01-20-2010, 08:05 | #1 (permalink) |
Insane Poster Join Date: Feb 2008 Location: Narra, Palawan
Member: 703121 Status: Offline Thanks Meter: 37 | 1100 ??????????? serial done sa mxkey with procedure 1100 ??????????? serial done sa mxkey with procedure Tols Jaf Box Mxkey Action taken: *Open Shell Of Mxkey *Go To Nokia service tool *Dct4 *Scan *Go To Service *Go to IMei and security *Go to Online Loger *Put User name and Pass word *Chk use dongle id *LogIn *Chk Dct4 Imei *Then Do Selected job *Done logs: Code: ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C3D117:2984DA60 ASIC type: 2 UEM Imei: 35089410775747 Connecting to server ...OK, Login ... Hello C0806C67, you have 3040 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35089410775747.RPL" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C3D117:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: 35089410775747-0 Product Code: 0512256 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AA Language Pack: English,Danish,Norwegian,Swedish Imei net: 35089410775747 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Screen Shot: Salamat Po Press Thanks If you Like It |
The Following 4 Users Say Thank You to aljolas For This Useful Post: |
LG-KH1800 SHOW (KOREAN PHONE) UNLOCKED DONE AGAIN! PIC'S and PROCEDURE INSIDE | Ligalig | LG | 1 | 03-30-2010 07:40 |
3110c no power nabuhay phone Restrition code Info sa MXkey Super Dangle Invalid! Done | aljolas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-11-2010 05:25 |
BB 8320 unlock done sa MXKEY | miguel_john1975 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-04-2010 11:49 |
707sc11 2008_06 unlock DONE!!!!..with procedure.. | nath15 | UST Pro II | 1 | 01-06-2010 15:35 |
2610b version 7.04 unlock done with procedure | hagard | Universalbox | 15 | 11-01-2009 08:19 |
