10-07-2010, 09:57 | #1 (permalink) | |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 2600c simlock data corupted (answered) Quote:
10-07-2010, 10:24 | #3 (permalink) |
Member: 282510 Status: Offline Thanks Meter: 33 | i did and this is the result mei net: 35931402259540 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 [CR1]DCT4PLUS remaining credit: 44 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-340_35931402259540_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35931402259540 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! |
10-07-2010, 16:44 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | there is no need to complete erase. all flasher will error on full erase for such phone. just ignore it. assume you have erased it correctly, now do full flash, make sl repair, write pm, do factory reset after. BR |
11-08-2010, 17:40 | #9 (permalink) |
Junior Member Join Date: Jun 2007
Member: 524156 Status: Offline Thanks Meter: 2 | i got this problem to, simlock corrupted because of fail running unlock, also fail update sp lock (on servive>imei&security>simlock>update sp lock). so i do erase flash (uncheck automatically save backup is posibble) and run full flash again, check on after flash processing>sp unlock>pm. after flash done just full factory setting 1time. that all. many ways to handle this problem... hope u can find ur way... |
11-09-2010, 06:32 | #13 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | not sl3 itis dct4 fone posebul to unlock f1st full erase and full flash and unlock problem solve and this modal is unlock by patch |
11-09-2010, 15:07 | #15 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Pakistan Age: 38
Member: 756333 Status: Offline Thanks Meter: 152 | Contact me: [email protected] |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
