Old 10-02-2009, 13:32   #1 (permalink)
Member: 421487
Thanks Meter: 58
charging not supported 3110c after write pm
sir this is 3110c with cantact service after pm other and write pm with ub its ok and warking fine one except charging not supporte this is due to pm oth and write pm for this i use ub. now i am trying with mx key this error apper pl pl
pported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35934302377553
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA is empty.
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
RPL saved to "D:\mobileEx\3.2\data\backup\BB5_35934302377553_BA CK.rpl"
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 117.197.163.24
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
No SX4 Card found.
Old 10-02-2009, 20:39   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u post BUS CHECK info here ?
br,
Old 10-03-2009, 06:53   #3 (permalink)
bireun's Avatar
Member: 796141
Thanks Meter: 25
Try write PM 309 Only from good PM, your problem be solved
br
bireun
3110c contect service after write pm with hwk khanmobiles0003 Nokia Base Band 5 ( BB-5 ) 8 04-11-2010 09:37
3110c big problem after write Pm foufou34 Nokia Hardware & Hardware Repair 6 01-19-2009 09:35
6280 After Write Rpl Charging Not Supported Nasmi MT-BOX 17 09-05-2008 05:58
after write rpl phon charge not supported. samirstare MT-BOX 6 12-18-2007 11:56
N70 after write pm simcard not valid plentong MT-BOX 3 12-11-2006 10:15
Page generated in 0.22236 seconds with 9 queries
