1661 RH 122 Only one sim is working..... (ANSWERED) 1661 RH122 only one sim working. Other sims showing - Insert sim. Simlock updated successfully in mx key. But still the same situation. Quote:
this indicates bad sim interface. check for sim emif, replace if needed. if problem still there, check uem. but on most case, sim emif is bad. BR |
just do full ui settings ur problem solved........ |
1 Attachment(s) check this ............. |
2 Attachment(s) check this image.....................help you |
100% hard ware problom |
That might be Rx or tx filter problem check both ;) Br Authenticated pics already given |
Because i googled but can't find :( |
Bro only change SIM ic 100% ok Quote:
Bro only change SIM ic 100% ok |
