1112 after 30se off i have 1112 after 30se off plz help me |
bro check imei number |
write rpl u r problem solve if not then may be uem is damage need 2 replase is try rpl |
bro maybe uem is damage....so replace it....and try to rpl write |
uem damage change uem and calculate rpl |
same problem with 1650 i trying write rpl see this log and help me ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0057F703:DA3BDA66 ASIC type: 11 UEM Imei: 35205102235940 Connecting to server ...OK, Login ... Hello C0805726, you have 1990 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35205102235940.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0057F703:DA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35205102235940-7 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: IA Language Pack: - not available. Failed to read SP data |
