05-10-2011, 12:20 | #17 (permalink) | |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
Confirm , this my mistable when i fix cailibration, and already fixed . so next version should be ok , which is not a big problem , Press “read” button still can get phone general info, thanks for your report. kor hai chok dee ! Mcnbox | |
The Following User Says Thank You to Mcnbox For This Useful Post: |
05-10-2011, 16:06 | #22 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562132 Status: Offline Thanks Meter: 86 | V 3.07 IT.S GOOD AND MORE FAST MOBILE BERYLE CAN,T BOOT AT 3.06 BUT BOOT GOOD AT V3.07 Welcome to use McnBox! Selected COM30 COM5 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN2008xxxxxxxxxx Firmware V1.10 Checksum 942F-B7BE Box Connected! Ready working at COM30 ------------------------------- Start Scanning... >>->......... Results: GND:8 10,RXD:1,TXD:3,BOOT:5 [G:5 8 10 R:1 T:3] Apply to Box Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Error. ID: s0006 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Error. ID: s0006 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 002088C0(FFFFFFFF) Flash Model ST M58WR064HU Flash Size 0x800000(8.0M) Check firmware,Wait... Privacy Code: 5 Privacy Code: 1234 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 002088C0(FFFFFFFF) Flash Model ST M58WR064HU Flash Size 0x800000(8.0M) Start Reading... Read Done! File saved: E:\flashes\china read good\spread good\BERYL G602\6600L_WT6228_ST M58WR064HU.bin THANKS MCN PRO TEAM Last edited by Mcnbox; 05-10-2011 at 16:15. Reason: S/N edited |
05-10-2011, 16:18 | #23 (permalink) |
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | @all Customer also can test the 3SIMs base on 6600L7 phone , working perfect too. Best regards Mcnbox |
The Following 2 Users Say Thank You to Mcnbox For This Useful Post: |
05-10-2011, 18:27 | #25 (permalink) |
Member: 562132 Status: Offline Thanks Meter: 86 | X6I 4SIM Welcome to use McnBox! Selected COM30 COM5 Baud setting ... Set Baud done Initialize in progress ... Checking data ... Serial No. MCN20xxxxxxxxxxxx Firmware V1.10 Checksum 942F-B7BE Box Connected! Ready working at COM30 ------------------------------- Start Scanning... ->.. Results: MTK Chipset CPU: MT6253. VCC:3,GND:9 12,RXD:7,TXD:6 [V:3 G:9 12 R:7 T:6] Apply to Box Press and Holding Power button now ! Connecting, wait... Phone detected, wait.. CPU: 6253 Ver: 8A02 SW:8A00 CPU ID: 00000F00 Initialize Boot6 ... Flash(Nor) Type [INTEL] PF38F30xxM0x1xx Flash(Nor) Code 00898903(00000000) Flash(Nor) Size 0x01000000 Hex Bytes Checking baud... Set Baud:921600 Done. Start Reading(Nor)... The phone information: HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.B052-2E_L138_V102.BIN_FLNPF38F3040M0Y3DE Read Done ! Time used: 4 mins 13 s File Saved: E:\flashes\china read good\4 SIM\X6I\HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00. B052-2E_L138_V102.BIN_FLNPF38F3040M0Y3DE Press and Holding Power button now ! Connecting, wait... CPU: 6253 Ver: 8A02 CPUID: 00000F00 Release Power Button now Phone detected Infr: MT6253_B052-2E_L138_V102_HEXING53_09A_GEMINI_HW_Melody_V0.0 NV Data saved to: E:\flashes\china read good\4 SIM\X6I\NV_MT6253_B052-2E_L138_V102_HEXING53_09A_GEMINI_HW_Melody_V0.0 Backup Done. TANKS MCNPRO Last edited by hacell; 05-10-2011 at 18:53. Reason: edited sn |
The Following User Says Thank You to almalizy For This Useful Post: |
05-10-2011, 18:52 | #26 (permalink) |
No Life Poster Join Date: Oct 2009 Location: love me if you can
Member: 1150088 Status: Offline Sonork: ============ Thanks Meter: 254 | @ almalizy Nice work bro....powerfull box MCN pro box and don't forget to edit the serial number your box salam hacell |
The Following User Says Thank You to hacell For This Useful Post: |
05-10-2011, 19:22 | #27 (permalink) |
Member: 562132 Status: Offline Thanks Meter: 86 | F600 TINMO Start Scanning... ->.. Results: SPD Chipset VCC:16,GND:1 5,RXD:11,TXD:13,BOOT:15 [V:16 G:1 5 15 R:11 T:13] Apply to Box Connecting, wait... User Abort Connecting, wait... User Abort Connecting, wait... User Abort Scanning pin status,please waiting... ->...................................... Pin-status Scan Done Detect Charge-pin... Vcc-Pin16 Set to empty Detect Charge-pin complete Scanning,waiting... ->=. Operation done, Pin detect out. USB D-: 9 USB D+: 8 Spread Total expend 4 seconds ... ->#.. ... ->#... Operation done, Pin detect out. BOOT: 11 set as oInvert USB D-: 9 USB D+: 8 GND:1 5 Press [ Save ] to save Pinout [G:1 5 11 D-:9 D+:8] Apply to Box If Scan other phone, please click [Stop] Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM34 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... Boot Not support,Please Try other boot. Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM34 Connecting, wait... Press and Holding Power button now ! Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM34 Connecting, wait... Phone Connected! Info: Spreadtrum Boot Block version 2.0 Initialize boot... CPU Info 6600L/WT6226 Flash Type NOR Flash ID 00980003(00000001) Flash Model TOSHIBA TV00570002CDGB Flash Size 0x1000000(16.0M) Start Reading... Read Done! File saved: E:\flashes\china read good\spread good\F600 LCK CODE IS\6600L_WT6226_TOSHIBA TV00570002CDGB.bin Analysing,Wait... Unlock Code: 1111 Privacy Code: 1234 Unlock Code: 147369 Checking SCI USB2Serial port, wait... SCI USB2Serial Port: COM34 Connecting, wait... User Abort |
05-11-2011, 02:32 | #28 (permalink) | |
Freak Poster Join Date: May 2006 Location: On The Way Age: 49
Member: 272091 Status: Offline Sonork: 100:114011 Thanks Meter: 129 | Quote:
B.R., | |
05-11-2011, 11:22 | #30 (permalink) | |
Registered User Join Date: Jun 2006
Member: 291029 Status: Offline Thanks Meter: 97 | Quote:
this my prob http://forum.gsmhosting.com/vbb/7298991-post15.html if you dont like ..i say sorry | |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
How unlock new nokia5110 version 5.20 ? | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-21-2011 07:45 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
How unlock Nokia version 5.20 | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-17-1999 17:35 |
