06-22-2012, 15:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: coimbatore
Member: 653676 Status: Offline Thanks Meter: 301 | 2310--rm-189 contact service Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C087347F Using device: HTI, FW ver: 00.50, SN: ======== Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CD299A:2984DA60 ASIC type: 2 UEM Imei: 35553201601022 Flash Imei: 35553201601022 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35553201601022_BACK.rpl" Processing MCU file: rm189_06.520 [DCT4,DCT4 ALGORITHM] size: 1.90 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CD299A:2984DA60 Area [01000000-0100FFFF] erased in 0.672 s Area [01010000-013BFFFF] erased in 39.282 s Area [013C0000-013EFFFF] erased in 1.906 s Area [017C0000-017EFFFF] erased in 0.016 s Area [01FC0000-01FEFFFF] erased in 0.031 s Flash programming ... Programming completed in 13.328 s File processed in 1 min 2.313 s Processing CNT file: rm1890_nai6.52ej [DCT4,DCT4 ALGORITHM] size: 184.07 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CD299A:2984DA60 Area [01380000-013BFFFF] erased in 2.656 s Flash programming ... Programming completed in 1.265 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.141 s File processed in 21.844 s Processing PPM file: rm189_06.52ej [DCT4,DCT4 ALGORITHM] size: 1.42 MB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CD299A:2984DA60 Area [011E0000-011EFFFF] erased in 0.672 s Area [011F0000-0137FFFF] erased in 16.641 s Flash programming ... Programming completed in 9.969 s File processed in 34.375 s Total time for flashing process(boot+erase+write) was 1 min 58.532 s After Flash Processing ... Reseting Factory Values OK. Phone type: RM-189 SW version: V 6.52 11-12-07 RM-189 (c) NMP Imei plain: 35553201601022-8 Product code: 0535131 Cellular system: GSM ASIC ID: 0x2201, type: 2 Ppm Id: EJ Language Pack: English,Russian,Ukrainian Master code: 4234536737 Imei net: 3555----------- Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-22-2012, 15:23 | #2 (permalink) |
Crazy Poster Join Date: Jan 2010 Location: YOGYAKARTA-INDONESIA
Member: 1203432 Status: Offline Thanks Meter: 16 | when viewed from log.nya, software is not a problem,, try to step into the hardware work,, "I often experienced the problem on the phone contac service DCT-4 between the UEM ic and flash ic. |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
