Yes finally I got the unlock code. Patience is needed. |
Connecting to Cyclone Server... Failed to Send SL3 COD File -> Failed to connect to Cyclone Server |
today 08:33h, (GMT +01:00) Code: Box Maintenance procedure started at 8:33:56 |
BR Alex |
Me too 10:30 gmt +01:00 : Quote:
I've just bought a cyclonebox and I can't activate it neither : Code: Box Registration Preparation procedure started at 10:30:40 |
Servers are working now. |
I think this is an external attack to the Server;). Who will be this Team??? |
Code: Box Maintenance procedure started at 16:35:29 (GMT +01:00) Still nothing. All day I trying, and nothing. Can not use box and need to work. Supporters need to tell when this server issue will be repaired!! If can not make server up at the moment, give us some executable file which we can run locally, which will update firmware of our box offline. What else! |
all my other boxes communicate without problem with they servers: - SETOOL check how much credits left - MICRO BOX checking activations on server without problem - etc. etc. Only Cyclone box, not work: Box Maintenance: Code: Box Maintenance procedure started at 22:03:03 (GMT +01:00) Code: Started credits checking procedure at 22:03:52 (GMT +01:00) Code: Support Area Launched, Engine Revision: 1.0.0.11948 Problem is, this last installer is not connecting correct to your server, or server is now accept connection from installer for some reason. |
My internet connection s u c k s (12% packet loss), and i don't see any problem connecting to Cyclone Server. Just checked few minutes ago..... Code: Box Maintenance procedure started at 06:14:14 p.m. sorry if i cant be of more help. BR |
I find where was problem in my case. I make like this: 1. Uninstall Cyclone software 2. Install older version - v1.17 3. Then, make Box Maintenance 4. Then update Cyclone software v1.86 and now working. If you first update Cyclone Software and after try Box Maintenance, will not work. At least for me was not. ;) |
