Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-03-2012, 14:37   #2686 (permalink)
GSM_STREET's Avatar
Member: 1149815
Sonork: N/A for now
Thanks Meter: 218
Nokia 201 Unlock Done!
[Nokia USB Phonet]: Port opened OK!
MCU Version	V 11.21
MCU Date	16-01-12
Product		RM-799 (Nokia RM-799)
Manufacturer	(c) Nokia
IMEI		358260047001902
Mastercode	542313270
IMEI Spare	3A85620074009100
IMEI SV		3385620074009100F3000000
PPM		V 11.21, 16-01-12, RM-799, (c) Nokia            , C1
CNT		Content: tesco GB SL, V 11.21, 16-01-12, RM-799, (c) Nokia
PSN		1155AA1BI
Product Code	059N351
Module Code	0205022
Basic Product Code	059J2K2
PSD		0000000000000000
LPSN		0
HW		2200
RFIC		Dummy RFIC version
LCD		TPO
BT		19e2-47026
Asic		11
HW Signature	9D2F0F29814BA264
Simlock Server	SIMLOCK SERVER
Simlock Key	2340000300000000
Simlock Profile	800000000003000B
Simlock Aux	000B0000
Simlock IMEI	00003582600470019000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 23410F
Simlock [1,2]	State: CLOSED	Type: 7FFF6F3EFFFFFFFF @ 8000	Data: 0A
Auto Selecting Flash Files on User Request...
Product Code: 059N351
No Flash Datapackage installed for this Phone!
Sending BB5 NCK Code...
NCK[7] - ACCEPTED
MCU Version	V 11.21
MCU Date	16-01-12
PSN		1155AA1BI
Module Code	0205022
LPSN		0
HW		2200
LCD		TPO
BT		19e2-47026
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 23410F
Simlock [1,2]	State: OPENED	Type: 7FFF6F3EFFFFFFFF @ 8000	Data: 0A
Last edited by ptt; 06-03-2012 at 14:54. Reason: MOVE TO THE RIGHT THREAD -- ADD [CODE] [/CODE] TAG TO THE LOG
Old 06-04-2012, 02:41   #2687 (permalink)
Member: 1322499
Sonork: C0801DE1
Thanks Meter: 3
Thumbs up cyc Repair 5800 OK
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:  00000296
CMT_EM_ASIC_ID:  00000B22
CMT_PUBLIC_ID:  10000106888D0052159A1DBC337BBB8255344A08
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box TX2 Data Pin set to: Service Pin 3
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
APE Boot skipped on user request
Restarting MCU...
[Nokia 5800 XpressMusic USB Generic]: Port opened OK!
MCU Version V ICPR72_09w44.4
MCU Date 20-11-09
Product  RM-356 (Nokia 5800 XpressMusic)
IMEI  XXXXXXXX1955161
Mastercode XXXXX51
IMEI Spare XXXXXXXX14591506
IMEI SV  XXXXXXXXXX591556F2000000
CNT  v 40.0.002_023_xxx_U01, 27-11-09, vanilla, RM356
PSN  CBL117701
Product Code 0592611
Basic Product Code 0584503
LPSN  0
WLAN MAC 3CF72A7BF101
APE SW  V 40.0.005
APE Variant V 40.0.005V 40.0.005 V 40.0.005
APE Test  eno_version
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  1106
RFIC  17141716
DSP  ICPR72_09w43
Failed to read info -> Failed to read SP info
BB5 Unlock Started...
MCU Date 20-11-09
Mastercode XXXXX51
Warning: Failed to read SP Info, Assuming defaults
Simlock Key 0000000000000000
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_91206.SecurityBlock.PM"
WARNING: "10000106888D0052159A1DBC337BBB8255344A08.B0001F05" Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
Switching to RAW Mode...
Old ROM Detected
CMT Ready!
New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5
Prepare phone failed with message -> Failed to set CMT Transmission Mode
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
BB5 Unlock Failed -> Failed to obtain Phone Unique Data
Sending User Abort Signal...
Phone not detected at USB -> User Abort
BB5 Unlock Failed -> Phone not detected (FBUS)
Booting CMT...
CMT Ready!
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
MCU Date 20-11-09
Mastercode XXXXX51
PSN  CBL117701
LPSN  0
APE SW  V 40.0.005
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  1106
RFIC  17141716
DSP  ICPR72_09w43
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_91902.SecurityBlock.PM"
Booting CMT...
CMT Ready!
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Readed OK, Saving to "10000106888D0052159A1DBC337BBB8255344A08.B0001F05"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (new method)
BB5 Unlock Failed -> Failed to read NCK Codes (both algos failed), Box Reported: Security Section Not Found (SL3 phone?)
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Connecting to Cyclone Server...
Cyclone Server (2.0.0.42), Cyclone Box Team 2008-2012 - Ready.
Checking job status...
Job not queued
BB5 Unlock Failed -> Submission cancelled by user
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_91925.SecurityBlock.PM"
Determining PA Simlock...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Determined PA Simlock: PA_SL2
Selected Unlock Method: PM Security Block Calculation
Booting CMT...
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Received Security Block OK !
BB5 Unlock Failed -> Simlock Array not found in PM 308, this is critical
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_92009.SecurityBlock.PM"
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Selected Unlock Method: NCK Calculation (old method)
Booting CMT...
CMT Ready!
BB5 Unlock Failed -> Failed to get Lock Key (6, 5)
SX4 Authorization / SD Repair Procedure Started....
"10000106888D0052159A1DBC337BBB8255344A08.B0001F05" Exists, That is good...
MCU Date 20-11-09
Mastercode XXXXX51
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_92103.SecurityBlock.PM"
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 98 bytes, Status: OK
[1,18] Written, Length: 98 bytes, Status: OK
[1,20] Written, Length: 98 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 98 bytes, Status: OK
[1,29] Written, Length: 10 bytes, Status: OK
[1,31] Written, Length: 98 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,37] Written, Length: 4 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[1,45] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 32, Record written NOT OK: 0
MCU Date 20-11-09
Mastercode XXXXX51
PSN  CBL117701
LPSN  0
APE SW  V 40.0.005
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  1106
RFIC  17141716
DSP  ICPR72_09w43
Started Phone Security Analysis...
MCU Date 20-11-09
Mastercode XXXXX51
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_92131.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
-- SIMLOCK PROBLEM --
Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED!
To repair simlock area, Select Unlock method : "RPL CALCULATION",
And then click DIRECT UNLOCK. SL Area will be re-formatted.
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-356_XXXXXXXX1955161_2012-6-4_92245.SecurityBlock.PM"
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 20-11-09
Mastercode XXXXX51
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Unlock finished! Time taken 3.844s
MCU Date 20-11-09
Mastercode XXXXX51
PSN  CBL117701
LPSN  0
APE SW  V 40.0.005
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  1106
RFIC  17141716
DSP  ICPR72_09w43
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Last edited by ptt; 06-04-2012 at 22:43. Reason: MOVE TO THE RIGHT THREAD -- ADD [CODE] [/CODE] TAG TO THE LOG
The Following User Says Thank You to weiqiyong For This Useful Post:
Old 06-04-2012, 13:33   #2688 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 764
Thumbs up N95 Flashing done.
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.03, (Jun  1 2012 21:16:13, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0000xxx
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 4.84v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.80v PASSED
VBAT Voltage 1.16v PASSED
VBAT Voltage 4.93v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 99
Avaiable Physical Memory: 1.324GB
Avaiable Virtual Memory: 1.488GB
Avaiable Pagefile: 3.15GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID:  6CB37C1500702BB9BA2082CBA3E56721C0380C45
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_PUBLIC_ID:  1BE000191A740052605D505888E688C82FBCFDEC
CMT Ready!
FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR
FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
Restarting MCU...
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-320_356842026058607_632012_125828 PM.SecurityBlock.PM"
"1BE000191A740052605D505888E688C82FBCFDEC.B0000474" Exists, That is good...
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Storing CMLA Key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
OMAP2420_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.48.0, Algo: BB5
Adding FUR Client (APE, State: Start)...
APE FUR Ready!
FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM
FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,APE]: 0x00EC004000000000, Samsung, ONENAND
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
OMAP2420_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.48.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG
TurboCache Loaded!
Writing APE KEYS Certificate...
Writing APE PASUBTOC Certificate...
Writing APE ALG Certificate...
APE Algorithm Ready!
Adding FUR Client (APE, State: Ready)...
APE FUR Ready!
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
Storing NPC...
Storing CCC...
Storing HWC...
Storing VARIANT...
CMT PARTNERC Not Found
Processing APE Part...
Storing PSN...
Storing HWID...
Storing NPC...
Storing CCC...
Storing HWC...
APE VARIANT Not Found
APE PARTNERC Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM-320_35.0.001_PR.C0R (CMT)...
Booting CMT...
CMT Ready!
RM-320_35.0.001_PR.C0R, Type: Flash Image, Algo: BB5, XSR 1.5, BB5, OMAP2420 UNISTORE-II-1.5.1 ALG
Flashbus Write baud set to 51Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00080000-0x007CF385, NOR
EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 37.640s
Writing all blocks...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 26.657s
Flashing Speed: 21864.64 kBit/S
Restarting MCU...
Processing RM-320_35.0.001_PR.C0R (APE)...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000200-0x0000AFFF, NAND
EraseArea[0,APE]: 0x0000B800-0x000AFFFF, NAND
EraseArea[0,APE]: 0x00000000-0x00000FFF, NAND
EraseArea[0,APE]: 0x0000D800-0x0000E9FF, NAND
EraseArea[0,APE]: 0x00080000-0x000BFFFF, NAND
EraseArea[0,APE]: 0x000E0000-0x0045FFFF, NAND
EraseArea[0,APE]: 0x004C0000-0x0073FFFF, NAND
EraseArea[0,APE]: 0x00A40000-0x06F3FFFF, NAND
Erase taken 1.344s
TurboCache Loaded!
Writing APE X-LOADER Certificate...
Writing APE PRIMAPP Certificate...
Writing APE SOS+XZIP Certificate...
Writing APE PAPUBKEYS Certificate...
Writing APE SOS+UPDAPP Certificate...
Writing APE SOS+CORE Certificate...
Writing APE SOS+ROFS Certificate...
All blocks written OK! Time taken 91.531s
Flashing Speed: 6367.74 kBit/S
Restarting MCU...
Processing RM-320_35.0.001_PR.v08 (CMT)...
Processing RM-320_35.0.001_PR.v08 (APE)...
Booting CMT...
CMT Ready!
RM-320_35.0.001_PR.v08, Type: Flash Image, Algo: BB5, OMAP2420 UNISTORE-II-1.5.1 ALG, BB5, XSR 1.5
Flashbus Write baud set to 650Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x05140000-0x06F3FFFF, NAND
Erase taken 0.360s
TurboCache Loaded!
Writing APE SOS+ROFX Certificate...
All blocks written OK! Time taken 16.31s
Flashing Speed: 5896.07 kBit/S
Restarting MCU...
Processing RM320_31.0.002_025_zzz_U03_uda.fpsx (CMT)...
Processing RM320_31.0.002_025_zzz_U03_uda.fpsx (APE)...
Booting CMT...
CMT Ready!
RM320_31.0.002_025_zzz_U03_uda.fpsx, Type: Flash Image, Algo: BB5, OMAP2420 UNISTORE-II-1.5.1 ALG, BB5, XSR 1.5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE FUR Ready!
TurboCache Loaded!
APE FUR Ready!
Box VPP disabled
EraseArea[0,APE]: 0x06F40000-0x0F87FFFF, NAND
Erase Certificate: SOS-USER (APE)
Erase taken 3.156s
TurboCache Loaded!
All blocks written OK! Time taken 41.63s
Flashing Speed: 5553.43 kBit/S
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 06wk41v64.20
MCU Date 01-10-09
Product  RM-320 (Nokia N95 8GB)
IMEI  356842026058607
Mastercode 6253362362
IMEI Spare 3A65480262506800
IMEI SV  3365480262506810F4000000
PPM  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
CNT  RM320_31.0.002_U03,
PSN  SCO809346
Product Code 0558787
Basic Product Code 0548236
LPSN  0
WLAN MAC 0022FD502950
APE SW  35.0.001
APE Variant 35.0.00108.01
APE Test  rm320_eno_Cust2008wk14updv0
APE HW  1
APE ADSP 256
APE BT  HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
RETU  16
TAHVO  22
AHNE  11
HW  4251i35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
PCI  i35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
UEM  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
UPP  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
RFIC  17141715
DSP  aino.ICPR62_08w28p2i35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
LCD  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
BT  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
ADSP Sw  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
ADSP DevID  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03,
ADSP RevID  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
AEM  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
Flip MCUSW  35.0.001j35.0.00108.01k rm320_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256rRM320_31.0.002_U03, ¥RM320_31.0.002_U03,
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 06-04-2012, 13:35   #2689 (permalink)
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 764
Arrow 7210 Flashing done.
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.02, (May 20 2012 18:02:27, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Box is activated
USB Voltage 4.98v PASSED
VBAT Voltage 1.29v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
VPP Voltage 4.97v PASSED
Box VPP disabled
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.381GB
Avaiable Virtual Memory: 1.473GB
Avaiable Pagefile: 3.186GB
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID:  00000295
CMT_PUBLIC_ID:  158001072FAA7C561E78641E3DD060CAB64E25E3
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Box VPP disabled
PAPUBKEYS Hash for CMT: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Restarting MCU...
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 122 products, Filtering BB5 Products - wait...
74 Products left after filtering. Ready.
Retrieving Variants for Product RM-436 - wait...
317 Variants Retrieved
Backing up RPL...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
Processing rm436__07.23.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0119FFFF, NOR
EraseArea[0,CMT]: 0x011A0000-0x0133FFFF, NOR
Erase taken 3.890s
TurboCache Loaded!
All blocks written OK! Time taken 58.203s
Flashing Speed: 2602.84 kBit/S
Restarting MCU...
Processing rm436__07.23.mcusw (APE)...
Processing rm436__07.23.ppm_f (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.ppm_f, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01340000-0x01BDFFFF, NOR
Erase taken 26.438s
TurboCache Loaded!
All blocks written OK! Time taken 36.344s
Flashing Speed: 1505.59 kBit/S
Restarting MCU...
Processing rm436__07.23.ppm_f (APE)...
Processing rm436__07.23.image_f (CMT)...
Booting CMT...
CMT Ready!
rm436__07.23.image_f, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01BE0000-0x01F7FFFF, NOR
EraseArea[0,CMT]: 0x01F80000-0x03FBFFFF, NOR
Erase taken 238.562s
TurboCache Loaded!
All blocks written OK! Time taken 58.500s
Flashing Speed: 3158.38 kBit/S
Restarting MCU...
Processing rm436__07.23.image_f (APE)...
Factory defaults OK
Reading info...
MCU Version V 07.23
MCU Date 17-07-09
Product  RM-436 (Nokia 7210 Supernova)
IMEI  351962031687458
Mastercode 617174243
IMEI Spare 3A15690213864705
IMEI SV  3315690213864745F0000000
PPM  V 07.23, 17-07-09, RM-436, (c) Nokia            , F
CNT  Content: f, V 07.23, 17-07-09, RM-436, (c) Nokia            ,
PSN  DAO869627
Product Code 0566806
Module Code 0203868
Basic Product Code 0563951
LPSN  0
RETU  15
TAHVO  22
AHNE  30
HW  1001
RFIC  06540601
DSP  ICPR72_09w17
LCD  SEIKO
BT  2222-143C
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Old 06-04-2012, 17:42   #2690 (permalink)
Member: 288521
Thanks Meter: 685
MCU Version	V 04.81
MCU Date	22-11-07
Product		RM-240 (Nokia 6500 slide)
IMEI		353076020602929
Mastercode	626335216
Simlock Key	2342000000000000
Simlock Profile	8000000000000002
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 23420F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 23594F
"RM-240_353076020602929_03062012_082953.SecurityBlock.PM"
read it...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101003000
CMT_PUBLIC_ID:		0D5000091CC44F50F8972D142BE7D6F61C2F6E97
CMT_ROOT_KEY_HASH:	BAF3A9C3DBFA8454937DB77F2B8852B1
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Old Loader Detected
Readed OK, Saving to "0D5000091CC44F50F8972D142BE7D6F61C2F6E97.B0000AF0"
#pw+848917004399592+1#
#pw+692216007742587+2#
#pw+589522938982728+3#
#pw+174681256934483+4#
#pw+023770407287399+5#
#pw+286327892825041+6#
#pw+620979191491202+7#
Sending NCK Codes..
NCK[1] - ACCEPTED
NCK[2] - Too fast between tries (bruteforce protection)
NCK[3] - Too fast between tries (bruteforce protection)
NCK[4] - Too fast between tries (bruteforce protection)
NCK[5] - Too fast between tries (bruteforce protection)
NCK[6] - Too fast between tries (bruteforce protection)
NCK[7] - Too fast between tries (bruteforce protection)
MCU Version	V 04.81
MCU Date	22-11-07
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 23420F
Last edited by ptt; 06-04-2012 at 22:20. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 06-05-2012, 08:03   #2691 (permalink)
Member: 762819
Thanks Meter: 232
Today I've successfully downgraded N73 to Arabic version. Which was not done with other Tools:- ATF, JAF, HWK, but finally it was successfully flashed with Cyclone Reloaded.
Thanks to Cyclone Team...
Backing up RPL...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
WMDRM Store not supported
Security block OK and saved to "RM-133_355718027******_642012_115210 PM.SecurityBlock.PM"
WARNING: "0490010E1A5B7D5612F2D73F7292BC202BDBD094.B0002188" Not Exists, Will read it...
Booting CMT...
APE_SYSTEM_ASIC_ID:	17100708
APE_PUBLIC_ID:		6FE4211340AA942BF8FC44664AF45E1F4CD74A1E
APE_ROOT_KEY_HASH:	49A97E826B93BA20B7ED0B082475C00500000000
APE_BOOT_ROM_CRC:	1DFD6613
APE_SECURE_ROM_CRC:	2C872FD4
CMT_PUBLIC_ID:		0490010E1A5B7D5612F2D73F7292BC202BDBD094
CMT Ready!
Old Loader Detected
Readed OK, Saving to "0490010E1A5B7D5612F2D73F7292BC202BDBD094.B0002188"
Storing CMLA Key...
Booting CMT...
CMT Ready!
FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR
FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V
Box VPP disabled
PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5
FlashChip[0,APE]: 0x00EC01A100000015, Samsung, NAND
FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND
FlashChip 0x00EC01A1 (Samsung), Size: 128MBytes, VPP: 21V
h3_xsr15_flash_alg.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1  ALG
Box VPP disabled
PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Storing NPC...
CMT CCC Not Found
CMT HWC Not Found
Storing VARIANT...
Storing PSN...
Storing HWID...
APE NPC Not Found
APE CCC Not Found
APE HWC Not Found
Restarting MCU...
RPL Saved OK
Applying downgrade patch...
Downgrade patch OK!
Processing N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx (CMT)...
Booting CMT...
CMT Ready!
N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1  ALG
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00080000-0x007314D1, NOR
EraseArea[0,CMT]: 0x001E0000-0x001FFFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR
Erase taken 47.79s
TurboCache Loaded!
Writing CMT ADL Certificate...
All blocks written OK! Time taken 35.203s
Flashing Speed: 11458.21 kBit/S
Restarting MCU...
Processing N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx (APE)...
Booting CMT...
CMT Ready!
Box VPP disabled
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND
EraseArea[0,APE]: 0x00080000-0x000FFFFF, NAND
EraseArea[0,APE]: 0x00100000-0x0025FFFF, NAND
EraseArea[0,APE]: 0x003C0000-0x04E1FFFF, NAND
Erase taken 0.860s
TurboCache Loaded!
Writing APE SOS+LOADER Certificate...
Writing APE SOS*UPDAPP Certificate...
Writing APE SOS+UZIP Certificate...
Writing APE ADL Certificate...
Writing APE SOS*CORE Certificate...
All blocks written OK! Time taken 56.110s
Flashing Speed: 7188.80 kBit/S
Restarting MCU...
Processing N73_rofx_4.0736.3.2.1_PRD.V08 (CMT)...
Processing N73_rofx_4.0736.3.2.1_PRD.V08 (APE)...
Booting CMT...
CMT Ready!
N73_rofx_4.0736.3.2.1_PRD.V08, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1  ALG, BB5, BB5 ALGORITHM
Flashbus Read baud set to 100Kbits
Box VPP disabled
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x03920000-0x04E1FFFF, NAND
Erase taken 0.250s
TurboCache Loaded!
All blocks written OK! Time taken 28.735s
Flashing Speed: 4154.33 kBit/S
Restarting MCU...
Processing N73_userarea_4.0736.3.2.1.U02 (CMT)...
Processing N73_userarea_4.0736.3.2.1.U02 (APE)...
Booting CMT...
CMT Ready!
N73_userarea_4.0736.3.2.1.U02, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1  ALG, BB5, BB5 ALGORITHM
Box VPP disabled
Box VPP disabled
EraseArea[0,APE]: 0x04E20000-0x07C9FFFF, NAND
Erase taken 0.500s
TurboCache Loaded!
All blocks written OK! Time taken 10.281s
Flashing Speed: 6025.25 kBit/S
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version	V 05wk47v51.5
MCU Date	29-08-07
Product		RM-133 (Nokia N73)
Manufacturer	(c) Nokia.
IMEI		35571802*******
Mastercode	652322034
Last edited by ptt; 06-05-2012 at 21:44. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 06-07-2012, 00:25   #2692 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
N8 (RM-596) USB Flash
Backing up RPL...
[Nokia N8-00 USB Phonet]: Port opened OK!
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-596_357919041603085_06062012_081303 p.m..SecurityBlock.PM"
"16B002145FDA034421CE67EB0AFA84B5554DC8DA.B0001D9F" Exists, That is good...
Storing CMLA Key...
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000030000022600010007600C192102031104
CMT_EM_ASIC_ID:		00000C35
CMT_EM_ASIC_ID:		00000C30
CMT_PUBLIC_ID:		16B002145FDA034421CE67EB0AFA84B5554DC8DA
CMT_ROOT_KEY_HASH:	916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC:	E693EF0D
CMT_SECURE_ROM_CRC:	AC22615B
CMT Ready!
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC005000000232, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6
TurboCache Loaded!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Waiting for FUR Client become avaiable...
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: D172C32473AE199B213465ABB3853246F9631231
Storing NPC...
Storing CCC...
Storing HWC...
Storing PARTNERC...
Restarting MCU...
RPL Saved OK
Processing RM-596_111.030.0609_79u_prd.core.fpsx (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
RM-596_111.030.0609_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND
EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND
Erase Partition (CMT)
Erase taken 0.812s
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT SOS+DECOMP Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS+IVE3A Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 19.79s
Flashing Speed: 52627,19 kBit/S
Processing RM-596_111.030.0609_79u_prd.core.fpsx (APE)...
Processing RM-596_111.030.0609_33.01_LTA_NO_FMTX_79u_prd.rofs2.fpsx (CMT)...
RM-596_111.030.0609_33.01_LTA_NO_FMTX_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND
Erase taken 0.203s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 7.46s
Flashing Speed: 57446,50 kBit/S
Processing RM-596_111.030.0609_33.01_LTA_NO_FMTX_79u_prd.rofs2.fpsx (APE)...
Processing RM-596_111.030.0609_352.01_default_79u.2011.44_prd.rofs3.fpsx (CMT)...
RM-596_111.030.0609_352.01_default_79u.2011.44_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x01378000-0x0139FFFF, ONENAND
EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND
Erase taken 0.125s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
Writing CMT SOS+IVE3B Certificate...
All blocks written OK! Time taken 0.421s
Flashing Speed: 20704,57 kBit/S
Processing RM-596_111.030.0609_352.01_default_79u.2011.44_prd.rofs3.fpsx (APE)...
Processing RM-596_111.030.0609_352.01_default_79u.2011.44.uda.fpsx (CMT)...
RM-596_111.030.0609_352.01_default_79u.2011.44.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0EA00000-0x1EFFFFFF, ONENAND
Erase taken 0.922s
TurboCache Loaded!
All blocks written OK! Time taken 16.390s
Flashing Speed: 51827,16 kBit/S
Processing RM-596_111.030.0609_352.01_default_79u.2011.44.uda.fpsx (APE)...
Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx (CMT)...
RM596_APE_ONLY_ENO_11w36_v0.162.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND
Erase taken 0.31s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 0.750s
Flashing Speed: 48998,87 kBit/S
Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx (APE)...
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version	V 79_sr1_11w42.5
MCU Date	25-11-11
Product		RM-596 (Nokia N8)
IMEI		357919041603085
Mastercode	331763472
IMEI Spare	3A75190914060308
IMEI SV		3375190914060338F3000000
PSN		CAR949759
Product Code	059G2H8
Basic Product Code	059F9M3
LPSN		0
WLAN MAC	AC81F36286DC
APE SW		111.030.0609
APE Variant	111.030.0609111.030.0609.33.01111.030.0609.352.01
APE Test		0.162
APE HW		256
APE ADSP	256
APE BT		HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
RETU		35
TAHVO		00
AHNE		11
HW		7460
RFIC		|Alli_4.3.4
DSP		79_SR1_11w42.5
Simlock Key	7223100000000000
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 74402F
Simlock [3,1]	State: OPENED	Type: 3F007F206F07FFFF @ FC00	Data: 722310
Simlock [4,1]	State: OPENED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 722310
Simlock [5,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock [6,1]	State: OPENED	Type: MCC-MNC	Data: 74810F
Simlock NCK	#pw+4}m\01610854215+1#
Old 06-07-2012, 11:33   #2693 (permalink)
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 764
Thumbs up N96 Flshing done.
Initializing box...
Box Serial Number: B0000474
Box is activated
USB Voltage 5.00v PASSED
VBAT Voltage 0.05v PASSED
VBAT Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 4.95v PASSED
Box VPP disabled
Avaiable Physical Memory: 1.109GB
Avaiable Pagefile: 2.814GB
Booting CMT...
APE_SYSTEM_ASIC_ID: 008815D3
APE_PUBLIC_ID:  E71E97BB9CDAA629C4E4F758D770B0573AB6FE0B
APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE_BOOT_ROM_CRC: 137A9A3B
APE_SECURE_ROM_CRC: 33259D2C
CMT_PUBLIC_ID:  1A90000DB96F0052D6A07CB628E6855116ED37A0
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Restarting MCU...
MCU Version V ICPR72_08w50.1.1
MCU Date 04-02-09
Product  RM-247 (Nokia N96)
IMEI  354863023513628
Mastercode 3151364442
IMEI Spare 3A45680332156302
IMEI SV  3345680332156302F7000000
PSN  CHH501475
Product Code 0543727
Basic Product Code 0542934
LPSN  0
WLAN MAC 0022FD33791A
RETU  15
TAHVO  22
AHNE  11
HW  1001
RFIC  17141715
DSP  mc_4032_ICPR72_08w50_p1
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Product Code: 0543727
Found 132 products, Filtering DCT4 Products - wait...
23 Products left after filtering. Ready.
Found 132 products, Filtering BB5 Products - wait...
78 Products left after filtering. Ready.
MCU Date 04-02-09
PPM  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
CNT  V 40.2009.12.xx PRD
PSN  CHH501475
LPSN  0
APE SW  20.050
APE Variant 20.05020.050.010.120.050.098.1
APE Test  4032_PR11.0835_003
APE HW  0
APE ADSP 0
RETU  15
TAHVO  22
AHNE  11
HW  1001o0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
PCI  o0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
UEM  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
UPP  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
RFIC  17141715
DSP  mc_4032_ICPR72_08w50_p1o0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
LCD  0n0W1083227i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
BT  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
ADSP Sw  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
ADSP DevID  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003
ADSP RevID  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
AEM  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
Flip MCUSW  0n0i20.050j$20.05020.050.010.120.050.098.1rV 40.2009.12.xx PRDk4032_PR11.0835_003¥V 40.2009.12.xx PRD
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Found 133 products, Filtering DCT4 Products - wait...
Found 133 products, Filtering BB5 Products - wait...
79 Products left after filtering. Ready.
This is Valid BB5 Product
Retrieving Variants for Product RM-247 - wait...
66 Variants Retrieved
Variant found for readen Product Data!
Read RPL operation not possible for Old USB Flashing Method
Processing RM-247_30.033_prd.core.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-247_30.033_prd.core.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5, N8815 ALG STNFMS, BB5
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR
FlashChip 0x00010035 (AMD), Size: 16MBytes, VPP: 9V
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00080000-0x007A6EE9, NOR
EraseArea[0,CMT]: 0x00880000-0x00EFFFFF, NOR
Erase taken 34.62s
TurboCache Loaded!
All blocks written OK! Time taken 29.94s
Flashing Speed: 28063.23 kBit/S
Restarting MCU...
Processing RM-247_30.033_prd.core.fpsx (APE)...
Booting CMT...
CMT Ready!
Box VPP disabled
nomadik8815_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.43.0, Algo: BB5
FlashChip[0,APE]: 0x002000B100000000, ST, NAND
Requested Algorithm: N8815 ALG STNFMS (APE)
FlashChip 0x002000B1 (ST), Size: 8MBytes, VPP: 21V
nomadik8815_alg.fg, Type: Algorithm, Rev: 0.1.57.0, Algo: N8815 ALG STNFMS
Box VPP disabled
PAPUBKEYS Hash for APE: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00840000-0x0A8FFFFF, NAND
Erase taken 2.485s
TurboCache Loaded!
Writing APE PRIMAAPP Certificate...
Writing APE SOS+ROFS1 Certificate...
All blocks written OK! Time taken 129.250s
Flashing Speed: 6316.99 kBit/S
Restarting MCU...
Processing RM-247_30.033_010.1_prd.language.fpsx (CMT)...
Processing RM-247_30.033_010.1_prd.language.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.033_010.1_prd.language.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
Box VPP disabled
Box VPP disabled
EraseArea[0,APE]: 0x07780000-0x099FFFFF, NAND
Erase taken 0.516s
TurboCache Loaded!
Writing APE SOS+ROFS2 Certificate...
All blocks written OK! Time taken 16.406s
Flashing Speed: 5928.92 kBit/S
Restarting MCU...
Processing RM-247_30.033_098.1_prd.customer.fpsx (CMT)...
Processing RM-247_30.033_098.1_prd.customer.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.033_098.1_prd.customer.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
Box VPP disabled
Box VPP disabled
EraseArea[0,APE]: 0x09A00000-0x0A8FFFFF, NAND
Erase taken 0.235s
TurboCache Loaded!
Writing APE SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.31s
Flashing Speed: 1421.68 kBit/S
Restarting MCU...
Processing RM-247_30.033_100.1_prd.uda.fpsx (CMT)...
Processing RM-247_30.033_100.1_prd.uda.fpsx (APE)...
Booting CMT...
CMT Ready!
RM-247_30.033_100.1_prd.uda.fpsx, Type: Flash Image, Algo: N8815 ALG STNFMS, BB5, XSR 1.5, BB5
Box VPP disabled
Box VPP disabled
Erase Partition (APE)
Erase taken 1.297s
TurboCache Loaded!
All blocks written OK! Time taken 18.219s
Flashing Speed: 5916.94 kBit/S
Restarting MCU...
Factory defaults OK
Reading info...
MCU Version V ICPR72_09w13.2
MCU Date 19-05-09
IMEI SV  3345680332156302F8000000
PSN  CHH501475
LPSN  0
RETU  15
TAHVO  22
AHNE  11
HW  1001
RFIC  17141715
DSP  MC_4032_ICPR72_09w13
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Old 06-08-2012, 04:41   #2694 (permalink)
Member: 1002064
Sonork: 100.1594824
Thanks Meter: 131
6650 d unlock with usb ok
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.392
Initializing box...
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: xxxxx
2009, wk01 / wk06
Initializing security card...
Card Serial Number: xxxxxx
Card Firmware Revision: 0109
Card is activated
Box is activated
Core Voltage    1.78v    PASSED
VBAT Voltage    0.01v    PASSED
VBAT Voltage    4.99v    PASSED
Box VPP disabled
VPP Voltage    4.79v    PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage    1.52v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
XGold/Blackberry Service Running, Counter: 98
Avaiable Physical Memory: 366.304MB
Avaiable Virtual Memory: 1.485GB
Avaiable Pagefile: 1.710GB
[Nokia 6650 USB Phonet]: Port opened OK!
Phone is in RF Inactive Mode
MCU Version    V 08w11.08
MCU Date    15-05-08
Product        RM-400 (Nokia 6650d-1c)
IMEI        35310302143xxxx
Mastercode    6062312740
Simlock Key    2343000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock [1,1]    State: CLOSED    Type: MCC-MNC    Data: 23430F
Simlock [2,1]    State: CLOSED    Type: MCC-MNC    Data: 23430F
AM.SecurityBlock.PM"
read it...
Booting CMT...
Old ROM Detected
CMT_PUBLIC_ID:        0D9000041B9A0158C9722579FFC70DE3D812B8B6
CMT Ready!
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC003000000221, Samsung, ONENAND
If phone doesn't powering into Local Mode now for some reason do following:
1. Re-insert battery
2. Power it on, when asked use Ovi/Pc Suite Mode
Readed OK, Saving to "0D9000041B9A0158C9722579FFC70DE3D812B8B6.C0000BB9"
Writing Simlock...
MCU Date    15-05-08
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Booting CMT...
Old ROM Detected
CMT Ready!
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
MCU Date    15-05-08
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Booting CMT...
Old ROM Detected
CMT Ready!
MCU Date    15-05-08
Simlock Key Cnt    0
Simlock FBUS Cnt    0
"0D9000041B9A0158C9722579FFC70DE3D812B8B6.C0000BB9" Exists, That is good...
Writing Simlock...
MCU Date    15-05-08
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Last edited by ptt; 06-08-2012 at 22:24. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 06-08-2012, 23:53   #2695 (permalink)
anrmobile's Avatar
Member: 1680232
Sonork: 100.1611221
Thanks Meter: 236
MCU Version	V 5.24
MCU Date	16-08-06
Product		RM-225 (Nokia 6030b CABLE 1100)
IMEI		011052006397960
Mastercode	34165122
Setting Local Mode...
Local mode Set
Asic		2
HW Signature	D5790E0E15B8556D
Simlock Server	SIMLOCK SERVER VERSION 63
Simlock Key	3102000000000000
Simlock Profile	8000000000010002
Simlock Aux	00025555
Simlock IMEI	00550110520063979600
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 20416F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21630F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 21901F
Simlock [4,1]	State: CLOSED	Type: MCC-MNC	Data: 23001F
Simlock [5,1]	State: CLOSED	Type: MCC-MNC	Data: 23102F
Simlock [6,1]	State: CLOSED	Type: MCC-MNC	Data: 23203F
Simlock [7,1]	State: CLOSED	Type: MCC-MNC	Data: 23430F
Simlock [8,1]	State: CLOSED	Type: MCC-MNC	Data: 25001F
Simlock [9,1]	State: CLOSED	Type: MCC-MNC	Data: 25502F
Simlock [10,1]	State: CLOSED	Type: MCC-MNC	Data: 26002F
Simlock [11,1]	State: CLOSED	Type: MCC-MNC	Data: 26201F
Simlock [12,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310160
Simlock [13,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310200
Simlock [14,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310210
Simlock [15,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310220
Simlock [16,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310230
Simlock [17,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310240
Simlock [18,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310250
Simlock [19,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310260
Simlock [20,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310270
Simlock [21,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310280
Simlock [22,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310300
Simlock [23,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310310
Simlock [24,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310580
Simlock [25,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310660
Simlock [26,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310800
Autodetecting SP Type...
Autodetection Finished
Proceeding with RSA Unlock...
Asking card to sign HW Signature...
Signed OK (14356D3A69A0F84B1273767983D6E6214EBE2588)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 06-09-2012 at 22:36. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 06-09-2012, 13:36   #2696 (permalink)
akh84's Avatar
Member: 1733938
Sonork: 100.1617311
Thanks Meter: 34
Nokia 2610
Simlock Aux	000B5555
Simlock IMEI	00553548080158787700
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 20810F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 20810F
Simlock [3,1]	State: CLOSED	Type: MCC-MNC	Data: 64710F
Simlock [4,1]	State: CLOSED	Type: MCC-MNC	Data: 64710F
Product Code: 0538850
Processing C:\Program Files (x86)\Cyclone Box\StoredFiles\...
Found 0 products, Filtering DCT4 Products - wait...
0 Products left after filtering. Ready.
Found 0 products, Filtering BB5 Products - wait...
MCU Version	V 06.70
MCU Date	16-11-07
Product		RH-86 (Nokia 2610 CABLE 1100)
IMEI		354808015878778
Mastercode	5153533550
Local mode Set
Asic		11
HW Signature	068EC2A02FDD62C2
Simlock Key	2081000000000000
Simlock Profile	800000000001000B
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Signed OK (CEF1C05C0FC748EE322E89677A3459F657368E1A)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
MCU Version	V 04.90
MCU Date	10-01-07
IMEI		355528015801930
Mastercode	677016637
Local mode Set
Asic		11
HW Signature	421FD0CDFBA47A4D
Simlock Key	2080100000000000
Simlock IMEI	00553555280158019300
Simlock Key Cnt	3
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 20801F
Signed OK (F978A1047F5BC42B8C7229333B076EF0404EA184)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Old 06-09-2012, 13:38   #2697 (permalink)
akh84's Avatar
Member: 1733938
Sonork: 100.1617311
Thanks Meter: 34
Nokia 6210 Navigator
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E
Certificates operation for RAPIDO USB is Disabled!
Failed to Create RPL from phone -> Failed to read CMT NPC
[Nokia 6210 Navigator USB Phonet]: Port opened OK!
MCU Version	V 08w17.08
MCU Date	17-06-08
Product		RM-367 (Nokia 6210 Navigator)
IMEI		352914025986551
Mastercode	3276632073
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security block OK and saved to "RM-367_352914025986551_20052012_111516.SecurityBlock.PM"
"15400116B9CA01582B3E1F601E8FB62878FC94EB.B0000A7E" Exists, That is good...
#pw+999783709387878+1#
#pw+757389652548053+2#
#pw+034623154795898+3#
#pw+353014397782289+4#
#pw+240623588735367+5#
#pw+554276254412630+6#
#pw+733774784884764+7#
Sending NCK Codes..
NCK[1] - ACCEPTED
MCU Date	17-06-08
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 20810F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 20810F
Simlock [3,1]	State: OPENED	Type: MCC-MNC	Data: 64710F
Simlock [4,1]	State: OPENED	Type: MCC-MNC	Data: 64710F
Simlock NCK	#pw+999783709387878+1#
Unlock finished! Time taken 44.710s
Old 06-10-2012, 19:47   #2698 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 705
Thumbs up 6680 RM-36 UNLOCK Done
6680 RM-36 UNLOCK Done when ATF -Box Failed to put the phone in local/test mode but always the Cyclone Box Did not ashamed me in the eyes of customer!!!Cyclone always rocks :-) :-) :-)
MCU Version	V 04wk47_m_v5
MCU Date	17-08-05
Product		RM-36 (Nokia 6680)
IMEI		357617003704616
Mastercode	57345515
IMEI Spare	3A75160730076401
IMEI SV		3375160730076411F8000000
PSN		SBF695951
Product Code	0529503
Basic Product Code	0516030
PSD		0000001700000000
RETU		32
TAHVO		41
AHNE		21
HW		6010
RFIC		150a160e
DSP		04w47v22
Simlock Server	SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task
Simlock Key	2229900093172790
Simlock Key Cnt	3
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 22299F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 22299F
Product Code: 0529503
Data\Nokia\Packages\Products\...
Found 31 products, Filtering DCT4 Products - wait...
Found 31 products, Filtering BB5 Products - wait...
MCU Date	17-08-05
Mastercode	57345515
Simlock Key Cnt	3
Simlock FBUS Cnt	0
"06F0001630BE4F5796FF9F6815B441DF4C8A316A.C0005CBB" Exists, That is good...
Writing Simlock...
MCU Date	17-08-05
Mastercode	57345515
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Unlock finished!
Old 06-11-2012, 14:18   #2699 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 931
NOKIA 500 PHONE LOCK SUCESSFULLY UNLOCKED
http://img820.imageshack.us/img820/8...ksucessful.png
Last edited by ptt; 06-11-2012 at 22:53. Reason: REMOVE [IMG] TAG - YOU CAN POST TXT LOG AS ALL OTHERS DO
Old 06-11-2012, 17:44   #2700 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
nokia 101 RM-769 FLASH OK
Processing pre-flash tasks...
Pre-flash tasks finished
Checking rm769_006.900...
Flash file sorted Okay.
1 file(s) embedded into image.
Booting X-Gold via ASC (press power-on if used non-battery cable)...
X-Gold: Ready, MCU ID: 0x3400
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Default_RAM_Bootloader
[EBL] : Ready
Setting Baudrate to 921600bps...
Baudrate Accepted (921600bps)
Flash Chip 0x00EC2404, Samsung, Size: 16MBytes
Processing "hw_f3_rm769_r06.900.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x00000000-0x0001FFFF...
Flashing at 0x00000000...
Flashed 24576 bytes OK
Erasing 0x00800000-0x00BFFFFF...
Flashing at 0x00800000...
Flashed 4128768 bytes OK
Erasing 0x00C5D000-0x00E5FFFF...
Flashing at 0x00C5D000...
Flashed 1697536 bytes OK
Box VPP disabled
Checking rm7690_nai06.90ic...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f3_rm7690_nai06.90ic.fls"...
Erasing 0x00E60000-0x00F5FFFF...
Flashing at 0x00E60000...
Flashed 729664 bytes OK
Box VPP disabled
Checking rm769_006.90ic...
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Ready
Processing "hw_f3_rm769_006.90ic.fls"...
Erasing 0x00100000-0x007FFFFF...
Flashing at 0x00100000...
Flashed 5025024 bytes OK
Box VPP disabled
Processing post-flash tasks...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
Last edited by ptt; 06-11-2012 at 22:52. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.65913 seconds with 10 queries
