Old 02-21-2010, 14:01   #1 (permalink)
Dami_gsm's Avatar
Member: 1082892
Sonork: 100.1585374
Thanks Meter: 412
How to Repair Imei Dct4 ???????4
1)How to Repair imei Dct4
2)how to change imei 5030
Please Send Me Video???
Old 02-21-2010, 14:21   #2 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
repair imei
http://www.4shared.com/file/22664686...ith_mxkey.html
change imei
http://www.4shared.com/file/22664751..._uzmantel.html
The Following User Says Thank You to Ramzan khan For This Useful Post:
Old 02-21-2010, 14:28   #3 (permalink)
Member: 405696
Thanks Meter: 148
one more video for rpl .imei repair
http://www.4shared.com/file/22665190...eo_Tested.html
5030 not possible imei change
The Following 3 Users Say Thank You to Ramzan khan For This Useful Post:
Old 02-22-2010, 05:45   #4 (permalink)
Dami_gsm's Avatar
Member: 1082892
Sonork: 100.1585374
Thanks Meter: 412
Rizwan khan is very very good helper................
Old 02-22-2010, 06:01   #5 (permalink)
Member: 405696
Thanks Meter: 148
Dami gsm brother thanx for ur wording.but not rizwan khan i am ramzan khan
but very very thanks. and gsm forum mean get help and also help other.
and i have more videos of mx key i download and then give you link
Old 02-22-2010, 07:05   #6 (permalink)
Member: 464543
Sonork: 100.1622465
Thanks Meter: 152
ramzan khan
thnq help
Old 02-22-2010, 15:35   #7 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 112
WTF is the imei change option???? only see imei rebuild....
Old 02-22-2010, 22:51   #8 (permalink)
alarmtech's Avatar
Member: 71189
Sonork: 100.1617065
Thanks Meter: 90
SECURITY_TEST failed!
please help me
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.00 19-08-08 RM-217 (c) Nokia.
Imei plain: 35523403016582-9
Product Code: 0537631
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 355234030165829
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-22-2010, 22:58   #9 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Thanks Meter: 94
@ alarmtech
Do selft test, so you can sure what the next step. SX4 and then writing PM value 1 and 309 or another options steps. Post results here.
Old 02-22-2010, 23:14   #10 (permalink)
alarmtech's Avatar
Member: 71189
Sonork: 100.1617065
Thanks Meter: 90
Originally Posted by sijibae View Post
@ alarmtech
Product Code: 0555111
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
can you post a vedio?
Old 02-22-2010, 23:48   #11 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Thanks Meter: 94
Remember to fully backup PM and RPL before doing next steps. Now, try Repair SD -> "Super SD Auth" for solve this.
Old 02-23-2010, 10:59   #12 (permalink)
alarmtech's Avatar
Member: 71189
Sonork: 100.1617065
Thanks Meter: 90
after sd and sd auth
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 02-23-2010, 11:07   #13 (permalink)
Member: 507861
Thanks Meter: 69
goto imei security\imei rebuild and tick recover certificate.. if no luck write ccc_hwc rpl
Old 02-23-2010, 12:57   #14 (permalink)
alarmtech's Avatar
Member: 71189
Sonork: 100.1617065
Thanks Meter: 90
thanks but were can found ccc_hwc rpl ?
Old 11-03-2010, 09:13   #15 (permalink)
Member: 319322
Thanks Meter: 14
5030 imei corrupt
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00A1A09CA3BDA66
ASIC type: 11
UEM Imei: Empty
Phone Type: RM-524
SW Version: V 03.75 21-04-09 RM-524 (c) Nokia
Imei plain: ??????????????-?
Product Code: 0578231
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MG
Language Pack:
- not available.
TimeStamp: 2009-04-21T07:34:55Z
SW Version: 03.75
Variant Version: 001
ProductProfile: RM524_0578231_03.75_001.spr
Simlock: 0578231_SimLockDataVerifier_vDCT4.sim
Imei plain is invalid !!!
Imei net: 00000000000000
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
anybody can help
how to repair imei dct4 with ufs 3 fares_gsm Nokia Digital Core Technology 4 ( DCT-4 ) 7 01-01-2014 13:34
How To Repair IMEI??????? DCT4 DaWizard Cyclonebox 7 05-24-2009 06:37
[Guide]How To Repair IMEI (?????????????????) Damage In Dct4 Wd2 Tiku Phone? stanner_austin Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-17-2008 17:20
How To Repair Imei (?????????????????) Damage In Dct4 Wd2 Tiku Phone? stanner_austin WD2 & APE (Symbian Phones) 0 09-11-2007 13:42
Page generated in 0.28262 seconds with 9 queries
