08-22-2010, 11:22 | #7 (permalink) |
No Life Poster Join Date: Mar 2004 Location: ALGERIA Age: 50
Member: 59556 Status: Offline Sonork: 197200 Thanks Meter: 17 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0035097CA3BDA66 ASIC type: 11 UEM Imei: 35932903852028 Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: ¼«* Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data |
08-22-2010, 12:28 | #9 (permalink) |
Member: 59556 Status: Offline Sonork: 197200 Thanks Meter: 17 | ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0035097CA3BDA66 ASIC type: 11 UEM Imei: 35932903852028 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35932903852028.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0035097CA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: ¼«* Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data |
1202 Mobile MB Plz | SKVACHANDRAN | Nokia Multimedia | 1 | 11-18-2008 16:45 |
1202 w/ 624h stand-by how's that possible? | LukeCDMA | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-07-2008 06:42 |
need mobile mb for 1202 latest modal in nokia pl some one share thx in advance | lavkey | Nokia Multimedia | 0 | 10-31-2008 06:40 |
Nokia 1202 | tsm2318 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-03-2008 02:48 |
