08-25-2010, 05:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1276771 Status: Offline Thanks Meter: 33 | 1112 simcard registration failed plss help me A.S.A.P [email protected] |
08-25-2010, 10:59 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
08-25-2010, 18:18 | #8 (permalink) |
No Life Poster Join Date: May 2009 Location: ISLAMABAD Age: 33
Member: 1033862 Status: Offline Sonork: 100.1652017 Thanks Meter: 538 | Bro ur set is blocked and by chance its working in other sims & after some times its will also dont work with other sim tested by me [email protected] |
08-26-2010, 12:15 | #15 (permalink) |
Member: 1276771 Status: Offline Thanks Meter: 33 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00083EEF:2984DA60 ASIC type: 2 UEM Imei: 35957101053547 Flash Imei: 35957101053547 MasterCode: 1011246752 RPL saved to "C:\mobileEx\3.4\data\backup\35957101053547_BACK.r pl" Phone Type: RH-93 SW Version: V 6.01 22-11-06 RH-93 (c) NMP Imei plain: 35957101053547-1 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AC Language Pack: English,Danish,Icelandic Imei net: 35957101053547 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED UPDATING SPLOCK Imei net: 35957101053547 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-93_35957101053547_SIM.RPL" Updating SIMLOCK ...ERROR: 01 Reading Simlock info ... Imei net: 35957101053547 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED\ ADD ME ID AND USE TEAMVIEWER PLSSS [email protected] |
SimCard Blocked | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-20-2000 04:25 |
5110 5.28 simcard rejected | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-03-2000 13:44 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
