01-21-2010, 17:09 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 533912 Status: Offline Thanks Meter: 115 | 1200 imei problem Version Info: HW version: 1501 UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR62_08w31_UPP LCD version: WIN:MYKS:01 ST7506 PPM version: V 5.80 14-11-08 RH-99 (c) NMP AA ADSP SW version: p V 5.80\n14-11-08\nRH-99\n(c) NMP\naa Product Info: Production serial number: DFT925708 Product code: 0546862 Module code: 0203402 Basic production code: 0544418 Serial Numbers: IMEI plain: ??????????????? IMEI spare to net: FA FF FF FF FF FF FF 0F IMEI SV to net: F3 FF FF FF FF FF FF 6F F8 Other Info: CS type : GSM/DCS1800 BSI: 3.4 KOhm Imei net: 00000000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
01-21-2010, 17:11 | #2 (permalink) |
Member: 533912 Status: Offline Thanks Meter: 115 | 2nd info Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004D304FA3BDA66 ASIC type: 11 UEM Imei: 35955401319682 Flash Imei: 35293302635625 MasterCode: 6027447222 Flash Imei: 35293302635625 MasterCode: 6027447222 Invalid imei checksum ! Phone Type: RH-99 SW Version: V 5.80 14-11-08 RH-99 (c) NMP Imei plain: ??????????????-? Product Code: 0546862 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. |
01-21-2010, 17:13 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | you can repair it just go to service----imei security----online logger " need user and pass" chose dct4 or dct4+ and clic do select job and imei wil be repaired via server |
The Following 3 Users Say Thank You to mscomp For This Useful Post: |
01-22-2010, 10:32 | #8 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Quote:
The Following User Says Thank You to Umair Rashid For This Useful Post: |
China 1200-1203-1208-1209 0049XX IMEI ProbLem %% 100000 Ok | gsmservisi | Chinese Models & Cloned Phones | 4 | 05-28-2011 17:11 |
1200 imei problems | sami1989 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 07-25-2009 15:12 |
1200 imei ????????? and 30 sec off problem | dil_PAKISTANI | Universalbox | 3 | 06-01-2008 11:43 |
