all Image files -> Failed to prepare BB5 USB Flashing
Processing rm217__07.30.mcusw (CMT)...
Booting CMT...
Old ROM Detected
CMT_PUBLIC_ID:		23A0020383187F560543D3497E533B54EAE42F81
CMT Ready!
rm217__07.30.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
transport, update loaders maybe ?
Failed to Process all Image files -> Failed to process rm217__07.30.mcusw
Old ROM Detected
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
Sending CMT UPDAPP Certificate and Data...
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
ADL Server Startup Confirmed OK!
Started flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR
EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR
EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR
EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR
EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR
Erase taken 43.524s
TurboCache Loaded!
All blocks written OK! Time taken 100.730s
Flashing Speed: 1207.52 kBit/S
Processing rm217__07.30.ppm_c (CMT)...
rm217__07.30.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01080000-0x015FFFFF, NOR
Erase taken 15.148s
TurboCache Loaded!
All blocks written OK! Time taken 35.537s
Flashing Speed: 1217.28 kBit/S
Processing rm217__07.30.image_c_tr_choco (CMT)...
rm217__07.30.image_c_tr_choco, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01600000-0x01FDFFFF, NOR
Erase taken 28.814s
TurboCache Loaded!
All blocks written OK! Time taken 41.871s
Flashing Speed: 1178.42 kBit/S
Restarting CMT...
[Nokia 6300 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version	V 07.30
MCU Date	07-05-09
Product		RM-217 (Nokia 6300)
IMEI		355234039430703
Mastercode	154401077
IMEI Spare	3A55320493347000
IMEI SV		3355320493347020F7000000
PPM		V 07.21, 05-11-08, RM-217, (c) Nokia.           , V
PSN		KNJ289924
Product Code	0575104
Module Code	0203166
Basic Product Code	0537040
RETU		32
TAHVO		53
AHNE		11
HW		3044
RFIC		17211721
DSP		ICPR61_08w10
BT		06cc-P9.1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 07.30
MCU Date	07-05-09
PSN		KNJ289924
Module Code	0203166
RETU		32
TAHVO		53
AHNE		11
HW		3044
RFIC		17211721
DSP		ICPR61_08w10
BT		06cc-P9.1
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Selftests to proceed: 30
Passed		ST_EAR_DATA_LOOP_TEST
Passed		ST_SIM_CLK_LOOP_TEST
Passed		ST_SIM_IO_CTRL_LOOP_TEST
Passed		ST_SLEEP_X_LOOP_TEST
Passed		ST_UEM_CBUS_IF_TEST
Passed		ST_KEYBOARD_STUCK_TEST
Passed		ST_CAMERA_IF_TEST
Passed		ST_BACKUP_BATT_TEST
Passed		ST_LPRF_IF_TEST
Passed		ST_LPRF_AUDIO_LINES_TEST
Passed		ST_CURRENT_CONS_TEST
Passed		ST_RADIO_TEST
Passed		ST_BACKLIGHT_TEST
Passed		ST_SIM_LOCK_TEST
Passed		ST_SECURITY_TEST
Passed		ST_BT_WAKEUP_TEST
Passed		ST_HOOKINT_TEST
Passed		ST_TAHVOINT_TEST
Passed		ST_SLEEPCLK_FREQ_TEST
Passed		ST_BTEMP_TEST
Passed		ST_BT_SLEEP_CLK_TEST
Passed		ST_EXT_DEVICE_TEST
Failed		ST_CDSP_RF_BB_IF_TEST
Failed		ST_CDSP_RF_SUPPLY_TEST
Failed		ST_CDSP_TX_IQ_TEST
Failed		ST_CDSP_TXC_DATA_TEST
Failed		ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed		ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Failed		ST_CDSP_RX_IQ_LOOP_BACK_TEST
Failed		ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 30, Tests passed: 22, Tests not passed: 8
Phone is in Test Mode
Normal mode set
Old 04-24-2012, 19:24   #2549 (permalink)
Member: 388033
Thanks Meter: 704
Thumbs up 2310 full erase and repair
Initializing box...
2009, wk23
Card is activated
Box is activated
USB Voltage	5.00v	PASSED
VBAT Voltage	1.44v	PASSED
VBAT Voltage	4.95v	PASSED
Box VPP disabled
Box VPP disabled
VPP Voltage	0.04v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Avaiable Physical Memory: 843.0MB
Avaiable Pagefile: 2.255GB
Booting UPP...
UPP ID: 2201 [HW_UPP2M_v2]
u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.04V
Boot operation took 6.318s
Booting UPP...
Booting UPP...
DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.02V
Erasing NOR Region [0x01000000-0x013FFFFF]
Erase All Chips finished
Booting UPP...
rm189_06.330, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
DCT4 ALGORITHM
MSID-Crypted: 84D38C08D0C212C786DC9AD373
MSID-Plain: 3E4EBAE900CC4D57A8000000
FAID-Crypted: A1D9E84557E7987CD7749F75
Erasing NOR Region [0x01010000-0x013BFFFF]
Erasing NOR Region [0x013C0000-0x013EFFFF]
Erase taken 38.330s
Writing 123 blocks...
All blocks written OK! Time taken 11.466s
Box VPP disabled
Booting UPP...
rm1890_nai6.33ej, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
DCT4 ALGORITHM
MSID-Crypted: 847A613ED472772422F340DACA
MSID-Plain: 3E4EBAE900CC4D57A9000000
FAID-Crypted: 8E3346A75127B4BE876050EF
Erasing NOR Region [0x01380000-0x013BFFFF]
Erase taken 2.449s
Writing 12 blocks...
All blocks written OK! Time taken 1.124s
Box VPP disabled
Booting UPP...
rm189_06.33ej, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
DCT4 ALGORITHM
Erasing NOR Region [0x011E0000-0x011EFFFF]
Erasing NOR Region [0x011F0000-0x0137FFFF]
Erase taken 15.834s
Writing 91 blocks...
All blocks written OK! Time taken 8.580s
Box VPP disabled
[1,0] Written, Length: 120 bytes, Status: OK
[1,2] Written, Length: 90 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,5] Written, Length: 2 bytes, Status: OK
[1,6] Written, Length: 90 bytes, Status: OK
[1,11] Written, Length: 2 bytes, Status: OK
[1,12] Written, Length: 2 bytes, Status: OK
[2,0] Written, Length: 132 bytes, Status: OK
[4,0] Written, Length: 1 bytes, Status: OK
[4,1] Written, Length: 8 bytes, Status: OK
[4,2] Written, Length: 44 bytes, Status: OK
[4,3] Written, Length: 10 bytes, Status: OK
[4,4] Written, Length: 8 bytes, Status: OK
[4,5] Written, Length: 8 bytes, Status: OK
[4,6] Written, Length: 8 bytes, Status: OK
[4,9] Written, Length: 5 bytes, Status: OK
[5,0] Written, Length: 78 bytes, Status: OK
[7,0] Written, Length: 4 bytes, Status: OK
[7,1] Written, Length: 32 bytes, Status: OK
[7,2] Written, Length: 4 bytes, Status: OK
[8,0] Written, Length: 12 bytes, Status: OK
[120,0] Written, Length: 78 bytes, Status: Not accepted, Code: 5
[238,0] Written, Length: 320 bytes, Status: Not accepted, Code: 5
Write PM Finished, Record written OK: 21, Record written NOT OK: 2
MCU Version	V 6.33
MCU Date	03-09-07
Product		RM-189 (Nokia 2310 CABLE 1100)
Manufacturer	(c) NMP
IMEI		353654013006470
Mastercode	271351122
Local mode Set
Asic		2
HW Signature	6B44D4BAE606F953
Simlock Server
Simlock Key	FFFFFFFFFFFFFFFF
Simlock Profile	0000000000010000
Simlock Aux	00020000
Simlock IMEI	00003536540130064700
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 00101F
Signed OK (9C58C636A056417B4E5A0547B2A5FC3A230319BD)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Test mode set
MCU Version	V 6.33
MCU Date	03-09-07
IMEI Spare	3A35560431004607
IMEI SV		3335560431004637F2000000
PPM		V 6.33, 03-09-07, RM-189, (c) NMP, EJ
PSN		DMH540109
Product Code	0541719
Module Code	0203013
Basic Product Code	0531456
PSD		0000000D00000000
HW		0501
UEM		1314
UPP		2201
RFIC		0500
DSP		P05w06.v39
LCD		SEID:NAXvA1, S6B33BD
ADSP Sw		p&V 6.33\n03-09-07\nRM-189\n(c) NMP\nej
Asic		2
Simlock Server
Simlock Profile	8000000000010002
Simlock Aux	00024E4D
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Product Code: 0541719
No Flash Datapackage installed for this Phone!
Booting UPP...
DCT4 ALGORITHM
Boot operation took 5.740s
Old 04-24-2012, 19:33   #2550 (permalink)
Member: 388033
Thanks Meter: 704
Thumbs up 6303 read Sl3 log success
MCU Version	V 09.10
MCU Date	25-08-09
Product		RM-443 (Nokia 6303 classic)
IMEI		358005037315154
Mastercode	336121366
15 Digits NCK Found
"1110021149F667502BF0E4A4F720FA3DF9A48844.C0005CBB" Exists, That is good...
Success!
MCU Version	V 09.10
MCU Date	25-08-09
15 Digits NCK Found
Success!
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.73221 seconds with 10 queries
