1100 flash prob get 1100 hang try flash it with ufs & jaf dont boot with mx boot but dont finish flash reheat pcb & change version same prob Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D2E857:2984DA60 ASIC type: 2 UEM Imei: 35837500506440 Flash Imei: 35837500506440 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35837500506440_BA CK.rpl" Processing file: rh18_06.640 as MCU [DCT4,DCT4 ALGORITHM] size: 1.45 MB Supported Ids: 0120, 0121, 1120, 1021, 1201, 2201 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D2E857:2984DA60 Area [01000000-0100FFFF] erased in 0.750 s Area [01010000-011EFFFF] erased in 22.078 s Area [011F0000-011FBFFF] erased in 1.203 s Area [013F0000-013FBFFF] erased in 0.031 s Area [017F0000-017FBFFF] erased in 0.062 s Flash programming ... Error while programming [14] at 0x010CC000, Result: 0872 flashing terminated ! Flashing terminated with error(s) in 1 min 34.015 s RX Buffer: 0872 |
problem resolved by changing batt connector & flash ok |
temchi tnayyek 5irlak 1100 ya zebbi |
