09-05-2013, 22:24 | #18 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 44
Member: 70206 Status: Offline Sonork: 100.1616268 Thanks Meter: 27 | pls ihave peoblem in i9300 when use this boot clip when try repair dead phone i9300 by gpgs boot phone go to download mood but lcd inverter when try normal open whit screen this with 5 phone i 9300 what is the problem pls help |
09-05-2013, 23:04 | #19 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Lima Age: 42
Member: 138423 Status: Offline Sonork: 75171702 Thanks Meter: 12 | Quote:
Hello you recover you S3 can you help me about steps to recovery if have images is better for me thanks | |
10-26-2013, 05:03 | #21 (permalink) |
Freak Poster Join Date: May 2008 Location: Morocco
Member: 782802 Status: Offline Sonork: lukbo3o Thanks Meter: 27 | follow steps exactlly and repeat 2nd time if not going download mode be sure thats hardware problem. for me thats worked for 7 pcs and not for 4!!! good luck |
10-29-2013, 11:25 | #23 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054081 Status: Offline Sonork: 100.1648306 Thanks Meter: 0 | Success to realive but stuck on IMEI I try to use s-boot clip to repair dead I9300 bought from ebay (no sign of life at all). It still 90% success, the other 10% is the IMEI problem that shown generic IMEI. This is what I've done: 1. Insert S Boot clip as described in many thread. 2. Flash with original ROM I900XXALF2 (using another stock rom for i9300 is always stuck on samsung logo). Found anoher problem, based band 'unknown', IMEI null and efs folder is empty. I try to clone from good phone (N7000) to insert efs file, succeed using EFS-cwm-flasher (please find the flasher from google). Based band problem resolved. 3. Still remain IMEI problem, now I'm trying to resolve the problem without box...hopefully succeed and sharing to others. Thanks. |
11-02-2013, 20:46 | #24 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | Done 10 pieces I9300 Regards .::M Irfan::. |
The Following 2 Users Say Thank You to .::M Irfan::. For This Useful Post: |
11-12-2013, 22:42 | #25 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1240599 Status: Offline Thanks Meter: 11 | Going to post the final tutorial on how to use this properly step by step. 1. Plug sd card and cable into phone 2. Phone will come on in download mode and if screen is normal and not upside down then is fixed. 3. If screen comes on upside down then take cable out of phone without turning off and plug in USB cable to computer and flash fully with Odin ( I use 9300xella Korean factory files found at xda developer website just use search buttons.it works really well for z3x IMEI repair which you need to do later.) 4.straight after phone will not be able to come on and has no efs folder. 5. Search gsmhosting for i9300 efs repair file (it will be a .tar file extension) 6. Out phone into download mode again and flash this file in PDA 7. Phone will then restart into normal mode 8. IMEI will be 004499 but will have baseband so just repair using z3x as normal. 9. Done! Fully working phone! If your phone will not accept the efs-i9300.tar phone then it's hardware problem. I have fixed every handset that has come back on so far and all without needing to jtag! |
11-12-2013, 22:53 | #26 (permalink) | |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | Quote:
11-13-2013, 21:12 | #29 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | I disagree I disagree revolution cel.. This cable works fine.. I've done severals i9300 and all come baknto life again.. Maybe your cable is not working properly.. |
