05-18-2009, 16:48 | #1 (permalink) |
Junior Member Join Date: Oct 2004
Member: 86780 Status: Offline Thanks Meter: 0 | Error unlocking n73 1.- INF and CHK using JAF JAF version 1.98.63 Detected PKEY: 9001721E Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. HW version: 7200 PCI version: RFIC version: 17211721 DSP version: scarfe_mc.05wk46v50p2 Retu version: 15 Tahvo version: 22 Production serial number: CCG710421 Product code: 0529790 Module code: 0202855 Basic production code: 0531418 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: IMEI spare to net: IMEI SV to net: LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140100000000000 Provider: Vodafone / Airtel Movil;Spain Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 21401F Block 2: Lock 1: CLOSED -> Lock Data: 21401F Searching for saved ini... Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0529790 Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-133\ Searching for default location of ini... Checking path: \Products\RM-133\ Searching for JAF saved location of ini... Checking path: C:\Archivos de programa\Nokia\Phoenix\Products\RM-133\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 17100708 Asic Mode ID: 00 Asic Public ID: EE646E180E0428EA7C0DFB7809292762E38363C6 HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 |
05-18-2009, 16:48 | #2 (permalink) |
Member: 86780 Status: Offline Thanks Meter: 0 | 2.- Phone Info with bb5 unlock: JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Read Phone Info OK Operation time: 00:11. Successfully done. Thread phone exit. |
05-18-2009, 16:49 | #3 (permalink) |
Member: 86780 Status: Offline Thanks Meter: 0 | 3.- Backing up the PM JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Saving to file: RM-133_352916028706282_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v60.1_20-03-08_RM-133_(c)_Nokia.__18_05_2009__12_39_42.bin PM308 backup OK Operation time: 00:14. Successfully done. Thread phone exit |
05-18-2009, 16:50 | #4 (permalink) |
Member: 86780 Status: Offline Thanks Meter: 0 | 4.- Finally the unlock log: JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length 8192 bytes Error. 0x10010401 Error. 0x10010401 Error. 0x10010403 Error. 0x10010403 Error. 0x10010301 Error. 0x10040201 And the programs freeze.... Anybody help me??? Regards from Spain. |
05-18-2009, 19:45 | #5 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 655846 Status: Offline Thanks Meter: 8 | Quote:
error unlocking n73 | RamSon83 | J.A.F. Plus | 5 | 07-10-2008 17:11 |
N73 error unlocking solved by .... | tomi_no | J.A.F. V-SPEC | 1 | 01-26-2008 21:45 |
N73 Always error unlocking | grahacenter | J.A.F. V-SPEC | 5 | 01-04-2008 20:42 |
Unlock N73 error please help | paimai51 | J.A.F. V-SPEC | 0 | 11-23-2007 16:36 |
