Old 05-03-2010, 05:47   #1 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 45
1661(rh-122)
Unlock/Repair Splock ok
But
still contact service
Imei net: 35823903181671
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Calculating SIMLOCK RPL using security server ...OK
RPL saved to "C:\mobileEx\3.3\data\backup\RH-122_35823903181671_SIM.RPL"
Updating SIMLOCK ...OK
Reading Simlock info ...
Counter: 0/3, 0/10
PROFILE_BITS: 800000000003000B
Plz help................How to solved
The Following User Says Thank You to rajibsaha For This Useful Post:
Old 05-03-2010, 05:53   #2 (permalink)
chandio_180's Avatar
Member: 602248
Thanks Meter: 69
dear mat
try this for bttr rult
1)full erase.....
2)flash with any vrsion..
3)write full PM...
4)then unlock..
stil same then its 100% hrdware
reball UEM ic ...
or change...
R,G
chandio
The Following User Says Thank You to chandio_180 For This Useful Post:
Old 05-03-2010, 06:37   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
But
Counter: 0/3, 0/10
Counter: 0/3, 0/10
Do self Test you will detect the actual problem . Post the log if possible
The Following User Says Thank You to srinibas For This Useful Post:
Old 05-03-2010, 06:48   #4 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
big contact service ya litet contact service big contact service by sound ic remove and litet contact service ching lcd and uem
100 okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkk
The Following User Says Thank You to javedsf For This Useful Post:
Old 05-03-2010, 09:06   #5 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
First the set was already unlocked
contact service is due to '' lcd '' or due to hardware problem (water damage)
The Following User Says Thank You to cel_phon For This Useful Post:
Old 05-03-2010, 09:10   #6 (permalink)
Member: 1040070
Thanks Meter: 28
if big contact service re hot um ic problem solve
The Following User Says Thank You to Faruk Ahmed For This Useful Post:
Old 05-03-2010, 10:08   #7 (permalink)
faisal.u7's Avatar
Member: 1028120
Sonork: 100.1607216
Thanks Meter: 90
change um ic and chek lcd 100% solve your problem
The Following User Says Thank You to faisal.u7 For This Useful Post:
error unlock 1661 rh-121 3.10 cellcarcol MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 12-28-2009 19:30
nokia 1661 flash RH-121 renes Universalbox 2 12-15-2009 02:50
1661 rh-121 alvaroc Universalbox 1 11-09-2009 20:51
Cyclone Box Team, please create 2 unlock patch for 1661-2b [rh-121] and 2680s-2b cj_neonyx Cyclonebox 1 11-06-2009 03:00
solution to unlock 1661 rh-121 ver3.1??? calicell150769 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 10-13-2009 17:06
Page generated in 0.18091 seconds with 9 queries
