02-11-2010, 14:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 966792 Status: Offline Sonork: 100.1602610 Thanks Meter: 199 | 1661-2 flasing Secussfully Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00EE7B18A3BDA66 ASIC type: 11 UEM Imei: 35419888********** Flash Imei: 35419************* RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35419803379928_BA CK.rpl" Processing file: rh122_005.010 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00EE7B18:2984DA60 Area [01000000-0100FFFF] erased in 0.766 s Area [01010000-0179FFFF] erased in 1 min 28.750 s Area [017A0000-017EFFFF] erased in 3.610 s Area [01F00000-01FDFFFF] erased in 0.265 s Flash programming ... Programming completed in 17.282 s File Processed in 2 min 1.985 s Processing file: rh1220_nai05.01mg as CNT [DCT4,DCT4 ALGORITHM] size: 142.60 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00EE7B18:2984DA60 Area [01750000-0178FFFF] erased in 2.968 s Flash programming ... Programming completed in 1.047 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.063 s File Processed in 19.640 s Processing file: rh122_005.01mg as PPM [DCT4,DCT4 ALGORITHM] size: 3.75 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00EE7B18:2984DA60 Area [01250000-0125FFFF] erased in 0.735 s Area [01260000-0174FFFF] erased in 57.907 s Flash programming ... Programming completed in 27.375 s File Processed in 1 min 33.657 s Flashing completed in 4 min 38.500 s Phone Type: RH-122 SW Version: V 05.01 23-09-09 RH-122 (c) Nokia Imei plain: 3541********** Product Code: 0573014 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 3541*********** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 4 min 59.531 s |
The Following User Says Thank You to mayank.gupta For This Useful Post: |
2330c-2 Unlocked Secussfully | alamgarh | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-11-2010 13:31 |
