Old 02-20-2010, 16:47   #1 (permalink)
Member: 530442
Thanks Meter: 11
1680c problem
Phone Type: RM-392 (Nokia 2680s-2)
SW Version: V 56.17 24-03-09 RM-392 (c) Nokia
Imei plain: 35523703208547-3
Imei OTP: 35523703208547
Product Code: 0560306
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Language Pack:
- not available.
Imei net: 35523703208547
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 5555555555555555
PROFILE_BITS: 5555555555035555
SIMLOCK_DATA corrupted!
Old 02-20-2010, 17:03   #2 (permalink)
Member: 530442
Thanks Meter: 11
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11893, Date: 26-01-2010
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 00103711:3B8ADA60
ASIC type: 11
UEM Imei: 35523703208547
Flash Imei: 35523703208547
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35523703208547_BA CK.rpl"
Processing file: rm392__56.17.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 11.81 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
Area [01000000-0101FFFF] erased in 1.140 s
Area [01020000-01CFFFFF] erased in 1 min 56.672 s
Flash programming ...
Programming completed in 1 min 12.969 s
File Processed in 3 min 23.734 s
Processing file: rm392__56.17.image_ae_uk as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.88 MB
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH - COMBO FLASH
UEM ID: 00103711:C5A4DA78
Area [02180000-02E7FFFF] erased in 1 min 57.187 s
Area [02E80000-02FBFFFF] erased in 11.109 s
Converting UCP blocks to 128 K.
Programming completed in 27.843 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.047 s
File Processed in 3 min 10.375 s
Processing file: rm392__56.17.ppm_ae as PPM
[DCT4,DCT4 ALGORITHM] size: 2.32 MB
UEM ID: 00103711:2984DA60
Area [01D00000-0217FFFF] erased in 41.438 s
Programming completed in 14.375 s
File Processed in 1 min 8.719 s
Flashing completed in 8 min 35.140 s
Ppm Id: AE
Language Pack:
- not available.
Counter: 0/3, 0/10
Total time to process is 8 min 47.984 s
Old 02-20-2010, 17:06   #3 (permalink)
Member: 317993
Thanks Meter: 3
write good pm and then unlock
Old 02-20-2010, 17:07   #4 (permalink)
Member: 888048
Sonork: 123
Thanks Meter: 30
update your Mx-key and unlock.
Old 02-20-2010, 17:28   #5 (permalink)
Member: 530442
Thanks Meter: 11
When i do unlock then phone no respond after
PhoneType:RM-392
SwVersion: V 56.17 24-03-09 RM-392 (c) Nokia
MCU file: rm392__56.17.mcusw
Trying to find patch position ...OK
Area [01000000-0101FFFF] erased in 1.125 s
Area [01220000-0123FFFF] erased in 1.141 s
Area [01440000-0145FFFF] erased in 1.141 s
Area [014C0000-014DFFFF] erased in 1.140 s
Area [01CE0000-01CFFFFF] erased in 1.110 s
Programming ...
Programming completed.
Phone not responding !
Area [01000000-0101FFFF] erased in 1.141 s
Area [01220000-0123FFFF] erased in 1.140 s
Area [014C0000-014DFFFF] erased in 1.141 s
Area [01CE0000-01CFFFFF] erased in 1.141 s
Programming ...
Old 02-20-2010, 19:10   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
like unsupported frimware
can u try it with other frimware version.
br,
Old 02-20-2010, 19:12   #7 (permalink)
uzmantel's Avatar
Member: 163458
Sonork: 100.1606694
Thanks Meter: 503
can u update with suported one
br,
Yes ım tested 5.61 unlock ok 100% tested
Old 02-20-2010, 21:30   #8 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
br,
yes 100% unlocking succes with 5.61 tested by me
Old 02-23-2010, 18:25   #9 (permalink)
Member: 530442
Thanks Meter: 11
but i got 56.17 version....
nokia 1680c camera problem salman_4_ever Nokia Hardware & Hardware Repair 5 11-11-2010 15:36
1680c unlocking problem? shamshad quresh HWK 2 12-18-2008 08:04
nokia 1680c camera problem salman_4_ever Nokia Hardware & Hardware Repair 0 09-04-2008 06:08
Page generated in 0.20168 seconds with 9 queries
