![]() | #2851 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: spain
Member: 980172 Status: Offline Thanks Meter: 85 | E71 fast unlocked Code: BB5 Unlock Started... MCU Version V 100.71.821.4 MCU Date 06-06-08 Product RM-346 (Nokia E71) Manufacturer (c) Nokia IMEI 3560590395445xx Mastercode 5672102071 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F Reading Security Block... Security block OK and saved to "RM-346_3560590395445xx_10112012_234559.SecurityBlock.PM" WARNING: "14D00010B67D0052EB92E235480A10D596AEDB6D.C0001463" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14D00010B67D0052EB92E235480A10D596AEDB6D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... Readed OK, Saving to "14D00010B67D0052EB92E235480A10D596AEDB6D.C0001463" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+107017549258321+1# #pw+935652279732650+2# #pw+103812757719180+3# #pw+753600890317373+4# #pw+292258125487208+5# #pw+494534565564377+6# #pw+403565296585790+7# Sending NCK Codes.. NCK[1] - ACCEPTED NCK[2] - Too fast between tries (bruteforce protection) NCK[3] - Too fast between tries (bruteforce protection) NCK[4] - Too fast between tries (bruteforce protection) NCK[5] - Too fast between tries (bruteforce protection) NCK[6] - Too fast between tries (bruteforce protection) NCK[7] - Too fast between tries (bruteforce protection) MCU Version V 100.71.821.4 MCU Date 06-06-08 Product RM-346 (Nokia E71) Manufacturer (c) Nokia IMEI 3560590395445xx Mastercode 5672102071 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock NCK #pw+107017549258321+1# Unlock finished! Time taken 15.47s Last edited by ptt; 11-11-2012 at 15:55. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2852 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: Paraguay
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock X2-01 RM-709 Code: [Nokia X2-01 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-709 (Nokia X2-01) Manufacturer (c) Nokia IMEI 35194605 Mastercode 5031525234 IMEI Spare 3A15490685283004 IMEI SV 3315490685283034F2000000 PPM V 08.63, 25-03-11, RM-709, (c) Nokia , L CNT Content: claro AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia PSN CHN199110 Product Code 059K1C5 Module Code 0204674 Basic Product Code 059J9S5 PSD 0000000000000000 LPSN 0 HW 1001 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35194605 #pw+747655450209183+1# #pw+890227577935881+2# #pw+518709656386671+3# #pw+132664714999917+4# #pw+259770544010214+5# #pw+555677990191212+6# #pw+........................+7# Sending BB5 NCK Code... [Nokia X2-01 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia X2-01 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-709 (Nokia X2-01) Manufacturer (c) Nokia IMEI 35194605 Mastercode 5031525234 IMEI Spare 3A15490685283004 IMEI SV 3315490685283034F2000000 PPM V 08.63, 25-03-11, RM-709, (c) Nokia , L CNT Content: claro AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia PSN CHN199110 Product Code 059K1C5 Module Code 0204674 Basic Product Code 059J9S5 PSD 0000000000000000 LPSN 0 HW 1001 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+8KLo72511455617+7# |
![]() | #2853 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock E5-00 RM-634 Code: [Nokia E5-00 USB Phonet]: Port opened OK! MCU Version V ICPR82_11w16.3 MCU Date 19-05-11 Product RM-634 (NOkia E5-00) Manufacturer (c) Nokia IMEI 357920048 Mastercode 1340544143 IMEI Spare 3A75290084576201 IMEI SV 3375290084576221F3000000 PSN 3652A9EAA Product Code 059H6R8 Module Code 0204474 Basic Product Code 059H390 PSD 0000000000000000 LPSN 0 WLAN MAC 943AF07E3249 APE SW 071.003 APE Variant 071.003071.003.57.01071.003.379.03 APE Test v0.034 APE HW 256 APE ADSP 256 RETU 35 TAHVO 00 AHNE 11 HW 3108 RFIC |Vapaus_5.1 | Mikki_1.1 DSP ICPR82_11w16 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ E000 Data: 740FFF Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 73404F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 357920048 #pw+220278978331457+1# #pw+503538160390197+2# #pw+421677499081747+3# #pw+684775357999691+4# #pw+465735474316987+5# #pw+515502845227502+6# #pw+........................+7# Sending BB5 NCK Code... [Nokia E5-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia E5-00 USB Phonet]: Port opened OK! MCU Version V ICPR82_11w16.3 MCU Date 19-05-11 Product RM-634 (NOkia E5-00) Manufacturer (c) Nokia IMEI 357920048 Mastercode 1340544143 IMEI Spare 3A75290084576201 IMEI SV 3375290084576221F3000000 PSN 3652A9EAA Product Code 059H6R8 Module Code 0204474 Basic Product Code 059H390 PSD 0000000000000000 LPSN 0 WLAN MAC 943AF07E3249 APE SW 071.003 APE Variant 071.003071.003.57.01071.003.379.03 APE Test v0.034 APE HW 256 APE ADSP 256 RETU 35 TAHVO 00 AHNE 11 HW 3108 RFIC |Vapaus_5.1 | Mikki_1.1 DSP ICPR82_11w16 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72207F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 73002F Simlock [5,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [6,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ E000 Data: 740FFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: 70604F Simlock [8,1] State: OPENED Type: MCC-MNC Data: 70403F Simlock [9,1] State: OPENED Type: MCC-MNC Data: 33403F Simlock [10,1] State: OPENED Type: MCC-MNC Data: 71030F Simlock [11,1] State: OPENED Type: MCC-MNC Data: 71402F Simlock [12,1] State: OPENED Type: MCC-MNC Data: 71606F Simlock [13,1] State: OPENED Type: MCC-MNC Data: 74807F Simlock [14,1] State: OPENED Type: MCC-MNC Data: 73404F Simlock NCK #pw+8x***5522243516+7# |
![]() | #2854 (permalink) |
Junior Member ![]() ![]() Join Date: Mar 2012 Location: UNITED ARAB EMIRATES
Member: 1735447 Status: Offline Sonork: 100.1614319 Thanks Meter: 18 | Nokia C-101 Rm-607 Flash Done With Cyclone Last edited by ptt; 11-18-2012 at 15:12. Reason: MOVE TO THE RIGHT THREAD --> PLEASE POST TXT LOG AS ALL OTHERS DO !!! |
![]() | #2855 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,661 | ![]() Code: Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! XGold223 ROM Detected Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm694__11.79.mcusw (XGold2)... Checking rm694__11.79.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.46_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Processing "rm694__11.79.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4015FFFF... Flashing at 0x40060000... Flashed 1048576 bytes OK Erasing 0x40280000-0x41BFFFFF... Flashing at 0x40280000... Flashed 26214400 bytes OK Erasing 0x43E20000-0x43E5FFFF... Processing rm694__11.79.ppm_c (XGold2)... Checking rm694__11.79.ppm_c... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_c.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41C00000-0x422FFFFF... Flashing at 0x41C00000... Flashed 4833640 bytes OK Processing rm694__11.79.image_c_059J8Z9 (XGold2)... Checking rm694__11.79.image_c_059J8Z9... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_c_059J8Z9.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x42300000-0x43E1FFFF... Flashing at 0x42300000... Flashed 13762560 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia USB Phonet]: Port opened OK! MCU Version V 11.79 MCU Date 15-08-12 Product RM-694 (Nokia RM-694) Manufacturer (c) Nokia IMEI 351959056572227 Mastercode 710575757 IMEI Spare 3A15590965752202 IMEI SV 3315590965752212F0000000 PPM V 11.79, 15-08-12, RM-694, (c) Nokia , C CNT Content: c_059J8Z9, V 11.79, 15-08-12, RM-694, (c) Nokia PSN 81DAEEEAH Product Code 059D1B7 Module Code 0204922 Basic Product Code 059C943 PSD 0000000000000000 LPSN 0 HW 1000 RFIC Dummy RFIC version LCD TPO BT 19e2-47026 Asic 11 HW Signature 3BC6CDE850ED75F5 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 00003519590565722200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 11-19-2012 at 23:00. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2856 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock C3-00 RM-614 Code: [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 35860804 Mastercode 5274112426 IMEI Spare 3A85060894188109 IMEI SV 3385060894188139F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: telecom AR SKD V2, V 08.63, 25-03-11, RM-614, (c) Nokia PSN 050AC95AY Product Code 059D9P7 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 04A82A098E29 HW 1009 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72234F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35860804 #pw+584309035530701+1# #pw+892762891148318+2# #pw+772061540326328+3# #pw+126250419152889+4# #pw+930330722219464+5# #pw+582110030665631+6# #pw+........................+7# Sending BB5 NCK Code... [Nokia C3-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 35860804 Mastercode 5274112426 IMEI Spare 3A85060894188109 IMEI SV 3385060894188139F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: telecom AR SKD V2, V 08.63, 25-03-11, RM-614, (c) Nokia PSN 050AC95AY Product Code 059D9P7 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 04A82A098E29 HW 1009 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72234F Simlock NCK #pw+1p`_24381786712+7# |
![]() | #2857 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock 5130 RM-495 Code: MCU Version V 05.80 MCU Date 18-12-08 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 35523203 Mastercode 543044632 IMEI Spare 3A55320283107604 IMEI SV 3355320283107624F6000000 PPM V 05.80, 18-12-08, RM-495, (c) Nokia , UA CNT Content: ua_blue_movistar_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia , , PSN GEK660578 Product Code 0580811 Module Code 0204024 Basic Product Code 0567773 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 4000 RFIC 06540601 DSP ICPR72_08w50 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 21402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35523203 #pw+689805439497673+1# #pw+717480104627517+2# #pw+192561939133967+3# #pw+850807738199565+4# #pw+036481113679216+5# #pw+848338599643338+6# #pw+........................+7# Sending BB5 NCK Code... NCK[7] - ACCEPTED MCU Version V 05.80 MCU Date 18-12-08 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 35523203 Mastercode 543044632 IMEI Spare 3A55320283107604 IMEI SV 3355320283107624F6000000 PPM V 05.80, 18-12-08, RM-495, (c) Nokia , UA CNT Content: ua_blue_movistar_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia , , PSN GEK660578 Product Code 0580811 Module Code 0204024 Basic Product Code 0567773 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 4000 RFIC 06540601 DSP ICPR72_08w50 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72207F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock NCK #pw+81Yp08915397744+7# |
![]() | #2858 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock C3-00 RM-614 Code: [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.70 MCU Date 29-07-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 3579210412 Mastercode 231621275 IMEI Spare 3A75290114224209 IMEI SV 3375290114224249F2000000 PPM V 08.70, 29-07-11, RM-614, (c) Nokia , L CNT Content: l_0594793, V 08.70, 29-07-11, RM-614, (c) Nokia PSN 005EDD5AY Product Code 059C238 Module Code 0204418 Basic Product Code 0587486 PSD 0000000000000000 LPSN 0 WLAN MAC 48DCFB510665 HW 1008 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 3579210412 #pw+931428929710160+1# #pw+936043769680122+2# #pw+109671917503238+3# #pw+724303380227369+4# #pw+827012558810157+5# #pw+409003161751069+6# #pw+........................+7# Sending BB5 NCK Code... [Nokia C3-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.70 MCU Date 29-07-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 3579210412 Mastercode 231621275 IMEI Spare 3A75290114224209 IMEI SV 3375290114224249F2000000 PPM V 08.70, 29-07-11, RM-614, (c) Nokia , L CNT Content: l_0594793, V 08.70, 29-07-11, RM-614, (c) Nokia PSN 005EDD5AY Product Code 059C238 Module Code 0204418 Basic Product Code 0587486 PSD 0000000000000000 LPSN 0 WLAN MAC 48DCFB510665 HW 1008 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+1Y‘{68936957355+7# Code: [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.70 MCU Date 29-07-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 358275041 Mastercode 6460747420 IMEI Spare 3A85720514156501 IMEI SV 3385720514156541F2000000 PPM V 08.70, 29-07-11, RM-614, (c) Nokia , M CNT Content: m_059C470, V 08.70, 29-07-11, RM-614, (c) Nokia PSN 921AC57AI Product Code 059C238 Module Code 0204418 Basic Product Code 0587486 PSD 0000000000000000 LPSN 0 WLAN MAC AC81F367E029 HW 2009 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 358275041 #pw+600147838738592+1# #pw+587301366243079+2# #pw+384948362341085+3# #pw+567904483646639+4# #pw+002403404993344+5# #pw+484342033964743+6# #pw+........................+7# Sending BB5 NCK Code... [Nokia C3-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.70 MCU Date 29-07-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 358275041 Mastercode 6460747420 IMEI Spare 3A85720514156501 IMEI SV 3385720514156541F2000000 PPM V 08.70, 29-07-11, RM-614, (c) Nokia , M CNT Content: m_059C470, V 08.70, 29-07-11, RM-614, (c) Nokia PSN 921AC57AI Product Code 059C238 Module Code 0204418 Basic Product Code 0587486 PSD 0000000000000000 LPSN 0 WLAN MAC AC81F367E029 HW 2009 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+98uH84239525828+7# Code: MCU Version V 05.80 MCU Date 18-12-08 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 358268035 Mastercode 7520143 IMEI Spare 3A85620853655800 IMEI SV 3385620853655820F6000000 PPM V 05.80, 18-12-08, RM-495, (c) Nokia , UA CNT Content: ua_red_claro_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia , , PSN GEM269558 Product Code 0580923 Module Code 0204024 Basic Product Code 0567772 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 4000 RFIC 06540601 DSP ICPR72_08w50 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 358268035 #pw+868488646353098+1# #pw+835206374959352+2# #pw+501309086437505+3# #pw+008378218856236+4# #pw+483629454837273+5# #pw+239780317264881+6# #pw+........................+7# Sending BB5 NCK Code... NCK[7] - ACCEPTED MCU Version V 05.80 MCU Date 18-12-08 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 358268035 Mastercode 7520143 IMEI Spare 3A85620853655800 IMEI SV 3385620853655820F6000000 PPM V 05.80, 18-12-08, RM-495, (c) Nokia , UA CNT Content: ua_red_claro_argentina, V 05.80, 18-12-08, RM-495, (c) Nokia , , PSN GEM269558 Product Code 0580923 Module Code 0204024 Basic Product Code 0567772 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 4000 RFIC 06540601 DSP ICPR72_08w50 LCD SEIKO BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+3=J05735645913+7# |
![]() | #2859 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | USB Unlock N85 RM-333 Code: [Nokia N85 USB Phonet]: Port opened OK! MCU Version V ICPR72_09w09 MCU Date 02-03-09 Product RM-333 (Nokia N85) Manufacturer (c) Nokia IMEI 35637602 Mastercode 7465731346 IMEI Spare 3A65730682477703 IMEI SV 3365730682477703F5000000 PPM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 CNT V 53.32.2009.34.xx PRD PSN CXD143043 Product Code 0574167 Basic Product Code 0555813 PSD 0000000000000000 LPSN 0 WLAN MAC 00BD3ABA6E09 APE SW 20.175 APE Variant 20.17520.175.021.120.175.223.9 APE Test RM333_ENO_x_2009wk03v41 APE HW 256 APE ADSP 256 APE BT HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. RETU 16 TAHVO 22 AHNE 11 HW 1550o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 PCI o256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 UEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 UPP 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 RFIC |Vapaus_4.0 | ??? DSP ICPR72_09w09 LCD 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 BT 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 ADSP Sw 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 ADSP DevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 ADSP RevID 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 AEM 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 Flip MCUSW 256qPIHCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.n256 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F BB5 Unlock Started... [Nokia N85 USB Phonet]: Port opened OK! MCU Version V ICPR72_09w09 MCU Date 02-03-09 Product RM-333 (Nokia N85) Manufacturer (c) Nokia IMEI 35637602 Mastercode 7465731346 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK and saved to "RM-333_35637602_26112012_150541.SecurityBlock.PM" WARNING: "1C800014F18200524D9695A4258C5CD5A7B9B322.C0001FF6" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C800014F18200524D9695A4258C5CD5A7B9B322 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Sending Auxiliary Loader... Auxiliary Loader Sent! Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... If phone doesn't powering into Local Mode now for some reason do following: 1. Re-insert battery 2. Power it on, when asked use Ovi/Pc Suite Mode Readed OK, Saving to "1C800014F18200524D9695A4258C5CD5A7B9B322.C0001FF6" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+075348961645687+1# #pw+450637857319116+2# #pw+933168185563083+3# #pw+656404548091290+4# #pw+413932489902940+5# #pw+458213207346745+6# #pw+246416630271758+7# [Nokia N85 USB Phonet]: Port opened OK! Sending NCK Codes.. [Nokia N85 USB Phonet]: Port opened OK! NCK[1] - ACCEPTED [Nokia N85 USB Phonet]: Port opened OK! NCK[2] - Too fast between tries (bruteforce protection) [Nokia N85 USB Phonet]: Port opened OK! NCK[3] - Too fast between tries (bruteforce protection) [Nokia N85 USB Phonet]: Port opened OK! NCK[4] - Too fast between tries (bruteforce protection) [Nokia N85 USB Phonet]: Port opened OK! NCK[5] - Unlocked Already [Nokia N85 USB Phonet]: Port opened OK! NCK[6] - Unlocked Already [Nokia N85 USB Phonet]: Port opened OK! NCK[7] - Too fast between tries (bruteforce protection) [Nokia N85 USB Phonet]: Port opened OK! MCU Version V ICPR72_09w09 MCU Date 02-03-09 Product RM-333 (Nokia N85) Manufacturer (c) Nokia IMEI 35637602 Mastercode 7465731346 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21401F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21401F Simlock NCK #pw+075348961645687+1# Unlock finished! Time taken 128.531s |
![]() | #2860 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock X2-01 RM-709 Code: [Nokia X2-01 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-709 (Nokia X2-01) Manufacturer (c) Nokia IMEI 352426057 Mastercode 5153403163 IMEI Spare 3A25240675777104 IMEI SV 3325240675777134F2000000 PPM V 08.63, 25-03-11, RM-709, (c) Nokia , L CNT Content: claro AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia PSN CJR664770 Product Code 059K1C4 Module Code 0204674 Basic Product Code 059J9S5 PSD 0000000000000000 LPSN 0 HW 1001 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 74402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 352426057 #pw+196243804851302+1# #pw+977042473132304+2# #pw+139087023319699+3# #pw+879642747990350+4# #pw+401491644303130+5# #pw+076996342177131+6# #pw+ +7# Sending BB5 NCK Code... [Nokia X2-01 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia X2-01 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-709 (Nokia X2-01) Manufacturer (c) Nokia IMEI 352426057 Mastercode 5153403163 IMEI Spare 3A25240675777104 IMEI SV 3325240675777134F2000000 PPM V 08.63, 25-03-11, RM-709, (c) Nokia , L CNT Content: claro AR SL SKD, V 08.63, 25-03-11, RM-709, (c) Nokia PSN CJR664770 Product Code 059K1C4 Module Code 0204674 Basic Product Code 059J9S5 PSD 0000000000000000 LPSN 0 HW 1001 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock NCK #pw+4rs81637162550+7# Code: MCU Version V ICPR72_09w36.16 MCU Date 01-12-09 Product RM-594 (Nokia 5230) Manufacturer (c) Nokia IMEI 35801803 Mastercode 212554423 IMEI Spare 3A85100843084102 IMEI SV 3385100843084102F7000000 CNT 12.2.089_001_U374 PSN GAK831172 Product Code 059B0G3 Module Code 0204358 Basic Product Code 0584531 PSD 0000000000000000 LPSN 0 APE SW V 12.2.089 APE Variant V 12.2.089V 12.2.089 12.2.089.374.01 APE Test rm588_ENO_x_09wk43v0.050_4G APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0522 RFIC 17141716 DSP simon_72_09w36_v04 Simlock Server SIMLOCK SERVER Simlock Key 9999900017382363 Simlock Profile 8000000000000000 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 74000F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 73404F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35801803 #pw+066244831807852+1# #pw+366906499355457+2# #pw+354365137980454+3# #pw+640576286816886+4# #pw+385951641756183+5# #pw+467621854875802+6# #pw+ +7# Sending BB5 NCK Code... [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_09w36.16 MCU Date 01-12-09 Product RM-594 (Nokia 5230) Manufacturer (c) Nokia IMEI 35801803 Mastercode 212554423 IMEI Spare 3A85100843084102 IMEI SV 3385100843084102F7000000 CNT 12.2.089_001_U374 PSN GAK831172 Product Code 059B0G3 Module Code 0204358 Basic Product Code 0584531 PSD 0000000000000000 LPSN 0 APE SW V 12.2.089 APE Variant V 12.2.089V 12.2.089 12.2.089.374.01 APE Test rm588_ENO_x_09wk43v0.050_4G APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0522 RFIC 17141716 DSP simon_72_09w36_v04 Simlock Server SIMLOCK SERVER Simlock Key 9999900017382363 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72207F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 73002F Simlock [3,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [4,1] State: OPENED Type: MCC-MNC Data: 74000F Simlock [5,1] State: OPENED Type: MCC-MNC Data: 70604F Simlock [6,1] State: OPENED Type: MCC-MNC Data: 70403F Simlock [7,1] State: OPENED Type: MCC-MNC Data: 33403F Simlock [8,1] State: OPENED Type: MCC-MNC Data: 71030F Simlock [9,1] State: OPENED Type: MCC-MNC Data: 71402F Simlock [10,1] State: OPENED Type: MCC-MNC Data: 71606F Simlock [11,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [12,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock [13,1] State: OPENED Type: MCC-MNC Data: 74807F Simlock [14,1] State: OPENED Type: MCC-MNC Data: 73404F Simlock NCK #pw+0p‚h57290944961+7# |
![]() | #2861 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 48
Member: 388033 Status: Offline Thanks Meter: 705 | ![]() Code: Pre flash tasks finished, continuing... Processing RM-626_111.040.1511_79u_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1B20020A84DB0344E1375A2C5BD7743C7BD230ED CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-626_111.040.1511_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020006800000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020006800000031, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200068 (ST), Size: 1024MBytes, VPP: Not Supported FlashChip 0x00200068 (ST), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0FC7FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 8.877s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT SOS+DECOMP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS+IVE3A Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 25.117s Flashing Speed: 41225.15 kBit/S Processing RM-626_111.040.1511_79u_prd.core.fpsx (APE)... Processing RM-626_111.040.1511_17.01_Euro3_QW3_79u_prd.rofs2.fpsx (CMT)... 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x0A580000-0x0E8FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.639s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 8.908s Flashing Speed: 47895.22 kBit/S Processing RM-626_111.040.1511_17.01_Euro3_QW3_79u_prd.rofs2.fpsx (APE)... Processing RM-626_111.040.1511_C00.01_79u_prd.rofs3.fpsx (CMT)... RM-626_111.040.1511_C00.01_79u_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x01378000-0x0139FFFF, ONENAND EraseArea[0,CMT]: 0x0E900000-0x0FC7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.234s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Writing CMT SOS+IVE3B Certificate... Programming Status OK! All blocks written OK! Time taken 0.530s Flashing Speed: 447.83 kBit/S Processing RM-626_111.040.1511_C00.01_79u_prd.rofs3.fpsx (APE)... Processing RM-626_111.040.1511_U01.01_79u.uda.fpsx (CMT)... RM-626_111.040.1511_U01.01_79u.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x0FC80000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 8.97s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 29.780s Flashing Speed: 59546.31 kBit/S Processing RM-626_111.040.1511_U01.01_79u.uda.fpsx (APE)... Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx (CMT)... RM626_APE_ONLY_ENO_11w36_v0.037.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.125s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 1.29s Flashing Speed: 37210.30 kBit/S Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia E7-00 USB Phonet]: Port opened OK! MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-626 (Nokia E7-00) Manufacturer (c) Nokia IMEI 357909041709974 Mastercode 6173537130 IMEI Spare 3A75090914079907 IMEI SV 3375090914079947F5000000 PSN CML385931 Product Code 059D0P1 Basic Product Code 0591820 PSD 0000000000000000 LPSN 0 WLAN MAC B05CE5ED81F5 APE SW 111.040.1511 APE Variant 111.040.1511111.040.1511.17.01111.040.1511.C00.01 APE Test 0.037 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 5030 RFIC |Alli_4.3.4 DSP 92_12w18 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 11-29-2012 at 19:13. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2862 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: portugal Age: 47
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 268 | UNLOCK 6210N fast wed USB CABLE Code: BB5 Unlock Started... [Nokia 6210 Navigator USB Phonet]: Port opened OK! MCU Version V ICPR71_09w12.1 MCU Date 31-03-09 Product RM-367 (Nokia 6210 Navigator) Manufacturer (c) Nokia IMEI 356950030246132 Mastercode 2034656017 Simlock Server SIMLOCK SERVER Simlock Key 2680100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26801F Reading Security Block... Security block OK and saved to "RM-367_356950030246132_01-12-2012_005541.SecurityBlock.PM" "17D001062C208B5223743B2B5CEDCE867642B700.C00039B4" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+668024598766233+1# #pw+502009587522129+2# #pw+482637651678580+3# #pw+038049909930340+4# #pw+141214211442571+5# #pw+763420542846501+6# #pw+879174363302358+7# [Nokia 6210 Navigator USB Phonet]: Port opened OK! Sending NCK Codes.. [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[1] - ACCEPTED [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[2] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[3] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[4] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[5] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[6] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! NCK[7] - Too fast between tries (bruteforce protection) [Nokia 6210 Navigator USB Phonet]: Port opened OK! MCU Version V ICPR71_09w12.1 MCU Date 31-03-09 Product RM-367 (Nokia 6210 Navigator) Manufacturer (c) Nokia IMEI 356950030246132 Mastercode 2034656017 Simlock Server SIMLOCK SERVER Simlock Key 2680100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 26801F Simlock NCK #pw+668024598766233+1# Unlock finished! Time taken 4.602 Last edited by ptt; 12-01-2012 at 22:59. Reason: CHANGE [QUOTE] TAG TO [CODE] TAG |
![]() | #2863 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: Macedonia Age: 50
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 349 | nokia 2220s unlock ok Code: MCU Version V 10.20 MCU Date 04-05-10 Product RM-590 (Nokia RM-590) Manufacturer (c) Nokia IMEI 357402049735514 Mastercode 4114306377 Setting Local Mode... Local mode Set Asic 11 HW Signature 6D628499E47579D0 Simlock Server SIMLOCK SERVER Simlock Key 2280200000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553574020497355100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 22802F Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (D86E5DBB8C117AB296E8ACC3247A63B6FDD35D6B) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 10.20 MCU Date 04-05-10 Product RM-590 (Nokia RM-590) Manufacturer (c) Nokia IMEI 357402049735514 Mastercode 4114306377 IMEI Spare 3A75040294375501 IMEI SV 3375040294375551F8000000 PPM V 10.20, 04-05-10, RM-590, (c) Nokia , AE CNT Content: SUNRISE CH, V 10.20, 04-05-10, RM-590, (c) Nokia , , PSN 1C70372AH Product Code 0597933 Module Code 0204340 Basic Product Code 0582851 PSD 0000000D00000000 LPSN 0 HW 1000 UEM 1328 UPP 3168 RFIC 0500 DSP ICPR72_09w52_U LCD SUEZ Asic 11 HW Signature 6D628499E47579D0 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553574020497355100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Last edited by ptt; 12-01-2012 at 22:57. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2864 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 275 | Nokia C2-02 (RM-692) Contact Service.. Done!! Logs: Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0001716 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D00007E9 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 93 Avaiable Physical Memory: 648.168MB Avaiable Virtual Memory: 1.886GB Avaiable Pagefile: 1.235GB Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 153 products, Filtering BB5 Products - wait... 41 Products left after filtering. Ready. Retrieving Variants for Product RM-692 - wait... 1 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm692__07.65.mcusw (XGold2)... Checking rm692__07.65.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.46_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Processing "rm692__07.65.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4015FFFF... Flashing at 0x40060000... Flashed 1048576 bytes OK Erasing 0x40280000-0x41DBFFFF... Flashing at 0x40280000... Flashed 28049408 bytes OK Erasing 0x43E20000-0x43E5FFFF... Processing rm692__07.65.ppm_a (XGold2)... Checking rm692__07.65.ppm_a... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_a.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41DC0000-0x424BFFFF... Flashing at 0x41DC0000... Flashed 4432764 bytes OK Processing rm692__07.65.image_a_059L6P9 (XGold2)... Checking rm692__07.65.image_a_059L6P9... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_a_059L6P9.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x424C0000-0x43E1FFFF... Flashing at 0x424C0000... Flashed 13369344 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia C2-02 USB Phonet]: Port opened OK! [Nokia C2-02 USB Phonet]: Port opened OK! [Nokia C2-02 USB Phonet]: Port opened OK! [Nokia C2-02 USB Phonet]: Port opened OK! [Nokia C2-02 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia C2-02 USB Phonet]: Port opened OK! MCU Version V 07.65 MCU Date 19-09-12 Product RM-692 (Nokia C2-02 / C2-07) Manufacturer (c) Nokia IMEI 358641042639707 Mastercode 3135341750 IMEI Spare 3A85460124367900 IMEI SV 3385460124367920F6000000 PPM V 07.65, 19-09-12, RM-692, (c) Nokia , A CNT Content: a_059L6P9, V 07.65, 19-09-12, RM-692, (c) Nokia PSN 4CC24A9AH Product Code 059L1X3 Module Code 0204666 Basic Product Code 059D008 PSD 0000000000000000 LPSN 0 HW 1000 RFIC Dummy RFIC version LCD TPO BT 19b5-22012 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Starting PM read in range 0-512... [Nokia C2-02 USB Phonet]: Port opened OK! [4] Reading 8 records [4,3] Reading 10 bytes [4,4] Reading 8 bytes [4,5] Reading 8 bytes [4,6] Reading 8 bytes [4,9] Reading 5 bytes [4,18] Reading 80 bytes [4,19] Reading 4 bytes [4,26] Reading 132 bytes [8] Reading 3 records [8,0] Reading 2 bytes [8,3] Reading 128 bytes [8,4] Reading 128 bytes [11] Reading 5 records [11,0] Reading 4 bytes [11,1] Reading 4 bytes [11,2] Reading 4 bytes [11,3] Reading 4 bytes [11,4] Reading 241 bytes [13] Reading 167 records [13,0] Reading 1 bytes [13,1] Reading 2 bytes [13,2] Reading 1 bytes [13,3] Reading 2 bytes [13,4] Reading 1 bytes [13,5] Reading 1 bytes [13,6] Reading 1 bytes [13,7] Reading 1 bytes [13,8] Reading 2 bytes [13,9] Reading 1 bytes [13,10] Reading 1 bytes [13,11] Reading 48 bytes [13,12] Reading 4 bytes [13,13] Reading 1 bytes [13,14] Reading 1 bytes [13,15] Reading 886 bytes [13,16] Reading 2 bytes [13,17] Reading 1 bytes [13,18] Reading 1 bytes [13,19] Reading 8 bytes [13,20] Reading 1 bytes [13,21] Reading 1 bytes [13,22] Reading 1 bytes [13,23] Reading 1 bytes [13,24] Reading 1 bytes [13,25] Reading 2 bytes [13,26] Reading 1 bytes [13,27] Reading 1 bytes [13,28] Reading 1 bytes [13,29] Reading 1 bytes [13,30] Reading 1 bytes [13,31] Reading 1 bytes [13,32] Reading 1 bytes [13,33] Reading 1 bytes [13,34] Reading 1 bytes [13,35] Reading 1 bytes [13,36] Reading 1 bytes [13,37] Reading 4 bytes [13,38] Reading 1 bytes [13,39] Reading 1 bytes [13,40] Reading 1 bytes [13,41] Reading 1 bytes [13,42] Reading 4 bytes [13,43] Reading 4 bytes [13,44] Reading 1 bytes [13,45] Reading 4 bytes [13,46] Reading 4 bytes [13,47] Reading 1 bytes [13,48] Reading 4 bytes [13,49] Reading 1 bytes [13,50] Reading 1 bytes [13,51] Reading 1 bytes [13,52] Reading 2 bytes [13,53] Reading 4 bytes [13,54] Reading 4 bytes [13,55] Reading 1 bytes [13,56] Reading 1 bytes [13,57] Reading 1 bytes [13,58] Reading 2 bytes [13,59] Reading 1 bytes [13,60] Reading 4 bytes [13,61] Reading 4 bytes [13,62] Reading 1 bytes [13,63] Reading 4 bytes [13,64] Reading 4 bytes [13,65] Reading 1 bytes [13,66] Reading 4 bytes [13,67] Reading 4 bytes [13,68] Reading 1 bytes [13,69] Reading 1 bytes [13,70] Reading 1 bytes [13,71] Reading 4 bytes [13,72] Reading 4 bytes [13,73] Reading 1 bytes [13,74] Reading 4 bytes [13,75] Reading 2 bytes [13,76] Reading 2 bytes [13,77] Reading 2 bytes [13,78] Reading 1 bytes [13,79] Reading 1 bytes [13,80] Reading 1 bytes [13,81] Reading 1 bytes [13,82] Reading 1 bytes [13,83] Reading 2 bytes [13,84] Reading 1 bytes [13,85] Reading 4 bytes [13,86] Reading 4 bytes [13,87] Reading 2 bytes [13,88] Reading 1 bytes [13,89] Reading 4 bytes [13,90] Reading 4 bytes [13,91] Reading 2 bytes [13,92] Reading 1 bytes [13,93] Reading 4 bytes [13,94] Reading 4 bytes [13,95] Reading 2 bytes [13,96] Reading 1 bytes [13,97] Reading 4 bytes [13,98] Reading 4 bytes [13,99] Reading 2 bytes [13,100] Reading 4 bytes [13,101] Reading 2 bytes [13,102] Reading 1 bytes [13,103] Reading 4 bytes [13,104] Reading 4 bytes [13,105] Reading 4 bytes [13,106] Reading 4 bytes [13,107] Reading 4 bytes [13,108] Reading 2 bytes [13,109] Reading 4 bytes [13,110] Reading 4 bytes [13,111] Reading 4 bytes [13,112] Reading 2 bytes [13,113] Reading 4 bytes [13,114] Reading 4 bytes [13,115] Reading 1 bytes [13,116] Reading 1 bytes [13,117] Reading 1 bytes [13,118] Reading 4 bytes [13,119] Reading 4 bytes [13,120] Reading 1 bytes [13,121] Reading 1 bytes [13,122] Reading 1 bytes [13,123] Reading 8 bytes [13,124] Reading 1 bytes [13,125] Reading 1 bytes [13,126] Reading 1 bytes [13,127] Reading 1 bytes [13,128] Reading 1 bytes [13,129] Reading 4 bytes [13,130] Reading 4 bytes [13,131] Reading 1 bytes [13,132] Reading 1 bytes [13,133] Reading 2 bytes [13,134] Reading 1 bytes [13,135] Reading 2 bytes [13,136] Reading 1 bytes [13,137] Reading 1 bytes [13,138] Reading 4 bytes [13,139] Reading 4 bytes [13,140] Reading 1 bytes [13,141] Reading 1 bytes [13,142] Reading 1 bytes [13,143] Reading 1 bytes [13,144] Reading 4 bytes [13,145] Reading 8 bytes [13,146] Reading 4 bytes [13,147] Reading 4 bytes [13,148] Reading 1 bytes [13,149] Reading 1 bytes [13,150] Reading 1 bytes [13,151] Reading 1 bytes [13,152] Reading 1 bytes [13,153] Reading 1 bytes [13,154] Reading 1 bytes [13,155] Reading 1 bytes [13,156] Reading 1 bytes [13,157] Reading 1 bytes [13,158] Reading 1 bytes [13,159] Reading 2 bytes [13,160] Reading 2 bytes [13,161] Reading 1 bytes [13,162] Reading 1 bytes [13,163] Reading 1 bytes [13,164] Reading 1 bytes [13,165] Reading 1 bytes [13,166] Reading 1 bytes [42] Reading 27 records [42,0] Reading 2 bytes [42,1] Reading 12 bytes [42,2] Reading 36 bytes [42,3] Reading 36 bytes [42,4] Reading 36 bytes [42,5] Reading 36 bytes [42,6] Reading 36 bytes [42,7] Reading 40 bytes [42,8] Reading 40 bytes [42,9] Reading 40 bytes [42,10] Reading 40 bytes [42,11] Reading 40 bytes [42,12] Reading 40 bytes [42,13] Reading 40 bytes [42,14] Reading 40 bytes [42,15] Reading 40 bytes [42,16] Reading 40 bytes [42,17] Reading 40 bytes [42,18] Reading 40 bytes [42,19] Reading 40 bytes [42,20] Reading 40 bytes [42,21] Reading 40 bytes [42,22] Reading 40 bytes [42,23] Reading 40 bytes [42,24] Reading 40 bytes [42,25] Reading 40 bytes [42,26] Reading 40 bytes [54] Reading 1 records [54,0] Reading 2 bytes [96] Reading 1 records [96,0] Reading 2 bytes [107] Reading 5 records [107,0] Reading 21 bytes [107,1] Reading 89 bytes [107,2] Reading 69 bytes [107,3] Reading 70 bytes [107,26] Reading 12 bytes [116] Reading 17 records [116,0] Reading 2 bytes [116,1] Reading 12 bytes [116,2] Reading 36 bytes [116,3] Reading 36 bytes [116,4] Reading 36 bytes [116,5] Reading 36 bytes [116,6] Reading 36 bytes [116,7] Reading 40 bytes [116,8] Reading 40 bytes [116,9] Reading 40 bytes [116,10] Reading 40 bytes [116,11] Reading 40 bytes [116,12] Reading 40 bytes [116,13] Reading 40 bytes [116,14] Reading 40 bytes [116,15] Reading 40 bytes [116,16] Reading 40 bytes [120] Reading 4 records [120,0] Reading 56 bytes [120,1] Reading 160 bytes [120,2] Reading 130 bytes [120,3] Reading 112 bytes [193] Reading 4 records [193,2] Reading 8 bytes [193,3] Reading 32 bytes [193,4] Reading 32 bytes [193,9] Reading 64 bytes [217] Reading 1 records [217,0] Reading 32 bytes [218] Reading 1 records [218,0] Reading 2 bytes [238] Reading 1 records [238,1] Reading 1 bytes [301] Reading 17 records [301,0] Reading 2 bytes [301,1] Reading 12 bytes [301,2] Reading 36 bytes [301,3] Reading 36 bytes [301,4] Reading 36 bytes [301,5] Reading 36 bytes [301,6] Reading 36 bytes [301,7] Reading 40 bytes [301,8] Reading 40 bytes [301,9] Reading 40 bytes [301,10] Reading 40 bytes [301,11] Reading 40 bytes [301,12] Reading 40 bytes [301,13] Reading 40 bytes [301,14] Reading 40 bytes [301,15] Reading 40 bytes [301,16] Reading 40 bytes [308] Reading 8 records [308,0] Reading 1 bytes [308,3] Reading 1 bytes [308,4] Reading 1 bytes [308,5] Reading 10 bytes [308,6] Reading 1 bytes [308,7] Reading 1 bytes [308,8] Reading 1 bytes [308,9] Reading 40 bytes [322] Reading 1 records [322,0] Reading 1 bytes [339] Reading 2 records [339,0] Reading 511 bytes [339,1] Reading 511 bytes [341] Reading 3 records [341,0] Reading 1 bytes [341,3] Reading 4 bytes [341,4] Reading 4394 bytes [354] Reading 1 records [354,0] Reading 3 bytes [355] Reading 1 records [355,0] Reading 19071 bytes [362] Reading 2 records [362,0] Reading 1 bytes Warning: Failed to Read PM Record 362,0 Failed to read PM -> Failed to get PM Record 362,1 Length Started Phone Security Analysis... [Nokia C2-02 USB Phonet]: Port opened OK! MCU Version V 07.65 MCU Date 19-09-12 Product RM-692 (Nokia C2-02 / C2-07) Manufacturer (c) Nokia IMEI 358641042639707 Mastercode 3135341750 Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical Analyze Security Error -> Failed to read Security Block Reading XGold2 Certificates... Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia C2-02 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot XGold213 -> Failed to Initialize USB Handshake Failed to Read XGold2 Certificates -> Failed to Boot XGold213 Repairing XGold2 Security Area... Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_2.5_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes [Nokia C2-02 USB Phonet]: Port opened OK! Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical Repaired OK [Nokia C2-02 USB Phonet]: Port opened OK! MCU Version V 07.65 MCU Date 19-09-12 Product RM-692 (Nokia C2-02 / C2-07) Manufacturer (c) Nokia IMEI 358641042639707 Mastercode 3135341750 IMEI Spare 3A85460124367900 IMEI SV 3385460124367920F6000000 PPM V 07.65, 19-09-12, RM-692, (c) Nokia , A CNT Content: a_059L6P9, V 07.65, 19-09-12, RM-692, (c) Nokia PSN 4CC24A9AH Product Code 059L1X3 Module Code 0204666 Basic Product Code 059D008 PSD 0000000000000000 LPSN 0 HW 1000 RFIC Dummy RFIC version LCD TPO BT 19b5-22012 Asic 11 HW Signature 6B5CEF864E5BEF0E Simlock Server SIMLOCK SERVER Simlock Key 5150200000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 00003586410426397000 Simlock Key Cnt 3 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 51502F |
![]() | #2865 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 234 | Code: Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh106_05.320, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 841CC2BF84CC82EA6ADA96FA9E MSID-Plain: 3E4EBAE900B68A03AA000000 FAID-Crypted: 8680194AEA95CECF629DB895 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 73.906s Writing 134 blocks... All blocks written OK! Time taken 11.797s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh1060_nai5.32ub_na, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8411F75E5EBCEEE53066F31BF6 MSID-Plain: 3E4EBAE900B68A03A9000000 FAID-Crypted: 28BD344BF74529EE9120D91B Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.532s Writing 9 blocks... All blocks written OK! Time taken 0.766s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh106_05.32ub, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 84DFD77179B80AAEAE2C9A9046 MSID-Plain: 3E4EBAE900B68A03A8000000 FAID-Crypted: 94E072F164D9C801B0157AF6 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01210000-0x0121FFFF] Erasing NOR Region [0x01220000-0x0137FFFF] Erase taken 26.891s Writing 84 blocks... All blocks written OK! Time taken 7.437s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Unlocking... MCU Version V 5.32 MCU Date 05-18-08 Product RH-106 (Nokia RH-106) Manufacturer (c) NMP IMEI 012190008723467 Mastercode 6415567675 Setting Local Mode... Failed to set Local Mode, Trying to unlock anyway... Asic 11 HW Signature 70B0E7BDB112801B Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B0000 Simlock IMEI 00000121900087234600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (14BB9EA37C0AC4A05E43E7B05CFA5D482ADA6CF7) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! Unlock thread finished, continuing... Post-flash tasks finished... Flash successfully finished! Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Booting UPP... UPP ID: 2292 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Flashbus Write baud set to 500Kbits Flashbus Read baud set to 4Kbits Flashbus Write baud set to 1.0Mbits Erasing NOR Region [0x01000000-0x013FFFFF] Code: MCU Version V 5.32 MCU Date 05-18-08 Product RH-106 (Nokia RH-106) Manufacturer (c) NMP IMEI 011513008454109 Mastercode 264327335 Setting Local Mode... Local mode Set Warning: Failed to read SP Info, Assuming defaults Asic 11 HW Signature E99DAE8C87763BF2 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 0000000000010002 Simlock Aux 000B0000 Simlock IMEI 00000115130084541000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (6B6E41DDE3CEDBAD1DEE2DBB1BAA6CF41CF0008C) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000554C HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35 Initializing security card... Card Serial Number: D006029C Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.01v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.81v PASSED VBAT Voltage 1.24v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.07v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.884GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work MCU Version V 5.32 MCU Date 05-18-08 Product RH-106 (Nokia RH-106) Manufacturer (c) NMP IMEI 011513008454109 Mastercode 264327335 IMEI Spare 0A11150380541400 IMEI SV 0311150380541450F9000000 PPM V 5.32, 05-18-08, RH-106, (c) NMP, UB PSN RAP327495 Product Code 0549801 Module Code 0203485 Basic Product Code 0565808 PSD 0000001800000000 HW 0337 UEM 1328 UPP 2292 RFIC 0700 DSP P06w45.v50 LCD WINTEK:NAXv84, ST7628 ADSP Sw p*V 5.32\n05-18-08\nRH-106\n(c) NMP\nub_lta Asic 11 HW Signature E99DAE8C87763BF2 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 0000000000010002 Simlock Aux 000B0000 Simlock IMEI 00000115130084541000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Auto Selecting Flash Files on User Request... Product Code: 0549801 Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 1 products, Filtering DCT4 Products - wait... 1 Products left after filtering. Ready. This is Valid DCT4 Product Retrieving Variants for Product RH-106 - wait... 45 Variants Retrieved Variant found for readen Product Data! Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh106_05.320, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84DE51F3044C02DAEDDF012EDD MSID-Plain: 3E4EBAE9008D3F7CAA000000 FAID-Crypted: BBC73BB26BEED5CB9860410D Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013AFFFF] Erasing NOR Region [0x013B0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 67.954s Writing 134 blocks... All blocks written OK! Time taken 11.812s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh1060_nai5.32ub_lta, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 842D12B92DD7314C3B85A3C52F MSID-Plain: 3E4EBAE9008D3F7CA9000000 FAID-Crypted: 6B1D97170E8E19AE855A7D3A Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013AFFFF] Erase taken 3.250s Writing 9 blocks... All blocks written OK! Time taken 0.782s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2292 [HW_UNKNOWN] rh106_05.32ub, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208828 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00000321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x00208828 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 842A6F87583C807FAC145731AE MSID-Plain: 3E4EBAE9008D3F7CA8000000 FAID-Crypted: 1025BFB5DE6EB73FCA5F3D88 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01210000-0x0121FFFF] Erasing NOR Region [0x01220000-0x0137FFFF] Erase taken 24.734s Writing 84 blocks... All blocks written OK! Time taken 7.437s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! Last edited by ptt; 12-04-2012 at 21:40. Reason: Merge the 3 posts & ADD!!! CODE TAG TO THE LOGS |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
