10-27-2010, 12:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2009
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | 1616 After Flash Cann't Power On Show Error Checksum failed 1616 After Flash Cann't Power On Show Error Checksum failed Using device: UFS_USB V2.8 (c) SarasSoft 2007.Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)I Have Tick On xGold And Flash With 4.65 Version Log Is Here Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110]Sending Primary Boot Loader ...OK Changing baudrate to: 921600Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11Boot mode: CCEBL version: 10.13, Default_RAM_BootloaderFlash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r04.650.fls from file rh125_004.650 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 37.797 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 36.953 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.063 s Checksum failed Processing CUST:hw_f11_rh125_004.65ia.fls from file rh125_004.65ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 34.297 s Checksum failed Processing CUST:hw_f11_rh1250_nai04.65ia.fls from file rh1250_nai04.65ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.875 s Checksum failed Flashing completed in 3 min 40.094 s Phone Type: RH-125 SW Version: V 04.65 24-04-10 RH-125 (c) Nokia Imei plain: 35375104441839-1Product Code: 0590493Cellular System: GSMASIC ID: 0x2292, type: 11Ppm Id: IA Language Pack:- not available. Imei net: 35375104441839Version: Provider: ALL Operator, Country: -Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPENBLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to ~The JoKeR~ For This Useful Post: |
10-27-2010, 14:21 | #3 (permalink) |
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | I Am Trying To Flash With 5.80 Version But Same Condition. Here Is Log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r05.800.fls from file rh125_005.800 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 38.390 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 43.406 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.063 s Checksum failed Processing CUST:hw_f11_rh125_005.80ia.fls from file rh125_005.80ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 33.125 s Checksum failed Processing CUST:hw_f11_rh1250_nai05.80ia.fls from file rh1250_nai05.80ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 6.094 s Checksum failed Flashing completed in 3 min 46.828 s Phone not responding ! |
10-28-2010, 05:07 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | v3.4 revision 1.4 fix, Partial Update To update: Goto Options->Module, select "Nokia Service Tool" and click "Update" Whats New: NK - Fixed, BB5 USB flashing bug(RAP3G, RAPIDO) - Added, New definition for XGOLD platform in xgold.xml and tick xgold and flash with letest version i hope u r problem solved SAQIB-GHAZI |
10-28-2010, 05:28 | #7 (permalink) |
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | THEN TRY TICK EMULATIONS WITH LOW SPEED AND SAME PROBLEM THEN CHANGE FBUS CABLE THEN SAME PROBLEM THEN CHEQ SET IN HARDWARE SAQIB-GHAZI |
10-28-2010, 05:43 | #8 (permalink) | |
Freak Poster Join Date: Jul 2010 Location: Daudkandi,Comilla,Bangladesh.
Member: 1350057 Status: Offline Sonork: Not use Thanks Meter: 36 | 1616 flash problem Quote:
same problem 2set flash same condition anyone help? ?///???/??? | |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
