05-23-2013, 19:48 | #1 (permalink) |
Insane Poster Join Date: Mar 2013
Member: 1900065 Status: Offline Thanks Meter: 3 | X300 module in Pegasus says use A300 cable? (listed among Pegasus-supported devices). When I create the module in Pegasus for the X300, the hints direct to use A300 cable. I cannot find a cable marked A300 among the included cables (which are supposed to cover all Pegasus-supported phones). Is there an "A300-equivalent" cable among the included cable set, maybe with a different name? |
05-23-2013, 23:27 | #3 (permalink) |
Member: 1900065 Status: Offline Thanks Meter: 3 | Tried using the E700 cable to unlock SGH-X300, and received the following error: CHECKING CLIENT/SERVER COMPATIBILITY : FAILED; ERROR : COMMUNICATION WITH HARDLOCK FAILED The hints column says to use A300 cable, but I've read (on gsmserver.com) that the E700 cable (included with Pegasus) should be a compatible alternate. Maybe I need to restart Pegasus (box wasn't plugged in when I started the software)? Edit: Okay, reloading Pegasus app (with box already connected) worked Last edited by IceOnMars; 05-23-2013 at 23:33. Reason: added info |
