Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #2866 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,100 | ASHA 305 flash successfully Code: Processing rm766__03.60.mcusw (XGold2)... Checking rm766__03.60.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.49_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00EC3012, Samsung, Size: 64MBytes Processing "rm766__03.60.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4011FFFF... Flashing at 0x40060000... Flashed 786432 bytes OK Erasing 0x40120000-0x41BFFFFF... Flashing at 0x40120000... Flashed 28065792 bytes OK Erasing 0x43EE0000-0x43EFFFFF... Processing rm766__03.60.ppm_e (XGold2)... Checking rm766__03.60.ppm_e... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_e.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41C00000-0x423FFFFF... Flashing at 0x41C00000... Flashed 7014916 bytes OK Processing rm766__03.60.image_e_059L1Z2 (XGold2)... Checking rm766__03.60.image_e_059L1Z2... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_e_059L1Z2.image.fls"... Sending Certificate... Certificate Accepted Erasing 0x42400000-0x43EDFFFF... Flashing at 0x42400000... Flashed 13107200 bytes OK Erasing 0x43F00000-0x43F7FFFF... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! [Nokia USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia USB Phonet]: Port opened OK! MCU Version V 03.60 MCU Date 06-06-12 Product RM-766 (Nokia RM-766) Manufacturer (c) Nokia IMEI 354634050868064 Mastercode 4322325313 IMEI Spare 3A45360405680806 IMEI SV 3345360405680816F4000000 PPM V 03.60, 06-06-12, RM-766, (c) Nokia , E CNT Content: e_059L1Z2, V 03.60, 06-06-12, RM-766, (c) Nokia PSN C7C11C3AH Product Code 059L1F3 Module Code 0204884 Basic Product Code 059L087 PSD 0000000000000000 LPSN 0 AHNE 11 HW 1000 RFIC Dummy RFIC version LCD TPO BT 19b5-22012 Asic 11 HW Signature 392CEA79DEF3DCAC Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 00003546340508680600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-06-2012 at 21:27. Reason: Change [Quote] to [Code] Tag ;) |
The Following User Says Thank You to Mr.3. For This Useful Post: |
![]() | #2867 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,202 ![]() | Nokia 110.RM-827 Flash with usb ok Select BB5 Tab,select usb,select flash fil.write flash. Code: Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000014D HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D10003F2 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.04v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.83v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.93v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 99 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.879GB Avaiable Pagefile: 3.978GB Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Checking rm827__03.04.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... Failed to process Image File -> MCU not responds Box VPP disabled Failed to Flash -> Problem with processing MCU Image file Processing pre-flash tasks... Pre-flash tasks finished Checking rm827__03.04.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... Failed to process Image File -> MCU not responds Box VPP disabled Failed to Flash -> Problem with processing MCU Image file Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm827__03.04.mcusw (XGold2)... Checking rm827__03.04.mcusw... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_10.49_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Processing "rm827__03.04.mcusw_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x40000000-0x4001FFFF... Flashing at 0x40000000... Flashed 131072 bytes OK Erasing 0x40040000-0x4005FFFF... Flashing at 0x40040000... Flashed 131072 bytes OK Erasing 0x40060000-0x4015FFFF... Flashing at 0x40060000... Flashed 1048576 bytes OK Erasing 0x40280000-0x41BBFFFF... Flashing at 0x40280000... Flashed 25952256 bytes OK Erasing 0x43E20000-0x43E5FFFF... Processing rm827__03.04.ppm_q (XGold2)... Checking rm827__03.04.ppm_q... Flash file sorted Okay. 1 file(s) embedded into image. Processing "package_q.ppm_ebl_psi.fls"... Sending Certificate... Certificate Accepted Erasing 0x41BC0000-0x421BFFFF... Flashing at 0x41BC0000... Flashed 4409248 bytes OK Processing rm827__03.04.image_q_059M9S4_059P677_201_01 (XGold2)... Checking rm827__03.04.image_q_059M9S4_059P677_201_01... Flash file sorted Okay. 1 file(s) embedded into image. Processing "rm827__03.04.image_q_059M9S4_059P677_201_01.fls"... Sending Certificate... Certificate Accepted Erasing 0x421C0000-0x43E1FFFF... Flashing at 0x421C0000... Flashed 15073280 bytes OK Erasing 0x43E60000-0x43F3FFFF... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-06-2012 at 21:30. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
The Following User Says Thank You to Dooha_Bd For This Useful Post: |
![]() | #2868 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: Paraguay
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock N97 mini RM-555 Done! Code: [Nokia N97 mini USB Phonet]: Port opened OK! MCU Version V ICPR72_09w44.11 MCU Date 20-01-10 Product RM-555 (Nokia N97 mini) Manufacturer (c) Nokia IMEI 353391048 Mastercode 202275146 IMEI Spare 3A35930184653601 IMEI SV 3335930184653601F3000000 CNT 11.0.102_002_U310rRM555_101_000_M008, PSN CFN701613 Product Code 0597725 Basic Product Code 0580176 PSD 0000000000000000 LPSN 0 WLAN MAC 303855443AFF APE SW v 11.0.102 APE Variant v 11.0.10211.0.102.05.0111.0.102.310.03 APE Test 0.032 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 6461 RFIC |Vapaus_5.1 | Aura_?.? DSP gadget_ICPR72_09w43_p1 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 353391048 #pw+587342016960822+1# #pw+687333223348136+2# #pw+074049438782834+3# #pw+013179319647683+4# #pw+433192063280995+5# #pw+308680703710127+6# #pw+ +7# Sending BB5 NCK Code... [Nokia N97 mini USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia N97 mini USB Phonet]: Port opened OK! MCU Version V ICPR72_09w44.11 MCU Date 20-01-10 Product RM-555 (Nokia N97 mini) Manufacturer (c) Nokia IMEI 353391048 Mastercode 202275146 IMEI Spare 3A35930184653601 IMEI SV 3335930184653601F3000000 CNT 11.0.102_002_U310rRM555_101_000_M008, PSN CFN701613 Product Code 0597725 Basic Product Code 0580176 PSD 0000000000000000 LPSN 0 WLAN MAC 303855443AFF APE SW v 11.0.102 APE Variant v 11.0.10211.0.102.05.0111.0.102.310.03 APE Test 0.032 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 6461 RFIC |Vapaus_5.1 | Aura_?.? DSP gadget_ICPR72_09w43_p1 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock NCK #pw+7{608677542682+7# |
![]() | #2869 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: RAWALPINDI Age: 33
Member: 596555 Status: Offline Sonork: 100.1615495 Thanks Meter: 156 | E-7 rm-626 flash done with usb without any problem THANKS CYCLONE BOX .... Code: Scanning avaiable products... Processing D:\FLASH FILES\NEW FLASH FILE NOKIA\... Processing D:\FLASH FILES\NOKIA FLASH FILE\BB5\... Found 509 products, Filtering BB5 Products - wait... 123 Products left after filtering. Ready. Retrieving Variants for Product RM-626 - wait... 2 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-626_025.008_79.92_prd.core.fpsx (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1BC00206BBD60344697E2C3C4D9703211F896EE2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-626_025.008_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020006800000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020006800000031, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200068 (ST), Size: 1024MBytes, VPP: Not Supported FlashChip 0x00200068 (ST), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0FC7FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 5.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 22.687s Flashing Speed: 45923.56 kBit/S Processing RM-626_025.008_79.92_prd.core.fpsx (APE)... Processing RM-626_025.008_51.01_NAM_QW1_79.92_prd.rofs2.fpsx (CMT)... RM-626_025.008_51.01_NAM_QW1_79.92_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x0A580000-0x0E8FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.609s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 7.109s Flashing Speed: 54279.00 kBit/S Processing RM-626_025.008_51.01_NAM_QW1_79.92_prd.rofs2.fpsx (APE)... Processing RM-626_025.008_282.06_default_79.92.2011.37_01_prd.rofs3.fpsx (CMT)... RM-626_025.008_282.06_default_79.92.2011.37_01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x0E900000-0x0FC7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.188s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.250s Flashing Speed: 1173.09 kBit/S Processing RM-626_025.008_282.06_default_79.92.2011.37_01_prd.rofs3.fpsx (APE)... Processing RM-626_025.008_282.06_default_79.92.2011.37_01.uda.fpsx (CMT)... RM-626_025.008_282.06_default_79.92.2011.37_01.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Started group flash erase EraseArea[0,CMT]: 0x0FC80000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 5.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 21.750s Flashing Speed: 53747.46 kBit/S Processing RM-626_025.008_282.06_default_79.92.2011.37_01.uda.fpsx (APE)... Processing RM626_APE_ONLY_ENO_11w15_v0.033.fpsx (CMT)... RM626_APE_ONLY_ENO_11w15_v0.033.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x008C0000-0x00DBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... Programming Status OK! All blocks written OK! Time taken 0.875s Flashing Speed: 39781.93 kBit/S Processing RM626_APE_ONLY_ENO_11w15_v0.033.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! [Nokia E7-00 USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia E7-00 USB Phonet]: Port opened OK! MCU Version V 92_11w37.1 MCU Date 21-11-11 Product RM-626 (Nokia E7-00) Manufacturer (c) Nokia IMEI 354864047753612 Mastercode 754035635 IMEI Spare 3A45680474576301 IMEI SV 3345680474576321F2000000 PSN CCM736410 Product Code 059G4Q6 Basic Product Code 0591820 PSD 0000000000000000 LPSN 0 WLAN MAC 90CF15D1F14D APE SW 025.008 APE Variant 025.008025.008.51.01025.008.282.06 APE Test 0.33 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 5010 RFIC |Alli_4.3.4 DSP 92_11w36 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23420F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 23594F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 23420F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 23594F Simlock NCK #pw+99I67109885694+7# Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-12-2012 at 22:03. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2870 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Full Flash 603 RM-779 Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-779_113.010.1506_79u_prd.core.fpsx (CMT)... Booting CMT... [Nokia 603 USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007400C192103032108 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: F2370004FFFB3C404A28DC53BA118CCEE489C383 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT_BOOT_ROM_CRC: 2CAC45E2 CMT_SECURE_ROM_CRC: 3BC33C8B CMT Ready! RM-779_113.010.1506_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020006000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020006000000031, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200060 (ST), Size: 1024MBytes, VPP: Not Supported FlashChip 0x00200060 (ST), Size: 1024MBytes, VPP: Not Supported RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x010C0000-0x170FFFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 3.969s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT SOS+DECOMP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS+IVE3A Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 19.703s Flashing Speed: 56354,67 kBit/S Processing RM-779_113.010.1506_79u_prd.core.fpsx (APE)... Processing RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx (CMT)... RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 Started group flash erase EraseArea[0,CMT]: 0x0D1C0000-0x135BFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.93s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 9.547s Flashing Speed: 69789,77 kBit/S Processing RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx (APE)... Processing RM-779_113.010.1506_C00.01_79u_prd.rofs3.fpsx (CMT)... RM-779_113.010.1506_C00.01_79u_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 Started group flash erase EraseArea[0,CMT]: 0x01678000-0x0169FFFF, ONENAND EraseArea[0,CMT]: 0x135C0000-0x170FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.157s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Writing CMT SOS+IVE3B Certificate... Programming Status OK! All blocks written OK! Time taken 0.531s Flashing Speed: 365,03 kBit/S Processing RM-779_113.010.1506_C00.01_79u_prd.rofs3.fpsx (APE)... Processing RM-779_113.010.1506_U01.01_79u.uda.fpsx (CMT)... RM-779_113.010.1506_U01.01_79u.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364 Started group flash erase EraseArea[0,CMT]: 0x17100000-0x2E0FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 4.703s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 25.63s Flashing Speed: 65275,43 kBit/S Processing RM-779_113.010.1506_U01.01_79u.uda.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Reading info... [Nokia 603 USB Phonet]: Port opened OK! MCU Version V 79u_sr2_12w20.8 MCU Date 20-08-12 Product RM-779 (Nokia RM-779) Manufacturer (c) Nokia IMEI 35864704 Mastercode 76333613 IMEI Spare 3A85460774774101 IMEI SV 3385460774774131F0000000 PSN CVG119289 Product Code 059L568 Module Code 0204943 Basic Product Code 059G4W3 PSD 0000000000000000 LPSN 0 WLAN MAC 045A95E3C4EB APE SW 113.010.1506 APE Variant 113.010.1506113.010.1506.01.01113.010.1506.C00.01 APE Test rm779_ENO_11wk32_v0.041 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 21 HW 0701 RFIC |Alli_4.b.1 DSP 79u_sr2_12w20_2 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
![]() | #2871 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock C6-01 RM-718 Code: [Nokia C6-01 USB Phonet]: Port opened OK! MCU Version V 92PS1_10w36.4 MCU Date 06-10-10 Product RM-718 (Nokia C6-01) Manufacturer (c) Nokia IMEI 35862704 Mastercode 207736635 IMEI Spare 3A85260724182401 IMEI SV 3385260724182401F4000000 PSN 2D7DB21AA Product Code 059D916 Module Code 0204365 Basic Product Code 059C012 PSD 0000000000000000 LPSN 0 WLAN MAC 28D1AF0E637C APE SW 012.006 APE Variant 012.006.00.01012.006.09.01012.006.202.05 APE Test 0.063 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 0610 RFIC |Alli_4.3.4 DSP TB92PS1_10w36 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35862704 #pw+440605401642126+1# #pw+877126364799877+2# #pw+721230690217412+3# #pw+071282825758320+4# #pw+073084608200387+5# #pw+971641961092579+6# #pw+ +7# Sending BB5 NCK Code... [Nokia C6-01 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C6-01 USB Phonet]: Port opened OK! MCU Version V 92PS1_10w36.4 MCU Date 06-10-10 Product RM-718 (Nokia C6-01) Manufacturer (c) Nokia IMEI 35862704 Mastercode 207736635 IMEI Spare 3A85260724182401 IMEI SV 3385260724182401F4000000 PSN 2D7DB21AA Product Code 059D916 Module Code 0204365 Basic Product Code 059C012 PSD 0000000000000000 LPSN 0 WLAN MAC 28D1AF0E637C APE SW 012.006 APE Variant 012.006.00.01012.006.09.01012.006.202.05 APE Test 0.063 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 0610 RFIC |Alli_4.3.4 DSP TB92PS1_10w36 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock NCK #pw+747p55202893776+7# Code: [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_10w21.3.1 MCU Date 08-09-10 Product RM-625 (Nokia 5233/5232/5228) Manufacturer (c) Nokia IMEI 35485004 Mastercode 752277133 IMEI Spare 3A45580034916105 IMEI SV 3345580034916105F8000000 CNT 21.1.102_001_U530 PSN 077CAAFAA Product Code 059D4Q9 Module Code 0204695 Basic Product Code 059B123 PSD 0000000000000000 LPSN 0 APE SW V 21.1.102 APE Variant V 21.1.102V 21.1.102 21.1.102.530.01 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0531 RFIC 17141716 DSP ICPR72_10w16p1 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 74402F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74402F Simlock [3,1] State: CLOSED Type: 3F007F206F07FFFF @ FC00 Data: 722310 Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 74810F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 74810F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35485004 #pw+745060223911555+1# #pw+081056751043291+2# #pw+791169566633405+3# #pw+742705183717863+4# #pw+651102508955971+5# #pw+271668751734373+6# #pw+ +7# Sending BB5 NCK Code... [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia 5800 XpressMusic USB Phonet]: Port opened OK! MCU Version V ICPR72_10w21.3.1 MCU Date 08-09-10 Product RM-625 (Nokia 5233/5232/5228) Manufacturer (c) Nokia IMEI 35485004 Mastercode 752277133 IMEI Spare 3A45580034916105 IMEI SV 3345580034916105F8000000 CNT 21.1.102_001_U530 PSN 077CAAFAA Product Code 059D4Q9 Module Code 0204695 Basic Product Code 059B123 PSD 0000000000000000 LPSN 0 APE SW V 21.1.102 APE Variant V 21.1.102V 21.1.102 21.1.102.530.01 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0531 RFIC 17141716 DSP ICPR72_10w16p1 Simlock Server SIMLOCK SERVER Simlock Key 7223100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 74402F Simlock [3,1] State: OPENED Type: 3F007F206F07FFFF @ FC00 Data: 722310 Simlock [4,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 722310 Simlock [5,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock [6,1] State: OPENED Type: MCC-MNC Data: 74810F Simlock NCK #pw+6\e70623158692+7# |
![]() | #2872 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: Macedonia Age: 48
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 309 | 6700 flash ok Code: Processing rm470__13.10.mcusw (CMT)... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00000C34 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 02B00111F27A0344717583337DBD1AC4F7DCB5AB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! rm470__13.10.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0098004000000031, Toshiba, ONENAND Searching for BootCode: DualLine 32Bit FlashChip 0x00980040 (Toshiba), Size: 256MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND EraseArea[0,CMT]: 0x00060000-0x0009FFFF, ONENAND EraseArea[0,CMT]: 0x000A0000-0x0041FFFF, ONENAND EraseArea[0,CMT]: 0x00420000-0x0069FFFF, ONENAND EraseArea[0,CMT]: 0x006A0000-0x01F1FFFF, ONENAND EraseArea[0,CMT]: 0x02900000-0x02FBFFFF, ONENAND EraseArea[0,CMT]: 0x0F2C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.859s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT MCUSW Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 7.328s Flashing Speed: 28854.20 kBit/S Processing rm470__13.10.mcusw (APE)... Processing rm470__13.10.ppm_c (CMT)... rm470__13.10.ppm_c, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x01F20000-0x028FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.157s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 1.593s Flashing Speed: 32463.08 kBit/S Processing rm470__13.10.ppm_c (APE)... Processing rm470__13.10_ISM_020.image_c_de_black (CMT)... rm470__13.10_ISM_020.image_c_de_black, Type: Flash Image, Algo: BB5, XSR 1.6 PAPUBKEYS Hash for CMT: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x02FC0000-0x0F2BFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 4.719s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 5.281s Flashing Speed: 40777.82 kBit/S Processing rm470__13.10_ISM_020.image_c_de_black (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Last edited by ptt; 12-16-2012 at 15:08. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2873 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 309 | n73 flash ok Code: Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 405 products, Filtering BB5 Products - wait... 2 Products left after filtering. Ready. Retrieving Variants for Product 0539291 - wait... 1 Variants Retrieved Processing pre flash tasks... Read RPL operation not possible for Old USB Flashing Method Pre flash tasks finished, continuing... Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 355DF77C9DAFBC3378A851D29CE7989781883DCA APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1210011080C20154EB9D6DB90D17F7D96092D2D7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00080000-0x00731951, NOR EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x001E0000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00880000-0x00FEFFFF, NOR Waiting 320s for erasure finish... Erase taken 42.625s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT ADL Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 31.515s Flashing Speed: 13041.25 kBit/S Restarting MCU... Processing N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 355DF77C9DAFBC3378A851D29CE7989781883DCA APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1210011080C20154EB9D6DB90D17F7D96092D2D7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 51Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND EraseArea[0,APE]: 0x00080000-0x000FFFFF, NAND EraseArea[0,APE]: 0x00100000-0x0025FFFF, NAND EraseArea[0,APE]: 0x003C0000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 1.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS*UPDAPP Certificate... Writing APE SOS+UZIP Certificate... Writing APE PAPUBKEYS Certificate... Writing APE PASUBTOC Certificate... Writing APE ADL Certificate... Writing APE SOS+XZIP Certificate... Writing APE SOS*CORE Certificate... Writing APE SOS+ROFS Certificate... Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 56.687s Flashing Speed: 7250.25 kBit/S Restarting MCU... Processing N73_rofx_4.0839.42.2.1_PRD.V07 (CMT)... Processing N73_rofx_4.0839.42.2.1_PRD.V07 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 355DF77C9DAFBC3378A851D29CE7989781883DCA APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1210011080C20154EB9D6DB90D17F7D96092D2D7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x03920000-0x04E1FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.297s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE SOS+ROFX Certificate... Programming Status OK! All blocks written OK! Time taken 30.922s Flashing Speed: 4368.53 kBit/S Restarting MCU... Processing N73_userarea_4.0839.42.2.1.U02 (CMT)... Processing N73_userarea_4.0839.42.2.1.U02 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 355DF77C9DAFBC3378A851D29CE7989781883DCA APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1210011080C20154EB9D6DB90D17F7D96092D2D7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC22E8 (Samsung), Size: 16MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,APE]: 0x04E20000-0x07C9FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.641s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 10.359s Flashing Speed: 5979.88 kBit/S Last edited by ptt; 12-16-2012 at 15:12. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2874 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 494 ![]() | Code: MCU Version V 09.85 MCU Date 11-03-10 Product RM-519 (Nokia RM-519) Manufacturer (c) Nokia IMEI 3534250481xxxxxxxxx Mastercode 1130442545 IMEI Spare 3A35240584411506 IMEI SV 3335240584411556F6000000 PPM V 09.85, 11-03-10, RM-519, (c) Nokia , AE CNT Content: outre FR sl, V 09.85, 11-03-10, RM-519, (c) Nokia , , PSN 20B9BA1AI Product Code 059C663 Module Code 0204102 Basic Product Code 0572278 PSD 0000000D00000000 LPSN 0 HW 1001 UEM 4386 UPP 3168 RFIC 0500 DSP ICPR72_09w52_U LCD SUEZ BT 1673-46034 Asic 11 HW Signature 67BA65C85EF22311 Simlock Server SIMLOCK SERVER Simlock Key 6470200033120528 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553534250481451600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 64702F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 34002F Auto Selecting Flash Files on User Request... Product Code: 059C663 No Flash Datapackage installed for this Phone! MCU Version V 09.85 MCU Date 11-03-10 Product RM-519 (Nokia RM-519) Manufacturer (c) Nokia IMEI 35342504xxxxxxxx Mastercode 1130442545 Setting Local Mode... Local mode Set Asic 11 HW Signature 67BA65C85EF22311 Simlock Server SIMLOCK SERVER Simlock Key 6470200033120528 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553534250481451600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 64702F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 34002F Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (DCE8C30BF97EBF0B847F98A52FA301A9B85804C2) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! |
![]() | #2875 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock C3-00 RM-614 Code: [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 35976104 Mastercode 3041147127 IMEI Spare 3A95670154083800 IMEI SV 3395670154083830F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: l_059K4P4, V 08.63, 25-03-11, RM-614, (c) Nokia PSN CXF055626 Product Code 059K4P4 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 943AF066AB92 HW 4000 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ E000 Data: 740FFF Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 71402F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 73404F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 35976104 #pw+613120712236890+1# #pw+541253042522560+2# #pw+198261661251397+3# #pw+493583798818361+4# #pw+511214133779191+5# #pw+126373038640209+6# #pw+ +7# Sending BB5 NCK Code... [Nokia C3-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 35976104 Mastercode 3041147127 IMEI Spare 3A95670154083800 IMEI SV 3395670154083830F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , L CNT Content: l_059K4P4, V 08.63, 25-03-11, RM-614, (c) Nokia PSN CXF055626 Product Code 059K4P4 Module Code 0204418 Basic Product Code 059D7P2 PSD 0000000000000000 LPSN 0 WLAN MAC 943AF066AB92 HW 4000 RFIC 9 LCD SEIKO BT 4217-v529 Simlock Server SIMLOCK SERVER Simlock Key 7220700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72207F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21407F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 21402F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 73002F Simlock [5,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [6,1] State: OPENED Type: 7FFF6F07FFFFFFFF @ E000 Data: 740FFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: 70604F Simlock [8,1] State: OPENED Type: MCC-MNC Data: 70403F Simlock [9,1] State: OPENED Type: MCC-MNC Data: 33403F Simlock [10,1] State: OPENED Type: MCC-MNC Data: 71030F Simlock [11,1] State: OPENED Type: MCC-MNC Data: 71402F Simlock [12,1] State: OPENED Type: MCC-MNC Data: 71606F Simlock [13,1] State: OPENED Type: MCC-MNC Data: 74807F Simlock [14,1] State: OPENED Type: MCC-MNC Data: 73404F Simlock NCK #pw+3jAJ20854381472+7# Code: [Nokia Asha 303 USB Phonet]: Port opened OK! MCU Version V 14.76 MCU Date 23-08-12 Product RM-763 (Nokia RM-763) Manufacturer (c) Nokia IMEI 351665058 Mastercode 37322170 IMEI Spare 3A15660585581103 IMEI SV 3315660585581113F1000000 PPM V 14.76, 23-08-12, RM-763, (c) Nokia , L1 CNT Content: telecom AR SL SKD v2, V 14.76, 23-08-12, RM-763, (c) Nokia PSN 0CE6091BI Product Code 059M5P3 Module Code 0205152 Basic Product Code 059M5G6 PSD 0000000000000000 LPSN 0 WLAN MAC F48E09BB0941 RETU 51 TAHVO 00 AHNE 21 HW 2010 RFIC |Alli_4.b.1 DSP 104_PM5_14.76 LCD TPO BT 4217-v924 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72234F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 351665058 #pw+471431565550522+1# #pw+451542424791243+2# #pw+339995941700479+3# #pw+142644792434090+4# #pw+469002849821929+5# #pw+853621997038283+6# #pw+ +7# Sending BB5 NCK Code... [Nokia Asha 303 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia Asha 303 USB Phonet]: Port opened OK! MCU Version V 14.76 MCU Date 23-08-12 Product RM-763 (Nokia RM-763) Manufacturer (c) Nokia IMEI 351665058 Mastercode 37322170 IMEI Spare 3A15660585581103 IMEI SV 3315660585581113F1000000 PPM V 14.76, 23-08-12, RM-763, (c) Nokia , L1 CNT Content: telecom AR SL SKD v2, V 14.76, 23-08-12, RM-763, (c) Nokia PSN 0CE6091BI Product Code 059M5P3 Module Code 0205152 Basic Product Code 059M5G6 PSD 0000000000000000 LPSN 0 WLAN MAC F48E09BB0941 RETU 51 TAHVO 00 AHNE 21 HW 2010 RFIC |Alli_4.b.1 DSP 104_PM5_14.76 LCD TPO BT 4217-v924 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72234F Simlock NCK #pw+1t\085129677143+7# Code: [Nokia E5-00 USB Phonet]: Port opened OK! MCU Version V ICPR82_11w16.3 MCU Date 19-05-11 Product RM-634 (NOkia E5-00) Manufacturer (c) Nokia IMEI 357920046 Mastercode 3662235576 IMEI Spare 3A75290064700709 IMEI SV 3375290064700729F3000000 PSN 2F577A2AA Product Code 059K7C7 Module Code 0204474 Basic Product Code 059H390 PSD 0000000000000000 LPSN 0 WLAN MAC 28D1AF5D6D0D APE SW 071.003 APE Variant 071.003071.003.57.01071.003.386.01 APE Test v0.034 APE HW 256 APE ADSP 256 RETU 35 TAHVO 00 AHNE 11 HW 3107 RFIC |Vapaus_5.1 | Mikki_1.1 DSP ICPR82_11w16 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72234F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 72234F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 357920046 #pw+537151164564199+1# #pw+141993364075722+2# #pw+662557080991147+3# #pw+710582382020922+4# #pw+521820712106136+5# #pw+187718590148216+6# #pw+ +7# Sending BB5 NCK Code... [Nokia E5-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia E5-00 USB Phonet]: Port opened OK! MCU Version V ICPR82_11w16.3 MCU Date 19-05-11 Product RM-634 (NOkia E5-00) Manufacturer (c) Nokia IMEI 357920046 Mastercode 3662235576 IMEI Spare 3A75290064700709 IMEI SV 3375290064700729F3000000 PSN 2F577A2AA Product Code 059K7C7 Module Code 0204474 Basic Product Code 059H390 PSD 0000000000000000 LPSN 0 WLAN MAC 28D1AF5D6D0D APE SW 071.003 APE Variant 071.003071.003.57.01071.003.386.01 APE Test v0.034 APE HW 256 APE ADSP 256 RETU 35 TAHVO 00 AHNE 11 HW 3107 RFIC |Vapaus_5.1 | Mikki_1.1 DSP ICPR82_11w16 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72234F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 72234F Simlock NCK #pw+3T`30881240540+7# |
![]() | #2876 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | 1 More! Code: oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 357884046474 #pw+554174832692217+1# #pw+929781359588937+2# #pw+298883593521909+3# #pw+295006709134263+4# #pw+528335204487900+5# #pw+100452014760052+6# #pw+344660227021721+7# |
![]() | #2877 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 309 | 2760 unlock ok Code: MCU Version V 07.60 MCU Date 10-04-09 Product RM-258 (Nokia 2760 (Asia/Europe) CABLE 2760) Manufacturer (c) Nokia IMEI 356031030279298 Mastercode 527442107 Setting Local Mode... Local mode Set Asic 11 HW Signature 9B3A06E37CFB2B60 Simlock Server SIMLOCK SERVER Simlock Key 2280100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553560310302792900 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 22801F Autodetecting SP Type... Autodetection Finished Proceeding with RSA Unlock... Asking card to sign HW Signature... Signed OK (13C3DFAC5A111853ABE8B91631B9CF76B2D1A1B6) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 07.60 MCU Date 10-04-09 Product RM-258 (Nokia 2760 (Asia/Europe) CABLE 2760) Manufacturer (c) Nokia IMEI 356031030279298 Mastercode 527442107 IMEI Spare 3A65300103722909 IMEI SV 3365300103722959F1000000 PPM V 07.60, 10-04-09, RM-258, (c) Nokia, AE CNT Content: ae, V 07.60, 10-04-09, RM-258, (c) Nokia, PSN KGX091372 Product Code 0553176 Module Code 0203784 Basic Product Code 0515047 PSD 0000000D00000000 LPSN 0 HW 6001 UEM 1328 UPP 3162 RFIC 0500 DSP ICPR62_08w36_UPP LCD SUEZ BT 2222-v101 Asic 11 HW Signature 9B3A06E37CFB2B60 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553560310302792900 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Last edited by ptt; 12-21-2012 at 02:02. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2878 (permalink) |
Junior Member ![]() ![]() Join Date: Mar 2012 Location: UNITED ARAB EMIRATES
Member: 1735447 Status: Offline Sonork: 100.1614319 Thanks Meter: 18 | 5530 Xpress Music Flashing Done..Cyclone Code: Selecting USB Flashing Method... Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 23300108EE7E0052788AA129C8428EA0DF05B9A3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... DeadUSB.alg, Type: Algorithm, Rev: , Algo: XSR 1.5 Sending CMT RAW Algorithm... [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing RM-504_32.0.007_prd.core.C00 (CMT)... RM-504_32.0.007_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 Partitioning... Partitioning OK Started flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND Erase Partition (CMT) Erase taken 0.875s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*ENO Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... All blocks written OK! Time taken 31.593s Flashing Speed: 27329.48 kBit/S Processing RM-504_32.0.007_prd.rofs2.V05 (CMT)... RM-504_32.0.007_prd.rofs2.V05, Type: Flash Image, Algo: XSR 1.5, BB5 Started flash erase EraseArea[0,CMT]: 0x07260000-0x0935FFFF, ONENAND Erase taken 0.172s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... All blocks written OK! Time taken 8.750s Flashing Speed: 26645.43 kBit/S Processing RM-504_32.0.007_C03_prd.rofs3.fpsx (CMT)... RM-504_32.0.007_C03_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Started flash erase EraseArea[0,CMT]: 0x09360000-0x09E5FFFF, ONENAND Erase taken 0.62s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... All blocks written OK! Time taken 1.735s Flashing Speed: 26007.67 kBit/S Processing RM-504_32.0.007_007_000_U001.uda.fpsx (CMT)... RM-504_32.0.007_007_000_U001.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Started flash erase EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND Erase taken 0.47s Writing all blocks... Initializing TurboCache... TurboCache Loaded! All blocks written OK! Time taken 3.172s Flashing Speed: 16220.44 kBit/S Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Phone not detected at USB -> Timeout, no any compatible USB device detected. [Nokia USB Flashing Generic]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. [Nokia USB Flashing Generic]: Port opened OK! Phone not detected at USB -> Timeout, no any compatible USB device detected. Factory defaults OK Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 12-22-2012 at 21:46. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
![]() | #2879 (permalink) |
Member: 1064967 Status: Offline Thanks Meter: 131 | Unlock X2-00 RM-618 N9 Only other Tool ![]() ![]() Code: [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 357393041 Mastercode 613031670 IMEI Spare 3A75930314995909 IMEI SV 3375930314995939F9000000 PPM V 08.25, 19-05-11, RM-618, (c) Nokia , SP CNT Content: Movistar ES sl v3, V 08.25, 19-05-11, RM-618, (c) Nokia PSN DNP742918 Product Code 059C3H2 Module Code 0204491 Basic Product Code 059F742 PSD 0000000000000000 LPSN 0 HW 1000 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 72234F oclHashCat Format Detected COD File Seems to be Valid, Calculating... Codes for IMEI: 357393041 #pw+855066523039166+1# #pw+656639492389212+2# #pw+855791494413881+3# #pw+827997883540003+4# #pw+217372650569287+5# #pw+041265014308270+6# #pw+ +7# Sending BB5 NCK Code... [Nokia X2-00 USB Phonet]: Port opened OK! NCK[7] - ACCEPTED [Nokia X2-00 USB Phonet]: Port opened OK! MCU Version V 08.25 MCU Date 19-05-11 Product RM-618 (Nokia X2-00) Manufacturer (c) Nokia IMEI 357393041 Mastercode 613031670 IMEI Spare 3A75930314995909 IMEI SV 3375930314995939F9000000 PPM V 08.25, 19-05-11, RM-618, (c) Nokia , SP CNT Content: Movistar ES sl v3, V 08.25, 19-05-11, RM-618, (c) Nokia PSN DNP742918 Product Code 059C3H2 Module Code 0204491 Basic Product Code 059F742 PSD 0000000000000000 LPSN 0 HW 1000 RFIC 9 LCD SEIKO BT 2.31-SP2.31 Simlock Server SIMLOCK SERVER Simlock Key 7223400000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 72234F Simlock NCK #pw+064201057165+7# |
![]() | #2880 (permalink) |
Junior Member ![]() Join Date: Feb 2010 Location: batangas
Member: 1232240 Status: Offline Sonork: non at the moment Thanks Meter: 11 | c1-01 HANG "DONE via CYCLONE" for reference............ history: hang.... action taken : open cyclone.. choose usb for connection. add flash files...{add image) then click " Write all flash Images" result: http://imageshack.us/photo/my-images/6/rm607.png http://imageshack.us/photo/my-images/801/c101s.jpg Last edited by ptt; 12-24-2012 at 13:27. Reason: REMOVE [IMG] [IMG] TAG -- IS BETTER IF YOU POST THE TXT LOG OF THE OPERATION AS ALL OTHERS DO |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
