Old 12-18-2010, 11:43   #1 (permalink)
Member: 411207
Thanks Meter: 164
7210c can't repaired/only vibration when power
i have received 7210c RM-436
BUS CHECK
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1D00010C09DE5550212DF7DAB14BFD5EC0885E6C
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Original Imei: 35574302025421
Original Product code: 0566904
Bluetooth ID: 00226650D7BD
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35574302025421-1
Product Code: 0566904
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_DATA corrupted!
I try all solution (repair SD,repair SL after erease eeprom+unlock with rpl...) but some problem
Old 12-20-2010, 06:21   #2 (permalink)
Member: 1472549
BUS CHECK
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
hey. 1st go to simlock and check mark. repair simlock and make simlock rpl and update simlock. now repair sd and verify pm and write. your problem will be 100% solved
Old 12-20-2010, 06:41   #3 (permalink)
Member: 752215
Thanks Meter: 23
Hmmm
try first to remove camera....
then try to do sd simlock solution....i hope you know how to...
Old 12-20-2010, 07:08   #4 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
if already tried above all methods then try to reflow the betty ic and then do this procedure.........will get 100% success..........
wbr: sanjubhai.
Old 12-20-2010, 12:02   #5 (permalink)
Member: 411207
Thanks Meter: 164
Originally Posted by Mr.Furious View Post
Hmmm
lol bro
already solved with this method.
The Following User Says Thank You to blaw For This Useful Post:
Old 12-27-2010, 06:50   #6 (permalink)
Member: 1002064
Sonork: 100.1594824
Thanks Meter: 131
i have nokia 7210supernowa with vibrater problem pleas help me i am still wating
The Following User Says Thank You to Indus For This Useful Post:
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 09:41
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.29218 seconds with 9 queries
