02-13-2010, 08:12 | #1 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE SW Version: V 06.93 20-05-09 RM-495 (c) Nokia Imei plain: 354223xxxxxxxxxxxxxxxx Product Code: 0576445 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! HELP |
The Following 5 Users Say Thank You to >>.123.<< For This Useful Post: |
02-13-2010, 13:25 | #9 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Pakistan
Member: 339227 Status: Offline Thanks Meter: 236 | Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35417903912114-4 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
03-10-2010, 10:17 | #10 (permalink) |
Junior Member Join Date: Mar 2009
Member: 1000648 Status: Offline Thanks Meter: 2 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 16100207CC2D7F56AE664B5AEC4F6E978A231E70 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35523203234518 Original Product code: 0577793 Bluetooth ID: 0025CFFD2B22 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35523203234518-3 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355232032345183 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF plzzz help with this error |
The Following User Says Thank You to amankataria For This Useful Post: |
03-10-2010, 10:20 | #11 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | write pm 1 & 309 erea with super sd auth and post result |
The Following 3 Users Say Thank You to ..::Rizwan::.. For This Useful Post: |
10-12-2010, 09:53 | #12 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1343279 Status: Offline Sonork: black mark on left hand Thanks Meter: 1 | AFTER WRITING 1& 309 THIS IS THE RESULT Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2170020F1EA87D56D7034ADCBBD3793381AF1B26 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35523203439548 Original Product code: 0576625 Bluetooth ID: 0025D007B164 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35523203439548-3 Product Code: 0576625 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
The Following User Says Thank You to navneetalaria44 For This Useful Post: |
10-14-2010, 15:17 | #13 (permalink) |
Member: 771334 Status: Offline Thanks Meter: 58 | 5130 9978509801 [email protected] SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
10-24-2010, 11:05 | #15 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,292 | sl3 Simlock unlock not supported YET. BR |
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK TEST failed! SECURITY_T | >>.123.<< | Nokia Base Band 5 ( BB-5 ) | 6 | 04-19-2010 10:26 |
SUPERDONGLE_KEY seems to be valid but can't PM-Auth | bireun | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-24-2010 14:15 |
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE | >>.123.<< | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-17-2010 05:29 |
SUPERDONGLE_KEY seems to be valid but pmauth not working | hmyeamin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-04-2010 15:20 |
5310 contack service SUPERDONGLE_KEY seems to be valid | kirta | Nokia Base Band 5 ( BB-5 ) | 2 | 09-04-2009 12:22 |
