Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-15-2012, 15:10   #76 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by naveedbutt View Post
hi cyclone team see my box plz not update last 2 days
s/n D00C0587
Box Maintenance procedure started at 6:50:41 PM
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 20C5E9BCDDD9A84422337A665895A68A
Connecting to Cyclone Server
Box Maintenance Error -> Can't connect to Cyclone Server
Hi
You need try, because it can take couple time till you will get connection.
Old 02-16-2012, 10:36   #77 (permalink)
Member: 1675632
Thanks Meter: 2
@kaisak
me too having the same problem! tried atleast 15times but nothing! whts the error for? and i hve a lot of phones to unlock but cant fill credtis! pls do something to the server!
Security card found with ATR [3BFA1800008131FE454A434F503431563232319D]
Checking credits...
Card is empty, proceeding with credits fill...
Service Tag: 56DF5F5AC5A63B28FA5E5F6F336FDF98
Card credits fill error -> Can't connect to Cyclone Server
wbr
ATSCLLC
Old 02-16-2012, 11:10   #78 (permalink)
Member: 1356794
Im ned upgrade box firmware server not conect
Box Maintenance procedure started at 10:08:00 AM
Service Tag: A41E1E9376A93DC6BA9BE4A834DDF220
Old 02-16-2012, 11:46   #79 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
I restarted server, it should helps- pls try now.
Old 02-18-2012, 10:16   #80 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
Box Maintenance procedure started at 11:15:58 AM
Service Tag: C9E5A15910B6A16EFC4F9FFDAA4611ED
Old 02-18-2012, 10:46   #81 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
TRY NOW, sorry server works correctly.
Old 02-19-2012, 05:46   #82 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
mian server not work plz solve
http://forum.gsmhosting.com/vbb/f528...3/#post8162098
Old 02-19-2012, 09:24   #83 (permalink)
Member: 227348
Sonork: yolem053
Thanks Meter: 44
please solve
http://i43.tinypic.com/34q0oxi.jpg
Last edited by ptt; 02-19-2012 at 14:39. Reason: REMOVE [IMG] TAG - YOU CAN COPY & PASTE THE TXT LOG OR AT LEAST EDIT/RESIZE THE IMG BEFORE POST
Old 02-19-2012, 14:42   #84 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Server seems to be fine now
Cyclone Server (1.0.0.686), Cyclone Box Team 2008-2011 - Ready.
Old 02-21-2012, 08:32   #85 (permalink)
Cellcraft India's Avatar
Member: 287529
Thanks Meter: 62
Box Maintenance procedure started at 1:02:08 PM
Service Tag: 144A53F0220C9B16B76B3DB5015CFCF1
Old 02-21-2012, 09:32   #86 (permalink)
Cheater -Don't Deal with him-
Member: 643212
Thanks Meter: 19
To cyclone supporter,
How can i fix this problem about updating my box,
I always got an error even after update.
Can any one help me to fix this problem
This is the Screen shot.
I always got that error even after update my box.
THNX.
Old 02-21-2012, 14:42   #87 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
THNX.
Post your Box SN in this Sticky: If you need to do and get Update Skipped, Not allowed- write there SN box for update - GSM-Forum
Old 02-21-2012, 22:26   #88 (permalink)
Member: 1245922
Thanks Meter: 13
fails to load the software on your computer, save the backup and start doing their job but either ppm msw or fails, the computer shuts down and disconnects the program
Old 02-21-2012, 22:39   #89 (permalink)
Member: 1245922
Thanks Meter: 13
aqui el log
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Skipping erase on user request
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Block Write Failed -> Failed to write data data (2)
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm174__06.03.mcusw
Old 02-21-2012, 22:54   #90 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Originally Posted by louis83 View Post
aqui el log
Box VPP disabled
Certificates OK
Please Use correct thread to solve Your problem- this thread is used to report problems with server.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.20176 seconds with 10 queries
