Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-10-2009, 22:47   #1 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
Wink ::solve:: box is not in needed mode
hello,
as i see many one have problem with cyclone, when you connect your box it connect in bootloader mode after clicking in read card options or dct4/wd2/bb5 module your box go to enter main mode normally, but if you problem your box cant connect in main mode and no driver asked for instal and 4 led powered, and program say:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Bootloader]
Initialization has failed -> No connection was established, or box is not in needed mode
ferst you can repair this problem by updating your box again, but if after update still the same problem using this my own method.
i have just tell you the diode and conductress name until i get a schematic for cyclone.
connect the Y1 ground to F50 for more help, you can found this name in your cyclone mother bourd.
if not cleere just give me a ful cyclone schematic and i create fixed schematic for you.
br
Mr KhaliD
Old 06-11-2009, 03:11   #2 (permalink)
DaWizard's Avatar
Member: 61557
Thanks Meter: 130
Originally Posted by mr khalid View Post
hello,
br
Mr KhaliD
for some reason i encountered this problem but, i just reformat My PC and install a fresh copy of windows and Installed Cyclone software and everything is back t normal.
PS the first time the box is ok and after 3 times PC reboot it no longer works and this problem occurred. First i thought it is a hardware problem.
Old 06-11-2009, 07:58   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
if some one having same problem he can try updating his box on another pc and check mostly works
Old 06-11-2009, 10:53   #4 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
its just my problem solution, because for me i format my pc change it update box ... and all that thing, and its just fix with this last HW solution, and tell that to seroya and he tell me that he will check that with factory.
and i say for eavery one make all sten before you tray to fix it by my solution.
use my solution at last time.
Mr KhaliD
Old 06-11-2009, 11:29   #5 (permalink)
Member: 389669
Sonork: 100.1583354
Thanks Meter: 226
Mr KhaliD
Old 09-15-2009, 08:16   #6 (permalink)
Member: 23459
Thanks Meter: 29
i also got this problem but box still under warranty cannot open it
Old 09-15-2009, 08:36   #7 (permalink)
Member: 23459
Thanks Meter: 29
where F50 cannot find in my box can you show the picture
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
URGENT No connection was established, or box is not in needed mode sirbigman Cyclonebox 0 10-31-2009 16:07
cyclone always says box is not in need mode deywet Cyclonebox 6 10-10-2009 10:59
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.17022 seconds with 9 queries
