01-18-2010, 17:25 | #1 (permalink) |
Product Manager Join Date: Jan 2003 Location: halagsm Age: 47
Member: 20059 Status: Offline Sonork: 100.73934 Thanks Meter: 2,756 | Octopus Box (Packaged with 17pcs cables) Octopusbox First in the world! Unlock LG GB190, GB190a and GB190b phones with new Octopus 1.0.7! Added support for the following phone models: * GB190 - Unlock, Write firmware, Read/Write EEPROM, Read/Write Full flash - All world first * GB190a - Unlock, Write firmware, Read/Write EEPROM, Read/Write Full flash - All world first * GB190b - Unlock, Write firmware, Read/Write EEPROM, Read/Write Full flash - All world first * GD900 - Unlock via USB/UART, Repair IMEI, Write Firmware via USB/UART, Read/Write EEPROM via USB/UART * GD900e - Unlock via USB/UART, Repair IMEI, Write Firmware via USB/UART, Read/Write EEPROM via USB/UART * GD900f - Unlock via USB/UART, Repair IMEI, Write Firmware via USB/UART, Read/Write EEPROM via USB/UART * KU830 - Unlock (by patch), Write Firmware, Read/Write/Repair NVM Main Octopus features: * Direct unlock * All locks reset * Read phone information * Firmware update * Read/write FullFlash and Calibration data files * Read firmware version * Full factory reset Depending on the platform, Octopus can perform additional features: * LG Qualcomm language packs editor * Writing firmware *.m0 files * Flashing FullFlash binary files * Flashing firmware *.ssw files * Single-file flashing * Read/write EEPROM * Read/write NVM * IMEI repair * Fast country change * Calibration data restore * Format FFS * Repair phone reset Octopus Box Package Contains * Octopus box with smart-card inside * Cable set for LG phones: o USB A-B cable o LG KF300 cable o LG KG800 cable o LG KE500 cable o LG 510 cable o LG B1200 cable o LG 7050 cable o LG U81XX cable o LG KG190 cable o LG 1800 cable o LG KG300 cable o LG U8XX cable o LG A2 cable o LG micro USB cable o LG KU 311 cable o LG FOMA cable o LG GW520 cable * Quick start guide * 1 year (with 10 GB download limit) of FREE access to flash file download area at Stock In ;- Hong Kong - UK - France ( Free shipment ) Contact US ICQ: 280918251 HalaGsm Ltd E-mail: [email protected] MSN: [email protected] Skype: halagsm Phone: 00447850327122 Web: www.halagsm.co.uk Sonork: 100.73934 |
The Following 2 Users Say Thank You to Halas For This Useful Post: |
01-19-2010, 16:09 | #2 (permalink) |
Member: 20059 Status: Offline Sonork: 100.73934 Thanks Meter: 2,756 | Octopus 1.1.0 - world's first solution with full support for LG GM750 and GM750n phones! Implemented features: LG GM750/ GM750n - Unlock, Security Repair, IMEI Repair, Bluetooth Address Repair, Firmware Write, NVM Read, Write and Repair. [!] You will need Micro UART cable to perform Unlock, Security Repair, IMEI Repair, Bluetooth Address Repair, or NVM Read, Write and Repair. To perform those operations, you will have to do following steps: 1. Turn off the phone. 2. Connect Micro UART cable to the phone and press the Power button 3. When windows logo appears, click the "Read info" button 4. If phone information is read properly, perform the operation [!] To flash the phone, you will have to enter the Emergency download mode. To do so, turn off the phone, press and hold Decrease Volume and Multitask key at the same time and then press the Power button |
09-17-2010, 15:39 | #3 (permalink) |
Member: 20059 Status: Offline Sonork: 100.73934 Thanks Meter: 2,756 | Octopus Box v 1.4.9 is out! We have added support for LG KP330, LG TU330, LG KG810, LG MG810c, LG MG810d, LG KP109b, LG GM360, LG GM360GO, LG GM360i, and world's first support for LG KH8200! Octopus Box v 1.4.9 Release Notes: * KH8200 – added world's first Unlock (KW820905 and KW820907 versions), Write Firmware, Read/Write/Repair NVM * KP330, TU330 – added Direct Unlock, Write firmware, Repair IMEI, Repair BlueTooth address, Read/Write/Repair NVM * KG810, MG810c, MG810d – added Unlock (direct and by reading codes), Write Firmware, Read/Write Full Flash, Read/Write EEPROM, Repair IMEI * KP109b – added Unlock (direct and by reading codes), Write Firmware, Read/Write EEPROM, Repair IMEI * GM360, GM360GO, GM360i – added Unlock (by reading codes), Write Firmware, Read/Write EEPROM * Improved unlock procedure for KH2100 (added direct unlock for KW210720 version) * Added new skins - "HeroesStyle" and "Terminal4bit" Bunch of models added to support LG KP330, LG TU330, LG KG810, LG MG810c, LG MG810d, LG KP109b, LG GM360, LG GM360GO, LG GM360i, and world's first support for LG KH8200! http://forum.gsmhosting.com/vbb/f475...9/#post6342772 Order Now B.r HalaGsm |
The Following 4 Users Say Thank You to Halas For This Useful Post: |
Octopus Box (Packaged with 17pcs cables) | IPMART | ipmart WebShop | 0 | 11-19-2009 10:40 |
COMBO Cable SET with USB Power + TX2 line enabled (Packaged with 17pcs cables) | IPMART | ipmart WebShop | 0 | 06-18-2009 03:20 |
Cable Compatible For Samsung and SE For HWK UFS / N-Box (Packaged with 22pcs cables) | IPMART | ipmart WebShop | 0 | 05-08-2009 01:50 |
Cable Set Compatible For Nokia BB5+ For Genie Box (Packaged with 17pcs cables) | IPMART | ipmart WebShop | 0 | 03-30-2009 06:30 |
i-Pmart BX Series Full Set Cable Compatible For NS Pro (Packaged with 17pcs cables) | IPMART | ipmart WebShop | 0 | 03-06-2009 15:20 |
