07-28-2010, 20:06 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: kolkata
Member: 772386 Status: Offline Thanks Meter: 157 | 1110i imei Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5718 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00903557:2984DA60 ASIC type: 2 UEM Imei: 35641401170778 Flash Imei: Empty MasterCode: Invalid imei checksum ! Phone Type: RH-93 SW Version: V 7.02 10-12-07 RH-93 (c) NMP Imei plain: ??????????????-? Product Code: 0533137 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: D56B8D5EBA7869A6 PROFILE_BITS: 36B856D253019EF7 when i go to write rpl select dct4 and click do selecet job then i can see the log what i do plz help me, log is under ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5718 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00903557:2984DA60 ASIC type: 2 UEM Imei: 35641401170778 [InternalErrorFault] Receive Timeout (case id=0xCB01) plz help me its very urzent , tell me what i do |
The Following User Says Thank You to tuntai For This Useful Post: |
07-29-2010, 05:34 | #5 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Everywhere Age: 39
Member: 1276738 Status: Offline Thanks Meter: 24 | Bro u can get rpl by MANUAL method. 1.click on Manual 2.select asic id ,(for 1110i select asic2) 3. write imei in imei box and do job,Your rpl saved in C:\mobileEx\3.4\data\backup\RPL |
07-29-2010, 08:36 | #8 (permalink) |
No Life Poster Join Date: Jul 2010 Location: serai naurang pakistan
Member: 1352180 Status: Offline Sonork: 100.1605782 Thanks Meter: 61 | ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0051FC52:2984DA60 ASIC type: 2 UEM Imei: 35481901075412 [InternalErrorFault] Receive Timeout (case id=0xCB01 im also facing this problem plz br manoli help us |
07-29-2010, 09:01 | #9 (permalink) | |
Member: 1352180 Status: Offline Sonork: 100.1605782 Thanks Meter: 61 | Quote:
[InternalErrorFault] Receive Timeout (case id=0xCB01) ??????????????/ | |
07-30-2010, 08:10 | #13 (permalink) |
Freak Poster Join Date: Oct 2008 Location: india.burdwan
Member: 875675 Status: Offline Sonork: no Thanks Meter: 11 | nokia110i ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: DEAD DEAD DEAD DEAD DEAD DEAD DEAD DEAD Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C32AB9:2984DA60 ASIC type: 2 UEM Imei: Empty |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
