04-04-2009, 00:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | What's up witht his new BB5plus v1.02??? it cannot backup my 5610b here is info from JAF Powering the phone... Reading... MCU SW version: V 08.23 21-11-08 RM-359 (c) Nokia HW version: 1902 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w22 LCD version: SHARP PPM version: V 08.23 21-11-08 RM-358 (c) Nokia NTM BT MCM version: 2222-143 Retu version: 15 Tahvo version: 22 Content Pack version: Content: n_tmobusa_white_v2 18-Dec-08 V 08.23 21-11-08 RM-358 (c) Nokia Production serial number: CNJ167567 Product code: 0565932 Module code: 0203577 Basic production code: 0561171 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 356380020452328 IMEI spare to net: 3A 65 83 00 02 54 32 02 IMEI SV to net: 33 65 83 00 02 54 32 62 F6 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310310 Block 11: Lock 1: CLOSED -> Lock Data: 310580 Block 12: Lock 1: CLOSED -> Lock Data: 310660 Block 13: Lock 1: CLOSED -> Lock Data: 310800 Block 14: Lock 1: CLOSED -> Lock Data: 310490 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-359.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0565932 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-359\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-359\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-359\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! then from JAF bb5plus version 1.02 backup say this! JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... Reading PM Field 308 Subfield 1 with length -1024 bytes Error. 0x12200002 Error. 0x13030010 Operation time: 00:11. Done with error(s). Thread phone exit. What the hell is this update I though the update is already fix the bugs!!! common MR. raskal and Cinek is Cracked BB5plus froom Zulea is working for 5610b but the JAF paid bb5plus is kinda messed up!!! Until now this is my second BB5plus unlocking and it will have problem, how can get my money back from this paid update??? if this will not work well!!! |
04-04-2009, 00:36 | #2 (permalink) |
Member: 621698 Status: Offline Thanks Meter: 405 | Please kindly I need explanation on this matter Mr. Raskal and Cinek... this is not right, I paid for somthing that I cannot use!!! how can I make money on this software |
04-04-2009, 06:56 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | May be they are sleeping? was friday night in europe... Anyway, instead of blaming the support read the sticky post.. is not an heavy job.. you will find something like.. Supported phone models by JAF Nokia BB5Plus No TP Unlocker v1.02 by [c]Cinek: * 3120C * 3555 * 3555b * 5310 - (V58.58; V59.59 NOT SUPPORTED) * 5310b * 5610 * 5610d * 6263 * 6300i * 6301 * 6500S - (V59.60 NOT SUPPORTED) * 6500C - (V59.45 NOT SUPPORTED) * 6555 * 7500 * 7900 * 8800e -------------------------- Once you read you will get immediately your phone is not supported... BR Alex Note: anyway, the error you get are cable errors.. so check if you put the test points correctly.. |
04-04-2009, 07:11 | #5 (permalink) | |
Member: 621698 Status: Offline Thanks Meter: 405 | Quote:
04-04-2009, 07:23 | #6 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | 5610b Yeah.. he get the first part.. but can't see the phone after the software reboot it... Normally is a) bad connection (universal cable not properly in line with tp) b) fbus cable not having a good contact (keep together with the hands mobile and fbus during the job) c) mobile slow in reboot (Can you find usefull slow down you computer doing an antivirus scan during the job so it gives more time to the mobile to restart) BR Alex |
04-04-2009, 07:47 | #7 (permalink) | |
04-04-2009, 07:55 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Timing prblem then.. You can check if is timing problem easily.. If you see the program going in error and immediately after the mobile going in local mode on the display it means the mobile is slow.. (Jaf software gives more time to the mobile to restart than Cineck one) If is this slow down the computer doing antivirus scan or copying big files from a directory to another one.. For me been working well this system. BR Alex |
04-04-2009, 08:18 | #9 (permalink) | |
Where is Cinek and Mr. Raskal in time like this??? lost money already on this BB5plus JAF activation then I will loss customer too if I cannot unlock this 5610b by tomorrow... | |
04-04-2009, 09:00 | #10 (permalink) |
Member: 621698 Status: Offline Thanks Meter: 405 | Where is Mr. RASKAL and CInek in times like this??? cannot backup 5610d-2b. I have one thread and still waiting for Mr. Raskal and Cinek to reply but until now I don't get any answer from them!!! https://forum.gsmhosting.com/vbb/f537/whats-up-witht-his-new-bb5plus-v1-02-cannot-backup-my-5610b-712760/ I have 5610d that cannot be backup via BB5plus v.1.03 this is my last day to unlock this phone and to get my $20 out of the $105 that I paid for bb5plus activation at " gsm-trader " this a embarrassment for JAF team because you released this software that doesn't work well. I used two cables already but still asme problem (JAF universal cable & UFC cable) but no luck to backup the phone first before I do the unlocking. I don't want to unlock this 5610d right away because as Cinek said backup first and then unlock after because you don't know what will happen after unlocking so I can return it to the same stateif there something goes wrong... But until now still no Mr.Raskal or Cinek answer on this matter. This is only my second time using my BB5plus to unlock BB5+ and still haven't get my money back because of my competitors that using Zulea's and charge so less than me because of free solution.... and now my BB5plus is not working well this is not good... |
04-04-2009, 10:33 | #11 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | This is cable problem 100%, i see many users facing similar problems when they use universal fbus cable Don't you have a regular 7 pins cable for this phone ? It's the same as 6500 slide or 7390 cable (eventually modified with 8.2 or 10K in bsi line) And the backup is better to be done using Jaf main sw, as Cinek said in one sticky thread, this way: Open Jaf to bb5 tab and without selecting any flash files press Flash button (CRT 308 and CRT BKP must be checked first). Jaf sw will automatically save simlock and imei backups which can be used later if needed. http://forum.gsmhosting.com/vbb/showthread.php?t=666284 Also i recommend always to save full PM before unlocking (read pm adress from 0 to 400) PS. As moulnisky said, it was friday night and we can't be all the time here to answer the same questions to every user who doesn't know how to use search Last edited by renegade; 04-04-2009 at 10:38. |
new setool v1.02 | zulu land | SETool2 | 2 | 03-29-2010 16:27 |
new update v1.02 | Mohsin-* | SETool2 | 1 | 03-29-2010 12:29 |
JAF Nokia BB5Plus No TP Unlocker v1.02 by [c]Cinek released | Raskal | Service Products News & Updates | 0 | 04-02-2009 18:06 |
