07-15-2010, 06:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: India
Member: 982335 Status: Offline Thanks Meter: 202 | 1200 dead....is there any solution..? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 8000 8001 [unused/removed] ExtBUSC: C6BC 626D C0EC 747E D3D9 4A32 40BE 6FF3 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00850759A3BDA66 ASIC type: 11 UEM Imei: 35573402639706 Processing file: rh99_06.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 8000 8001 [unused/removed] ExtBUSC: C6BC 626D C0EC 747E D3D9 4A32 40BE 6FF3 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00850759:2984DA60 Area [01000000-0100FFFF] erased in 0.593 s Area [01010000-013AFFFF] erased in 31.485 s Area [013B0000-013EFFFF] erased in 2.282 s Area [017C0000-017EFFFF] erased in 0.047 s Flash programming ... Programming completed in 18.797 s File Processed in 1 min 1.422 s Processing file: rh990_nai6.00mg as CNT [DCT4,DCT4 ALGORITHM] size: 151.84 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 8000 8001 [unused/removed] ExtBUSC: 052E 1408 123C 0282 5C00 60A0 404C 4004 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00850759:2984DA60 Area [01380000-013AFFFF] erased in 1.875 s Flash programming ... Programming completed in 1.281 s Content extract fail, continue anyway ... File Processed in 35.921 s Processing file: rh99_06.00mg as PPM [DCT4,DCT4 ALGORITHM] size: 987.43 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 8000 8001 [unused/removed] ExtBUSC: 052E 1408 123C 0282 5C00 60A0 404C 4004 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00850759:2984DA60 Area [01240000-0124FFFF] erased in 0.641 s Area [01250000-0137FFFF] erased in 10.547 s Flash programming ... Programming completed in 8.032 s File Processed in 29.766 s Flashing completed in 2 min 56.078 s Phone not responding ! Total time to process is 3 min 48.594 s |
The Following User Says Thank You to Rin2 For This Useful Post: |
07-15-2010, 07:46 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | Quote:
well boss fistly change the charging jack, also before soldering the charging jack just clean the tracks for the easy flash cable in the pcb by soldering iron, then just remove the components above the battery connector for the bsi line, then full flash it with latest version......... wbr: sanjubhai. | |
07-15-2010, 08:08 | #5 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 896307 Status: Offline Sonork: 0096 Thanks Meter: 231 | Sometimes problem of cable( fbus) use good cable erase fully use ufs-3 to flash them not max with higher ver. if this failed ,it is hardware prob. rehot ic flash and flash them salam |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
