02-21-2010, 19:24 | #1 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1242212 Status: Offline Thanks Meter: 0 | 2600c imei change problam SwVersion: V 05.61 18-04-08 RM-340 (c) Nokia MCU file: rm340__05.61.mcusw Trying to find patch position ...OK, case id: 4 New Imei: 356397021601117 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00943AEA:3B8ADA60 Area [01000000-0101FFFF] erased in 0.406 s Area [01080000-0109FFFF] erased in 0.406 s Area [01AC0000-01ADFFFF] erased in 0.438 s Programming ... Programming completed. SpUnlock skipped. ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00943AEA:3B8ADA60 Area [01000000-0101FFFF] erased in 0.422 s Area [01080000-0109FFFF] erased in 0.422 s Programming ... Programming completed. Completed in 58.328 s Phone Type: RM-340 (Nokia 2600c-2) SW Version: V 05.61 18-04-08 RM-340 (c) Nokia Imei plain: 35639702160111-7 Imei OTP: 35639702160101 Product Code: 0556652 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35639702160111 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN imei change ok but no signals when i flash it it says sim card registration fail how to fix my problam ? |
02-22-2010, 09:04 | #3 (permalink) |
Banned Join Date: Jul 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 318781 Status: Offline Thanks Meter: 50 | first check your imei is black list or not then try to change with an other imei if still same change the coupler brother because set is not black list |
2600c imei change ok but no network | javedsf | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 09-26-2011 04:29 |
2600c imei change ok tested byme or video (ANSWERED) | uzmantel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-07-2011 20:49 |
2600c imei change | mobile_sos | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 12-29-2009 08:00 |
