05-31-2009, 18:09 | #1 (permalink) |
Product Manager Join Date: Mar 2008
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | How is working ADI Chips with McnPro Box >> 2. Now you can see Software automatic convert to ADI interface ( Included related target boot ) 3. Start to unlock or format phone before we need readout the phone Flash. Press Direct read ,and keep press power on Key , don't leave your finger away from power on Key(This is very important). A . IF the phone switch on, still keep holding power on Key, just disconnect "+" from battery connector and reconnect "+" to battery connect. B . Or disconnect "+" and cable , phone will be go to switch off, pulg in cable , you can see software ready start going to downloading boot. then connect "+" to battery connect. Now Please waiting a few mins. then save the Bin file to computer. 4. Steup for unlock . Press the unlock and select the saved file which we read above. then you can get the phone unlock code , manual type into phone, Phone unlocked . 5. For format need make backup before . 6. For flash just choose the related flashfile then press Flash button Enjoy Easy plug / play games. Best Regards ! Mcnbox Team |
The Following 6 Users Say Thank You to Mcnbox For This Useful Post: |
05-31-2009, 19:58 | #2 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Sénégal Dakar
Member: 217769 Status: Offline Thanks Meter: 24 | hi ; not work for me . Please try to test it with " MSP430 Herc/Ath " i've test many phones many times like you say without success.It detects the pinouts but the phone always switch on on "read" process.So it display " Read Flash id Error 1 " THANKS |
05-31-2009, 20:45 | #3 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @elhadjioumar Try To Keep your finger Pressed on the Power Button during all Operations...... Try to post Logs Here. Good Luck |
05-31-2009, 21:09 | #4 (permalink) |
Member: 217769 Status: Offline Thanks Meter: 24 | Your explainations are clears and too easy to be executed but it don't work for me.That's why i ask you to test the soft with " MSP430 Herc/Ath "target please.I've 20 pieces with me and I have the same problem with all them. |
05-31-2009, 21:51 | #6 (permalink) | ||
Member: 726283 Status: Offline Sonork: 100.76027 Thanks Meter: 7,616 | Quote:
If problem still not fix yet ! Then Post Flash Type or better take a PCB picture of you phone . Thanks | ||
05-31-2009, 22:34 | #8 (permalink) | |
Member: 217769 Status: Offline Thanks Meter: 24 | Quote: Welcome to use McnBox! serial port now: COM14 S/N:MCN20******* - D0*** Firmware Ver:V1.01 CheckSum:952E-B6BE Box Connected ! The Box High-speed Serial port: COM14 ------------------------------- Scanning (please waiting...) ->... Scanning results: Type:Herc/Ath GND:1 5 10 12 13,RXD:7,TXD:9 >>[G:1 5 10 12 13 R:7 T:9] Apply to Box Holding power-key... Connected OK DownLoading boot... Boot OK >>Read Flash id Error 1 | |
The Following User Says Thank You to elhadjioumar For This Useful Post: |
06-01-2009, 01:05 | #9 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @elhadjioumar As we can see, Phone is Detected & Boot is loaded Perfectly. Try Taking a Picture of the PCB and post it here, make sure Cpu & Flash Ic's are Clearly Visible.... All new Flash Types will be added A.S.A.P. McnPro Team Last edited by PhoneCareCenter; 06-01-2009 at 01:39. |
06-02-2009, 04:12 | #10 (permalink) | |
I had test .check here is the logs : Code: Holding power-key... Connected OK DownLoading boot... Boot OK Flash ID: 00980095 Flash Types: TOSHIBA TC58FVB641XB( 0x800000 ) >>Reading... | |
The Following User Says Thank You to Mcnbox For This Useful Post: |
06-04-2009, 13:52 | #12 (permalink) | |
BUT I HAVE SUCCESS WITH SPIDER CRAKED.IT CONFIRM MCN DETECT THE ADI & SPD BUT CANNOT READ IT. THERE'S LONG DAYS I TRY TO EXPLAIN U THIS BUT YOU NEVER TRY TO BELIEVE ME .NOW I HOPE U WILL DO. MAY BE IT WILL HELP U TO SOLVE MY PROBLEM . ps: I USE MCN USB SCAN FOR CONNECTION | |
06-04-2009, 15:29 | #13 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @elhadjioumar SpreadTrum & ADI are very much Supported by McnPro Software, Tested on over 200pcs before Release. For ADI Chips just keep Power Button Pressed, am sure thats a Simple Instruction. As for SpreadTrum, there have been no complains, not here, not on our other Forums. We have Posted Instructions on How to Use McnPro Software,we also told u to post Picture of PCB to help u solve the problem. I also told u to Contact me on Messanger for Fast Support & Step by Step Instructions. Guess u choose not to be helped. |
06-04-2009, 16:05 | #14 (permalink) | |
06-04-2009, 18:46 | #15 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @elhadjioumar I'm Online 18hours Everyday Bro... Almost all Users Contact me on Messanger, anyway if ever u need Fast help. U know where to find me. Good Luck McnPro Team |
How is working OM CPU with Mcnpro Box >> | Mcnbox | McnPro Box | 0 | 07-19-2009 10:08 |
<< How is working Anyka CPU with Mcnpro Box | Mcnbox | McnPro Box | 0 | 07-04-2009 10:40 |
How is working Spreadtrum CPU with Mcnpro Box >> | Mcnbox | McnPro Box | 2 | 06-30-2009 18:17 |
How is working INFINEON Chips with McnPro Box >> | Mcnbox | McnPro Box | 0 | 06-02-2009 08:32 |
How to Format MTK Chips with Mcnpro Box >> | PhoneCareCenter | McnPro Box | 9 | 04-10-2009 18:58 |
