Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Pegasus
Old 05-01-2011, 04:17   #1 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Pegasus box how it WORKS INFO
Screencasts
In this section you can witness Pegasus box functionality
Old 05-04-2011, 08:20   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
Subscribe to our YouTube channel
___
Best Regards
GsmServer Team
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post:
Old 05-04-2011, 12:47   #3 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 116,275
Samsung S5200 unlock with Pegasus Box
http://www.youtube.com/watch?v=vCFURqcPD5Q
The Following 2 Users Say Thank You to Gsmserver For This Useful Post:
Old 05-05-2011, 00:53   #4 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Old 06-10-2011, 01:46   #5 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Help center how to do
Service Mode Explanation
The “HELP” button is used to open Help file for the Pegasus software.
The “COPY TO CLIPBOARD” button copies all available info from the log file to Windows clipboard. It allows you to copy all required information to any *.txt file or messenger window.
The “SAVE LOG TO FILE” button is used to save operation logs of the Pegasus software to *.txt files. Log files are saved in the “LOGS” subfolder of the Pegasus installation folder. Files are automatically named as “Brandname dd.mm.yyyy. hh_mm_ss.log”. You may use this button to save the log information and send it to the Support Team if you encounter any technical problems.
The “CLEAR LOG” button erases all data from the log window.
The “CLOSE MODULE WINDOW” button closes active module window. Please note that all active procedures will be terminated if the module closes.
The “COM PORT” drop-down list is used to select an operation port. Pegasus software communicates through any interface that can create a virtual COM port on a PC. Native COM1 and USB operation is also supported.
The “BAUDRATE” drop-down menu is used to select operation speed. The higher speed is selected, the faster will the flashing procedure be.
The “IMEI” button reads IMEI number of the phone. It is an active window.
The “SN” button reads serial number of the handset. It is an active window.
Old 06-10-2011, 01:49   #6 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
The “WRITE FLASH” button starts the flashing procedure. Before flashing, mark the file parts that should be written. Gray (inactive) checkboxes mean that flash image does not contain corresponding flash parts. It is recommended to flash all flash parts to avoid handset software malfunction.
The “READ FLASH” button is used to dump handset flash memory into a .FLB file. This file format is used for debugging procedures. Please don’t send us backup files each time you have a problem, use this function upon our request only.
The “ERASE FLASH” button is used to erase firmware of a phone, including user data.
The ”Read Codes” button is used for reading unlock codes from the pnx490x based phone models in the flash mode.
The “CLOSE MODULE WINDOW” closes the module window.
Old 06-10-2011, 01:51   #7 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Pegasus Unlock Procedure Tutorial
1. Start the Pegasus software
2. Choose an appropriate phone brand and a model from the drop-down list.
3. Create a new module with a selected phone model.
4. Select the COM Port that your phone is connected to.
5. Press the “CONNECT” button to prepare a phone for servicing operations and connect it to the Pegasus software.
6. Service operations require an Internet connection for a smart-card authorization on a server. After a successful authorization you will see a window as shown below. At this point you will have to press Power On button on a phone keypad. Make sure that your phone is connected via cable.
7. After connecting a phone to a cable in a log window you will see the phone information such as the firmware version, IMEI, BT address, state of locks, lock codes etc.
8. To unlock your phone click the “UNLOCK” button.
9. The software will establish a connection to a server and will get re-authorized. Unlock procedure will start after the authorization process is complete.
Old 06-10-2011, 01:51   #8 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
10. An unlock procedure lasts for 4 seconds.
11. To complete an unlock procedure click the “DISCONNECT” button.
12. After the procedure the phone can be disconnected.
Old 06-10-2011, 01:52   #9 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Creating a Backup Copy
2. Choose the required phone brand and model from the drop-down list.
3. Create a new module with the selected phone model
4. Switch to the Flash mode
5. Select a COM Port that your phone is connected to.
6. Click the “READ FLASH” button
7. Pegasus software will read phone information
8. Backup save procedure will start.
9. After the procedure phone can be disconnected.
Old 06-10-2011, 01:53   #10 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Flash Procedure
1. Start Pegasus software
3. Create a new module with the required phone model selected
4. Switch to a flash mode
5. Select COM port the handset is connected to
6. Click the “Open Flash Image” button
7. Select the required firmware version/versions and click the “Open” button or just double-click the required file.
8. Pegasus uses its own flash files format named the .PGS, which is the special file that contains all flash file parts. To select required flash parts you just have to tick checkboxes on the right side of the “Flash Image” button. To begin the flash procedure, click the “Flash Image” button.
9. Press and hold the “Power On” button as soon as the software instructs you to do so.
Old 06-10-2011, 01:53   #11 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
10. This will start the Flash procedure
11. Flash procedure consist of several stages
12. After all stages completion the Flash procedure will finish.
Old 06-10-2011, 01:53   #12 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
Rebuild IMEI
1. Start Pegasus software.
2. Choose the required phone brand and model from a drop-down list.
5. Click the “CONNECT” button to prepare phone for servicing operations and connect it to the Pegasus software.
6. Service operations require Internet connection for the smart-card authorization on server. After a successful authorization you will see a window. At this point you have to press the “Power On” button on a phone keypad. Make sure that your phone is connected via cable.
7. After connecting the phone user can see the phone firmware version, IMEI, BT address, state of locks, lock codes etc. in a log window.
8. Type the Required IMEI number in the IMEI field and click the “Rebuild IMEI” button
Old 06-10-2011, 01:53   #13 (permalink)
Member: 1536588
Sonork: 100.1613366
Thanks Meter: 480
9. Software connects to the server and Rebuild IMEI procedure starts
10. The Rebuild IMEI procedure lasts for 2 seconds
11. After the procedure is completed, click the “Disconnect phone” button
12. This concludes the Rebuild IMEI procedure.
Old 06-10-2011, 10:01   #15 (permalink)
paffka's Avatar
Member: 212116
Thanks Meter: 178
FullFlash[SAM], you've done a big job, but this manual already placed in the Pegasusbox.COM as well as screencasts
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-26-1999 01:00
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.32820 seconds with 9 queries
