05-26-2012, 12:52 | #2671 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 40
Member: 288521 Status: Offline Thanks Meter: 685 | Code: Reading SL3 LOG File... [Nokia E7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_11w42.5 MCU Date 25-11-11 Product RM-626 (Nokia E7-00) Manufacturer (c) Nokia IMEI 354864047768370 Mastercode 3367653430 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found WARNING: "12C00209C4D70344E420B9E945E811C1C0ACD288.B0000AF0" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... [Nokia E7-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 12C00209C4D70344E420B9E945E811C1C0ACD288 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! New_RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020006800000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020006800000031, ST, ONENAND Sending Auxiliary Loader... Auxiliary Loader Sent! Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... If phone doesn't powering into Local Mode now for some reason do following: 1. Re-insert battery 2. Power it on, when asked use Ovi/Pc Suite Mode Readed OK, Saving to "12C00209C4D70344E420B9E945E811C1C0ACD288.B0000AF0" Success! Last edited by ptt; 05-26-2012 at 13:31. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
05-26-2012, 13:35 | #2672 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 764 | E 71 Flashing done. Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:02:27, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0000xxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 4.96v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.98v PASSED VBAT Voltage 4.98v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.333GB Avaiable Virtual Memory: 1.488GB Avaiable Pagefile: 3.9GB Initializing FBUS... All initialized - Ready to work Failed to read info -> Phone not detected Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Retrieving Variants for Product RM-346 - wait... 90 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-346_354856040767250_5262012_100640 AM.SecurityBlock.PM" WARNING: "19D0010DD7A400521A819A964758777F70A70E2C.B0000474" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... Readed OK, Saving to "19D0010DD7A400521A819A964758777F70A70E2C.B0000474" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm346_510.21.009_prd.c00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm346_510.21.009_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.625s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... Programming Status OK! All blocks written OK! Time taken 86.906s Flashing Speed: 6547.16 kBit/S Restarting MCU... Processing rm346_510.21.009_prd.c00 (APE)... Processing rm346_510.21.009_prd.v20 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm346_510.21.009_prd.v20, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.219s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 32.0s Flashing Speed: 6349.05 kBit/S Restarting MCU... Processing rm346_510.21.009_prd.v20 (APE)... Processing rm346_510.21.009.09U (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm346_510.21.009.09U, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 Flashbus Write baud set to 5.0Mbits Started group flash erase Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.31s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 23.94s Flashing Speed: 6317.58 kBit/S Restarting MCU... Processing rm346_510.21.009.09U (APE)... Processing RM346_ENO_0741.10_08wk42.a36.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19D0010DD7A400521A819A964758777F70A70E2C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM346_ENO_0741.10_08wk42.a36.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase Erase Certificate: SOS*ENO (CMT) Waiting 320s for erasure finish... Erase taken 0.31s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 2.94s Flashing Speed: 6122.25 kBit/S Restarting MCU... Processing RM346_ENO_0741.10_08wk42.a36.fpsx (APE)... Processing leevi_erase_y_drive.fpsx (CMT)... Processing leevi_erase_y_drive.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V ICPR71_09w47.10 MCU Date 20-01-11 Product RM-346 (Nokia E71) Manufacturer (c) Nokia IMEI 354856040767250 Mastercode 304377063 IMEI Spare 3A45580604672705 IMEI SV 3345580604672765F4000000 PSN MQM316883 Product Code 059B205 Basic Product Code 0552256 PSD 0000000000000000 LPSN 0 WLAN MAC 2CD2E7A40485 RETU 16 TAHVO 22 AHNE 11 HW 0915 RFIC 17141716 DSP ICPR71_09w40 LCD 510.21.009j 510.21.009510.21.009_v20n256 ADSP Sw 510.21.009j 510.21.009510.21.009_v20kRM346ENO74110842.a36n256 ADSP DevID 510.21.009510.21.009_v20kRM346ENO74110842.a36 ADSP RevID 510.21.009510.21.009_v20kRM346ENO74110842.a36¥0)510.21.009, 19-03-2011, RM-346, (c)Nokia , AEM )510.21.009, 19-03-2011, RM-346, (c)Nokia , Flip MCUSW )510.21.009, 19-03-2011, RM-346, (c)Nokia , Simlock Server SIMLOCK SERVER Simlock Key 5050200000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 50502F Simlock NCK #pw+7YuX64344901599+7# Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
05-26-2012, 14:25 | #2673 (permalink) |
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 764 | N73 Flashing done. Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:02:27, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B000xxxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.81v PASSED VBAT Voltage 4.93v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.268GB Avaiable Virtual Memory: 1.488GB Avaiable Pagefile: 2.962GB Initializing FBUS... All initialized - Ready to work Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Reading Security Block... Security block OK and saved to "RM-133_353640011391949_5262012_41632 PM.SecurityBlock.PM" WARNING: "1C3002053D9C0154897ED741F8C4AACB1F4F952C.B0000474" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "1C3002053D9C0154897ED741F8C4AACB1F4F952C.B0000474" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Storing NPC... CMT CCC Not Found CMT HWC Not Found Storing VARIANT... CMT PARTNERC Not Found Processing APE Part... Storing Product Code... Storing PSN... Storing HWID... APE NPC Not Found APE CCC Not Found APE HWC Not Found APE VARIANT Not Found APE PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x00731951, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x001E0000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR Waiting 320s for erasure finish... Erase taken 38.547s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT ADL Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 31.843s Flashing Speed: 12906.91 kBit/S Restarting MCU... Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND EraseArea[0,APE]: 0x00080000-0x000FFFFF, NAND EraseArea[0,APE]: 0x00100000-0x0025FFFF, NAND EraseArea[0,APE]: 0x003C0000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 1.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS*UPDAPP Certificate... Writing APE SOS+UZIP Certificate... Writing APE PAPUBKEYS Certificate... Writing APE PASUBTOC Certificate... Writing APE ADL Certificate... Writing APE SOS+XZIP Certificate... Writing APE SOS*CORE Certificate... Writing APE SOS+ROFS Certificate... Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 63.953s Flashing Speed: 6426.51 kBit/S Restarting MCU... Processing N73_rofx_4.0839.42.2.1_PRD.V08 (CMT)... Processing N73_rofx_4.0839.42.2.1_PRD.V08 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_rofx_4.0839.42.2.1_PRD.V08, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x03920000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.297s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 32.235s Flashing Speed: 3824.30 kBit/S Restarting MCU... Processing N73_userarea_4.0839.42.2.1.U02 (CMT)... Processing N73_userarea_4.0839.42.2.1.U02 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 9FE7129B8A6B80EAC5C34D0471DFFC94C640EDB2 APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 1C3002053D9C0154897ED741F8C4AACB1F4F952C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! N73_userarea_4.0839.42.2.1.U02, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,APE]: 0x04E20000-0x07C9FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.656s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 11.547s Flashing Speed: 5364.65 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 05wk47v61.1 MCU Date 09-07-08 Product RM-133 (Nokia N73) Manufacturer (c) Nokia. IMEI 353640011391949 Mastercode 5155126167 IMEI Spare 3A35460011939104 IMEI SV 3335460011939174F8000000 PSN SAM051496 Product Code 0529785 Module Code 0202855 Basic Product Code 0527006 PSD 0000002200000000 RETU 15 TAHVO 21 AHNE 30 HW 6019 RFIC 17191719 DSP scarfe_mc.05wk46v50p2 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
05-28-2012, 08:50 | #2674 (permalink) |
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 764 | 2630 Flashing done. Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:02:27, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0000xxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.01v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.22v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1012.140MB Avaiable Virtual Memory: 1.488GB Avaiable Pagefile: 2.761GB Initializing FBUS... All initialized - Ready to work MCU Version V 06.82 MCU Date 26-09-08 Product RM-298 (Nokia 2630 (Asia/Europe) CABLE 2630) Manufacturer (c) Nokia IMEI 359342021530152 Mastercode 3530505421 IMEI Spare 3A95430212351005 IMEI SV 3395430212351045F5000000 PPM V 06.82, 26-09-08, RM-298, (c) Nokia, IC CNT Content: ic, V 06.82, 26-09-08, RM-298, (c) Nokia, PSN DPL750278 Product Code 0549361 Module Code 0203409 Basic Product Code 0544206 PSD 0000000D00000000 LPSN 0 HW 1006 UEM 1328 UPP 3162 RFIC 0500 DSP ICPR62_08w27_U LCD SUEZ BT 2222-v101 Asic 11 HW Signature E6FDE57B8CE55A7E Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553593420215301500 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... Product Code: 0549361 Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 116 products, Filtering DCT4 Products - wait... 18 Products left after filtering. Ready. This is Valid DCT4 Product Retrieving Variants for Product RM-298 - wait... 332 Variants Retrieved Variant found for readen Product Data! Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm298__06.82.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 8408CBDFEAEE2DE4AB4D328E46 MSID-Plain: 2C40BAE9005757CCA9000000 FAID-Crypted: AD5690558E5C2C8DCF676FD8 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01C3FFFF] Erase taken 117.375s Writing 343 blocks... All blocks written OK! Time taken 64.515s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm298__06.82.image_ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 84AD13DFB373A272CB8910702E MSID-Plain: D26EBAF1005757CCAA000610 FAID-Crypted: A760EDEF36D4E2F4DF6C677F Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02000000-0x02DBFFFF] Erasing NOR Region [0x02DC0000-0x02F9FFFF] Erase taken 147.766s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 200 blocks... All blocks written OK! Time taken 19.140s Terminating flash session Extracting Content Package... CP Extract Failed -> CP Server not exists WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3162 [HW_UNKNOWN] rm298__06.82.ppm_ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 845044F6ACC32101ECBBEF3489 MSID-Plain: 3E4EBAE9005757CCA9000000 FAID-Crypted: 8CEF41BA07A397F20A795DEC Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01C40000-0x01FFFFFF] Erase taken 36.328s Writing 84 blocks... All blocks written OK! Time taken 15.531s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
05-28-2012, 12:30 | #2675 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Valencia, Spain
Member: 1655929 Status: Offline Sonork: arafay67 Thanks Meter: 2 | Successfully Flashed C7 with usb Code: Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... [Nokia C7-00 USB Phonet]: Port opened OK! Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-675_356252043328977_28052012_122400.SecurityBlock.PM" "141000057BD40344A1CF3A2502E2BE4467C37746.C0004B4D" Exists, That is good... Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 141000057BD40344A1CF3A2502E2BE4467C37746 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: Single Line 8Bit Prepare phone failed with message -> Not found required CMT Secondary Loader Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Backing up simlock... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 92PS1_10w36.3 MCU Date 27-09-10 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 356252043328977 Mastercode 213316351 Simlock backup OK, saved to RM-675_356252043328977_28052012_122615.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-675_012.004_79.92_prd.core.fpsx (CMT)... Booting CMT... [Nokia C7-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 141000057BD40344A1CF3A2502E2BE4467C37746 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_012.004_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 20.344s Flashing Speed: 52289,15 kBit/S Processing RM-675_012.004_79.92_prd.core.fpsx (APE)... Processing RM-675_012.004_01.01_Euro1_79.92_prd.rofs2.fpsx (CMT)... RM-675_012.004_01.01_Euro1_79.92_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.250s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 5.0s Flashing Speed: 68100,60 kBit/S Processing RM-675_012.004_01.01_Euro1_79.92_prd.rofs2.fpsx (APE)... Processing RM-675_012.004_00.01_79.92_prd.rofs3.fpsx (CMT)... RM-675_012.004_00.01_79.92_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.297s Flashing Speed: 132,42 kBit/S Processing RM-675_012.004_00.01_79.92_prd.rofs3.fpsx (APE)... Processing RM-675_012.004_U01.01_79.92_prd.uda.fpsx (CMT)... RM-675_012.004_U01.01_79.92_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Started group flash erase EraseArea[0,CMT]: 0x0E980000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 2.109s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 12.266s Flashing Speed: 52996,87 kBit/S Processing RM-675_012.004_U01.01_79.92_prd.uda.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C7-00 USB Phonet]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. Phone not detected at USB -> Timeout, no any compatible USB device detected. [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! [Nokia C7-00 USB Phonet]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. Phone not detected at USB -> Timeout, no any compatible USB device detected. Phone not detected at USB -> Timeout, no any compatible USB device detected. Factory defaults OK Reading info... [Nokia C7-00 USB Phonet]: Port opened OK! MCU Version V 92PS1_10w36.3 MCU Date 27-09-10 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 356---------- Mastercode 213316351 IMEI Spare 3A65----------- IMEI SV 3365520----------------- PPM 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 PSN 148D415AA Product Code 059D0B0 Module Code 0204505 Basic Product Code 0591401 PSD 0000000000000000 LPSN 0 WLAN MAC D45D42A62C4B APE SW 012.004 APE Variant 012.004.00.01012.004.01.01012.004.00.01 APE Test rm675_ENO_v_0.0414 APE HW 256 APE ADSP 256 APE BT HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928. RETU 40 TAHVO 00 AHNE 11 HW 6027o256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 PCI o256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 UEM 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 UPP 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 RFIC |Alli_4.3.4 DSP TB92PS1_10w36 LCD 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 BT 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 ADSP Sw 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 ADSP DevID 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 ADSP RevID 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 AEM 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 Flip MCUSW 256qLGHCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 1928.n256i012.004j,(012.004.00.01012.004.01.01012.004.00.01u!Žkrm675_ENO_v_0.0414¥012.004.U01.01 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21401F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21401F Simlock NCK #pw+;“3E53935719952+7# Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 05-28-2012 at 13:27. Reason: MOVE TO THE RIGHT THREAD -- ADD [CODE] [/CODE] TAG TO THE LOG |
05-29-2012, 07:25 | #2676 (permalink) |
No Life Poster Join Date: Aug 2010
Member: 1361078 Status: Offline Thanks Meter: 49 | succesfully flash x2 today i succesfully flash x2 just in 20 sec cyclon is the most powerful and best box of the world for nokia here is log Code: Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 00000000001C17C53A08F55D4E8FA49ECFE5252A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 APE Boot skipped on user request Restarting MCU... [Nokia X2-00 USB Phonet]: Port opened OK! Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 34 products, Filtering BB5 Products - wait... 6 Products left after filtering. Ready. Retrieving Variants for Product RM-618 - wait... 1 Variants Retrieved Booting CMT... [Nokia X2-00 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 00000000001C17C53A08F55D4E8FA49ECFE5252A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 APE Boot skipped on user request Restarting MCU... Phone not detected at USB -> Timeout, no any compatible USB device detected. Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 00000000001C17C53A08F55D4E8FA49ECFE5252A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm618__08.35.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! New ROM Detected CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000 CMT_EM_ASIC_ID: 00005361 CMT_PUBLIC_ID: 00000000001C17C53A08F55D4E8FA49ECFE5252A CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E CMT_BOOT_ROM_CRC: DE56D582 CMT_SECURE_ROM_CRC: BDDE7A3A CMT Ready! rm618__08.35.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020003000000131, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x011BFFFF, ONENAND EraseArea[0,CMT]: 0x011C0000-0x01CFFFFF, ONENAND EraseArea[0,CMT]: 0x02500000-0x028FFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.328s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT KEYS Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT ADA Certificate... Writing CMT RAP3NAND Certificate... Writing CMT ISA+DYNSW Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT UPDAPP Certificate... Programming Status OK! All blocks written OK! Time taken 6.422s Flashing Speed: 35222.68 kBit/S Processing rm618__08.35.mcusw (APE)... Processing rm618__08.35.ppm_c (CMT)... rm618__08.35.ppm_c, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x01D00000-0x024FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 1.391s Flashing Speed: 37387.35 kBit/S Processing rm618__08.35.ppm_c (APE)... Processing rm618__08.35.image_c_0595124 (CMT)... rm618__08.35.image_c_0595124, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: E9700989029D9E899915F781B1582048E042A738 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02900000-0x0753FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.15s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 4.360s Flashing Speed: 35869.05 kBit/S Processing rm618__08.35.image_c_0595124 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia X2-00 USB Phonet]: Port opened OK! [Nokia X2-00 USB Phonet]: Port opened OK! [Nokia X2-00 USB Phonet]: Port opened OK! [Nokia X2-00 USB Phonet]: Port opened OK! [Nokia X2-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.35 MCU Date 09-01-12 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 351657052404144 Mastercode 3761464054 IMEI Spare 3A15560725041404 IMEI SV 3315560725041444F1000000 PPM V 08.35, 09-01-12, RM-618, (c) Nokia , C CNT Content: c_0595124, V 08.35, 09-01-12, RM-618, (c) Nokia PSN CWF683370 Product Code 0595152 Module Code 0204519 Basic Product Code 0591975 PSD 0000000000000000 LPSN 0 HW 6001 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 05-29-2012 at 11:45. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
05-29-2012, 09:43 | #2677 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 40
Member: 288521 Status: Offline Thanks Meter: 685 | Code: Reading SL3 LOG File... [Nokia C2-01 USB Phonet]: Port opened OK! MCU Version V 10.50 MCU Date 07-01-11 Product RM-721 (Nokia C2-01) Manufacturer (c) Nokia IMEI 358650040115180 Mastercode 4117702324 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found "271003165EFC5E40C6FB4A4AFE0FF0A340C1EA3F.B0000AF0" Exists, That is good... Success! Reading SL3 LOG File... [Nokia C2-01 USB Phonet]: Port opened OK! MCU Version V 10.50 MCU Date 07-01-11 Product RM-721 (Nokia C2-01) Manufacturer (c) Nokia IMEI 358650040115180 Mastercode 4117702324 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found "271003165EFC5E40C6FB4A4AFE0FF0A340C1EA3F.B0000AF0" Exists, That is good... Success! Last edited by ptt; 05-29-2012 at 11:45. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
05-30-2012, 14:05 | #2678 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 931 | nokia 3120c user code reset in 2 seconds Last edited by ptt; 05-31-2012 at 00:01. Reason: REMOVE [IMG] TAG - YOU CAN POST TXT LOG AS ALL OTHERS DO |
05-30-2012, 18:30 | #2679 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 397 | nokia 6280 flashed and unlock this is my first nokia with cyclone box Code: MCU Version V 03.60 MCU Date 10-02-06 Product RM-78 (Nokia 6280/6288) Manufacturer (c) Nokia IMEI 35186101xxxxxxx Mastercode 453454055 IMEI Spare 3A15680101063905 IMEI SV 3315680101063905F3000000 PPM V 03.60, 13-02-06, RM-78, (c) Nokia, CVF CNT Content: vg_uk2, V 03.60, 13-02-06, RM-78, (c) Nokia, PSN CKI333873 Product Code 0531657 Basic Product Code 0520041 PSD 0000001F00000000 RETU 32 TAHVO 52 AHNE 30 HW 2003 RFIC 17191719 DSP pb05w32v23 LCD SHARP Simlock Server SIMLOCK SERVER VERSION 62 Simlock Key 2341500000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23415F Auto Selecting Flash Files on User Request... Product Code: 0531657 This is Valid BB5 Product Retrieving Variants for Product RM-78 - wait... 897 Variants Retrieved Variant found for readen Product Data! Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Ok CMT HWC Not Found CMT CCC Not Found CMT R&D Ok CMT PARTNERC Not Found CMT VARIANT Ok CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Reading Security Block... Security block OK and saved to "RM-78_35186101xxxxxxx_30052012_181401.SecurityBlock.PM" WARNING: "1750020420940054F549F395101FF2BB6CAC476D.B0001135" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "1750020420940054F549F395101FF2BB6CAC476D.B0001135" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... CMT CCC Not Found CMT HWC Not Found Storing VARIANT... CMT PARTNERC Not Found Restarting MCU... RPL Saved OK Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Reading Security Block... Security block OK and saved to "RM-78_35186101xxxxxxx_30052012_181548.SecurityBlock.PM" "1750020420940054F549F395101FF2BB6CAC476D.B0001135" Exists, That is good... Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... CMT CCC Not Found CMT HWC Not Found Storing VARIANT... CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V 03.60 MCU Date 10-02-06 Product RM-78 (Nokia 6280/6288) Manufacturer (c) Nokia IMEI 35186101xxxxxxx Mastercode 453454055 Simlock backup OK, saved to RM-78_35186101xxxxxxx_30052012_181603.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm7830006.430.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm7830006.430.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000202BF, NOR EraseArea[0,CMT]: 0x00020300-0x000252FF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0037FFFF, NOR EraseArea[0,CMT]: 0x00380000-0x011DDFFF, NOR EraseArea[0,CMT]: 0x011DE000-0x011DEFFF, NOR EraseArea[0,CMT]: 0x011DF000-0x011DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR Waiting 320s for erasure finish... Erase taken 77.111s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 80.59s Flashing Speed: 1670.44 kBit/S Restarting MCU... Processing rm7830006.430.mcusw (APE)... Processing rm783006.43.ppm_cvf (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm783006.43.ppm_cvf, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x011E0000-0x016DFFFF, NOR Waiting 320s for erasure finish... Erase taken 21.918s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 20.264s Flashing Speed: 1655.15 kBit/S Restarting MCU... Processing rm783006.43.ppm_cvf (APE)... Processing rm7830006.43.image_vg_uk3 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1750020420940054F549F395101FF2BB6CAC476D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm7830006.43.image_vg_uk3, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001002F00000121, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001002F (AMD), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x016E0000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 46.550s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 13.697s Flashing Speed: 1801.23 kBit/S Restarting MCU... Processing rm7830006.43.image_vg_uk3 (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 06.43 MCU Date 30-03-07 Product RM-78 (Nokia 6280/6288) Manufacturer (c) Nokia IMEI 35186101xxxxxxx Mastercode 453454055 IMEI Spare 3A15680101063905 IMEI SV 3315680101063915F8000000 PPM V 06.43, 30-03-07, RM-78, (c) Nokia, CVF PSN CKI333873 Product Code 0531657 Basic Product Code 0520041 PSD 0000001F00000000 RETU 32 TAHVO 52 AHNE 30 HW 2003 RFIC 17191719 DSP pb05w46v49 LCD SHARP Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2341500000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23415F Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! BB5 Unlock Started... MCU Version V 06.43 MCU Date 30-03-07 Product RM-78 (Nokia 6280/6288) Manufacturer (c) Nokia IMEI 35186101xxxxxxx Mastercode 453454055 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2341500000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23415F Reading Security Block... Security block OK and saved to "RM-78_35186101xxxxxxx_30052012_182135.SecurityBlock.PM" "1750020420940054F549F395101FF2BB6CAC476D.B0001135" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+986970993436735+1# #pw+057041811168448+2# #pw+064974814771015+3# #pw+919086710361071+4# #pw+587223314625631+5# #pw+984405929379441+6# #pw+508913943069847+7# Sending NCK Codes.. NCK[1] - ACCEPTED NCK[2] - Not locked on given lock level NCK[3] - Not locked on given lock level NCK[4] - Not locked on given lock level NCK[5] - Unlocked Already NCK[6] - Unlocked Already NCK[7] - Unlocked Already MCU Version V 06.43 MCU Date 30-03-07 Product RM-78 (Nokia 6280/6288) Manufacturer (c) Nokia IMEI 3518610xxxxxxxx Mastercode 453454055 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2341500000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23415F Unlock finished! Time taken 1.794s Last edited by ptt; 05-30-2012 at 23:59. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
05-30-2012, 18:35 | #2680 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Paraguay
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock C3-00 RM-614 Done! Code: [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 359335041 Mastercode 2554774041 IMEI Spare 3A95330514302004 IMEI SV 3395330514302034F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: claro AR SL SKD v2, V 08.63, 25-03-11, RM-614, (c) Nokia PSN CE020E0AI Product Code 059J9P9 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 9CCAD9B2C543 HW 2010 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F Sending BB5 NCK Code... [Nokia C3-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 359335041 Mastercode 2554774041 IMEI Spare 3A95330514302004 IMEI SV 3395330514302034F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: claro AR SL SKD v2, V 08.63, 25-03-11, RM-614, (c) Nokia PSN CE020E0AI Product Code 059J9P9 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 9CCAD9B2C543 HW 2010 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+8T2T13004276674+7# |
05-30-2012, 19:35 | #2681 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Revive X3-02 RM-639 Done! Always Dead RPL Saved... Code: [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 21900107CFDC03446F4F54EB5D9A7AD5D2BF9ABD CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0098003000000131, Toshiba, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00980030 (Toshiba), Size: 128MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C APE Boot skipped on user request Restarting MCU... Phone not detected at USB -> Timeout, no any compatible USB device detected. Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 63 products, Filtering BB5 Products - wait... Retrieving Variants for Product RH-36 - wait... 81 Variants Retrieved Retrieving Variants for Product RH-92 - wait... 37 Variants Retrieved Retrieving Variants for Product RM-167 - wait... 33 Variants Retrieved 50 Products left after filtering. Ready. Retrieving Variants for Product RM-639 - wait... 8 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Phone not detected at USB -> Timeout, no any compatible USB device detected. Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 21900107CFDC03446F4F54EB5D9A7AD5D2BF9ABD CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0098003000000131, Toshiba, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00980030 (Toshiba), Size: 128MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm639__07.16.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm639__07.16.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm639__07.16.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 21900107CFDC03446F4F54EB5D9A7AD5D2BF9ABD CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! rm639__07.16.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0098003000000131, Toshiba, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00980030 (Toshiba), Size: 128MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x0009FFFF, ONENAND EraseArea[0,CMT]: 0x000A0000-0x0041FFFF, ONENAND EraseArea[0,CMT]: 0x00420000-0x0069FFFF, ONENAND EraseArea[0,CMT]: 0x006A0000-0x006DFFFF, ONENAND EraseArea[0,CMT]: 0x006E0000-0x0123FFFF, ONENAND EraseArea[0,CMT]: 0x02060000-0x020BFFFF, ONENAND EraseArea[0,CMT]: 0x02CC0000-0x0333FFFF, ONENAND EraseArea[0,CMT]: 0x07540000-0x07B3FFFF, ONENAND EraseArea[0,CMT]: 0x01240000-0x0205FFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 3.125s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT RAP3NAND Certificate... Writing CMT UPDAPP Certificate... Writing CMT LDSP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT MCUSW1 Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 14.578s Flashing Speed: 17617,96 kBit/S Processing rm639__07.16.mcusw (APE)... Processing rm639__07.16.ppm_l (CMT)... rm639__07.16.ppm_l, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x020C0000-0x02CBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.312s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 3.344s Flashing Speed: 18180,57 kBit/S Processing rm639__07.16.ppm_l (APE)... Processing rm639__07.16.image_l_059B765_009 (CMT)... rm639__07.16.image_l_059B765_009, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x03340000-0x0753FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.687s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 13.829s Flashing Speed: 19649,75 kBit/S Processing rm639__07.16.image_l_059B765_009 (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Reading info... [Nokia X3 Touch and Type USB Phonet]: Port opened OK! MCU Version V 07.16 MCU Date 13-01-12 Product RM-639 (Nokia X3-02) Manufacturer (c) Nokia IMEI 358648047 Mastercode 1711141050 IMEI Spare 3A85460874125003 IMEI SV 3385460874125053F3000000 PPM V 07.16, 13-01-12, RM-639, (c) Nokia , L CNT Content: l_059B765, V 07.16, 13-01-12, RM-639, (c) Nokia PSN C9E939821 Product Code 059D3M4 Module Code 0204600 Basic Product Code 0593642 PSD 0000000000000000 LPSN 0 WLAN MAC 143605634F59 RETU 51 TAHVO 00 AHNE 11 HW 1007 RFIC |Alli_4.3.4 DSP 92_PM2_7.16 LCD TPO BT 4217-v924 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
05-31-2012, 08:41 | #2682 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 764 | E66 Flashing done. Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:02:27, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs Box Serial Number: B0000xxx HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27 Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.34v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.163GB Avaiable Virtual Memory: 1.488GB Avaiable Pagefile: 2.634GB Initializing FBUS... All initialized - Ready to work Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-343_351549047227799_5302012_64135 PM.SecurityBlock.PM" WARNING: "07D001027CA60052D4EBCD67443A9584D0F30ED1.B0000474" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... Readed OK, Saving to "07D001027CA60052D4EBCD67443A9584D0F30ED1.B0000474" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found CMT PARTNERC Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm343_510.21.009_prd.c00 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm343_510.21.009_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.641s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... Programming Status OK! All blocks written OK! Time taken 87.563s Flashing Speed: 6590.99 kBit/S Restarting MCU... Processing rm343_510.21.009_prd.c00 (APE)... Processing rm343_510.21.009_prd.v08 (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm343_510.21.009_prd.v08, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.234s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 31.421s Flashing Speed: 6402.94 kBit/S Restarting MCU... Processing rm343_510.21.009_prd.v08 (APE)... Processing rm343_510.21.009.01U (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm343_510.21.009.01U, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Flashbus Write baud set to 5.0Mbits Started group flash erase Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.62s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 20.907s Flashing Speed: 6337.27 kBit/S Restarting MCU... Processing rm343_510.21.009.01U (APE)... Processing RM343_ENO_0741.10_08wk42.a26.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 07D001027CA60052D4EBCD67443A9584D0F30ED1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RM343_ENO_0741.10_08wk42.a26.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase Erase Certificate: SOS*ENO (CMT) Waiting 320s for erasure finish... Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 2.109s Flashing Speed: 6140.86 kBit/S Restarting MCU... Processing RM343_ENO_0741.10_08wk42.a26.fpsx (APE)... Processing dawn_erase_y_drive.fpsx (CMT)... Processing dawn_erase_y_drive.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V ICPR71_09w47.10 MCU Date 20-01-11 Product RM-343 (Nokia E66) Manufacturer (c) Nokia IMEI 351549047227799 Mastercode 4477113170 IMEI Spare 3A15450974227709 IMEI SV 3315450974227759F6000000 PSN MOJ838629 Product Code 0557965 Basic Product Code 0552842 PSD 0000000000000000 LPSN 0 WLAN MAC E4EC1002EE2F RETU 16 TAHVO 22 AHNE 11 HW 0715 RFIC 17141716 DSP ICPR71_09w40 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
05-31-2012, 23:52 | #2683 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 231 | Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:01:57, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000554C HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35 Initializing security card... Card Serial Number: D006029C Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.81v PASSED VBAT Voltage 1.41v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.476GB Avaiable Pagefile: 3.1018GB Initializing FBUS... All initialized - Ready to work MCU Version V 07.15 MCU Date 05-06-08 Product RM-366 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 356404021965847 Mastercode 2514171646 IMEI Spare 3A65040412698504 IMEI SV 3365040412698544F9000000 PPM V 07.15, 05-06-08, RM-366, (c) Nokia , L CNT Content: l_claro_caribe, V 07.15, 07-07-08, RM-366, (c) Nokia , , PSN DLQ444781 Product Code 0569449 Module Code 0203725 Basic Product Code 0553932 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1001 RFIC 17141715 DSP ICPR71_08w17 LCD SEIKO BT 06cc-P9.2 Simlock Server SIMLOCK SERVER Simlock Key 3700200072402456 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 37002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 42502F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 338070 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 330110 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 20404F Auto Selecting Flash Files on User Request... Product Code: 0569449 Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! Scanning avaiable products... No flash paths set! Go to Settings -> Paths and set them! No Flash Datapackage installed for this Phone! BB5 Unlock Started... MCU Version V 07.15 MCU Date 05-06-08 Product RM-366 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 356404021965847 Mastercode 2514171646 Simlock Server SIMLOCK SERVER Simlock Key 3700200072402456 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 37002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 42502F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 338070 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 330110 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 20404F Reading Security Block... Security block OK and saved to "RM-366_356404021965847_5312012_55059 PM.SecurityBlock.PM" WARNING: "194002140811035449A664BAB57F916A19D9343C.C000554C" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 194002140811035449A664BAB57F916A19D9343C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "194002140811035449A664BAB57F916A19D9343C.C000554C" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+558230794572808+1# #pw+472667014578562+2# #pw+087628156592063+3# #pw+328517046597767+4# #pw+127715843650556+5# #pw+902469228207390+6# #pw+917173819563583+7# Sending NCK Codes.. NCK[1] - ACCEPTED NCK[2] - Too fast between tries (bruteforce protection) NCK[3] - Too fast between tries (bruteforce protection) NCK[4] - Too fast between tries (bruteforce protection) NCK[5] - Too fast between tries (bruteforce protection) NCK[6] - Too fast between tries (bruteforce protection) NCK[7] - Too fast between tries (bruteforce protection) MCU Version V 07.15 MCU Date 05-06-08 Product RM-366 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 356404021965847 Mastercode 2514171646 Simlock Server SIMLOCK SERVER Simlock Key 3700200072402456 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 37002F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 42502F Simlock [3,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 338070 Simlock [4,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 330110 Simlock [5,1] State: OPENED Type: MCC-MNC Data: 20404F Simlock NCK #pw+558230794572808+1# Unlock finished! Time taken 11.390s Last edited by ptt; 06-01-2012 at 21:59. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
06-01-2012, 16:48 | #2684 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock 5530 RM-504 Done! Code: [Nokia 5530 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_09w20.7 MCU Date 25-06-09 Product RM-504 (Nokia 5530 XpressMusic) Manufacturer (c) Nokia IMEI 358022038 Mastercode 43272475 IMEI Spare 3A85200283602008 IMEI SV 3385200283602008F4000000 CNT V 10.0.041 PSN RMF178664 Product Code 0591912 Basic Product Code 0569346 PSD 0000000000000000 LPSN 0 WLAN MAC 1886AC938DC1 APE SW V 10.0.050 APE Variant V 10.0.050V 10.0.050 10.0.050.286.01 APE Test rm504_ENO_x_09wk19v0.080 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0802 RFIC 17141715 DSP ICPR72_09w19_1 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 73212F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 74000F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 73404F Sending BB5 NCK Code... [Nokia 5530 XpressMusic USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 5530 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_09w20.7 MCU Date 25-06-09 Product RM-504 (Nokia 5530 XpressMusic) Manufacturer (c) Nokia IMEI 358022038 Mastercode 43272475 IMEI Spare 3A85200283602008 IMEI SV 3385200283602008F4000000 CNT V 10.0.041 PSN RMF178664 Product Code 0591912 Basic Product Code 0569346 PSD 0000000000000000 LPSN 0 WLAN MAC 1886AC938DC1 APE SW V 10.0.050 APE Variant V 10.0.050V 10.0.050 10.0.050.286.01 APE Test rm504_ENO_x_09wk19v0.080 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0802 RFIC 17141715 DSP ICPR72_09w19_1 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72207F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 73002F Simlock [5,1] State: OPENED Type: MCC-MNC Data: 71606F Simlock [6,1] State: OPENED Type: MCC-MNC Data: 74807F Simlock [7,1] State: OPENED Type: MCC-MNC Data: 73212F Simlock [8,1] State: OPENED Type: MCC-MNC Data: 74000F Simlock [9,1] State: OPENED Type: MCC-MNC Data: 70604F Simlock [10,1] State: OPENED Type: MCC-MNC Data: 70403F Simlock [11,1] State: OPENED Type: MCC-MNC Data: 33403F Simlock [12,1] State: OPENED Type: MCC-MNC Data: 71030F Simlock [13,1] State: OPENED Type: MCC-MNC Data: 71402F Simlock [14,1] State: OPENED Type: MCC-MNC Data: 73404F Simlock NCK #pw+0J_82734709818+7# |
06-02-2012, 15:57 | #2685 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock BB8520 Done! Code: Waiting for new Blackberry USB Device (timeout 30 seconds)... New device attached, checking if it's Blackberry... Blackberry Found! PIN: 26E55649 "RIM CalTask" Channel open failed, Retrying... PIN: 26E55649 "RIM CalTask" Channel open failed, Trying "Caltask Config" ... PIN: 26E55649 Opened Channel "Caltask Config", Proceeding... IMEI: 357256046 HWV-21408-004-5 SVP-23743-002_1 SVP-23744-008_1 SVP-26603-004_1A ASY-22465-002 MEP-06041-008 VSM-26674-003 CFG-10993-052 SFI-24398-043 APP-32601-001 Calculating Codes using Fetched Data... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Service Tag: F2BE945C6FEB33717544B3AAE70B81F1 MEP-2: 75894097371 Calculations Left: XX All Done! Code: Waiting for new Blackberry USB Device (timeout 30 seconds)... New device attached, checking if it's Blackberry... Blackberry Found! PIN: 22321744 "RIM CalTask" Channel open failed, Retrying... PIN: 22321744 "RIM CalTask" Channel open failed, Trying "Caltask Config" ... PIN: 22321744 Opened Channel "Caltask Config", Proceeding... IMEI: 3519690484 HWV-21408-004-1 SVP-23743-002_1 SVP-23744-003_1 ASY-22465-002 MEP-06041-008 VSM-26674-003 CFG-10993-052 SFI-24398-018 APP-26857-004 Calculating Codes using Fetched Data... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Service Tag: F2BE945C6FEB33717544B3AAE70B81F1 MEP-2: 91985883592 Calculations Left: XX All Done! |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
