01-30-2010, 12:30 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: jodhpur Age: 40
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | 1110i Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D244B5:2984DA60 ASIC type: 2 UEM Imei: 35363201397430 Flash Imei: 35363201397430 MasterCode: 5174143535 RPL saved to "C:\mobileEx\3.3\data\backup\35363201397430_BACK.r pl" Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: 35363201397430-1 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: - not available. Imei net: 35363201397430 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED then i update sp lock Imei net: 35363201397430 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 Updating SIMLOCK ...Error 0x14 |
01-30-2010, 13:41 | #3 (permalink) |
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | full erase flash phone write pm and when sp unlock show errer net: 35363201397430 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 Updating SIMLOCK ...Error 0x14 |
1110i but not 1110i...confusion...help... | asrar | Nokia Hardware & Hardware Repair | 8 | 10-24-2008 19:45 |
convert 1110 to 1110i or 1112 ? | gsmsikar | UFS2 + UFS3-Tornadoflasher | 4 | 04-17-2007 14:48 |
1110i need unlock | ..::M-GSM::.. | HWK | 3 | 12-18-2006 08:27 |
unlock 1112-1110i[RH93] fail | neo_urbon | Universalbox | 8 | 10-27-2006 02:11 |
