11-14-2010, 09:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | 1650 cannot unlock SCAN Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35933702262361-8 Product Code: 0547569 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: IA Language Pack: - not available. Failed to read SP data INFO IN SERVICE TAB Version Info: MCU SW version: V 5.91 27-03-09 RM-305 (c) NMP HW version: 2501 UEM version: 1328 UPP version: 8850 LCD version: SDI:GUINv87 S6B33D1 PPM version: V 5.91 27-03-09 RM-305 (c) NMP IA ADSP SW version: p V 5.91\n27-03-09\nRM-305\n(c) NMP\nia Product Info: Production serial number: IBJ298999 Product code: 0547569 Module code: 0203271 Basic production code: 0515495 Serial Numbers: IMEI warranty: 359564015464805 IMEI plain: 359337022623618 IMEI spare to net: 3A 95 33 07 22 26 63 01 IMEI SV to net: 33 95 33 07 22 26 63 71 F0 Other Info: CS type : GSM/DCS1800 BSI: 0.0 KOhm Failed to read SP data BUS CHECK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D6233BA3BDA66 ASIC type: 11 UEM Imei: 35933702262361 Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35933702262361-8 Product Code: 0547569 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: IA Language Pack: - not available. Failed to read SP data when try to unlock Failed to read SP data Imei net is empty, process aborted. |
11-14-2010, 10:22 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
br first full erase than full flash write good pm unlock and factory reset i hope ur problem will be solve | |
11-14-2010, 10:29 | #5 (permalink) |
Freak Poster Join Date: Nov 2010 Location: SUNDARBAN.THE MAGICAL MANGROVE
Member: 1432362 Status: Offline Thanks Meter: 39 | With a good cable( u can use 1100 cable or easy cable) first connect phone and cable with box push power button (skip bus check) go imei security tab sp lock info sp unlock IF NOT WORK..WRITE PM FIRST THAN AGAIN TRY |
11-15-2010, 15:15 | #13 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: Pakistan Age: 38
Member: 756333 Status: Offline Thanks Meter: 152 | Quote:
The Following User Says Thank You to Haider Ali For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
