Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > HalaGSM WebShop
Old 01-10-2009, 03:29   #1 (permalink)
HalaGsm's Avatar
Member: 107133
Sonork: 100.73934
Thanks Meter: 76
DreamBox SE
DreamBox SE is a new highly stable and reliable professional service
/ flash / repair product for Sony Ericsson and Siemens handsets.
__________________________________________________ ___
Description:
DreamBox SE is a new highly stable and reliable professional service / flash / repair product for Sony Ericsson and Siemens handsets. It’s based on the new thoroughly tested hardware platform that has proved to be extremely safe and efficient even after months of heavy tests under extreme loads. The producers have developed a unique unlock, flash and repair solution for Sony Ericsson handsets. DreamBox SE is the most reliable product among the tools of the type.
Outstanding Features. Supported platform DB2020, CID 49/51/52
Repair GDFS
“GDFS” – part of the handset firmware that contains phone calibrating data, service settings, phone book, SMS parameters, organizer etc. Also, GDFS contains a copy of the IMEI that has to be identical with the IMEI in OTP. DreamBox SE provides a unique GDFS repair solution. This option is not supported by other tools available on the market yet.
Standalone permanent unlock (by Test Point)
Remove SP lock using “Test Point” connection method. No patches applied. Lock is removed directly. The process doesn’t require Internet connection and is not limited.
Multiflash FOTA/Main Firmware/File System using DCU-60 cable
DreamBox provides an opportunity of multiflashing, i.e. working with numerous handsets simultaneously. The phones have to be connected to PC USB/USB HUB using DCU-60, standard SE USB data cable. A separate DBSS interface has to be run for each connected phone. In this case, the DreamBox works as a dongle and is only required for DBSS to be active.
Easy unlock by patch (CID52 only)
With this option the Unlock process is performed without “Test Point” connection. The user selects required firmware to flash the phone and DBSS offers all possible unlock patches for it automatically. No special firmware or patching tools are required. Automatic patch selection for any firmware is a unique DreamBox function.
A large and convenient flash files database.
The biggest Flash Files database. Each file is compressed to the minimum size to save the traffic. All flashes sorted by the model, platform, fw version, type and language - really easy to find the required one.
Read/write full flash
Important option for the handset repair process. Allows restoring full flash backed up from another working phone. “Test Point” connection only.
Read/write GDFS
Option for repairing handsets with corrupted GDFS zone. Allows restoring GDFS backed up from another working phone. “Test Point” connection only.
Phone customization
A simple way of the handset unbranding and language changing. No “Test Point” connection is required.
Changing CDA
CDA defines handset’s region and thus the firmware that is loaded to the phone. Also, CDA contains some phone customisation data. The correct CDA value is required for online firmware upgrades and proper handset functions.
Upgrade CID
CID - Certificate ID. This "number" defines the version of protection presented in the phone. Each CID requires its own loaders. To enable “Unlock by patch” option, CID version requires to be upgraded to CID52.
Read phone info
Read general phone information: fw version, language pack, CDA etc.
Read phone internal diagnostic log
Read advanced phone information, detect and analyze available firmware errors.
Supported models:
Sony Ericsson
K series: K530, K550, K610, K618, K770, K790, K800, K810, K818;
S series: S500;
T series: T650;
V series: V630;
W series: W580, W610, W660, W710, W830, W850, W880, Z610, Z710
Siemens
A50, A51, A52, A52V, A52M, A55, A56i, A57, A60, A65,
A70, A71, A75, AX75, A62, A62C, A65C, AX72, A31, AF51, AL21,
C45, C55,C56, C65, C66, C6C, C6V, C60, C70, C72, C72V, C75, CF75, CF110, CX6C, CX6V, CX7C, CX7V, CX65, CX70, CX75, CX7i, CF62, C81,
EL71
M46, M55, M56, MC60, , M65, M75, ME75, M6C, ME45, MT50,
S45, S45i, S46, S55, S65, S66, S68, S75, SK65, SK6R, SL6C,SL45, SL45i, SL55, SL65, S6V, S6C, SL75, SP65, SX1
3618, 6618
Package Contains : 1 x Dreambox SE
5 x cables
1 x TP cable
1 x USB connector cable
3 x Cables for connection with phones (for Siemens A31, for old models, for new models)
Price: 249 usd
To Order: http://www.halagsm.com/site.php?p=det&prod=129
BR,
HalaGsm
dreambox se plus mtbox se Fonefingz DreamBox 3 04-04-2008 19:58
DreamBox SE, DBSS v3.0 GSM_Support DreamBox 99 03-21-2008 19:16
dreambox siemen can update dreambox SE nxc DreamBox 1 03-10-2008 07:34
question about buy dreambox se .::GT-GSM MAN::. DreamBox 1 03-07-2008 01:20
DreamBOX SE Cables pinout rzeszu DreamBox 14 02-21-2008 10:59
Page generated in 0.22570 seconds with 9 queries
