11-21-2009, 15:25 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | 1202 contact service Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! PhoneType:RH-112 SwVersion: V 03.10 21-01-09 RH-112 (c) NMP MCU file: rh112_003.100 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B49C7B:2984DA60 Area [01000000-0101FFFF] erased in 0.735 s Area [01160000-0117FFFF] erased in 0.734 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B49C7B:2984DA60 Area [01000000-0101FFFF] erased in 0.734 s Area [01160000-0117FFFF] erased in 0.735 s Programming ... Programming completed. Imei net: 35797903091345 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! any solution |
The Following 3 Users Say Thank You to gsmsikar For This Useful Post: |
11-21-2009, 15:57 | #3 (permalink) |
Freak Poster Join Date: Apr 2008 Location: comilla bangladesh
Member: 743673 Status: Offline Thanks Meter: 7 | 1661 contact service.... CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! any solution |
The Following User Says Thank You to alam-mobile bos For This Useful Post: |
11-21-2009, 18:38 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | for all type of phone like this ASIC ID: 0x2293 [UPPCosto ver: 2.0] No solution yet to repair the simlock area !! (the one and only possible solution is change the UPP ic with ASIC ID:0X2292, but i think its not worthed ) |
The Following 6 Users Say Thank You to Chevka For This Useful Post: |
11-22-2009, 09:58 | #7 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Contact Service Quote:
This model is not yet supported for any tool bcoz its INFINEON | |
1202 Contact Service | rafiqnth | Nokia Digital Core Technology 4 ( DCT-4 ) | 74 | 02-21-2014 13:20 |
1202 Contact Service .............help | lahoot | Nokia Hardware & Hardware Repair | 40 | 06-04-2011 20:09 |
1202 contact service | ashraf_bcs | Nokia Digital Core Technology 4 ( DCT-4 ) | 33 | 10-29-2009 13:08 |
1202 contact service | sairat | Universalbox | 13 | 04-18-2009 20:21 |
