03-12-2010, 09:58 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Mirpur Azad Kashmir Age: 34
Member: 1154111 Status: Offline Sonork: 100.1620855 Thanks Meter: 158 | 1680 unlock ok whit mx-key , i used easy cable for unlock Provider: Mobil Rom DIALOG, Country: Romania Counter: 0/3, 0/10 CONFIG_DATA: 2261000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 22610F PhoneType:RM-394 SwVersion: V 05.63 20-06-08 RM-394 (c) Nokia MCU file: rm394__05.63.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 5 ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH KS COMUNNICATION CHAKSWARI ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009028A8:3B8ADA60 Area [01000000-0101FFFF] erased in 0.578 s Area [01080000-0109FFFF] erased in 0.562 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 009028A8:3B8ADA60 Area [01000000-0101FFFF] erased in 0.640 s Area [01080000-0109FFFF] erased in 0.563 s Programming ... Programming completed. Completed in 5 min 14.500 s Reading Simlock info ... Imei net: 35684102291312 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to kamranas For This Useful Post: |
htc p3470 unlock ok with mx-key | ponix | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 1 | 10-18-2010 11:25 |
1680 unlock ok whit mx-key , i used easy cable for unlock | kamranas | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 05-29-2010 13:26 |
2630 version 57.20 with mx key using easy cable | neeraj1st | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 07:52 |
3120c-1 not unlock with JAF_BB5Plus_102 unlock ok with MX-KEY | adelgsm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 07-11-2009 19:56 |
Can i use twister cable for unlock lg kg800 | Mounir | Multi-Box | 1 | 03-19-2007 10:51 |
