Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-21-2012, 17:21   #2656 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Nokia 2220s RM-590
MCU Version	V 10.25
MCU Date	30-07-10
Product		RM-590 (Nokia RM-590)
Manufacturer	(c) Nokia
IMEI		357888048319799
Mastercode	402476221
Setting Local Mode...
Local mode Set
Asic		11
HW Signature	49D597F2F7785312
Simlock Server	SIMLOCK SERVER
Simlock Key	2620100000000000
Simlock Profile	800000000003000B
Simlock Aux	000B5555
Simlock IMEI	00553578880483197900
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 26201F
Simlock [1,2]	State: CLOSED	Type: 7FFF6F3EFFFFFFFF @ 8000	Data: 02
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 26201F
Simlock [2,2]	State: CLOSED	Type: 7FFF6F3EFFFFFFFF @ 8000	Data: 99
Autodetecting SP Type...
Autodetection Finished
Proceeding with RSA Unlock...
Asking card to sign HW Signature...
Signed OK (0059BF18C22172835D33442206D2BFF650567A4B)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-21-2012 at 22:36. Reason: ADD [CODE] [/CODE] TAG TO THE LOG :D
Old 05-23-2012, 13:21   #2657 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 764
Thumbs up 6303 Flashing done.
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:01:57, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C000xxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Initializing security card...
Card Serial Number: D7000xxxx
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.05v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 1.51v PASSED
VBAT Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.84GB
Avaiable Virtual Memory: 1.488GB
Avaiable Pagefile: 2.770GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID:  00000295
CMT_EM_ASIC_ID:  00000B22
CMT_PUBLIC_ID:  0A0001068D137F562697968457B9DBBAADE599F6
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 106 products, Filtering BB5 Products - wait...
61 Products left after filtering. Ready.
Retrieving Variants for Product RM-443 - wait...
176 Variants Retrieved
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm443__10.12.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm443__10.12.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00060000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x0015FFFF, NOR
EraseArea[0,CMT]: 0x00160000-0x0023FFFF, NOR
EraseArea[0,CMT]: 0x01740000-0x0191FFFF, NOR
EraseArea[0,CMT]: 0x00240000-0x0173FFFF, NOR
EraseArea[0,CMT]: 0x022E0000-0x0261FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 102.781s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT ISA+DYNSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 67.328s
Flashing Speed: 3074.06 kBit/S
Restarting MCU...
Processing rm443__10.12.mcusw (APE)...
Processing rm443__10.12.ppm_c (CMT)...
Booting CMT...
CMT Ready!
rm443__10.12.ppm_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01920000-0x022DFFFF, NOR
Erase taken 24.781s
TurboCache Loaded!
All blocks written OK! Time taken 16.265s
Flashing Speed: 3350.38 kBit/S
Restarting MCU...
Processing rm443__10.12.ppm_c (APE)...
Processing rm443__10.12.image_c_it_steel (CMT)...
Booting CMT...
CMT Ready!
rm443__10.12.image_c_it_steel, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x02620000-0x029BFFFF, NOR
EraseArea[0,CMT]: 0x029C0000-0x03FBFFFF, NOR
Erase taken 169.531s
TurboCache Loaded!
All blocks written OK! Time taken 25.781s
Flashing Speed: 3339.07 kBit/S
Restarting MCU...
Processing rm443__10.12.image_c_it_steel (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 10.12
MCU Date 08-04-10
Product  RM-443 (Nokia 6303 classic)
IMEI  3531990365xxxxx
Mastercode 5142474147
IMEI Spare 3A35910963558405
IMEI SV  3335910963558445F5000000
PPM  V 10.12, 08-04-10, RM-443, (c) Nokia            , C
CNT  Content: c_it_steel, V 10.12, 08-04-10, RM-443, (c) Nokia            ,
PSN  DQH874163
Product Code 0569439
Module Code 0204197
Basic Product Code 0575069
PSD  0000000000000000
LPSN  0
RETU  15
TAHVO  22
AHNE  30
HW  1000
RFIC  0800
DSP  ICPR81_09w37
LCD  SHARP
BT  410B-v190
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 05-23-2012, 20:18   #2658 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
Unlock E5-00 RM-634!
[Nokia E5-00 USB Phonet]: Port opened OK!
MCU Version	V ICPR82_11w16.3
MCU Date	19-05-11
Product		RM-634 (NOkia E5-00)
IMEI		3579200465
Mastercode	156347620
IMEI Spare	3A75290064751308
IMEI SV		3375290064751328F3000000
PSN		30E0363AA
Product Code	059H6R8
Module Code	0204474
Basic Product Code	059H390
LPSN		0
WLAN MAC	9CCAD97585A2
APE SW		071.003
APE Variant	071.003071.003.57.01071.003.379.03
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
RFIC		|Vapaus_5.1 | Mikki_1.1
DSP		ICPR82_11w16
Simlock Key	7220700000000000
Simlock Profile	8000000000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
Simlock [4,1]	State: CLOSED	Type: MCC-MNC	Data: 73002F
Simlock [5,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 732123
Simlock [6,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ E000	Data: 740FFF
Simlock [7,1]	State: CLOSED	Type: MCC-MNC	Data: 70604F
Simlock [8,1]	State: CLOSED	Type: MCC-MNC	Data: 70403F
Simlock [9,1]	State: CLOSED	Type: MCC-MNC	Data: 33403F
Simlock [10,1]	State: CLOSED	Type: MCC-MNC	Data: 71030F
Simlock [11,1]	State: CLOSED	Type: MCC-MNC	Data: 71402F
Simlock [12,1]	State: CLOSED	Type: MCC-MNC	Data: 71606F
Simlock [13,1]	State: CLOSED	Type: MCC-MNC	Data: 74807F
Simlock [14,1]	State: CLOSED	Type: MCC-MNC	Data: 73404F
Sending BB5 NCK Code...
NCK[7] - ACCEPTED
MCU Date	19-05-11
IMEI		3579200465
PSN		30E0363AA
Module Code	0204474
LPSN		0
APE SW		071.003
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
DSP		ICPR82_11w16
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 72207F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: 73002F
Simlock [5,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 732123
Simlock [6,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ E000	Data: 740FFF
Simlock [7,1]	State: OPENED	Type: MCC-MNC	Data: 70604F
Simlock [8,1]	State: OPENED	Type: MCC-MNC	Data: 70403F
Simlock [9,1]	State: OPENED	Type: MCC-MNC	Data: 33403F
Simlock [10,1]	State: OPENED	Type: MCC-MNC	Data: 71030F
Simlock [11,1]	State: OPENED	Type: MCC-MNC	Data: 71402F
Simlock [12,1]	State: OPENED	Type: MCC-MNC	Data: 71606F
Simlock [13,1]	State: OPENED	Type: MCC-MNC	Data: 74807F
Simlock [14,1]	State: OPENED	Type: MCC-MNC	Data: 73404F
Simlock NCK	#pw+3ƒSR38518869033+7#
Old 05-23-2012, 22:45   #2659 (permalink)
Member: 288521
Thanks Meter: 685
Processing C:\Documents and Settings\ZH\Desktop\...
Found 24 products, Filtering BB5 Products - wait...
Retrieving Variants for Product 5800 - wait...
1 Variants Retrieved
Backing up RPL...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
Security block OK and saved to "RM-588_354845048782999_23052012_223943.SecurityBlock.PM"
"15F00112D5A200524627FD5D64E693F1E583D764.B0000AF0" Exists, That is good...
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006400C192101051103
CMT_EM_ASIC_ID:		00000296
CMT_PUBLIC_ID:		15F00112D5A200524627FD5D64E693F1E583D764
CMT_ROOT_KEY_HASH:	479C6DDE3942E12C429C1D6ADED80371
CMT_BOOT_ROM_CRC:	4B9B7510
CMT_SECURE_ROM_CRC:	3E691FF8
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000231, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5
TurboCache Loaded!
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Backing up simlock...
MCU Version	V ICPR72_10w04.5
MCU Date	22-03-10
Product		RM-588 (Nokia 5230)
IMEI		354845048782999
Mastercode	345137177
Simlock backup OK, saved to RM-588_354845048782999_23052012_223956.SLBackup.PM
Backup simlock thread finished, continuing...
Processing RM-588_51.9.002_prd.core.C00 (CMT)...
Booting CMT...
CMT Ready!
RM-588_51.9.002_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5
Flashbus Write baud set to 650Kbits
RAPIDOv11_XSR17_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.6
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase Partition (CMT)
Erase taken 1.16s
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*ENO Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 122.47s
Flashing Speed: 7331.09 kBit/S
Restarting MCU...
Processing RM-588_51.9.002_prd.core.C00 (APE)...
Processing RM-588_51.9.002_prd.rofs2.V25 (CMT)...
Booting CMT...
CMT Ready!
RM-588_51.9.002_prd.rofs2.V25, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x06FE0000-0x0915FFFF, ONENAND
Erase taken 0.219s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 31.141s
Flashing Speed: 7184.31 kBit/S
Restarting MCU...
Processing RM-588_51.9.002_prd.rofs2.V25 (APE)...
Processing RM-588_51.9.002_C01_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-588_51.9.002_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND
Erase taken 0.110s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 7.219s
Flashing Speed: 7156.35 kBit/S
Restarting MCU...
Processing RM-588_51.9.002_C01_prd.rofs3.fpsx (APE)...
Processing RM-588_51.0.002_000_001_U002.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-588_51.0.002_000_001_U002.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F47FFFF, ONENAND
Erase taken 0.500s
TurboCache Loaded!
All blocks written OK! Time taken 19.984s
Flashing Speed: 6848.04 kBit/S
Restarting MCU...
Processing RM-588_51.0.002_000_001_U002.uda.fpsx (APE)...
Factory defaults OK
Reading info...
MCU Version	V ICPR72_11w16.1
MCU Date	28-07-11
IMEI Spare	3A45480584879209
IMEI SV		3345480584879229F5000000
PSN		08D5EFCAA
Product Code	0597528
Module Code	0204359
Basic Product Code	0584528
LPSN		0
APE SW		V 51.9.002
APE Variant	V 51.9.002??????
APE Test		eno_version
APE HW		256
APE ADSP	256
RETU		16
TAHVO		22
AHNE		11
HW		0512
RFIC		17141716
DSP		ICPR72_11WK13
Simlock Key	2340000300000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 23410F
Simlock [1,2]	State: CLOSED	Type: 7FFF6F3EFFFFFFFF @ 8000	Data: 0A
Old 05-24-2012, 07:20   #2660 (permalink)
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 764
Thumbs up 5130 Flashing done.
Initializing box...
Box Serial Number: C0002xxx
Card is activated
Box is activated
USB Voltage 5.06v PASSED
VBAT Voltage 1.53v PASSED
VBAT Voltage 4.99v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
VPP Voltage 4.97v PASSED
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 1.89GB
Avaiable Pagefile: 2.750GB
Booting CMT...
CMT_PUBLIC_ID:  0A00010AE8950456414EDDBFED538AFECCC2B092
CMT Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Restarting MCU...
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-495_356985041982655_5232012_41222 PM.SecurityBlock.PM"
WARNING: "0A00010AE8950456414EDDBFED538AFECCC2B092.C000290B" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Old Loader Detected
Readed OK, Saving to "0A00010AE8950456414EDDBFED538AFECCC2B092.C000290B"
Storing CMLA Key...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Processing rm495__07.97.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Erase taken 97.672s
TurboCache Loaded!
All blocks written OK! Time taken 51.250s
Flashing Speed: 2978.47 kBit/S
Restarting MCU...
Processing rm495__07.97.mcusw (APE)...
Processing rm495__07.97.ppm_mena_a1 (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.ppm_mena_a1, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR
Erase taken 34.797s
TurboCache Loaded!
All blocks written OK! Time taken 15.297s
Flashing Speed: 3326.11 kBit/S
Restarting MCU...
Processing rm495__07.97.ppm_mena_a1 (APE)...
Processing rm495__07.97.image_mena_a1_red (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.image_mena_a1_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR
EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR
Erase taken 251.172s
TurboCache Loaded!
All blocks written OK! Time taken 25.328s
Flashing Speed: 3398.79 kBit/S
Restarting MCU...
Processing rm495__07.97.image_mena_a1_red (APE)...
Factory defaults OK
Reading info...
MCU Version V 07.97
MCU Date 13-09-10
Product  RM-495 (Nokia 5130 XpressMusic)
IMEI  35698504198xxxx
Mastercode 157135620
IMEI Spare 3A65890514896205
IMEI SV  3365890514896255F8000000
PPM  V 07.97, 13-09-10, RM-495, (c) Nokia            , MEN
CNT  Content: mena_a1_bd_red, V 07.97, 13-09-10, RM-495, (c) Nokia
PSN  HEM472536
Product Code 0572175
Module Code 0204024
Basic Product Code 0567773
LPSN  0
RETU  16
TAHVO  22
AHNE  30
HW  1005
RFIC  06560601
DSP  ICPR72_10w01
LCD  SEIKO
BT  2222-302
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Old 05-24-2012, 12:43   #2661 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
5130 cannot be turned on with battery [SOLVED]
The phone could only be turned on when connected to FBUS cable.
Booting CMT...
CMT_PUBLIC_ID:		0630010FE2A68A56255576E716440ADC49DAF919
CMT Ready!
Box VPP disabled
Erasing flash chip...
EraseArea[0,CMT]: 0x00000000-0x03FFFFFF, NOR
Waiting 640s for erasure finish...
Erase taken 154.769s
Restarting MCU...
BB5 Full Erase Finished!
Processing rm495__07.95.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Certificates OK
Erase taken 0.202s
TurboCache Loaded!
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
All blocks written OK! Time taken 54.662s
Flashing Speed: 2792,56 kBit/S
Restarting MCU...
Processing rm495__07.95.mcusw (APE)...
Processing rm495__07.95.ppm_ec (CMT)...
Booting CMT...
CMT Ready!
rm495__07.95.ppm_ec, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 14.196s
Flashing Speed: 3588,67 kBit/S
Restarting MCU...
Processing rm495__07.95.ppm_ec (APE)...
Processing rm495__07.95.image_ec_blu (CMT)...
Booting CMT...
CMT Ready!
rm495__07.95.image_ec_blu, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Erase taken 0.296s
TurboCache Loaded!
All blocks written OK! Time taken 30.888s
Flashing Speed: 3330,78 kBit/S
Restarting MCU...
Processing rm495__07.95.image_ec_blu (APE)...
Factory defaults OK
Reading info...
MCU Version	V 07.95
MCU Date	03-02-10
IMEI		12345610654321?
IMEI Spare	1A32541660452301
IMEI SV		1332541660452341F8000000
PPM		V 07.95, 03-02-10, RM-495, (c) Nokia            , EC
CNT		Content: ec_blu, V 07.95, 03-02-10, RM-495, (c) Nokia            ,
PSN		0
LPSN		0
RETU		16
TAHVO		22
AHNE		30
RFIC		06540601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Failed to read info -> Failed to read SP info
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Writing Simlock...
Handling as SL3 Simlock Data
Handling as SIMLOCK1 Format
Security block OK and saved to "RM-495_12345610654321_24.5.2012_133450.SecurityBlock.PM"
15 Digits NCK Found
Simlock ACCEPTED OK !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key ACCEPTED OK !
Writing WMDRM PD Data...
WMDRM PD Data ACCEPTED OK !
Processing FLASHBUS Part...
Booting CMT...
CMT Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Version	V 07.95
MCU Date	03-02-10
IMEI		356919035538686
Mastercode	44757604
IMEI Spare	3A65190953356808
IMEI SV		3365190953356848F8000000
PSN		IAV443210
Product Code	0586913
LPSN		0
RETU		16
TAHVO		22
AHNE		30
HW		2000
RFIC		06540601
DSP		ICPR72_10w01
LCD		SEIKO
BT		2222-302
Simlock Key Cnt	0
Simlock FBUS Cnt	0
SX4 Authorization / SD Repair Procedure Started....
"0630010FE2A68A56255576E716440ADC49DAF919.C0002E8C" Exists, That is good...
MCU Version	V 07.95
MCU Date	03-02-10
Mastercode	44757604
Security block OK and saved to "RM-495_356919035538686_24.5.2012_133520.SecurityBlock.PM"
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 12 bytes, Status: OK
[1,1] Written, Length: 70 bytes, Status: OK
[1,2] Written, Length: 70 bytes, Status: OK
[1,3] Written, Length: 70 bytes, Status: OK
[1,4] Written, Length: 70 bytes, Status: OK
[1,5] Written, Length: 276 bytes, Status: OK
[1,6] Written, Length: 276 bytes, Status: OK
[1,7] Written, Length: 276 bytes, Status: OK
[1,8] Written, Length: 276 bytes, Status: OK
[1,9] Written, Length: 384 bytes, Status: OK
[1,10] Written, Length: 384 bytes, Status: OK
[1,11] Written, Length: 384 bytes, Status: OK
[1,12] Written, Length: 384 bytes, Status: OK
[1,13] Written, Length: 384 bytes, Status: OK
[1,14] Written, Length: 384 bytes, Status: OK
[1,15] Written, Length: 384 bytes, Status: OK
[1,16] Written, Length: 384 bytes, Status: OK
[1,17] Written, Length: 32 bytes, Status: OK
[1,19] Written, Length: 16 bytes, Status: OK
[1,20] Written, Length: 32 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 29, Record written NOT OK: 0
Now works perfectly. (backup RPL, PM, crts, full erase, full flash, restore RPL, SX4)
thanks cyclone team
Last edited by ptt; 05-24-2012 at 12:51. Reason: CHANGE [QUOTE] TO [CODE] TAG -- MOVE TO THE RIGHT THREAD
Old 05-24-2012, 17:25   #2662 (permalink)
dapx's Avatar
Member: 1064967
Thanks Meter: 131
MCU Date	19-05-11
IMEI		3579200465
Mastercode	214423364
IMEI Spare	3A75290064855103
IMEI SV		3375290064855123F3000000
PSN		30DF032AA
Product Code	059K4J2
Module Code	0204474
LPSN		0
WLAN MAC	9CCAD97588E5
APE SW		071.003
APE Variant	071.003071.003.57.01071.003.385.01
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
DSP		ICPR82_11w16
Simlock Key Cnt	0
Simlock FBUS Cnt	0
NCK[7] - ACCEPTED
MCU Date	19-05-11
IMEI		3579200465
PSN		30DF032AA
Module Code	0204474
LPSN		0
APE SW		071.003
APE Test		v0.034
APE HW		256
APE ADSP	256
RETU		35
TAHVO		00
AHNE		11
HW		3107
DSP		ICPR82_11w16
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock NCK	#pw+9wZi35738304136+7#
Old 05-24-2012, 21:26   #2663 (permalink)
Member: 288521
Thanks Meter: 685
BB5 Unlock Started...
MCU Version	V 05.50
MCU Date	14-08-07
Product		RM-217 (Nokia 6300)
Manufacturer	(c) Nokia.
IMEI		352042026783833
Mastercode	010715563
Simlock Server	SIMLOCK SERVER VERSION 63
Simlock Key	2340000100000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 23430F
Simlock [1,2]	State: CLOSED	Type: GID	Data: 2800
Security block OK and saved to "RM-217_352042026783833_24052012_212140.SecurityBlock.PM"
WARNING: "20E00119975D6F56C0CF3EE7B0CED665E82A0F27.B0000AF0" Not Exists, Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:		00000232
CMT_EM_ASIC_ID:		00000353
CMT_PUBLIC_ID:		20E00119975D6F56C0CF3EE7B0CED665E82A0F27
CMT_ROOT_KEY_HASH:	BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC:	191EC665
CMT Ready!
Old Loader Detected
Readed OK, Saving to "20E00119975D6F56C0CF3EE7B0CED665E82A0F27.B0000AF0"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (new method)
#pw+093695282017871+1#
#pw+519561969218953+2#
#pw+226517579892480+3#
#pw+256226389981506+4#
#pw+793724235152745+5#
#pw+936869080474757+6#
#pw+410697696143178+7#
Sending NCK Codes..
NCK[1] - ACCEPTED
NCK[2] - ACCEPTED
NCK[3] - Not locked on given lock level
NCK[4] - Not locked on given lock level
NCK[5] - Unlocked Already
NCK[6] - Unlocked Already
NCK[7] - Unlocked Already
MCU Version	V 05.50
MCU Date	14-08-07
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 23430F
Simlock [1,2]	State: OPENED	Type: GID	Data: 2800
Unlock finished! Time taken 12.313s
Last edited by ptt; 05-24-2012 at 21:59. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-25-2012, 14:31   #2664 (permalink)
Azhar Nazeer's Avatar
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Some saves successful operation
[Nokia C3-00 USB Phonet]: Port opened OK!
MCU Version	V 07.20
MCU Date	29-10-10
Product		RM-614 (Nokia C3-00)
IMEI		35xxxxxxxxxxxxxxxxxxx
Mastercode	20212603
IMEI Spare	3A55530644511004
IMEI SV		3355530644511024F3000000
PPM		V 07.20, 29-10-10, RM-614, (c) Nokia            , SP
CNT		Content: sp_059D4R9, V 07.20, 29-10-10, RM-614, (c) Nokia
PSN		63BDE83AI
Product Code	059D4R9
Module Code	0204418
Basic Product Code	059D7P0
LPSN		0
WLAN MAC	2CD2E791869E
HW		2008
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 07.20
MCU Date	29-10-10
Mastercode	20212603
PSN		63BDE83AI
Module Code	0204418
LPSN		0
HW		2008
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-614_35xxxxxxxxxxx_462011_60441 PM.SecurityBlock.PM"
WARNING: "0000000000D52E71109E22B9A62159138BB59C2D.C0004A09" Not Exists, Will read it...
Prepare phone failed with message -> USB Loaders are not exploitable!
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
Booting CMT...
Switching to RAW Mode...
[Nokia USB Flashing Generic]: Port opened OK!
New ROM Detected
CMT_SYSTEM_ASIC_ID:	000000000000000022000509200C0000
CMT_EM_ASIC_ID:		00005361
CMT_PUBLIC_ID:		0000000000D52E71109E22B9A62159138BB59C2D
CMT_ROOT_KEY_HASH:	1B0D74C532CA1C6133940C740E8C786E
CMT_BOOT_ROM_CRC:	DE56D582
CMT_SECURE_ROM_CRC:	BDDE7A3A
CMT Ready!
BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.10.48.1, Algo: BB5
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND
FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported
BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.10.48.1, Algo: XSR 1.6
TurboCache Loaded!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Waiting for FUR Client become avaiable...
FUR Avaiable!
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Version	V 07.20
MCU Date	29-10-10
IMEI		35xxxxxxxxxxxxxxxxxxxxxxx
Mastercode	20212603
Simlock backup OK, saved to RM-614_35xxxxxxxxxxxx_462011_60500 PM.SLBackup.PM
Processing rm614__07.20.mcusw (CMT)...
Booting CMT...
New ROM Detected
CMT Ready!
rm614__07.20.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND
EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x012FFFFF, ONENAND
EraseArea[0,CMT]: 0x01300000-0x01DFFFFF, ONENAND
EraseArea[0,CMT]: 0x02600000-0x029FFFFF, ONENAND
Erase taken 0.375s
TurboCache Loaded!
Writing CMT MCUSW1 Certificate...
Writing CMT GENIO_INIT Certificate...
All blocks written OK! Time taken 6.844s
Flashing Speed: 34183.57 kBit/S
Processing rm614__07.20.mcusw (APE)...
Processing rm614__07.20.ppm_c1 (CMT)...
rm614__07.20.ppm_c1, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x01E00000-0x025FFFFF, ONENAND
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 1.125s
Flashing Speed: 44646.83 kBit/S
Processing rm614__07.20.ppm_c1 (APE)...
Processing rm614__07.20.image_c1_0593935 (CMT)...
rm614__07.20.image_c1_0593935, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x02A00000-0x0753FFFF, ONENAND
Erase taken 1.93s
TurboCache Loaded!
All blocks written OK! Time taken 2.719s
Flashing Speed: 40654.01 kBit/S
Processing rm614__07.20.image_c1_0593935 (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version	V 07.20
MCU Date	29-10-10
Mastercode	20212603
PPM		V 07.20, 29-10-10, RM-614, (c) Nokia            , C1
CNT		Content: c1_0593935, V 07.20, 29-10-10, RM-614, (c) Nokia
PSN		63BDE83AI
Module Code	0204418
LPSN		0
HW		2008
RFIC		9
LCD		SEIKO
BT		4217-v529
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Last edited by ptt; 05-25-2012 at 23:51. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-25-2012, 14:32   #2665 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Processing D:\PHONIEX\Products\...
Found 166 products, Filtering BB5 Products - wait...
31 Products left after filtering. Ready.
Can't add RM576_0589613_033.014_001_signature.bin, Bad image
Retrieving Variants for Product RM-576 - wait...
98 Variants Retrieved
Backing up RPL...
Sending User Abort Signal...
Phone not detected at USB -> User Abort
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000030000022600010007600C192102011104
CMT_EM_ASIC_ID:		00000C35
CMT_EM_ASIC_ID:		00000C30
CMT_PUBLIC_ID:		0930020AA6730344F5B19DE4364CD4F3BF340293
CMT_ROOT_KEY_HASH:	25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC:	3E273BF6
CMT_SECURE_ROM_CRC:	37BE26FA
CMT Ready!
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
FlashChip[0,CMT]: 0x0098004000000031, Toshiba, ONENAND
FlashChip 0x00980040 (Toshiba), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.48.1, Algo: XSR 1.6
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: B1302F79239A2431E816565B36374B1F676A23AC
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Simlock backup problem -> Phone not detected
Processing rm576_033.014_prd.core.fpsx (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
rm576_033.014_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0B53FFFF, ONENAND
Erase taken 2.719s
TurboCache Loaded!
Writing CMT SOS+PMML Certificate...
Writing CMT LDSP Certificate...
All blocks written OK! Time taken 18.187s
Flashing Speed: 38627.98 kBit/S
Processing rm576_033.014_prd.core.fpsx (APE)...
Processing rm576_033.014_30.01_MEA_C_x3_prd.rofs2.fpsx (CMT)...
rm576_033.014_30.01_MEA_C_x3_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x07800000-0x0A73FFFF, ONENAND
Erase taken 0.328s
TurboCache Loaded!
All blocks written OK! Time taken 7.203s
Flashing Speed: 40291.83 kBit/S
Processing rm576_033.014_30.01_MEA_C_x3_prd.rofs2.fpsx (APE)...
Processing rm576_033.014_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
rm576_033.014_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0A740000-0x0B53FFFF, ONENAND
Erase taken 0.94s
TurboCache Loaded!
All blocks written OK! Time taken 0.78s
Flashing Speed: 833.85 kBit/S
Processing rm576_033.014_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm576_033.014_URawAluminium005.000_prd.uda.fpsx (CMT)...
rm576_033.014_URawAluminium005.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0B540000-0x0F63FFFF, ONENAND
Erase taken 1.234s
TurboCache Loaded!
All blocks written OK! Time taken 1.140s
Flashing Speed: 28977.56 kBit/S
Processing rm576_033.014_URawAluminium005.000_prd.uda.fpsx (APE)...
Processing RM576_ENO_10w21v0.A28.fpsx (CMT)...
RM576_ENO_10w21v0.A28.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND
Erase taken 0.94s
TurboCache Loaded!
All blocks written OK! Time taken 0.531s
Flashing Speed: 36009.42 kBit/S
Processing RM576_ENO_10w21v0.A28.fpsx (APE)...
Restarting MCU...
Last edited by ptt; 05-25-2012 at 23:50. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-25-2012, 14:33   #2666 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Retrieving Variants for Product RM-540 - wait...
Backing up RPL...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000010000022600000001020C192102054100
CMT_EM_ASIC_ID:		00001040
CMT_EM_ASIC_ID:		00001030
CMT_PUBLIC_ID:		1D5001141623544049ADA9D40F4EEDB1BABCA37D
CMT_ROOT_KEY_HASH:	7B045400E1752022F9EB80B0DEA9C65D
CMT_BOOT_ROM_CRC:	67E82268
CMT_SECURE_ROM_CRC:	F29CEA60
CMT Ready!
RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5
ROM Ret: 0x0005317F
RAP3Gv40_XSR17_alg.fg, Type: Algorithm, Rev: 768.10.48.1, Algo: XSR 1.6
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Processing rm540__08.54.mcusw (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
rm540__08.54.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
ROM Ret: 0x0005317F
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00060000-0x0009FFFF, ONENAND
EraseArea[0,CMT]: 0x000A0000-0x0025FFFF, ONENAND
EraseArea[0,CMT]: 0x003E0000-0x005DFFFF, ONENAND
EraseArea[0,CMT]: 0x005E0000-0x010DFFFF, ONENAND
EraseArea[0,CMT]: 0x01EC0000-0x01EDFFFF, ONENAND
EraseArea[0,CMT]: 0x027C0000-0x02CBFFFF, ONENAND
EraseArea[0,CMT]: 0x077C0000-0x07B3FFFF, ONENAND
EraseArea[0,CMT]: 0x010E0000-0x01EBFFFF, ONENAND
Erase taken 0.500s
TurboCache Loaded!
All blocks written OK! Time taken 54.344s
Flashing Speed: 4029.05 kBit/S
Processing rm540__08.54.mcusw (APE)...
Processing rm540__08.54.ppm_meaa (CMT)...
rm540__08.54.ppm_meaa, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x01EE0000-0x027BFFFF, ONENAND
Erase taken 0.78s
TurboCache Loaded!
All blocks written OK! Time taken 11.0s
Flashing Speed: 4089.81 kBit/S
Processing rm540__08.54.ppm_meaa (APE)...
Processing rm540__08.54.image_meaa_0583926_006 (CMT)...
rm540__08.54.image_meaa_0583926_006, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x02CC0000-0x077BFFFF, ONENAND
Erase taken 1.125s
TurboCache Loaded!
All blocks written OK! Time taken 29.344s
Flashing Speed: 4030.75 kBit/S
Processing rm540__08.54.image_meaa_0583926_006 (APE)...
Restarting MCU...
[Nokia X3 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version	V 08.54
MCU Date	25-10-10
Product		RM-540 (Nokia X3)
IMEI		354865046694392
Mastercode	414244240
IMEI Spare	3A45680564963409
IMEI SV		3345680564963459F8000000
PPM		V 08.54, 25-10-10, RM-540, (c) Nokia            , MEA
CNT		Content: meaa_0583926, V 08.54, 25-10-10, RM-540, (c) Nokia
PSN		CAQ629371
Product Code	0584330
Module Code	0204201
Basic Product Code	0575592
LPSN		0
RETU		40
TAHVO		00
AHNE		41
HW		5003
RFIC		0831
DSP		ICPR91_10w11_2
LCD		SEIKO
BT		1673-46038
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 05-25-2012, 14:34   #2667 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: E00DA77BF32983F864BC7671FE7709A29D8E2C08
Restarting MCU...
COD File Seems to be Valid, Sending to Server...
Connecting to Cyclone Server...
Cyclone Server (1.0.0.656), Cyclone Box Team 2008-2011 - Ready. Happy Eid Milad un Nabi
COD File Accepted, use now Direct Unlock to receive Valid Code...
MCU Version	V ICPR72_09w46.5
MCU Date	22-02-10
Product		RM-559 (Nokia X6)
IMEI		354316046495455
Mastercode	764376374
Simlock Key	4500000088401881
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ E000	Data: 450FFF
Checking job status...
Code Ready, Code: #pw+222693266940454+7#
Sending code via FBUS...
NCK[7] - ACCEPTED
Code Accepted! Unlocking Finished
Old 05-25-2012, 14:35   #2668 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-304_352064020937_11042011_171901.SecurityBlock.PM"
WARNING: "20300110997A0254A8409DAB6C9F4B8A9387D0DE.C0001FF6" Not Exists, Will read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101013000
CMT_PUBLIC_ID:		20300110997A0254A8409DAB6C9F4B8A9387D0DE
CMT Ready!
Old Loader Detected
Readed OK, Saving to "20300110997A0254A8409DAB6C9F4B8A9387D0DE.C0001FF6"
Storing CMLA Key...
Booting CMT...
CMT Ready!
FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR
FlashChip 0x00EC220C (Samsung), Size: 64MBytes, VPP: 9V
Box VPP disabled
PAPUBKEYS Hash for CMT: 3E96DE4212587183E5E16BB2C79692A53C19875D
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Version	V 03.63
MCU Date	24-10-07
Product		RM-304 (Nokia 5310 XpressMusic)
IMEI		352064020937
Mastercode	1755364675
Simlock backup OK, saved to RM-304_352064020937_11042011_171957.SLBackup.PM
Processing rm304__08.22.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm304__08.22.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x00140000-0x010DFFFF, NOR
EraseArea[0,CMT]: 0x010E0000-0x0121FFFF, NOR
Erase taken 45.860s
TurboCache Loaded!
All blocks written OK! Time taken 167.515s
Flashing Speed: 854,00 kBit/S
Restarting MCU...
Processing rm304__08.22.mcusw (APE)...
Processing rm304__08.22.ppm_ntm (CMT)...
Booting CMT...
CMT Ready!
rm304__08.22.ppm_ntm, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01220000-0x0189FFFF, NOR
Erase taken 12.860s
TurboCache Loaded!
All blocks written OK! Time taken 36.922s
Flashing Speed: 1113,72 kBit/S
Restarting MCU...
Processing rm304__08.22.ppm_ntm (APE)...
Processing rm304__08.22_ISM_003.image_304_tmobusa_seed_purple_v4 (CMT)...
Booting CMT...
CMT Ready!
rm304__08.22_ISM_003.image_304_tmobusa_seed_purple_v4, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x018A0000-0x01B1FFFF, NOR
EraseArea[0,CMT]: 0x01B20000-0x03FBFFFF, NOR
Erase taken 105.703s
TurboCache Loaded!
All blocks written OK! Time taken 83.375s
Flashing Speed: 1208,77 kBit/S
Restarting MCU...
Processing rm304__08.22_ISM_003.image_304_tmobusa_seed_purple_v4 (APE)...
Reading info...
MCU Version	V 08.22
MCU Date	04-11-08
IMEI		352064020937
IMEI Spare	3A25600402393700
IMEI SV		3325600402393750F7000000
PPM		V 08.22, 04-11-08, RM-303, (c) Nokia            , NTM
CNT		Content: 304_tmobusa_seed_purple_v4 17-Nov-08, V 08.22, 04-11-08, RM-303, (c) Nokia            , ,
PSN		GAI441611
Product Code	0561403
Module Code	0203415
Basic Product Code	0544851
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		5501
RFIC		064c0609
DSP		ICPR71_08w22
LCD		SHARP
BT		2222-143
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Old 05-25-2012, 14:35   #2669 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Backing up RPL...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Booting CMT...
CMT Ready!
Old Loader Detected
Storing CMLA Key...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
MCU Version	V 03.63
MCU Date	24-10-07
IMEI		352064020937
Booting CMT...
CMT Ready!
Box VPP disabled
Certificates OK
Erase taken 45.860s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 12.860s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
TurboCache Loaded!
Restarting MCU...
Reading info...
MCU Version	V 08.22
MCU Date	04-11-08
IMEI		352064020937
PSN		GAI441611
Module Code	0203415
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		5501
RFIC		064c0609
DSP		ICPR71_08w22
LCD		SHARP
BT		2222-143
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Last edited by ptt; 05-25-2012 at 23:53. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-25-2012, 14:36   #2670 (permalink)
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
MCU Version	V 5.03
MCU Date	04-21-06
Product		RH-92 (Nokia 1112b CABLE 1100)
Manufacturer	(c) NMP
IMEI		011087008388
Mastercode	12767423
IMEI Spare	0A11800780831804
IMEI SV		0311800780831804F4000000
PPM		V 5.03, 04-21-06, RH-92, (c) NMP, UB
PSN		RCK720976
Product Code	0536343
Module Code	0203168
Basic Product Code	0532664
PSD		0000001800000000
HW		0529
UEM		1328
UPP		2201
RFIC		0500
DSP		P05w06.v34
LCD		WINTK:SYRS00
ADSP Sw		p1V 5.03\n04-21-06\nRH-92\n(c) NMP\nN1112b\nub_lta
Asic		2
HW Signature	89549E3A398B6536
Simlock Server
Simlock Key	7223400000000000
Simlock Profile	0000000000010002
Simlock Aux	00025927
Simlock IMEI	00000110870083881400
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 72234F
MCU Version	V 5.03
MCU Date	04-21-06
IMEI		011087008388
Mastercode	12767423
Local mode Set
Asic		2
Simlock Server
Simlock Aux	00020000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Signed OK (5CA97987D3B0E4CC339A2CB957A7B8B832ADD58E)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-25-2012 at 23:54. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.65119 seconds with 10 queries
