05-30-2012, 14:52 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1270231 Status: Offline Thanks Meter: 0 | 1616-2 rh125 flash prob flash ok but dont pwr on reflashed with 3 other versions same prob reheat pcb idem any idea MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C085CB22 Using device: HTI, FW ver: 00.50, SN: 010007E1 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rh125_006.510 Downloading item CODE:hw_f11_rh125_r06.510.fls, num block: 3, size: 4.14 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 48.890 s Erasing area 0x00C60000-0x00E72C7E ...OK Programming completed in 46.609 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Error reading checksum! Processing file: rh125_006.51ic Downloading item CUST:hw_f11_rh125_006.51ic.fls, num block: 1, size: 1.93 MB Erasing area 0x00210000-0x003FCAFE ...OK Programming completed in 35.344 s Checksum mismatch: Phone calculated 0x0040, software calculated 0x5706 Processing file: rh1250_nai06.51ic Downloading item CUST:hw_f11_rh1250_nai06.51ic.fls, num block: 1, size: 359.20 KB Erasing area 0x00EB0000-0x00F08FBE ...OK Programming completed in 6.515 s Checksum mismatch: Phone calculated 0x00F1, software calculated 0xE137 Total time for flashing process(boot+erase+write) was 3 min 55.360 s |
