01-22-2010, 12:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | 1680c security corrupted Done on New Update ng MXkey..... Code: Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11809, Date: 21-01-2010 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045286A:DA3BDA66 ASIC type: 11 UEM Imei: 35932402964762 Flash Imei: 35932402964762 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35932402964762_BACK.rpl" Processing file: rm394__06.82.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 10.19 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045286A:3B8ADA60 Area [01000000-0101FFFF] erased in 0.656 s Area [01020000-01C3FFFF] erased in 1 min 3.610 s Flash programming ... Programming completed in 3 min 39.406 s File Processed in 5 min 1.219 s Processing file: rm394__06.82.image_v as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045286A:C5A4DA78 Area [02000000-02DBFFFF] erased in 1 min 16.937 s Area [02DC0000-02F9FFFF] erased in 12.234 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 46.875 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.047 s File Processed in 3 min 51.500 s Processing file: rm394__06.82.ppm_v as PPM [DCT4,DCT4 ALGORITHM] size: 3.10 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045286A:2984DA60 Area [01C40000-01FFFFFF] erased in 23.110 s Flash programming ... Programming completed in 1 min 14.891 s File Processed in 1 min 55.281 s Flashing completed in 11 min 49.500 s Phone Type: RM-394 (3000) SW Version: V 06.82 26-09-08 RM-394 (c) Nokia Imei plain: 3593*********-6 Imei OTP: 3593********* Product Code: 0560349 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: V Language Pack: - not available. Imei net: 3593********** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 12 min 14.640 s done flashing smoothly....... another job well done by Mxkey...... |
7210c successfully sd repair with new update in mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-12-2010 10:41 |
5800 successfully sd repair with new update in mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-08-2010 11:24 |
Mxkey can"t unlock 7100s on new update | palash_c6 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-03-2009 15:09 |
Who working done with new update | gsmsky | FuriousGold | 2 | 08-19-2009 08:39 |
t303 unlock done with new update | moussa2309 | Cruiser Suite | 5 | 03-08-2009 17:03 |
